  4. Test Adapter luxtronik2 v0.4.x
adapterluxtronik wpwebsocket
292 Beiträge 52 Kommentatoren 97.4k Aufrufe 49 Beobachtet
  • H Offline
    Henning 1
    #170
    @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
    sudo usermod -aG iobroker pi
    Das liefert er:
    pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.luxtronik2@0.4.2
    added 7 packages from 82 contributors in 29.319s
    50 packages are looking for funding
      run `npm fund` for details
    Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
    H 1 Antwort Letzte Antwort
      @henning-1
      Der pi fehlt in der Gruppe 'iobroker'
      Henning 1
      #171
      Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
      pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
      pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
      host.iobroker-pi install adapter luxtronik2
      upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
      upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
      upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
      upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
      upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
      host.iobroker-pi object system.adapter.luxtronik2 created/updated
      host.iobroker-pi create instance luxtronik2
      host.iobroker-pi object system.adapter.luxtronik2.0.alive created
      host.iobroker-pi object system.adapter.luxtronik2.0.connected created
      host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
      host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
      host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
      host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
      host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
      host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
      host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
      host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
      host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
      host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
      host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
      host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
      host.iobroker-pi object luxtronik2.0.info created
      host.iobroker-pi object luxtronik2.0.info.connection created
      host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
      host.iobroker-pi object system.adapter.luxtronik2.0 created
      Ich mache mal nen Reboot und schaue dann, was ich sehe.
      • H Henning 1
        Das liefert er:
        Henning 1
        #172
        Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
        Schönes WE soweit noch :-)
        • H Offline
          Henning 1
          #173
          ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
          2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
          2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
          2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
          2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
          2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
          2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
          • H Henning 1
            #174
            @henning-1
            Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
            • H Offline
              Henning 1
              #175
              Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
              und geht so weiter bis 57. Danach kommt AV-Abtauventil...
              • H Offline
                Henning 1
                #176
                Das Ganze steht bei Wärmemenge auch nochmal drin
                • H Offline
                  Henning 1
                  #177
                  Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                  Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                  • H Offline
                    Henning 1
                    #178
                    @UncleSam Soll ich da ein Ticket aufmachen? Ich habe nämlich zwei Außeneinheiten an einer Steuerung. Daher gibt's bei mir einige Werte doppelt. Mit manchen schien der Adapter klar zu kommen ,mit anderen nicht.
                    • P Offline
                      pgBroker
                      schrieb am zuletzt editiert von pgBroker
                      #179
                      Musste meinen ioBroker nach einem Crash neu aufsetzen und bekomme jetzt im log im Sekundentakt diese Warnung:
                      Unknown data item parameters.mk1_curve_parallel_offset
                      Unknown data item parameters.mk1_curve_end_point
                      Unknown data item parameters.deltaMk1Reduction
                      Wie kriege ich die weg?
                      P 1 Antwort Letzte Antwort
                      • P pgBroker
                        pgBroker
                        #180
                        Hmmm, hat niemand ne idee? 😕
                        • Bernd 0B Offline
                          Bernd 0B Offline
                          Bernd 0
                          #181
                          kann man über den Adapter herausfinden, welchen Leistungsbezug die Wärmepumpe aus dem Netz bezieht? Also kWh?
                          Ich habe nur gefunden, dass man die erzeugte Wärmeleistung abfragen kann.
                          Vielen Dank.
                          GB
                          TbsJahT 1 Antwort Letzte Antwort
                          • Bernd 0B Bernd 0
                            Vielen Dank.
                            GB
                            TbsJahT Offline
                            TbsJahT Offline
                            TbsJah
                            #182
                            @bernd-0 aktuell gibt es dafür keinen Parameter.
                            Du könntest den Wert jedoch annäherungsweise über die Temperatur WQ ermitteln
                            Bernd 0B 1 Antwort Letzte Antwort
                            • H Offline
                              hg4711
                              #183
                              ich hatte den Adapter neu installiert (0.4.2). Er ist auch konfigurierbar mit dem Passwort, den Parametern Websocket 8214 und Port 8889 bekomme ich keine Verbindung. Im Log bekomme ich nach dem Start die Fehlermeldung:
                              2d9b730f-841d-4915-af6e-ce08dcbd6e27-image.png und weitere als Konsequenz ...
                              Hat jemand eine Idee was hier fehlt oder schief läuft?
                              Danke schon mal
                              • H hg4711
                                Danke schon mal
                                #184
                                @hg4711 sagte in Test Adapter luxtronik2 v0.4.x:
                                Eine aktuelle Version von nodejs.
                                Der vorgesehene Stand ist nodeJS 16.
                                Der js-controller ist auch veraltet:
                                stable: 4.0.23 for 4 months
                                Bring dein System auf Stand.
                                • L Offline
                                  lessthanmore
                                  #185
                                  @hg4711 Passwort korrekt?
                                  Gerne auch mal Port 8888 probieren.
                                  • L lessthanmore
                                    hg4711
                                    #186
                                    @lessthanmore
                                    Denke es liegt an einer alten FW Version der Luxtronik2. Was ich gelesen habe: Erst ab V. 3.81 gibt es Websockets. Muss ich mal prüfen ob die drauf ist. Bin aber gerade nicht vor Ort. Wochenende ...
                                    Port 8888 habe ich natürlich getestet und PW stimmt sicher, aber soweit kommt der Adapter gar nicht.
                                    Danke soweit
                                    • TbsJahT TbsJah
                                      Bernd 0B Offline
                                      Bernd 0B Offline
                                      Bernd 0
                                      schrieb am zuletzt editiert von Bernd 0
                                      #187
                                      @tbsjah Hi tbsjah,
                                      Danke für deine Antwort. Die Idee ist an sich nicht schlecht. Da die Leistungskurven aber keine einfachen Funktionen sind, könnte man nur für jeden Temperaturwert eine direkte Korrelation zur Leistungsaufnahme herstellen. Das finde ich ziemlich aufwändig und ist vermutlich auch nicht sehr genau. Bei meiner WP sind die Verläufe deutlich unschöner als in deinem Diagramm :)
                                      Desweiteren verstehe ich auch nicht, wieso es dann einen min/max Verlauf im Diagramm bzgl. Leistungsaufnahme und Abgabe der Heizleistung gibt und auch nicht, wieso die Leistungsaufnahme bei 65°C kleiner als bei 55°C ist. Da hab ich wohl eine Bildungslücke!
                                      Beste Grüße!
                                      • Bernd 0B Bernd 0
                                        @tbsjah Hi tbsjah,
                                        Beste Grüße!
                                        Jautze
                                        #188
                                        ich würde gerne die Warmwasser Soll Temperatur ändern. Das ist so leider nicht möglich da der Wert sich nicht setzen lässt oder mache ich etwas falsch?
                                        Wie kann ich in Blockly sagen das ich das als Kundendienst machen kann. Ich habe keinen Datenpunkt gefunden bei dem ich die PIN eingeben kann.
                                        Danke und viele Grüße
                                        Marcel
                                        L 1 Antwort Letzte Antwort
                                        • J Jautze
                                          Marcel
                                          lessthanmore
                                          #189
                                          @jautze Es müsste im Objektbaum ein Datenpunkt "Warmwater Target" geben. Den solltest du ändern können.
                                          Zeig mal einen Screenshot vom Objektbaum.
                                          Werden denn alle anderen Werte korrekt gelesen?
                                          Einen PIN musst du nicht setzen.
