  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • F Flo1988
    @afuerhoff
    Sry.
    node wurde auf 12.20.0 geupdated.
    Läuft trotzdem nicht.
    WLAN wurde während dem log bei "Florian" deaktiviert aber passiert nix.
    fb-checkpresence.0	2020-12-29 20:11:21.928	debug	(4210) loopDevices ends after 2,157899582 s
    fb-checkpresence.0	2020-12-29 20:11:21.924	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
    fb-checkpresence.0	2020-12-29 20:11:21.778	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
    fb-checkpresence.0	2020-12-29 20:11:21.662	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
    fb-checkpresence.0	2020-12-29 20:10:19.702	debug	(4210) loopDevices ends after 1,441445027 s
    fb-checkpresence.0	2020-12-29 20:10:19.700	debug	(4210) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Up","NewMaxBitRate":"Auto","NewChannel":"1","
    fb-checkpresence.0	2020-12-29 20:10:19.615	debug	(4210) external IP1: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANPPPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
    fb-checkpresence.0	2020-12-29 20:10:19.546	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
    fb-checkpresence.0	2020-12-29 20:10:13.252	info	(4210) createFbDeviceObjects finished successfully
    fb-checkpresence.0	2020-12-29 20:10:04.787	debug	(4210) getDeviceList: [{"Index":"1","IPAddress":"192.168.155.76","MACAddress":"9C:14:63:BB:12:EF","Active":"0","HostName":"5C045A9PAG178EB","InterfaceType":"Ethernet","X_AVM-DE_Port":"2","X_AVM-DE_Spe
    fb-checkpresence.0	2020-12-29 20:10:03.789	info	(4210) createMemberObjects finished successfully
    fb-checkpresence.0	2020-12-29 20:10:03.788	debug	(4210) enableHistory.2 Silke true
    fb-checkpresence.0	2020-12-29 20:10:03.762	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.752	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.625	debug	(4210) enableHistory.2 Florian true
    fb-checkpresence.0	2020-12-29 20:10:03.597	debug	(4210) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.584	debug	(4210) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2020-12-29 20:10:03.454	info	(4210) createGlobalObjects finished successfully
    fb-checkpresence.0	2020-12-29 20:10:03.085	info	(4210) service DeviceConfig1-Reboot is supported
    fb-checkpresence.0	2020-12-29 20:10:03.064	info	(4210) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
    fb-checkpresence.0	2020-12-29 20:10:02.952	info	(4210) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
    fb-checkpresence.0	2020-12-29 20:10:02.938	info	(4210) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2020-12-29 20:10:02.919	info	(4210) service WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0	2020-12-29 20:10:02.903	info	(4210) service WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0	2020-12-29 20:10:02.886	info	(4210) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2020-12-29 20:10:02.869	info	(4210) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2020-12-29 20:10:02.853	info	(4210) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-12-29 20:10:02.834	info	(4210) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-12-29 20:10:02.820	info	(4210) service Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0	2020-12-29 20:10:02.802	info	(4210) service Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-12-29 20:10:02.787	debug	(4210) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
    fb-checkpresence.0	2020-12-29 20:10:02.756	debug	(4210) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"226","Major":"154","Minor":"7","Patch":"21","Buil
    fb-checkpresence.0	2020-12-29 20:10:02.498	debug	(4210) configuratuion mesh info: false
    fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration fb-devices true
    fb-checkpresence.0	2020-12-29 20:10:02.497	debug	(4210) configuration familymembers: [{"familymember":"Florian","macaddress":"A0:FB:C5:21:AC:7B","ipaddress":"192.168.155.86","useip":false,"comment":"iPhone12pro","enabled":true},{"familymember":"Silk
    fb-checkpresence.0	2020-12-29 20:10:02.496	debug	(4210) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
    fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration history: <influxdb.0>
    fb-checkpresence.0	2020-12-29 20:10:02.495	debug	(4210) configuration user: <ioBroker_tr064>
    fb-checkpresence.0	2020-12-29 20:10:02.493	info	(4210) start fb-checkpresence: ip-address: "192.168.155.1" - interval devices: 1 Min. - interval members: 10 s
    fb-checkpresence.0	2020-12-29 20:10:02.451	info	(4210) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
    fb-checkpresence.0	2020-12-29 20:09:56.390	info	(4147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0	2020-12-29 20:09:56.388	info	(4147) terminating
    fb-checkpresence.0	2020-12-29 20:09:56.386	info	(4147) cleaned everything up ...
    fb-checkpresence.0	2020-12-29 20:09:56.384	info	(4147) Got terminate signal TERMINATE_YOURSELF
    Flo1988
    #243
    @Flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
    @afuerhoff
    Sry.
    Gibt es hier schon eine Idee, warum die Geräte nicht richtig erkannt werden?
    In der FritzBox werden sie korrekt als aktiv und inaktiv angezeigt.
    Bis Version 1.0.4 hat auch alles prima funktioniert.
    Der Fehler hat sich mit der Änderung auf 1.1.0 eingeschlichen.
    • Pedder007P Pedder007
      Hallo großer Meister @afuerhoff :-)
      Top-Leistung, so wie das hier bei mir aktuell aussieht.
      1.1.1 installiert und keine 'Ghost'-Einträge mehr und durch die Abänderung der 0-7/8'en in Klarnamen nun auch sicherlich keine Vertauschungen mehr in VIS.
      (... jetzt kann ich meine schönen Blockly-Workarounds wieder abschalten, .... 😢 , ... aber gut was gelernt dabei ;-) )
      Das macht mir meine VIS-Netzview auch nochmals schlanker, da überflüssige Felder wie z. B. LAN1 und LANBridge (insges. 6 Einträge) nun raus können.
      1000-DANK !!! :-)
      Pedder007P Offline
      Pedder007P Offline
      Pedder007
      #244
      An der Stelle nochmal kurz ein Feedback nach nun gut einer Woche Laufzeit nach dem Update.
      Keinerlei veraltete oder verwechselte Einträge mehr, Adapter läuft super stabil und sogar die Familie ist nun in der Lage zu sehen wo sie ggf. gerade am WLAN "hängen" und ggf. via VIS einzelne (Fritz) NW-Devices neu zu booten, sofern diese überhaupt noch erreichbar sind - sonst hilft natürlich nur Stecker ziehen ;-)
      Danke nochmal, dass erleichtert einem wirklich das Leben und reduziert meine persönlichen Tickets zum Thema "Papa das WLAN geht wieder nicht...." 😆 drastisch! 👍 👍 👍
      Pedder
      All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
      Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
      Under construction: Smart-WoMo auf Raspi4
      • afuerhoffA afuerhoff
        Aktuelle Test Version 1.1.25
        Veröffentlichungsdatum 21.01.2023
        Github Link https://github.com/afuerhoff/ioBroker.fb-checkpresence
        npm im Latest verfügbar
        Hinweis: Adapter muss nach Installation von Github einmal neu gestartet werden.
        Änderungen:
        1.1.0
        • second interval for family members implemented
        • mesh info added
        • configuration validation added
        • switch on, off guest wlan
        • switch on, off internet access of devices
        • structural changes
        • code optimization
        • new datapoint absenceAll
        • neue Funktion Reboot
        1.1.1
        • Admin Konfiguration optimiert
        • Im Dateformat dürfen jetzt auch Bindestriche benutzt werden
        • https workaround implementiert (Konfiguration)-> es gab einen Fall, wo der Adapter nicht mit * https die Fritzbox abfragen konnte.
        • Connection check wurde optimiert
        • Dokumentation geändert
        • Mesh Handling optimiert -> es werden jetzt die Channels im Klartext angelegt. Dies verhindert, dass sich die Id's ändern.
        1.1.2
        • Gäste WLAN QR-Code ist als State implementiert und kann mit dem Basic Bool SVG Widget benutzt werden.
        • Die Presence states werden nur geändert, wenn es eine Änderung gibt.
        • Die Benutzerrechte des Users werden ausgelesen und mit den unterstützten Services der Fritzbox abgeglichen. Es muss der Service unterstützt werden und die Benutzerrechte zum Service passen. Ist dies nicht der Fall, werden nur die Funktionen ausgeführt, die dann möglich sind. Man kann also die Accessrights (FRITZ!Box Einstellungen, Smart Home, ...) in der Fritzbox reduzieren ohne Fehler zu bekommen. Im Log wird das beim Start einmal als Warnung ausgegeben.
        • Der Name des Devices kann jetzt ebenfalls genutzt werden. Hierfür muss das Familienmitglied genauso wie in der Fritzbox benannt werden. (Achtung: Wenn der Name nur in der Fritzbox manuell umbenannt wurde und nicht im Handy, dann wird bei eingeschalteter Mac-Verschleierung der Name des neu in der Fritzbox hinzugefügten Devices ein anderer sein)
        • active / inactive Device Zähler korrigiert
        • 10s Intervall Bug gefixed
        • Dokumentation angepasst
        • PresentGuests state eingebaut
        Änderungen 1.1.3:
        • Familiengruppen. Diese werden im Ordner familyMembers angelegt.
        • Kompatibilitätsmodus -> in Zukunft gibt es nur noch den presence state bei den Familienmitgliedern. Nicht mehr den auf der obersten Ebene am Familienmitglied.
        • In der Konfiguration habe ich noch ein paar Optionen aufgenommen
        • Die Dialogboxen habe ich optimiert
        • Ein Filter kann jetzt pro Familienmitglied eingeschaltet werden. Ist ein Familienmitglied true wird sofort der Status gesetzt. Bei false wird nach der Filterzeit nochmal auf den Wert geschaut und nur dann der Status gesetzt falls der Status ebenfalls false ist.
        • Für das Passwort Handling nutze ich jetzt die neue ioBroker Funktionalität
        • und diverse Änderungen unter der Haube
        ich habe eine neue Testversion auf Github hochgeladen. Bitte testet diese und gebt hier Rückmeldung über Probleme mit der neuen Version.
        Wichtigste Neuerungen sind das Ein- und Ausschalten des Gäste-WLAN. Das deaktivieren des Internetzugriffs von Geräten und ein zusätzliches Interval für Familienmitglieder.
        Die Eingaben auf der Konfigurationsseite werden jetzt überprüft und ggfs. das Speichern deakiviert. Im Bereich der fb-devices werden jetzt zusätzliche Mesh-Informationen angelegt, falls dies in der Konfiguration aktiviert wurde.
        Viel Spaß beim Testen.
        Gäste-WLAN ein-, ausschalten -> Datenpunkt wlan
        Internetzugriff ein-, ausschalten -> fb-devices Datenpunkt disabled = true (Internet aus)
        #245
        @afuerhoff hab noch was entdeckt, was Du vielleicht gerne nachrüsten kannst... 🙂
        Einen DONATE 💰 Button in der Adapterkonfig, damits auch jeder sieht..
          Änderungen:
          1.1.0
          • mesh info added
          • code optimization
          1.1.1
          1.1.2
          Änderungen 1.1.3:
          Dominik F.D Offline
          Dominik F.D Offline
          Dominik F.
          #246
          @afuerhoff
          Nabend,
          ich nutze deinen Adapter in der Version 1.10 und der funktioniert auch sehr zuverlässig.
          Nun habe ich festgestellt, dass der Heatingcontrol Adapter ständig neu getriggert wird.
          Ich nutze dort einen Datenpunkt von deinem Adapter. Das Problem scheint zu sein, dass dein Adapter den Datenpunkt für Presence minütlich neu setzt auch wenn dieser sich nicht ändert.
          Gibt es eine Möglichkeit, oder ist es vielleicht schon in der neuen Version enthalten, dass die Datenpunkte nur bei Änderung neu gesetzt werden?
          • F Flo1988
            @afuerhoff
            Sry.
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #247
            Es sieht so aus, als ob die Routine für die Familienmitglieder gar nicht durchlaufen wird.
            Da müsste eigentlich eine Meldung im Log kommen.
            Kannst Du mal das Interval auf 11s setzen. Ich denke ich hab den Fehler gefunden.
            F 1 Antwort Letzte Antwort
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #248
              @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
              :-) Muss mich mal informieren wie hier die Abgabenlage so ist. Da möchte doch bestimmt das Finanzamt beteiligt werden.
              • Dominik F.D Dominik F.
                @afuerhoff
                Nabend,
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #249
                @Dominik-F sagte in Test Adapter fb-checkpresence v1.1.x:
                Bis jetzt ist das noch nicht vorgesehen. Für die presence Datenpunkte könnte ich das aber erstmal so einbauen. Die 1.1.1 ist ja noch nicht kpl. fertig.
                Dominik F.D 2 Antworten Letzte Antwort
                  #250
                  @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                  Wenn man dir Spendet, weniger.. :-) Ansonsten gibt da nur genaue Auskunft dein Steuerberater, kommt drauf an, was du alles so machst und Einkünfte hast.. :-)
                    Dominik F.D Offline
                    Dominik F.D Offline
                    Dominik F.
                    #251
                    @afuerhoff
                    Das wäre klasse, vielen lieben dank
                      Flo1988
                      #252
                      Funktioniert!
                      Habe den Intervall auf 11 Sekunden gestellt und die Geräte werden wieder zuverlässig erkannt.
                      Ich lasse es erstmal so, wenn es eine neue Version zum Testen gibt, bitte schreiben, dann kann ich schauen ob es auch bei mir mit 10 Sekunden wieder geht.
                      Verwunderlich, dass ich der einzige bin, bei dem der Fehler auftritt... 😕
                        Dominik F.D Offline
                        Dominik F.D Offline
                        Dominik F.
                        #253
                        @afuerhoff
                        Ich hätte noch einen Wunsch für deinen Adapter.
                        Einen Datenpunkt, wo gezählt wird wie viele gerade Anwesend sind.
                          @afuerhoff
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #254
                          @Dominik-F
                          Kein Problem
                          • FenriswolfF Offline
                            FenriswolfF Offline
                            Fenriswolf
                            #255
                            Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
                            2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                            2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                            2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                            2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                            2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                            2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                            2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                            2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
                            2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
                            Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
                            2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
                            Was hat das DSL-Forum damit zu tun ??
                            bis denne
                            afuerhoffA 2 Antworten Letzte Antwort
                            • FenriswolfF Fenriswolf
                              bis denne
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #256
                              @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
                              dslforum-org
                              Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
                              Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
                              Das hat mit dem TR-064 Standard zu tun.
                              FenriswolfF 1 Antwort Letzte Antwort
                                dslforum-org
                                FenriswolfF Offline
                                FenriswolfF Offline
                                Fenriswolf
                                #257
                                dslforum-org
                                OK ;-) danke für die schnelle Antwort
                                  bis denne
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #258
                                  @Fenriswolf
                                  Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
                                    @Fenriswolf
                                    FenriswolfF Offline
                                    FenriswolfF Offline
                                    Fenriswolf
                                    #259
                                    @Fenriswolf
                                    Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
                                    Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
                                      @Fenriswolf
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #260
                                      Die Meshdaten werden nur wenn angehakt geladen und im gleichen Intervall aktulisiert wie die
                                      Fb-Devicedaten.
                                        @TG70
                                        Du brauchst die Fritzbox Version 7.20 damit es schneller geht.
                                        TG70T Offline
                                        TG70T Offline
                                        TG70
                                        Forum Testing
                                        #261
                                        @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                                        @TG70
                                        Also ich bin jetzt auf der Fritz! 7.23 ... Allerdings merke ich nichts davon, dass die Erkennung schneller geht.
                                        Den Zustand "Offline" wird mir erst nach ca. 10 Minuten angezeigt? Wie lange dauert es bei euch mit der Erkennung der Zustände "Online" und "Offline"
                                        ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
                                        • TG70T TG70
                                          @TG70
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          schrieb am zuletzt editiert von afuerhoff
                                          #262
                                          @TG70
                                          Wie ist denn die Intervalleinstellung für Familienmitglieder?
                                          EDIT: Bei mir dauert es mit der Version 7.21 (Intervall 10s) max. 20-30 s.
                                          TG70T 1 Antwort Letzte Antwort
