  4. Test Adapter Javascript 4.6.x
    6.6k
javascriptblockly
145 Beiträge 24 Kommentatoren 24.2k Aufrufe 20 Beobachtet
    @paul53 Dein Modul core-js ist alt...
    Bei meinem Updater ist von dem Modul auch keine Rede:
    2020-05-19 13:14:08.964  - info: host.raspberrypi iobroker Update javascript from @4.6.11 to @4.6.13
    2020-05-19 13:14:10.496  - info: host.raspberrypi iobroker NPM version: 6.14.4
    2020-05-19 13:14:10.499  - info: host.raspberrypi iobroker npm install iobroker.javascript@4.6.13 --loglevel error --prefix "/opt/iobroker" (System call)
    2020-05-19 13:14:43.676  - info: host.raspberrypi iobroker node-aead-crypto not needed on this system, since all ciphers are natively supported
    2020-05-19 13:15:00.409  - info: host.raspberrypi iobroker Update "system.adapter.javascript.0"
    2020-05-19 13:15:00.479  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
    2020-05-19 13:15:00.489  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
    2020-05-19 13:15:00.501  - info: javascript.0 (949) Got terminate signal TERMINATE_YOURSELF
    2020-05-19 13:15:00.539  - info: javascript.0 (949) terminating
    2020-05-19 13:15:00.542  - info: javascript.0 (949) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2020-05-19 13:15:01.282  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-05-19 13:15:03.531  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 16021
    2020-05-19 13:15:04.949  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2020-05-19 13:15:10.951  - info: javascript.0 (16021) starting. Version 4.6.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.16.3, js-controller: 3.1.4
    2020-05-19 13:15:11.069  - info: javascript.0 (16021) requesting all states
    2020-05-19 13:15:11.072  - info: javascript.0 (16021) requesting all objects
    2020-05-19 13:15:11.561  - info: javascript.0 (16021) received all states
    2020-05-19 13:15:12.622  - info: javascript.0 (16021) received all objects
    2020-05-19 13:15:13.207  - info: host.raspberrypi iobroker upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/php/php.js vs/basic-languages/php/php.js application/javascript
    2020-05-19 13:15:13.815  - info: host.raspberrypi iobroker upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
    2020-05-19 13:15:15.987  - info: host.raspberrypi iobroker upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/bat/bat.js vs/basic-languages/bat/bat.js application/javascript
    2020-05-19 13:15:18.512  - info: host.raspberrypi iobroker upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/2.59922a79.chunk.js.LICENSE.txt static/js/2.59922a79.chunk.js.LICENSE.txt text/plain
    2020-05-19 13:15:19.788  - info: host.raspberrypi iobroker upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
    2020-05-19 13:15:20.816  - info: host.raspberrypi iobroker upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
    2020-05-19 13:15:23.082  - info: host.raspberrypi iobroker upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
    2020-05-19 13:15:55.258  - info: info.0 (926) Popup news was read...
    2020-05-19 13:16:02.447  - info: host.raspberrypi iobroker upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
    2020-05-19 13:16:03.590  - info: host.raspberrypi iobroker upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
    2020-05-19 13:16:03.654  - info: host.raspberrypi iobroker upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
    2020-05-19 13:16:03.731  - info: host.raspberrypi iobroker upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
    2020-05-19 13:16:03.798  - info: host.raspberrypi iobroker upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
    2020-05-19 13:16:03.855  - info: host.raspberrypi iobroker upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
    2020-05-19 13:16:03.913  - info: host.raspberrypi iobroker upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
    2020-05-19 13:16:03.975  - info: host.raspberrypi iobroker upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
    2020-05-19 13:16:04.036  - info: host.raspberrypi iobroker upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
    2020-05-19 13:16:04.099  - info: host.raspberrypi iobroker upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
    2020-05-19 13:16:04.161  - info: host.raspberrypi iobroker upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
    2020-05-19 13:16:04.268  - info: host.raspberrypi iobroker upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
    2020-05-19 13:16:04.329  - info: host.raspberrypi iobroker upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
    2020-05-19 13:16:04.391  - info: host.raspberrypi iobroker upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    2020-05-19 13:16:04.470  - info: host.raspberrypi iobroker upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
    2020-05-19 13:16:04.617  - info: host.raspberrypi iobroker upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
    2020-05-19 13:16:04.688  - info: host.raspberrypi iobroker upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
    2020-05-19 13:16:04.781  - info: host.raspberrypi iobroker upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
    2020-05-19 13:16:04.897  - info: host.raspberrypi iobroker upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
    2020-05-19 13:16:05.033  - info: host.raspberrypi iobroker upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    2020-05-19 13:16:05.101  - info: host.raspberrypi iobroker upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
    2020-05-19 13:16:05.165  - info: host.raspberrypi iobroker upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    2020-05-19 13:16:05.231  - info: host.raspberrypi iobroker Adapter "javascript" updated
    2020-05-19 13:16:06.255  - info: host.raspberrypi iobroker exit 0
    @Thomas-Braun
    Sorry, habe mich falsch ausgedrückt: Die Fehlermeldung erscheint erst beim ersten Start der Instanz javascript.1 nach dem Update. Bei einem Neustart erscheint sie nicht mehr.
    @Thomas-Braun sagte in Test Adapter Javascript 4.6.x:
    Verwende js-controller 3.0.20. Ist der schon zu alt ?
      @Thomas-Braun
      @paul53 Ich vermute, das ist ein Kernmodul von node selber. Du fährst da mit node 8 rum, oder?
        @Thomas-Braun sagte:
        Nein, Node.js 12.16.3.
        • AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          core-js wird von vielen verschiedenen npm-Modulen verwendet, ist aber kein Kernmodul:
          Modular standard library for JavaScript. Includes polyfills for ECMAScript up to 2020
          Klingt für mich als kommt die beim Installieren der Module, die du in den Adaptereinstellungen eingetragen hast.
          Welches findest du heraus mit
          cd /opt/iobroker/node_modules/iobroker.javascript
          npm ls core-js
          Aber ist das wirklich ein Fehler oder wird es nur als "error" geloggt? Klingt für mich nach einer npm deprecation warning.
            In meinem npm tree ist das Modul gar nicht drin:
            pi@raspberrypi:/opt/iobroker $ npm list --depth 5 | grep core-js
            npm ERR! missing: @types/node@10.17.21, required by iobroker.javascript@4.6.13
            npm ERR! missing: @types/node@10.17.21, required by @types/iobroker@3.0.10
            Nur eine andere missing dependency
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @Thomas-Braun Wie ich schon schrieb, ist vermutlich Teil eines der Module, die auf Pauls Wunsch vom JS-Adapter nachinstalliert werden. Oder depth 5 ist zu wenig, such doch mal mit npm ls core-js direkt danach.
              • AlCalzoneA AlCalzone
                @AlCalzone sagte:
                Danke. Ja, es ist ein zusätzlich installiertes NPM-Modul, das den Fehler-Log verursachte.
                iobroker.inst@2.0.3 /opt/iobroker
                └─┬ iobroker.javascript@4.6.13
                  └─┬ @throneless/libsignal-service@1.1.1
                    └─┬ libphonenumber-js@0.3.15
                      └─┬ babel-runtime@6.26.0
                        └── core-js@2.6.11
                Das Modul hatte ich mal zum Test installiert und offenbar vergessen, es wieder zu entfernen (jetzt schon).
                • ChaotC Offline
                  ChaotC Offline
                  Chaot
                  Ich habe mal wieder permissions Probleme.
                  Wobei es jetzt so aussieht als wäre ein Verzeichnis nicht vorhanden.
                  javascript.1	2020-05-19 19:10:37.926	error	(5917) Cannot install xml2js: 254
                  javascript.1	2020-05-19 19:10:37.900	error	npm ERR! /home/iobroker/.npm/_logs/2020-05-19T17_10_37_886Z-debug.log
                  javascript.1	2020-05-19 19:10:37.900	error	(5917) npm ERR! A complete log of this run can be found in:
                  javascript.1	2020-05-19 19:10:37.898	error	(5917)
                  javascript.1	2020-05-19 19:10:37.884	error	npm ERR! enoent
                  javascript.1	2020-05-19 19:10:37.884	error	npm ERR! enoent This is related to npm not being able to find a file.
                  javascript.1	2020-05-19 19:10:37.884	error	(5917) ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-core'
                  javascript.1	2020-05-19 19:10:37.883	error	(5917) npm ERR! enoent
                  javascript.1	2020-05-19 19:10:37.882	error	npm ERR! errno -2
                  javascript.1	2020-05-19 19:10:37.882	error	(5917) path /opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-core
                  javascript.1	2020-05-19 19:10:37.881	error	npm ERR!
                  javascript.1	2020-05-19 19:10:37.881	error	npm ERR! syscall access
                  javascript.1	2020-05-19 19:10:37.881	error	(5917) ERR! code ENOENT
                  javascript.1	2020-05-19 19:10:37.879	error	(5917) npm
                  javascript.1	2020-05-19 19:10:36.957	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-native
                  javascript.1	2020-05-19 19:10:36.957	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/stealthy-require
                  javascript.1	2020-05-19 19:10:36.957	error	(5917) WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/request-promise-core
                  javascript.1	2020-05-19 19:10:36.951	error	(5917) npm
                  Wäre das mit
                  iobroker rebuild
                  lösbar?
                  • ChaotC Chaot
                    Wäre das mit
                    iobroker rebuild
                    lösbar?
                    @Chaot Bist du da mit Docker oder sowas unterwegs?
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      @Thomas-Braun So ähnlich. Ist ein Container unter Proxmox.
                      Ich denke aber das ich das jetzt gelöst habe. Ich habe die Module nach dem Update zunächst aus JS entfernt und dann nochmal hinzugefügt.
                      Dann gab es keine Fehlermeldung mehr und bieher scheint das auch so zu bleiben.
                      Aber auch wie schon vorher. Selbst mit Rechten 777 auf dem gesamten Ordner (mit Unterordnern) hat er mir die Warnung mit der Permission ausgegeben.
                      • ChaotC Chaot
                        @Chaot Das sind halt so typische Phänomene mit Containern und VMs.
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          @Thomas-Braun Ok, das das Module im Adapter sind habe ich ehrlich gesagt die ganze Zeit fleißig übersehen. Ich habe immer nach ganzen Adaptern gesucht.
                          Vielleicht wurden die irgendwann nicht sauber installiert und sind jetzt eben aufgefallen. Die Installation ist ja auch schon ein paar Tage alt.
                          • ChaotC Chaot
                            #66
                            @Chaot Ich meine im Zusammenhang mit Docker irgendwo gelesen zu haben, dass da Promises z. B. nicht funktionieren. Deswegen meine Frage danach.
                            ChaotC AlCalzoneA 2 Antworten Letzte Antwort
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              schrieb am zuletzt editiert von Chaot
                              #67
                              @Thomas-Braun Guter Tip.
                              Muss ich mal schauen warum ich die damals hinzugefügt habe. Das war irgendein Script das damit arbeitet.
                              Bisher funktioniert alles, so kann es also sein das das Script gar nicht mehr aktiv ist und die Promises gar nicht mehr gebraucht werden. - Na ja, am Donnerstag ist eh alles noch zu......
                              Edit: Gefunden: https://forum.iobroker.net/topic/28447/tv-programm-mini-anzeige-html-tabelle/30?page=2
                              Mal überlegen was ich da mache. Wenn es jetzt funktioniert erstmal lassen, aber wird langfristig vermutlich in die Hose gehen.
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #68
                                Das würde mich doch schwer wundern...
                                • ChaotC Chaot
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #69
                                  @Chaot Was kommt bei
                                  ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules
                                  als Ausgabe?
                                    als Ausgabe?
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #70
                                    @AlCalzone Schwer zu sagen. Das sind aktuell die beiden Module mit den richtigen Rechten aufgeführt. Aber das kann auch daran liegen das es ja aktuell funktioniert nachdem ich die im Adapter deaktiviert und neu hinzugefügt habe.
                                    Danach war der Spuk ja vorbei.
                                    Ich werde das mal im Hinterkopf behalten und beim nächsten derartigen Fehler zuerst die Abfrage machen. Danke für den Tip.
                                    • ChaotC Chaot
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #71
                                      @Chaot sagte in Test Adapter Javascript 4.6.x:
                                      Schwer zu sagen
                                      Wieso? Kopier doch einfach die Konsolenausgabe :)
                                        Schwer zu sagen
                                        ChaotC Offline
                                        ChaotC Offline
                                        Chaot
                                        #72
                                        @AlCalzone Ach so! Ich meinte das anders.
                                        In der Ausgabe sind alle fraglichen Module mit den richtigen Rechten aufgeführt. Wie das zum Fehlerzeitpunkt aussah kann ich nicht mehr nachvollziehen.
                                        • ChaotC Chaot
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #73
                                          @Chaot ah ok. Mir geht es auch um die Rechte des Ordners selbst
