  4. Test Adapter luxtronik2 v0.4.x
adapterluxtronik wpwebsocket
292 Beiträge 52 Kommentatoren 97.4k Aufrufe 49 Beobachtet
  • H Offline
    Henning 1
    #158
    sorry, meine geistige Umnachtung :-) Ist irgendwie zu warm draußen... Ich machs gleich nochmal anders.
    • H Offline
      Henning 1
      #159
      Hmm, ging auch nicht:
      pi@iobroker-pi:~ $ iobroker add luxtronik2
      host.iobroker-pi Unknown packetName luxtronik2. Please install packages from outside the repository using npm!
      pi@iobroker-pi:~ $ iobroker add iobroker.luxtronik2
      Ich versuchs jetzt nochmal im opt/iobroker mittels npm. Geht auch nicht :-(
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /opt/iobroker/node_modules
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
      npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/opt/iobroker/node_modules'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/pi/.npm/_logs/2022-07-03T11_29_51_613Z-debug.log
      • H Henning 1
        npm ERR! errno -13
        npm ERR! }
        npm ERR!
        npm ERR!
        #160
        @henning-1
        Mach es so...
        • H Offline
          Henning 1
          #161
          Das hatte ich schon probiert. Der Adapter ist nicht sichtbar.
          • H Henning 1
            #162
            @henning-1
            iobroker update -i
            • H Offline
              Henning 1
              #163
              Used repository: stable
              Adapter    "admin"        : 5.3.8    , installed 5.3.8
              Adapter    "backitup"     : 2.4.9    , installed 2.4.9
              Adapter    "discovery"    : 3.0.3    , installed 3.0.3
              Adapter    "fronius"      : 1.1.3    , installed 1.1.3
              Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
              Adapter    "javascript"   : 5.7.0    , installed 5.7.0
              Controller "js-controller": 4.0.23   , installed 4.0.23
              Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
              Adapter    "openknx"      : 0.2.5    , installed 0.1.22 [Updatable]
              Adapter    "pvforecast"   : 2.1.4    , installed 2.1.4
              Adapter    "unifi"        : 0.5.10   , installed 0.5.10
              Adapter    "valloxmv"     : 1.1.3    , installed 1.1.3
              Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
              • H Henning 1
                npm ERR! errno -13
                npm ERR! }
                npm ERR!
                npm ERR!
                #164
                @henning-1 sagte in Test Adapter luxtronik2 v0.4.x:
                Was genau hast du da eingegeben?
                Bitte IMMER vollständige Ein- wie Ausgaben zeigen.
                • H Offline
                  Henning 1
                  #165
                  Hier inkl. eingegebenes Kommando:
                  pi@iobroker-pi:/opt/iobroker $ npm i iobroker.luxtronik2                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules
                  npm ERR! errno -13
                  npm ERR! }
                  npm ERR!
                  npm ERR!
                  npm ERR!     /home/pi/.npm/_logs/2022-07-03T12_13_16_514Z-debug.log
                  • H Henning 1
                    npm ERR! errno -13
                    npm ERR! }
                    npm ERR!
                    npm ERR!
                    #166
                    @henning-1
                    groups
                    als pi ausgeführt liefert?
                    • H Offline
                      Henning 1
                      #167
                      pi@iobroker-pi:/opt/iobroker $ groups
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
                      • H Henning 1
                        npm ERR! errno -13
                        npm ERR! }
                        npm ERR!
                        npm ERR!
                        #168
                        Alternativ:
                        cd /opt/iobroker
                        sudo -H -u iobroker npm i iobroker.luxtronik2
                        • H Henning 1
                          #169
                          @henning-1
                          Der pi fehlt in der Gruppe 'iobroker'
                          sudo usermod -aG iobroker pi
                          H 1 Antwort Letzte Antwort
                          • H Offline
                            Henning 1
                            #170
                            @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
                            Das liefert er:
                            pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            + iobroker.luxtronik2@0.4.2
                            added 7 packages from 82 contributors in 29.319s
                            50 packages are looking for funding
                              run `npm fund` for details
                            Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
                              @henning-1
                              Henning 1
                              #171
                              Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
                              pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
                              pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
                              host.iobroker-pi install adapter luxtronik2
                              upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
                              upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
                              upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
                              upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
                              upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
                              host.iobroker-pi object system.adapter.luxtronik2 created/updated
                              host.iobroker-pi create instance luxtronik2
                              host.iobroker-pi object system.adapter.luxtronik2.0.alive created
                              host.iobroker-pi object system.adapter.luxtronik2.0.connected created
                              host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
                              host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
                              host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
                              host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
                              host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
                              host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
                              host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
                              host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
                              host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
                              host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
                              host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
                              host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
                              host.iobroker-pi object luxtronik2.0.info created
                              host.iobroker-pi object luxtronik2.0.info.connection created
                              host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
                              host.iobroker-pi object system.adapter.luxtronik2.0 created
                              Ich mache mal nen Reboot und schaue dann, was ich sehe.
                              • H Henning 1
                                Das liefert er:
                                Henning 1
                                #172
                                Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
                                Schönes WE soweit noch :-)
                                • H Offline
                                  Henning 1
                                  #173
                                  ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
                                  2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
                                  2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
                                  2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
                                  2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
                                  2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
                                  2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
                                  • H Henning 1
                                    #174
                                    @henning-1
                                    Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
                                    • H Offline
                                      Henning 1
                                      #175
                                      Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
                                      und geht so weiter bis 57. Danach kommt AV-Abtauventil...
                                      • H Offline
                                        Henning 1
                                        #176
                                        Das Ganze steht bei Wärmemenge auch nochmal drin
                                        • H Offline
                                          Henning 1
                                          #177
                                          Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                                          Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
