  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • FenriswolfF Offline
    FenriswolfF Offline
    Fenriswolf
    #255
    Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
    2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
    2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
    2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
    2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
    2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
    2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
    2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
    2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
    2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
    Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
    2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
    Was hat das DSL-Forum damit zu tun ??
    bis denne
    afuerhoffA 2 Antworten Letzte Antwort
    • FenriswolfF Fenriswolf
      bis denne
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      #256
      @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
      dslforum-org
      Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
      Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
      Das hat mit dem TR-064 Standard zu tun.
      FenriswolfF 1 Antwort Letzte Antwort
      • afuerhoffA afuerhoff
        dslforum-org
        FenriswolfF Offline
        FenriswolfF Offline
        Fenriswolf
        #257
        @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
        dslforum-org
        OK ;-) danke für die schnelle Antwort
          bis denne
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #258
          @Fenriswolf
          Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
            @Fenriswolf
            FenriswolfF Offline
            FenriswolfF Offline
            Fenriswolf
            #259
            @Fenriswolf
            Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
            Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
              @Fenriswolf
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #260
              Die Meshdaten werden nur wenn angehakt geladen und im gleichen Intervall aktulisiert wie die
              Fb-Devicedaten.
                @TG70
                Du brauchst die Fritzbox Version 7.20 damit es schneller geht.
                TG70T Offline
                TG70T Offline
                TG70
                Forum Testing
                #261
                @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                @TG70
                Also ich bin jetzt auf der Fritz! 7.23 ... Allerdings merke ich nichts davon, dass die Erkennung schneller geht.
                Den Zustand "Offline" wird mir erst nach ca. 10 Minuten angezeigt? Wie lange dauert es bei euch mit der Erkennung der Zustände "Online" und "Offline"
                ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
                • TG70T TG70
                  @TG70
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  schrieb am zuletzt editiert von afuerhoff
                  #262
                  @TG70
                  Wie ist denn die Intervalleinstellung für Familienmitglieder?
                  EDIT: Bei mir dauert es mit der Version 7.21 (Intervall 10s) max. 20-30 s.
                  TG70T 1 Antwort Letzte Antwort
                  • afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #263
                    ich habe die Version 1.1.2 auf Github zum Testen veröffentlicht. Die Änderungen sind im ersten Beitrag beschrieben. Bitte gebt Rückmeldung, ob alles funktioniert.
                    ? FenriswolfF 2 Antworten Letzte Antwort
                      #264
                      @afuerhoff laeuft... :-)
                        @TG70
                        TG70T Offline
                        TG70T Offline
                        TG70
                        Forum Testing
                        #265
                        @TG70
                        Steht bei mir auf 10s. Wie gesagt Offlie Zustand dauert bis 10 Minuten. Online geht schneller ca. <= 1 Min.
                          FenriswolfF Offline
                          FenriswolfF Offline
                          Fenriswolf
                          schrieb am zuletzt editiert von Fenriswolf
                          #266
                          habe jetzt folgende Eintragungen im Log:
                          2021-01-14 07:32:33.719 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                          2021-01-14 07:32:33.720 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:32:33.720 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                          2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                          2021-01-14 07:32:33.721 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                          2021-01-14 07:32:33.722 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                          2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                          2021-01-14 07:32:33.723 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                          2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                          2021-01-14 07:32:33.724 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:32:33.724 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                          2021-01-14 07:32:33.725 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                          2021-01-14 07:32:33.725 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.613 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                          2021-01-14 07:43:11.614 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.615 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                          2021-01-14 07:43:11.615 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                          2021-01-14 07:43:11.616 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                          2021-01-14 07:43:11.617 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.617 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                          2021-01-14 07:43:11.618 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                          2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                          2021-01-14 07:43:11.619 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.619 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                          2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                          2021-01-14 07:43:11.620 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                          2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                          alle 11 Minuten
                          bis denne
                          sigi234S afuerhoffA 2 Antworten Letzte Antwort
                            alle 11 Minuten
                            bis denne
                            sigi234S Online
                            sigi234S Online
                            #267
                            @fenriswolf
                            Kann ich bestätigen.
                            Es werden auch keine Devices angelegt.
                            Wobei ich die Beta vom JS controller Installiert: 3.2.6-0 habe.
                            Dadurch kommen auch massenweise diese Warn:
                            fb-checkpresence.0	2021-01-14 10:35:15.977	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.link" has no existing object, this might lead to an error in future versions
                            fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                            fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                            • TG70T TG70
                              @TG70
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #268
                              @tg70 said in Test Adapter fb-checkpresence v1.1.x:
                              Hallo, hast Du das schon mit der neuen Version getestet. In der 1.1.1 war noch ein Bug bei 10s Einstellung.
                                alle 11 Minuten
                                bis denne
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #269
                                @fenriswolf said in Test Adapter fb-checkpresence v1.1.x:
                                Da hat sich ein Fehler eingeschlichen. Korrigiere ich.
                                • sigi234S sigi234
                                  @fenriswolf
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #270
                                  @Fenriswolf @sigi234
                                  Ich habe ein Update hochgeladen. Bitte neu testen. Am Besten einmal die Objekte unter fb-devices löschen. Die sind falsch angelegt worden.
                                  sigi234S FenriswolfF 3 Antworten Letzte Antwort
                                    sigi234S Online
                                    sigi234S Online
                                    #271
                                    Schaut wieder gut aus. Bis auf die Warn wegen Beta JS Controller.
                                    • sigi234S sigi234
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #272
                                      @sigi234
                                      Welche Warnungen meinst du ? Die vom Post oben?
                                      Hast Du die Objekte einmal gelöscht?
                                        @sigi234
                                        sigi234S Online
                                        sigi234S Online
                                        #273
                                        Ja
                                        Log:
                                        2021-01-14 21:51:08.500 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.name" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.link" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.type" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.name" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.link" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.type" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.name" has no existing object, this might lead to an error in future versions
                                        2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.link" has no existing object, this might lead to an error in future versions
                                        • sigi234S sigi234
                                          Ja
                                          Log:
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #274
                                          @sigi234
                                          Kannst Du mal ein Bild der entsprechenden Objekte posten. CCU3 sollte z.B. als Device angelegt sein.
