  4. Test Adapter Javascript 4.6.x
javascriptblockly
145 Beiträge 24 Kommentatoren 23.7k Aufrufe 20 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    #61
    Ich habe mal wieder permissions Probleme.
    Wobei es jetzt so aussieht als wäre ein Verzeichnis nicht vorhanden.
    javascript.1	2020-05-19 19:10:37.926	error	(5917) Cannot install xml2js: 254
    javascript.1	2020-05-19 19:10:37.900	error	npm ERR! /home/iobroker/.npm/_logs/2020-05-19T17_10_37_886Z-debug.log
    javascript.1	2020-05-19 19:10:37.900	error	(5917) npm ERR! A complete log of this run can be found in:
    javascript.1	2020-05-19 19:10:37.898	error	(5917)
    javascript.1	2020-05-19 19:10:37.884	error	npm ERR! enoent
    javascript.1	2020-05-19 19:10:37.884	error	npm ERR! enoent This is related to npm not being able to find a file.
    javascript.1	2020-05-19 19:10:37.884	error	(5917) ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-core'
    javascript.1	2020-05-19 19:10:37.883	error	(5917) npm ERR! enoent
    javascript.1	2020-05-19 19:10:37.882	error	npm ERR! errno -2
    javascript.1	2020-05-19 19:10:37.882	error	(5917) path /opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-core
    javascript.1	2020-05-19 19:10:37.881	error	npm ERR!
    javascript.1	2020-05-19 19:10:37.881	error	npm ERR! syscall access
    javascript.1	2020-05-19 19:10:37.881	error	(5917) ERR! code ENOENT
    javascript.1	2020-05-19 19:10:37.879	error	(5917) npm
    javascript.1	2020-05-19 19:10:36.957	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-native
    javascript.1	2020-05-19 19:10:36.957	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/stealthy-require
    javascript.1	2020-05-19 19:10:36.957	error	(5917) WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-core
    javascript.1	2020-05-19 19:10:36.951	error	(5917) npm
    Wäre das mit
    iobroker rebuild
    lösbar?
    • ChaotC Chaot
      Wäre das mit
      iobroker rebuild
      lösbar?
      #62
      @Chaot Bist du da mit Docker oder sowas unterwegs?
        ChaotC Offline
        ChaotC Offline
        Chaot
        #63
        @Thomas-Braun So ähnlich. Ist ein Container unter Proxmox.
        Ich denke aber das ich das jetzt gelöst habe. Ich habe die Module nach dem Update zunächst aus JS entfernt und dann nochmal hinzugefügt.
        Dann gab es keine Fehlermeldung mehr und bieher scheint das auch so zu bleiben.
        Aber auch wie schon vorher. Selbst mit Rechten 777 auf dem gesamten Ordner (mit Unterordnern) hat er mir die Warnung mit der Permission ausgegeben.
        • ChaotC Chaot
          #64
          @Chaot Das sind halt so typische Phänomene mit Containern und VMs.
            ChaotC Offline
            ChaotC Offline
            Chaot
            #65
            @Thomas-Braun Ok, das das Module im Adapter sind habe ich ehrlich gesagt die ganze Zeit fleißig übersehen. Ich habe immer nach ganzen Adaptern gesucht.
            Vielleicht wurden die irgendwann nicht sauber installiert und sind jetzt eben aufgefallen. Die Installation ist ja auch schon ein paar Tage alt.
            • ChaotC Chaot
              #66
              @Chaot Ich meine im Zusammenhang mit Docker irgendwo gelesen zu haben, dass da Promises z. B. nicht funktionieren. Deswegen meine Frage danach.
              ChaotC AlCalzoneA 2 Antworten Letzte Antwort
                ChaotC Offline
                ChaotC Offline
                Chaot
                schrieb am zuletzt editiert von Chaot
                #67
                @Thomas-Braun Guter Tip.
                Muss ich mal schauen warum ich die damals hinzugefügt habe. Das war irgendein Script das damit arbeitet.
                Bisher funktioniert alles, so kann es also sein das das Script gar nicht mehr aktiv ist und die Promises gar nicht mehr gebraucht werden. - Na ja, am Donnerstag ist eh alles noch zu......
                Edit: Gefunden: https://forum.iobroker.net/topic/28447/tv-programm-mini-anzeige-html-tabelle/30?page=2
                Mal überlegen was ich da mache. Wenn es jetzt funktioniert erstmal lassen, aber wird langfristig vermutlich in die Hose gehen.
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #68
                  @Thomas-Braun sagte in Test Adapter Javascript 4.6.x:
                  Das würde mich doch schwer wundern...
                  • ChaotC Chaot
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #69
                    @Chaot Was kommt bei
                    ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules
                    als Ausgabe?
                    • AlCalzoneA AlCalzone
                      als Ausgabe?
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #70
                      @AlCalzone Schwer zu sagen. Das sind aktuell die beiden Module mit den richtigen Rechten aufgeführt. Aber das kann auch daran liegen das es ja aktuell funktioniert nachdem ich die im Adapter deaktiviert und neu hinzugefügt habe.
                      Danach war der Spuk ja vorbei.
                      Ich werde das mal im Hinterkopf behalten und beim nächsten derartigen Fehler zuerst die Abfrage machen. Danke für den Tip.
                      • ChaotC Chaot
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        #71
                        @Chaot sagte in Test Adapter Javascript 4.6.x:
                        Schwer zu sagen
                        Wieso? Kopier doch einfach die Konsolenausgabe :)
                          Schwer zu sagen
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          #72
                          @AlCalzone Ach so! Ich meinte das anders.
                          In der Ausgabe sind alle fraglichen Module mit den richtigen Rechten aufgeführt. Wie das zum Fehlerzeitpunkt aussah kann ich nicht mehr nachvollziehen.
                          • ChaotC Chaot
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            schrieb am zuletzt editiert von AlCalzone
                            #73
                            @Chaot ah ok. Mir geht es auch um die Rechte des Ordners selbst
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              #74
                              • ChaotC Chaot
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #75
                                @Chaot joar, sieht jetzt eigentlich gut aus.
                                ChaotC 2 Antworten Letzte Antwort
                                  ChaotC Offline
                                  ChaotC Offline
                                  Chaot
                                  #76
                                  @AlCalzone Ja, das denke ich auch. Aber das ist ja leider schon nach der "Reparatur". Mein Log ist aktuell absolut fehlerfrei und ich kann den Fehler auch nicht mehr provozieren (außer ich lösche den Ordner). Von daher werde ich mal abwarten müssen ob das Problem nochmal auftaucht. Aber zumindest habe ich jetzt eine Idee wo ich suchen muss.
                                  • apollon77A Offline
                                    #77
                                    Hey, all, bitte checkt mal die 4.6.14 ob da jetzt alles soweit passt.
                                    Nur falls die eine Änderung verwirrend klingt: "Namen von Skripten mit punkten sind nicht mehr erlaubt ... alle anderen State Namen und so gehen natürlich noch auch mit punkten. :-)"
                                    ANsonsten: Wie ist das jetzt genau mit Timeouts in Blockly wenn man von einer 4.5.1 kommt? Was muss man tun? Könnte mir das ein "betroffener" mal so aufschreiben das man es FAQ artig anderen Usern geben kann? ;-) Würde dann beim Stable-Release auch eine Info.Adapter Medung dazu machen.
                                    Danke!!
                                    Ingo
                                    ? paul53P 2 Antworten Letzte Antwort
                                    • apollon77A apollon77
                                      Danke!!
                                      Ingo
                                      #78
                                      @apollon77 Hi, also die 4.6.14 läuft hier soweit so gut.
                                      Fehler hatte ich bei blocklys mit timeout drin, hier war meist das stop-timeout verstellt, bzw n ganz falscher Name drin teilweise.
                                      Hier hilft nur, alle Scripte durch zu sehen und zu korrigieren.
                                        Danke!!
                                        Ingo
                                        #79
                                        @apollon77 sagte:
                                        In den News und im Changelog steht aber
                                        State names with dot are not allowed any more
                                          ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          #80
                                          @AlCalzone So, sind wir wieder soweit:
                                          javascript.1	2020-05-21 16:31:06.452	error	(17645) Cannot install open-fin-ts-js-client: 254
                                          javascript.1	2020-05-21 16:31:06.409	error	(17645) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-05-21T14_31_06_395Z-debug.log
                                          javascript.1	2020-05-21 16:31:06.407	error	(17645)
                                          javascript.1	2020-05-21 16:31:06.395	error	(17645) ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlbuilder npm ERR! errno -2 npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroke
                                          javascript.1	2020-05-21 16:31:06.387	error	(17645) npm ERR! code ENOENT npm ERR! syscall access npm
                                          javascript.1	2020-05-21 16:31:05.376	error	(17645) WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlbuilder npm WARN checkPermissions Missing write access to /opt/iobroker/node_module
                                          javascript.1	2020-05-21 16:31:05.373	error	(17645) npm
                                          AlCalzoneA E 2 Antworten Letzte Antwort
