  4. Test Adapter SmartControl 0.3.x-0.6.x Latest
    1.0k
    6.1k
testadaptersmartcontrolbewegungsmelderiftttlichterzeitplan
1.0k Beiträge 93 Kommentatoren 412.1k Aufrufe 88 Beobachtet
  • F FuXXz2
    Ich finde den Adapter echt toll und hatte ihn jetzt sehr lange Zeit nicht genutzt.
    Ein neuer Versuch führt wieder zu Tonnenweise Log Einträgen.
    Ist das normal oder mache ich immer noch was falsch?
    2022-10-21 09:46:46.780 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:46.740 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:39.441 warn State "smartcontrol.0.targetDevices.Schalter_enum-16" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:39.401 warn State "smartcontrol.0.targetDevices.Schalter_enum-16" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:36.747 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:36.706 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:26.747 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:26.706 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:16.784 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:16.743 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:06.770 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:46:06.731 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:45:56.744 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:45:56.705 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:45:46.795 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    smartcontrol.0
    2022-10-21 09:45:46.754 warn State "smartcontrol.0.targetDevices.Schalter_enum-19" has no existing object, this might lead to an error in future versions
    oelisonO Offline
    oelisonO Offline
    oelison
    #801
    @fuxxz2 Kannst Du mal prüfen, ob die oben genannten objekte wirklich nicht existieren? Diese Fehler sehe ich bei mir nicht.
    I like Rust. ioBroker-Adapter: matrix, mediola-gateway, support for reolink
    F M 2 Antworten Letzte Antwort
    • oelisonO oelison
      FuXXz2
      #802
      @oelison
      Das Problem ist, ich weiß gar nicht, was er mit _enum-19 etc. meint. Ich habe als Ziel zwei Aufzählungen(Funktionen) hinterlegt, sonst nichts. Darin enthalten sind jeweils Dimmer und in der anderen Schalter.
      Aber diese Angabe von _enum_XX keine Ahnung was das sein soll ?
      • oelisonO oelison
        Mike Hellracer
        #803
        @oelison
        Hallo zusammen, endlich kann ich auch mal wieder etwas zur Weiterentwicklung dieses genialen Adapters beitragen...
        Ursache ist die Verwendung von Aufzählungen unter Zielgeräte.
        Die Eingabe-Validierung prüft das Vorhandensein dieser Einträge für jedes einzelne Mitglied der Aufzählungen (*****_enum#)
        Da sie nicht existieren kommen dann die Einträge im Log.
        Da ich nicht weiß, ob sie für die Funktion wirklich benötigt werden habe ich sie einfach mal angelegt und dann sind die Meldungen weg.
        Leider nur bis zum nächsten speichern/Neustart des Adapter.
        ggf. könnte man sie einfach nach dem speichern des Adapter alle anlegen lassen, oder aus der Prüfung rausnehmen. Aber wie gesagt ich kann leider nicht mit Sicherheit sagen, ob sie für die Funktion nicht doch benötigt werden.
        Mein Vorschlag wäre der Einfachheit halber das Anlegen.
        oelisonO 1 Antwort Letzte Antwort
        • M Mike Hellracer
          @oelison
          oelisonO Offline
          oelisonO Offline
          oelison
          #804
          @mike-hellracer @FuXXz2 Okay, ich sehe mir das mal an mit den enums. Da lässt sich bestimmt was korrigieren. Danke für die Infos.
          • F FuXXz2
            @oelison
            crunchipC Offline
            crunchipC Offline
            #805
            @fuxxz2 vllt fehlt die enum zuweisung bei diesem schalter
            man kann aber auch die Prüfung deaktivieren
            F 1 Antwort Letzte Antwort
              FuXXz2
              #806
              @crunchip
              ich weiß wie gesagt gar nicht, wer sich hinter den Meldungen verbirgt.
              Wer soll das sein? Ich kenne keine 19 :)
              smartcontrol.0.targetDevices existiert aber auch gar nicht.
              oelisonO crunchipC 2 Antworten Letzte Antwort
              • F FuXXz2
                @crunchip
                oelisonO Offline
                oelisonO Offline
                oelison
                #807
                @fuxxz2 Dieser Ordner war für das Erste aufstarten des Adapters mit den Beispielen gefüllt. Kann sein, das die nicht richtig ausgeblendet werden, wenn die alle gelöscht sind. Ich werde das mal hier versuchen nach zu stellen. Aber das dauert etwas.
                • oelisonO oelison
                  FuXXz2
                  #808
                  @oelison Ich kann ja auch den Adapter mal komplett löschen und neu installieren, mal schauen wie dann die Datenpunkte aussehen
                  • F FuXXz2
                    oelisonO Offline
                    oelisonO Offline
                    oelison
                    #809
                    @fuxxz2 Wenn Dir nichts dabei verloren geht, wäre das super. Leider gibt es noch keine Import und export Funktion.
                    • apollon77A apollon77
                      Hallo liebe SmartControl Nutzer :-)
                      wie schon diskutiert wurde hat der Adapter-Entwickler gerade eine Auszeit und es kam der Wunsch auf das der Adapter von einem anderen Entwickler übernommen werden sollte. Es hätte sich auch jemand gefunden, ABER ich würde Euch gern mal eine Frage stellen:
                      So wie ich den Adapter verstehe ist er dafür gedacht einfache Steuerlogiken zu bauen ohne das man ein JavaScript Skript schreiben muss. Als der Adapter raus kam hatten wir dafür auch nichts, also alles valide.
                      Inzwischen hat der JavaScript Adapter aber die "Rules" bekommen und wenn ich mir so ansehe was der Adapter im Default kann, dann kommt bei mir (als Aussenstehender nicht-Adapter-Nutzer!) die Frage auf ob man nicht das gleiche fast genauso einfach über Rules bauen kann wie es hier über den Adapter geht.
                      Hinzu kommt das, wenn ich mir so einige Erweiterungswünsche anschaue, ich eher zu der Frage komme, wie komplex man denn den Adapter noch machen sollte oder ob nicht dann erst recht Rules - oder ggf sogar Blockly nicht der sinnvollere Weg ist.
                      Ich möchte niemandem den Adapter "madig machen" (bitte nicht falsch verstehen), sondern eher gemeinsam überlegen ob es in der Zwischenzeit nicht andere varianten gibt die das gleiche ebenso "einfach" erlauben.
                      Wir haben am Ende für Community-getriebene Adapter nur begrenzte Entwickler-Resourcen und diese würde ich gern zielgerichtet einsetzen :-)
                      Also hätte ich die Bitte an Euch Nutzer dieses Adapters. Schaut Euch mal Rules an. Diese kamen mit JavaScript 5 dazu (siehe https://forum.iobroker.net/topic/42725/test-javascript-adapter-5-0-7-rules?_=1664349589763). Überlegt mal ob das nicht equivalent ist und gebt Bitte Feedback.
                      Danke,
                      Ingo
                      Deanna4711D Offline
                      Deanna4711D Offline
                      Deanna4711
                      #810
                      @apollon77 said in Test Adapter SmartControl 0.3.x-0.6.x Latest:
                      Hi!
                      Ich glaube, die "Rules" Möglichkeit ist einfach nicht bekannt genug. Wenn ich nach Lösungen für meine Probleme suche, finde ich eigentlich nur Blockly oder Javascript Lösungsansätze. Und die sind für Nicht-Informatiker nicht immer ganz einfach nachzuvollziehen. Von daher war der SmartControl Adapter eine gute Möglichkeit für JS-Noobs wie mich.
                      Mir ist noch kein einziger Beitrag (bei meinen Suchen auch auf YT) mit Rules als Lösungsansatz untergekommen. Selbst wenn ich ganz gezielt nach "Rules iobroker" suche, kommen nur Blockly Ergebniss.
                      Es war mir schlicht unbekannt. Und wie ich in einigen Threads jetzt bei Suchen hier im Forum gesehen habe, bin ich damit nicht völlig alleine.
                      Also wäre meine Antwort auf Deine Frage: Fehlendes Marketing! 😉
                      • F Offline
                        FuXXz2
                        #811
                        Dann bau mir doch mal mit Rules einen funktionierenden, vernünftigen Bewegungsmelder, der die Helligkeit bei eingeschalteten Licht berüchsichtigt.
                        Allein dafür nutze ich schon gerne Smart Control.
                        @oelison
                        Habe den Adapter neu installiert, aber Fehler kommt immer noch. Er hat aber jetzt zumindest den ORdner target devices
                        • F FuXXz2
                          @oelison
                          HomoranH Offline
                          HomoranH Offline
                          #812
                          @fuxxz2 sagte in Test Adapter SmartControl 0.3.x-0.6.x Latest:
                          dafür war Rules nie gedacht. Nur für ganz einfache wenn - dann Regeln.
                          so etwas geht mit dem 2.Level = Blockly
                          • Deanna4711D Deanna4711
                            Hi!
                            crunchipC Offline
                            crunchipC Offline
                            #813
                            @deanna4711 aber es gibt z.b.
                            Deanna4711D 1 Antwort Letzte Antwort
                              Deanna4711D Offline
                              Deanna4711D Offline
                              Deanna4711
                              schrieb am zuletzt editiert von Deanna4711
                              #814
                              @crunchip
                              Das ist richtig. Aber sonst? Ich meine ja nur, weil Apollon die Frage gestellt hat, warum Rules so wenig genutzt wird. Es gibt keine guten Beispiele, Anleitungen und es wird im Netz auf den gängigen DIY SmartHome Seiten und YT Channels quasi nicht erwähnt. 🤷
                              • F FuXXz2
                                @crunchip
                                crunchipC Offline
                                crunchipC Offline
                                #815
                                na eines deiner Schalter/Lampen (Zielgeräte)
                                möglicherweise hast du vllt auch einen verwaisten Eintrag in deinen Enums
                                  FuXXz2
                                  #816
                                  @crunchip Ja, aber welches? Er haut ja zig Nummern raus, aber wie soll ich prüfen, wenn ich nicht weiß wer das ist?
                                  Zudem nutze ich die Aufzählungen im Jarvis, VIS, iQontrol, Blockly, Alexa. Die Geräte sind alle nutzbar. Nur Smart Control meckert
                                  • F FuXXz2
                                    crunchipC Offline
                                    crunchipC Offline
                                    #817
                                    @fuxxz2 ich weiss nur, bzw kann mich erinnern, wenn ein Gerät Raum und Funktion zugeordnet war und man löscht bzw ändert das Gerät, bleit es dort weiterhin drin stehen. Wenn du dann darüber in Smartcontrol daruf zugreifst, findet er die Geräte ja nicht mehr.
                                    Bei Vis, Jarvis..etc, greifst du ja nicht darüber zu, sondern auf einzelne Geräte.
                                    target devices sind ja die Zielgeräte die du anlegst, sieh Beispiel bei mir, allerdings habe ich per enums noch nie etwas eingerichtet im smartcontrol
                                    c12dc116-f6ce-4bfb-8db0-4847ffbdeafe-image.png eed1784a-78b9-4ed4-a626-d92d7345c0b3-image.png
                                      FuXXz2
                                      schrieb am zuletzt editiert von FuXXz2
                                      #818
                                      @crunchip
                                      Ich habe jetzt eine ganz neue Funktion erstellt und genau ein Gerät da rein gelegt.
                                      Smart Control sagt
                                      State "smartcontrol.0.targetDevices.Lichter_enum-1" has no existing object, this might lead to an error in future versions
                                      Aber er schaltet und es funktioniert, er müllt halt nur das Log mit Tonnen von dieser Meldung zu.
                                      • F FuXXz2
                                        @crunchip
                                        Smart Control sagt
                                        HomoranH Offline
                                        HomoranH Offline
                                        #819
                                        da kannst du nichts gegen machen, ist für den Entwickler wie die Datenpunkte anzulegen sind
                                        crunchipC oelisonO 2 Antworten Letzte Antwort
                                          crunchipC Offline
                                          crunchipC Offline
                                          #820
                                          @homoran sollte doch aber auch nur einmalig beim start kommen?
