  4. Test Adapter luxtronik2 v0.4.x
  • Neuer Installer und neuer Fixer: ĂŒbersichtliche OberflĂ€che und `iob docker`
  • Mitmachen: Sprich „ioBroker“ ein – fĂŒr ein lokales Aktivierungswort
adapterluxtronik wpwebsocket
292 BeitrÀge 52 Kommentatoren 111.7k Aufrufe 49 Beobachtet
    @henning-1
    Der pi fehlt in der Gruppe 'iobroker'
    sudo usermod -aG iobroker pi
    H
    H
    Henning 1
    #171
    @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
    Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgefĂŒhrt
    pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
    pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
    host.iobroker-pi install adapter luxtronik2
    upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
    upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
    upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
    upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
    upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
    host.iobroker-pi object system.adapter.luxtronik2 created/updated
    host.iobroker-pi create instance luxtronik2
    host.iobroker-pi object system.adapter.luxtronik2.0.alive created
    host.iobroker-pi object system.adapter.luxtronik2.0.connected created
    host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
    host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
    host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
    host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
    host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
    host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
    host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
    host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
    host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
    host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
    host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
    host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
    host.iobroker-pi object luxtronik2.0.info created
    host.iobroker-pi object luxtronik2.0.info.connection created
    host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
    host.iobroker-pi object system.adapter.luxtronik2.0 created
    Ich mache mal nen Reboot und schaue dann, was ich sehe.
    • H Henning 1
      Das liefert er:
      pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + iobroker.luxtronik2@0.4.2
      added 7 packages from 82 contributors in 29.319s
      50 packages are looking for funding
        run `npm fund` for details
      Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
      H
      H
      Henning 1
      #172
      Vielen Dank fĂŒr Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
      Schönes WE soweit noch :-)
      • H
        H
        Henning 1
        #173
        ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
        2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.AusgÀnge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.AusgÀnge.51-0_C-53-1_C
        2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.WÀrmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.WÀrmemenge.51-0_C-53-1_C
        2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.WÀrmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
        2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.AusgÀnge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.AusgÀnge.51-0_C-53-2_C
        2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.WÀrmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.WÀrmemenge.51-0_C-53-2_C
        2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.WÀrmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
        • H Henning 1
          Thomas BraunT
          Thomas BraunT
          Most Active Developer
          #174
          @henning-1
          Die Gradzeichen sind nicht zulĂ€ssig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
          • H
            H
            Henning 1
            #175
            Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei AusgÀngen so aus:
            und geht so weiter bis 57. Danach kommt AV-Abtauventil...
            • H
              H
              Henning 1
              #176
              Das Ganze steht bei WĂ€rmemenge auch nochmal drin
              • H
                H
                Henning 1
                #177
                Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei EingÀnge fehlt bsw. Durchfluss 2 etc
                Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                • H
                  H
                  Henning 1
                  #178
                  @UncleSam Soll ich da ein Ticket aufmachen? Ich habe nĂ€mlich zwei Außeneinheiten an einer Steuerung. Daher gibt's bei mir einige Werte doppelt. Mit manchen schien der Adapter klar zu kommen ,mit anderen nicht.
                  • P
                    P
                    pgBroker
                    schrieb am zuletzt editiert von pgBroker
                    #179
                    Musste meinen ioBroker nach einem Crash neu aufsetzen und bekomme jetzt im log im Sekundentakt diese Warnung:
                    Unknown data item parameters.mk1_curve_parallel_offset
                    Unknown data item parameters.mk1_curve_end_point
                    Unknown data item parameters.deltaMk1Reduction
                    Wie kriege ich die weg?
                    P 1 Antwort Letzte Antwort
                    • P pgBroker
                      P
                      P
                      pgBroker
                      #180
                      Hmmm, hat niemand ne idee? 😕
                      • Bernd 0B
                        Bernd 0B
                        Bernd 0
                        #181
                        kann man ĂŒber den Adapter herausfinden, welchen Leistungsbezug die WĂ€rmepumpe aus dem Netz bezieht? Also kWh?
                        Ich habe nur gefunden, dass man die erzeugte WĂ€rmeleistung abfragen kann.
                        Vielen Dank.
                        GB
                        TbsJahT 1 Antwort Letzte Antwort
                        • Bernd 0B Bernd 0
                          Vielen Dank.
                          GB
                          TbsJahT
                          TbsJahT
                          TbsJah
                          #182
                          @bernd-0 aktuell gibt es dafĂŒr keinen Parameter.
                          Du könntest den Wert jedoch annĂ€herungsweise ĂŒber die Temperatur WQ ermitteln
                          Bernd 0B 1 Antwort Letzte Antwort
                          • H
                            H
                            hg4711
                            #183
                            ich hatte den Adapter neu installiert (0.4.2). Er ist auch konfigurierbar mit dem Passwort, den Parametern Websocket 8214 und Port 8889 bekomme ich keine Verbindung. Im Log bekomme ich nach dem Start die Fehlermeldung:
                            2d9b730f-841d-4915-af6e-ce08dcbd6e27-image.png und weitere als Konsequenz ...
                            Hat jemand eine Idee was hier fehlt oder schief lÀuft?
                            Danke schon mal
                            • H hg4711
                              Danke schon mal
                              Thomas BraunT
                              Thomas BraunT
                              #184
                              @hg4711 sagte in Test Adapter luxtronik2 v0.4.x:
                              Eine aktuelle Version von nodejs.
                              Der vorgesehene Stand ist nodeJS 16.
                              Der js-controller ist auch veraltet:
                              stable: 4.0.23 for 4 months
                              Bring dein System auf Stand.
                              • L
                                L
                                lessthanmore
                                #185
                                @hg4711 Passwort korrekt?
                                Gerne auch mal Port 8888 probieren.
                                H 1 Antwort Letzte Antwort
                                • L lessthanmore
                                  H
                                  H
                                  hg4711
                                  #186
                                  @lessthanmore
                                  Denke es liegt an einer alten FW Version der Luxtronik2. Was ich gelesen habe: Erst ab V. 3.81 gibt es Websockets. Muss ich mal prĂŒfen ob die drauf ist. Bin aber gerade nicht vor Ort. Wochenende ...
                                  Port 8888 habe ich natĂŒrlich getestet und PW stimmt sicher, aber soweit kommt der Adapter gar nicht.
                                  Danke soweit
                                  • TbsJahT TbsJah
                                    Bernd 0B
                                    Bernd 0B
                                    Bernd 0
                                    schrieb am zuletzt editiert von Bernd 0
                                    #187
                                    @tbsjah Hi tbsjah,
                                    Danke fĂŒr deine Antwort. Die Idee ist an sich nicht schlecht. Da die Leistungskurven aber keine einfachen Funktionen sind, könnte man nur fĂŒr jeden Temperaturwert eine direkte Korrelation zur Leistungsaufnahme herstellen. Das finde ich ziemlich aufwĂ€ndig und ist vermutlich auch nicht sehr genau. Bei meiner WP sind die VerlĂ€ufe deutlich unschöner als in deinem Diagramm :)
                                    Desweiteren verstehe ich auch nicht, wieso es dann einen min/max Verlauf im Diagramm bzgl. Leistungsaufnahme und Abgabe der Heizleistung gibt und auch nicht, wieso die Leistungsaufnahme bei 65°C kleiner als bei 55°C ist. Da hab ich wohl eine BildungslĂŒcke!
                                    Beste GrĂŒĂŸe!
                                    • Bernd 0B Bernd 0
                                      @tbsjah Hi tbsjah,
                                      Beste GrĂŒĂŸe!
                                      J
                                      J
                                      Jautze
                                      #188
                                      ich wĂŒrde gerne die Warmwasser Soll Temperatur Ă€ndern. Das ist so leider nicht möglich da der Wert sich nicht setzen lĂ€sst oder mache ich etwas falsch?
                                      Wie kann ich in Blockly sagen das ich das als Kundendienst machen kann. Ich habe keinen Datenpunkt gefunden bei dem ich die PIN eingeben kann.
                                      Danke und viele GrĂŒĂŸe
                                      Marcel
                                      L 1 Antwort Letzte Antwort
                                      • J Jautze
                                        Marcel
                                        L
                                        L
                                        lessthanmore
                                        #189
                                        @jautze Es mĂŒsste im Objektbaum ein Datenpunkt "Warmwater Target" geben. Den solltest du Ă€ndern können.
                                        Zeig mal einen Screenshot vom Objektbaum.
                                        Werden denn alle anderen Werte korrekt gelesen?
                                        Einen PIN musst du nicht setzen.
                                        • L lessthanmore
                                          J
                                          J
                                          Jautze
                                          #190
                                          @lessthanmore
                                          Der Datenpunkt heißt Warmwasser-Soll und ist nicht schreibbar.
                                          Hast du es satt, bei jedem Besuch durch die gleichen BeitrĂ€ge zu scrollen? Wenn du dich fĂŒr ein Konto anmeldest, kommst du immer genau dorthin zurĂŒck, wo du zuvor warst, und kannst dich ĂŒber neue Antworten benachrichtigen lassen (entweder per E-Mail oder Push-Benachrichtigung). Du kannst auch Lesezeichen speichern und BeitrĂ€ge positiv bewerten, um anderen Community-Mitgliedern deine WertschĂ€tzung zu zeigen.
                                          84.1k
                                          BeitrÀge
