  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • F Flo1988
    @Flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
    @afuerhoff
    Sry.
    node wurde auf 12.20.0 geupdated.
    Läuft trotzdem nicht.
    WLAN wurde während dem log bei "Florian" deaktiviert aber passiert nix.
    fb-checkpresence.0	2020-12-29 20:11:21.928	debug	(4210) loopDevices ends after 2,157899582 s
    fb-checkpresence.0	2020-12-29 20:11:21.924	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
    fb-checkpresence.0	2020-12-29 20:11:21.778	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
    fb-checkpresence.0	2020-12-29 20:11:21.662	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
    fb-checkpresence.0	2020-12-29 20:10:19.702	debug	(4210) loopDevices ends after 1,441445027 s
    fb-checkpresence.0	2020-12-29 20:10:19.700	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
    fb-checkpresence.0	2020-12-29 20:10:19.615	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
    fb-checkpresence.0	2020-12-29 20:10:19.546	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
    fb-checkpresence.0	2020-12-29 20:10:13.252	info	(4210) createFbDeviceObjects finished successfully
    fb-checkpresence.0	2020-12-29 20:10:04.787	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
    fb-checkpresence.0	2020-12-29 20:10:03.789	info	(4210) createMemberObjects finished successfully
    fb-checkpresence.0	2020-12-29 20:10:03.788	debug	(4210) enableHistory.2 Silke true
    fb-checkpresence.0	2020-12-29 20:10:03.762	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.752	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.625	debug	(4210) enableHistory.2 Florian true
    fb-checkpresence.0	2020-12-29 20:10:03.597	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.584	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.454	info	(4210) createGlobalObjects finished successfully
    fb-checkpresence.0	2020-12-29 20:10:03.085	info	(4210) service DeviceConfig1-Reboot is supported
    fb-checkpresence.0	2020-12-29 20:10:03.064	info	(4210) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
    fb-checkpresence.0	2020-12-29 20:10:02.952	info	(4210) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
    fb-checkpresence.0	2020-12-29 20:10:02.938	info	(4210) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2020-12-29 20:10:02.919	info	(4210) service WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0	2020-12-29 20:10:02.903	info	(4210) service WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0	2020-12-29 20:10:02.886	info	(4210) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2020-12-29 20:10:02.869	info	(4210) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2020-12-29 20:10:02.853	info	(4210) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-12-29 20:10:02.834	info	(4210) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-12-29 20:10:02.820	info	(4210) service Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0	2020-12-29 20:10:02.802	info	(4210) service Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-12-29 20:10:02.787	debug	(4210) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
    fb-checkpresence.0	2020-12-29 20:10:02.756	debug	(4210) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"226","Major":"154","Minor":"7","Patch":"21","Buil
    fb-checkpresence.0	2020-12-29 20:10:02.498	debug	(4210) configuratuion mesh info: false
    fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration fb-devices true
    fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration familymembers: [{"familymember":"Florian","macaddress":"A0:FB:C5:21:AC:7B","ipaddress":"192.168.155.86","useip":false,"comment":"iPhone12pro","enabled":true},{"familymember":"Silk
    fb-checkpresence.0	2020-12-29 20:10:02.496	debug	(4210) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
    fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration history: <influxdb.0>
    fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration user: <ioBroker_tr064>
    fb-checkpresence.0	2020-12-29 20:10:02.493	info	(4210) start fb-checkpresence: ip-address: "192.168.155.1" - interval devices: 1 Min. - interval members: 10 s
    fb-checkpresence.0	2020-12-29 20:10:02.451	info	(4210) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
    fb-checkpresence.0	2020-12-29 20:09:56.390	info	(4147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0	2020-12-29 20:09:56.388	info	(4147) terminating
    fb-checkpresence.0	2020-12-29 20:09:56.386	info	(4147) cleaned everything up ...
    fb-checkpresence.0	2020-12-29 20:09:56.384	info	(4147) Got terminate signal TERMINATE_YOURSELF
    Gibt es hier schon eine Idee, warum die Geräte nicht richtig erkannt werden?
    In der FritzBox werden sie korrekt als aktiv und inaktiv angezeigt.
    Bis Version 1.0.4 hat auch alles prima funktioniert.
    Der Fehler hat sich mit der Änderung auf 1.1.0 eingeschlichen.
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #247
    Es sieht so aus, als ob die Routine für die Familienmitglieder gar nicht durchlaufen wird.
    Da müsste eigentlich eine Meldung im Log kommen.
    Kannst Du mal das Interval auf 11s setzen. Ich denke ich hab den Fehler gefunden.
    F 1 Antwort Letzte Antwort
      @afuerhoff hab noch was entdeckt, was Du vielleicht gerne nachrüsten kannst... 🙂
      Einen DONATE 💰 Button in der Adapterkonfig, damits auch jeder sieht..
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      #248
      @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
      :-) Muss mich mal informieren wie hier die Abgabenlage so ist. Da möchte doch bestimmt das Finanzamt beteiligt werden.
      • Dominik F.D Dominik F.
        @afuerhoff
        Nabend,
        ich nutze deinen Adapter in der Version 1.10 und der funktioniert auch sehr zuverlässig.
        Nun habe ich festgestellt, dass der Heatingcontrol Adapter ständig neu getriggert wird.
        Ich nutze dort einen Datenpunkt von deinem Adapter. Das Problem scheint zu sein, dass dein Adapter den Datenpunkt für Presence minütlich neu setzt auch wenn dieser sich nicht ändert.
        Gibt es eine Möglichkeit, oder ist es vielleicht schon in der neuen Version enthalten, dass die Datenpunkte nur bei Änderung neu gesetzt werden?
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #249
        @Dominik-F sagte in Test Adapter fb-checkpresence v1.1.x:
        Bis jetzt ist das noch nicht vorgesehen. Für die presence Datenpunkte könnte ich das aber erstmal so einbauen. Die 1.1.1 ist ja noch nicht kpl. fertig.
        Dominik F.D 2 Antworten Letzte Antwort
        • afuerhoffA afuerhoff
          #250
          @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
          Wenn man dir Spendet, weniger.. :-) Ansonsten gibt da nur genaue Auskunft dein Steuerberater, kommt drauf an, was du alles so machst und Einkünfte hast.. :-)
            Dominik F.D Offline
            Dominik F.D Offline
            Dominik F.
            #251
            @afuerhoff
            Das wäre klasse, vielen lieben dank
              Flo1988
              #252
              Funktioniert!
              Habe den Intervall auf 11 Sekunden gestellt und die Geräte werden wieder zuverlässig erkannt.
              Ich lasse es erstmal so, wenn es eine neue Version zum Testen gibt, bitte schreiben, dann kann ich schauen ob es auch bei mir mit 10 Sekunden wieder geht.
              Verwunderlich, dass ich der einzige bin, bei dem der Fehler auftritt... 😕
                Dominik F.D Offline
                Dominik F.D Offline
                Dominik F.
                #253
                @afuerhoff
                Ich hätte noch einen Wunsch für deinen Adapter.
                Einen Datenpunkt, wo gezählt wird wie viele gerade Anwesend sind.
                  @afuerhoff
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #254
                  @Dominik-F
                  Kein Problem
                  • FenriswolfF Offline
                    FenriswolfF Offline
                    Fenriswolf
                    #255
                    Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
                    2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                    2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                    2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                    2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                    2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                    2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                    2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                    2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                    2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                    Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
                    2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
                    Was hat das DSL-Forum damit zu tun ??
                    bis denne
                    afuerhoffA 2 Antworten Letzte Antwort
                    • FenriswolfF Fenriswolf
                      bis denne
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #256
                      @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
                      dslforum-org
                      Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
                      Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
                      Das hat mit dem TR-064 Standard zu tun.
                      FenriswolfF 1 Antwort Letzte Antwort
                        dslforum-org
                        FenriswolfF Offline
                        FenriswolfF Offline
                        Fenriswolf
                        #257
                        dslforum-org
                        OK ;-) danke für die schnelle Antwort
                          bis denne
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #258
                          @Fenriswolf
                          Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
                            @Fenriswolf
                            FenriswolfF Offline
                            FenriswolfF Offline
                            Fenriswolf
                            #259
                            @Fenriswolf
                            Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
                            Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
                              @Fenriswolf
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #260
                              Die Meshdaten werden nur wenn angehakt geladen und im gleichen Intervall aktulisiert wie die
                              Fb-Devicedaten.
                                @TG70
                                Du brauchst die Fritzbox Version 7.20 damit es schneller geht.
                                TG70T Offline
                                TG70T Offline
                                TG70
                                Forum Testing
                                #261
                                @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                                @TG70
                                Also ich bin jetzt auf der Fritz! 7.23 ... Allerdings merke ich nichts davon, dass die Erkennung schneller geht.
                                Den Zustand "Offline" wird mir erst nach ca. 10 Minuten angezeigt? Wie lange dauert es bei euch mit der Erkennung der Zustände "Online" und "Offline"
                                ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
                                • TG70T TG70
                                  @TG70
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  schrieb am zuletzt editiert von afuerhoff
                                  #262
                                  @TG70
                                  Wie ist denn die Intervalleinstellung für Familienmitglieder?
                                  EDIT: Bei mir dauert es mit der Version 7.21 (Intervall 10s) max. 20-30 s.
                                  TG70T 1 Antwort Letzte Antwort
                                  • afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #263
                                    ich habe die Version 1.1.2 auf Github zum Testen veröffentlicht. Die Änderungen sind im ersten Beitrag beschrieben. Bitte gebt Rückmeldung, ob alles funktioniert.
                                    ? FenriswolfF 2 Antworten Letzte Antwort
                                      #264
                                      @afuerhoff laeuft... :-)
                                        @TG70
                                        TG70T Offline
                                        TG70T Offline
                                        TG70
                                        Forum Testing
                                        #265
                                        @TG70
                                        Steht bei mir auf 10s. Wie gesagt Offlie Zustand dauert bis 10 Minuten. Online geht schneller ca. <= 1 Min.
                                          FenriswolfF Offline
                                          FenriswolfF Offline
                                          Fenriswolf
                                          schrieb am zuletzt editiert von Fenriswolf
                                          #266
                                          habe jetzt folgende Eintragungen im Log:
                                          2021-01-14 07:32:33.719 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                                          2021-01-14 07:32:33.720 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:32:33.720 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                                          2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                                          2021-01-14 07:32:33.721 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                                          2021-01-14 07:32:33.722 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                                          2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                                          2021-01-14 07:32:33.723 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                                          2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                                          2021-01-14 07:32:33.724 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:32:33.724 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                                          2021-01-14 07:32:33.725 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                                          2021-01-14 07:32:33.725 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.613 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                                          2021-01-14 07:43:11.614 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.615 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                                          2021-01-14 07:43:11.615 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                                          2021-01-14 07:43:11.616 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                                          2021-01-14 07:43:11.617 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.617 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                                          2021-01-14 07:43:11.618 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                                          2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                                          2021-01-14 07:43:11.619 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.619 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                                          2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                                          2021-01-14 07:43:11.620 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                                          2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                                          alle 11 Minuten
                                          bis denne
                                          sigi234S afuerhoffA 2 Antworten Letzte Antwort
