  4. Test Adapter fb-checkpresence v1.1.x
    6.6k
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 386.4k Aufrufe 78 Beobachtet
  • afuerhoffA afuerhoff
    @Thomas-Jansen
    Bitte unter Instanzen die Log Stufe auf debug setzen und hier das Log posten.
    Die andere Meldung sagt nur, dass die Firmware der Fritzbox das Feature nicht supported.
    Thomas JansenT Offline
    Thomas Jansen
    #241
    @afuerhoff hi, hier das LOG:
    fb-checkpresence.0 2021-01-05 21:08:00.216 info (30355) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0 2021-01-05 21:08:00.211 info (30355) terminating
    fb-checkpresence.0 2021-01-05 21:08:00.210 info (30355) cleaned everything up ...
    fb-checkpresence.0 2021-01-05 21:08:00.208 info (30355) Got terminate signal TERMINATE_YOURSELF
    fb-checkpresence.0 2021-01-05 21:08:00.152 error (30355) createFbDeviceObjects -> can't read devices from fritzbox! Adapter stops
    fb-checkpresence.0 2021-01-05 21:08:00.151 error (30355) getDeviceList: {"message":"Request failed with status code 503","name":"Error","stack":"Error: Request failed with status code 503\n at createError (/opt/iobroker/node_modules/axios/lib/cor
    fb-checkpresence.0 2021-01-05 21:07:59.788 info (30355) createMemberObjects finished successfully
    fb-checkpresence.0 2021-01-05 21:07:59.787 debug (30355) enableHistory.2 Galaxy-Note10 true
    fb-checkpresence.0 2021-01-05 21:07:59.759 debug (30355) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0 2021-01-05 21:07:59.744 debug (30355) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0 2021-01-05 21:07:59.622 info (30355) createGlobalObjects finished successfully
    fb-checkpresence.0 2021-01-05 21:07:59.365 info (30355) service DeviceConfig1-Reboot is supported
    fb-checkpresence.0 2021-01-05 21:07:59.345 warn (30355) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0 2021-01-05 21:07:59.344 warn (30355) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
    fb-checkpresence.0 2021-01-05 21:07:59.342 info (30355) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0 2021-01-05 21:07:59.325 info (30355) service WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0 2021-01-05 21:07:59.310 info (30355) service WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0 2021-01-05 21:07:59.296 info (30355) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0 2021-01-05 21:07:59.281 info (30355) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0 2021-01-05 21:07:59.267 info (30355) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0 2021-01-05 21:07:59.255 info (30355) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0 2021-01-05 21:07:59.242 info (30355) service Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0 2021-01-05 21:07:59.228 info (30355) service Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0 2021-01-05 21:07:59.214 debug (30355) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
    fb-checkpresence.0 2021-01-05 21:07:59.193 debug (30355) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"233","Major":"161","Minor":"7","Patch":"13","Bui
    fb-checkpresence.0 2021-01-05 21:07:59.083 debug (30355) configuratuion mesh info: false
    fb-checkpresence.0 2021-01-05 21:07:59.083 debug (30355) configuration fb-devices true
    fb-checkpresence.0 2021-01-05 21:07:59.082 debug (30355) configuration familymembers: [{"familymember":"Galaxy-Note10","macaddress":"92:65:A8:12:99:34","ipaddress":"192.168.178.23","useip":false,"comment":"Galaxy-Note10","enabled":true}]
    fb-checkpresence.0 2021-01-05 21:07:59.082 debug (30355) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
    fb-checkpresence.0 2021-01-05 21:07:59.081 debug (30355) configuration history: <influxdb.0>
    fb-checkpresence.0 2021-01-05 21:07:59.080 debug (30355) configuration user: <burger20202.4>
    fb-checkpresence.0 2021-01-05 21:07:59.079 info (30355) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
    fb-checkpresence.0 2021-01-05 21:07:59.044 info (30355) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.1.6
    afuerhoffA 1 Antwort Letzte Antwort
    • Thomas JansenT Thomas Jansen
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      schrieb am zuletzt editiert von afuerhoff
      #242
      @Thomas-Jansen
      Hallo, es scheint keine Antwort von der Fritzbox zu kommen, wenn es um den User und das Passwort geht. Bitte mal den Punkt aus dem Usernamen entfernen. Und dann erneut versuchen.
      Bitte auch Passwort einmal neu eingeben, falls das nicht geholfen hat. Und zu guter Letzt könnte noch ein Neustart der Fritzbox helfen.
      • F Flo1988
        @afuerhoff
        Sry.
        node wurde auf 12.20.0 geupdated.
        Läuft trotzdem nicht.
        WLAN wurde während dem log bei "Florian" deaktiviert aber passiert nix.
        fb-checkpresence.0	2020-12-29 20:11:21.928	debug	(4210) loopDevices ends after 2,157899582 s
        fb-checkpresence.0	2020-12-29 20:11:21.924	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
        fb-checkpresence.0	2020-12-29 20:11:21.778	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
        fb-checkpresence.0	2020-12-29 20:11:21.662	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
        fb-checkpresence.0	2020-12-29 20:10:19.702	debug	(4210) loopDevices ends after 1,441445027 s
        fb-checkpresence.0	2020-12-29 20:10:19.700	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
        fb-checkpresence.0	2020-12-29 20:10:19.615	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
        fb-checkpresence.0	2020-12-29 20:10:19.546	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
        fb-checkpresence.0	2020-12-29 20:10:13.252	info	(4210) createFbDeviceObjects finished successfully
        fb-checkpresence.0	2020-12-29 20:10:04.787	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
        fb-checkpresence.0	2020-12-29 20:10:03.789	info	(4210) createMemberObjects finished successfully
        fb-checkpresence.0	2020-12-29 20:10:03.788	debug	(4210) enableHistory.2 Silke true
        fb-checkpresence.0	2020-12-29 20:10:03.762	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-12-29 20:10:03.752	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-12-29 20:10:03.625	debug	(4210) enableHistory.2 Florian true
        fb-checkpresence.0	2020-12-29 20:10:03.597	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-12-29 20:10:03.584	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-12-29 20:10:03.454	info	(4210) createGlobalObjects finished successfully
        fb-checkpresence.0	2020-12-29 20:10:03.085	info	(4210) service DeviceConfig1-Reboot is supported
        fb-checkpresence.0	2020-12-29 20:10:03.064	info	(4210) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
        fb-checkpresence.0	2020-12-29 20:10:02.952	info	(4210) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
        fb-checkpresence.0	2020-12-29 20:10:02.938	info	(4210) service DeviceInfo1-GetInfo is supported
        fb-checkpresence.0	2020-12-29 20:10:02.919	info	(4210) service WLANConfiguration3-GetInfo is supported
        fb-checkpresence.0	2020-12-29 20:10:02.903	info	(4210) service WLANConfiguration3-SetEnable is supported
        fb-checkpresence.0	2020-12-29 20:10:02.886	info	(4210) service WANPPPConnection1-GetInfo is supported
        fb-checkpresence.0	2020-12-29 20:10:02.869	info	(4210) service DeviceInfo1-GetSecurityPort is supported
        fb-checkpresence.0	2020-12-29 20:10:02.853	info	(4210) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2020-12-29 20:10:02.834	info	(4210) service Hosts1-GetSpecificHostEntry is supported
        fb-checkpresence.0	2020-12-29 20:10:02.820	info	(4210) service Hosts1-X_AVM-DE_GetMeshListPath is supported
        fb-checkpresence.0	2020-12-29 20:10:02.802	info	(4210) service Hosts1-X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2020-12-29 20:10:02.787	debug	(4210) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
        fb-checkpresence.0	2020-12-29 20:10:02.756	debug	(4210) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"226","Major":"154","Minor":"7","Patch":"21","Buil
        fb-checkpresence.0	2020-12-29 20:10:02.498	debug	(4210) configuratuion mesh info: false
        fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration fb-devices true
        fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration familymembers: [{"familymember":"Florian","macaddress":"A0:FB:C5:21:AC:7B","ipaddress":"192.168.155.86","useip":false,"comment":"iPhone12pro","enabled":true},{"familymember":"Silk
        fb-checkpresence.0	2020-12-29 20:10:02.496	debug	(4210) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
        fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration history: <influxdb.0>
        fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration user: <ioBroker_tr064>
        fb-checkpresence.0	2020-12-29 20:10:02.493	info	(4210) start fb-checkpresence: ip-address: "192.168.155.1" - interval devices: 1 Min. - interval members: 10 s
        fb-checkpresence.0	2020-12-29 20:10:02.451	info	(4210) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
        fb-checkpresence.0	2020-12-29 20:09:56.390	info	(4147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0	2020-12-29 20:09:56.388	info	(4147) terminating
        fb-checkpresence.0	2020-12-29 20:09:56.386	info	(4147) cleaned everything up ...
        fb-checkpresence.0	2020-12-29 20:09:56.384	info	(4147) Got terminate signal TERMINATE_YOURSELF
        Flo1988
        #243
        @Flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
        @afuerhoff
        Sry.
        Gibt es hier schon eine Idee, warum die Geräte nicht richtig erkannt werden?
        In der FritzBox werden sie korrekt als aktiv und inaktiv angezeigt.
        Bis Version 1.0.4 hat auch alles prima funktioniert.
        Der Fehler hat sich mit der Änderung auf 1.1.0 eingeschlichen.
        • Pedder007P Pedder007
          Hallo großer Meister @afuerhoff :-)
          Top-Leistung, so wie das hier bei mir aktuell aussieht.
          1.1.1 installiert und keine 'Ghost'-Einträge mehr und durch die Abänderung der 0-7/8'en in Klarnamen nun auch sicherlich keine Vertauschungen mehr in VIS.
          (... jetzt kann ich meine schönen Blockly-Workarounds wieder abschalten, .... 😢 , ... aber gut was gelernt dabei ;-) )
          Das macht mir meine VIS-Netzview auch nochmals schlanker, da überflüssige Felder wie z. B. LAN1 und LANBridge (insges. 6 Einträge) nun raus können.
          1000-DANK !!! :-)
          Pedder007P Online
          Pedder007P Online
          Pedder007
          #244
          An der Stelle nochmal kurz ein Feedback nach nun gut einer Woche Laufzeit nach dem Update.
          Keinerlei veraltete oder verwechselte Einträge mehr, Adapter läuft super stabil und sogar die Familie ist nun in der Lage zu sehen wo sie ggf. gerade am WLAN "hängen" und ggf. via VIS einzelne (Fritz) NW-Devices neu zu booten, sofern diese überhaupt noch erreichbar sind - sonst hilft natürlich nur Stecker ziehen ;-)
          Danke nochmal, dass erleichtert einem wirklich das Leben und reduziert meine persönlichen Tickets zum Thema "Papa das WLAN geht wieder nicht...." 😆 drastisch! 👍 👍 👍
          Pedder
          All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
          Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
          Under construction: Smart-WoMo auf Raspi4
            Aktuelle Test Version 1.1.25
            Veröffentlichungsdatum 21.01.2023
            Github Link https://github.com/afuerhoff/ioBroker.fb-checkpresence
            npm im Latest verfügbar
            Hinweis: Adapter muss nach Installation von Github einmal neu gestartet werden.
            Änderungen:
            1.1.0
            • second interval for family members implemented
            • mesh info added
            • configuration validation added
            • switch on, off guest wlan
            • switch on, off internet access of devices
            • structural changes
            • code optimization
            • new datapoint absenceAll
            • neue Funktion Reboot
            1.1.1
            • Admin Konfiguration optimiert
            • Im Dateformat dürfen jetzt auch Bindestriche benutzt werden
            • https workaround implementiert (Konfiguration)-> es gab einen Fall, wo der Adapter nicht mit * https die Fritzbox abfragen konnte.
            • Connection check wurde optimiert
            • Dokumentation geändert
            • Mesh Handling optimiert -> es werden jetzt die Channels im Klartext angelegt. Dies verhindert, dass sich die Id's ändern.
            1.1.2
            • Gäste WLAN QR-Code ist als State implementiert und kann mit dem Basic Bool SVG Widget benutzt werden.
            • Die Presence states werden nur geändert, wenn es eine Änderung gibt.
            • Die Benutzerrechte des Users werden ausgelesen und mit den unterstützten Services der Fritzbox abgeglichen. Es muss der Service unterstützt werden und die Benutzerrechte zum Service passen. Ist dies nicht der Fall, werden nur die Funktionen ausgeführt, die dann möglich sind. Man kann also die Accessrights (FRITZ!Box Einstellungen, Smart Home, ...) in der Fritzbox reduzieren ohne Fehler zu bekommen. Im Log wird das beim Start einmal als Warnung ausgegeben.
            • Der Name des Devices kann jetzt ebenfalls genutzt werden. Hierfür muss das Familienmitglied genauso wie in der Fritzbox benannt werden. (Achtung: Wenn der Name nur in der Fritzbox manuell umbenannt wurde und nicht im Handy, dann wird bei eingeschalteter Mac-Verschleierung der Name des neu in der Fritzbox hinzugefügten Devices ein anderer sein)
            • active / inactive Device Zähler korrigiert
            • 10s Intervall Bug gefixed
            • Dokumentation angepasst
            • PresentGuests state eingebaut
            Änderungen 1.1.3:
            • Familiengruppen. Diese werden im Ordner familyMembers angelegt.
            • Kompatibilitätsmodus -> in Zukunft gibt es nur noch den presence state bei den Familienmitgliedern. Nicht mehr den auf der obersten Ebene am Familienmitglied.
            • In der Konfiguration habe ich noch ein paar Optionen aufgenommen
            • Die Dialogboxen habe ich optimiert
            • Ein Filter kann jetzt pro Familienmitglied eingeschaltet werden. Ist ein Familienmitglied true wird sofort der Status gesetzt. Bei false wird nach der Filterzeit nochmal auf den Wert geschaut und nur dann der Status gesetzt falls der Status ebenfalls false ist.
            • Für das Passwort Handling nutze ich jetzt die neue ioBroker Funktionalität
            • und diverse Änderungen unter der Haube
            ich habe eine neue Testversion auf Github hochgeladen. Bitte testet diese und gebt hier Rückmeldung über Probleme mit der neuen Version.
            Wichtigste Neuerungen sind das Ein- und Ausschalten des Gäste-WLAN. Das deaktivieren des Internetzugriffs von Geräten und ein zusätzliches Interval für Familienmitglieder.
            Die Eingaben auf der Konfigurationsseite werden jetzt überprüft und ggfs. das Speichern deakiviert. Im Bereich der fb-devices werden jetzt zusätzliche Mesh-Informationen angelegt, falls dies in der Konfiguration aktiviert wurde.
            Viel Spaß beim Testen.
            Gäste-WLAN ein-, ausschalten -> Datenpunkt wlan
            Internetzugriff ein-, ausschalten -> fb-devices Datenpunkt disabled = true (Internet aus)
            #245
            @afuerhoff hab noch was entdeckt, was Du vielleicht gerne nachrüsten kannst... 🙂
            Einen DONATE 💰 Button in der Adapterkonfig, damits auch jeder sieht..
              Änderungen:
              1.1.0
              • mesh info added
              • code optimization
              1.1.1
              1.1.2
              Änderungen 1.1.3:
              Dominik F.D Offline
              Dominik F.D Offline
              Dominik F.
              #246
              @afuerhoff
              Nabend,
              ich nutze deinen Adapter in der Version 1.10 und der funktioniert auch sehr zuverlässig.
              Nun habe ich festgestellt, dass der Heatingcontrol Adapter ständig neu getriggert wird.
              Ich nutze dort einen Datenpunkt von deinem Adapter. Das Problem scheint zu sein, dass dein Adapter den Datenpunkt für Presence minütlich neu setzt auch wenn dieser sich nicht ändert.
              Gibt es eine Möglichkeit, oder ist es vielleicht schon in der neuen Version enthalten, dass die Datenpunkte nur bei Änderung neu gesetzt werden?
              • F Flo1988
                @afuerhoff
                Sry.
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #247
                Es sieht so aus, als ob die Routine für die Familienmitglieder gar nicht durchlaufen wird.
                Da müsste eigentlich eine Meldung im Log kommen.
                Kannst Du mal das Interval auf 11s setzen. Ich denke ich hab den Fehler gefunden.
                F 1 Antwort Letzte Antwort
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #248
                  @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
                  :-) Muss mich mal informieren wie hier die Abgabenlage so ist. Da möchte doch bestimmt das Finanzamt beteiligt werden.
                  ? 1 Antwort Letzte Antwort
                  • Dominik F.D Dominik F.
                    @afuerhoff
                    Nabend,
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #249
                    @Dominik-F sagte in Test Adapter fb-checkpresence v1.1.x:
                    Bis jetzt ist das noch nicht vorgesehen. Für die presence Datenpunkte könnte ich das aber erstmal so einbauen. Die 1.1.1 ist ja noch nicht kpl. fertig.
                    Dominik F.D 2 Antworten Letzte Antwort
                      #250
                      @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                      Wenn man dir Spendet, weniger.. :-) Ansonsten gibt da nur genaue Auskunft dein Steuerberater, kommt drauf an, was du alles so machst und Einkünfte hast.. :-)
                        Dominik F.D Offline
                        Dominik F.D Offline
                        Dominik F.
                        #251
                        @afuerhoff
                        Das wäre klasse, vielen lieben dank
                          Flo1988
                          #252
                          Funktioniert!
                          Habe den Intervall auf 11 Sekunden gestellt und die Geräte werden wieder zuverlässig erkannt.
                          Ich lasse es erstmal so, wenn es eine neue Version zum Testen gibt, bitte schreiben, dann kann ich schauen ob es auch bei mir mit 10 Sekunden wieder geht.
                          Verwunderlich, dass ich der einzige bin, bei dem der Fehler auftritt... 😕
                            Dominik F.D Offline
                            Dominik F.D Offline
                            Dominik F.
                            #253
                            @afuerhoff
                            Ich hätte noch einen Wunsch für deinen Adapter.
                            Einen Datenpunkt, wo gezählt wird wie viele gerade Anwesend sind.
                              @afuerhoff
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #254
                              @Dominik-F
                              Kein Problem
                              • FenriswolfF Offline
                                FenriswolfF Offline
                                Fenriswolf
                                #255
                                Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
                                2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                                2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                                Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
                                2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
                                Was hat das DSL-Forum damit zu tun ??
                                bis denne
                                Press any key to continue or any other to quit
                                afuerhoffA 2 Antworten Letzte Antwort
                                • FenriswolfF Fenriswolf
                                  bis denne
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #256
                                  @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
                                  dslforum-org
                                  Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
                                  Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
                                  Das hat mit dem TR-064 Standard zu tun.
                                  FenriswolfF 1 Antwort Letzte Antwort
                                    dslforum-org
                                    FenriswolfF Offline
                                    FenriswolfF Offline
                                    Fenriswolf
                                    #257
                                    dslforum-org
                                    OK ;-) danke für die schnelle Antwort
                                      bis denne
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #258
                                      @Fenriswolf
                                      Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
                                        @Fenriswolf
                                        FenriswolfF Offline
                                        FenriswolfF Offline
                                        Fenriswolf
                                        #259
                                        @Fenriswolf
                                        Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
                                        Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
                                          @Fenriswolf
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #260
                                          Die Meshdaten werden nur wenn angehakt geladen und im gleichen Intervall aktulisiert wie die
                                          Fb-Devicedaten.
