  5. Sonoff Geräte als HTML Tabelle - Vis
    6.6k
javascriptmonitoringtemplate
632 Beiträge 34 Kommentatoren 202.5k Aufrufe 39 Beobachtet
  • liv-in-skyL liv-in-sky
    @Latzi geändert - im ersten post
    ChaotC Offline
    ChaotC Offline
    Chaot
    #221
    @liv-in-sky
    Ich war ein paar Tage nicht bei der Sache.
    Was läuft hier verkehrt:
    javascript.0	2020-01-30 22:28:40.025	warn	(530) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-30 22:28:40.025	warn	(530) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-30 22:28:40.025	warn	(530) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-30 22:28:40.025	warn	(530) at ontimeout (timers.js:436:11)
    javascript.0	2020-01-30 22:28:40.024	warn	(530) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-30 22:28:40.024	warn	(530) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-30 22:28:40.024	warn	(530) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-30 22:28:40.024	warn	(530) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-01-30 22:28:40.024	warn	(530) at Object.<anonymous> (script.js.Systeminfo.Tasmota2:1513:3)
    javascript.0	2020-01-30 22:28:40.024	warn	(530) at writeHTML (script.js.Systeminfo.Tasmota2:445:31)
    javascript.0	2020-01-30 22:28:40.023	warn	(530) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-01-30 22:28:40.023	warn	(530) at script.js.Systeminfo.Tasmota2:460:23
    javascript.0	2020-01-30 22:28:40.022	warn	(530) getState "sonoff.0.Sender.POWER" not found (3) states[id]=null
    javascript.0	2020-01-30 22:28:32.530	warn	(530) at script.js.Systeminfo.Tasmota2:1516:3
    javascript.0	2020-01-30 22:28:32.529	warn	(530) at writeHTML (script.js.Systeminfo.Tasmota2:445:31)
    javascript.0	2020-01-30 22:28:32.529	warn	(530) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-01-30 22:28:32.529	warn	(530) at script.js.Systeminfo.Tasmota2:460:23
    javascript.0	2020-01-30 22:28:32.528	warn	(530) getState "sonoff.0.Sender.POWER" not found (3) states[id]=null
    • ChaotC Chaot
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      #222
      @Chaot sieht nach fehlenden datenpunkt aus
      probieren wir mal das:
      • script stoppen
      • sonoff instanzen stoppen
      • alle sonoff dp löschen - den ganzen sonoff.x ordner oder aber mindestens sonoff.0.Sender
      • sonoff instanz wieder starten
      • scipt wieder starten
      • chucky666C Online
        chucky666C Online
        chucky666
        #223
        Hallo
        danke für das script, leider bekomme ich es nicht ans laufen
        javascript.0	2020-01-31 04:25:07.237	error	(937) at Script.runInContext (vm.js:133:20)
        javascript.0	2020-01-31 04:25:07.237	error	(937) at script.js.Sonoffliste:1407:2
        javascript.0	2020-01-31 04:25:07.237	error	(937) at writeHTML (script.js.Sonoffliste:521:30)
        javascript.0	2020-01-31 04:25:07.237	error	(937) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
        javascript.0	2020-01-31 04:25:07.237	error	(937) at script.js.Sonoffliste:534:67
        javascript.0	2020-01-31 04:25:07.236	error	(937) TypeError: Cannot read property 'toString' of null
        javascript.0	2020-01-31 04:25:07.236	error	(937) ^
        javascript.0	2020-01-31 04:25:07.236	error	(937) val3=getState(id.replace("INFO.Module","Wifi_RSSI")).val.toString()+" %";
        javascript.0	2020-01-31 04:25:07.236	error	(937) script.js.Sonoffliste: script.js.Sonoffliste:534
          • script stoppen
          ChaotC Offline
          ChaotC Offline
          Chaot
          #224
          @liv-in-sky Danke für den Tip.
          Ich habe den Fehler gefunden.
          Das Modul "Sender" ist generic und hat gar keinen Datenpunkt Power sondern nur Power1 und Power2.
          Ich muss mir mal überlegen wie ich das löse, da ich ja noch andere Generic habe bei denen das anders ist.
          • ChaotC Chaot
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            #225
            @Chaot ich habe mir schon gedacht, das generic irgendwann ärger machen wird - ich nehme das power wieder raus - bzw werde bei generic eine existiert-power abfrage reinbasteln
            • chucky666C chucky666
              Hallo
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              #226
              @chucky666 schau doch mal nach, welcher deiner sonoff's keinen "Wifi_RSSI" datenpunkt hat
              • ChaotC Chaot
                liv-in-skyL Offline
                liv-in-skyL Offline
                liv-in-sky
                #227
                @Chaot teste mal das script im ersten post - ich frage da POWER ab bevor ich es ausgebe
                  ChaotC Offline
                  ChaotC Offline
                  Chaot
                  #228
                  @liv-in-sky Jup! Schaut besser aus. Keine Fehlermeldung mehr.
                    ChaotC Offline
                    ChaotC Offline
                    Chaot
                    #229
                    @liv-in-sky
                    Ähem, ich will jetzt nicht nörgeln, aber macht es viel Arbeit die tollen Zeilenfarben auch hier umzusetzen wie du das in der Tabelle für Batteriezustaände gemacht hast.
                    Übrigens: Saugeile Sache was duhier machst! Ganz herzlichen Dank dafür!
                    • ChaotC Chaot
                      @liv-in-sky
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #230
                      @Chaot bin gerade dabei meine templates alle umzustellen - dauert ein wenig - werde es aber dann aber auch da rein tun
                      bei 8 spalten verliert man leicht den überblick, wie das html aufzubauen ist :-(
                        MyMeyer
                        #231
                        Hallo, ich habe gerade das Problem das ein Sonoff gefunden wird und einer nicht, obwohl alle im Netz sind sich auch schalten lassen. Und auch unter Objekte ist alles normal.
                        MyMeyer
                        >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                        >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                        • M MyMeyer
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #232
                          @MyMeyer rot wird er , wenn das auf false steht
                            MyMeyer
                            #233
                            Er steht ja auf True !
                            MyMeyer
                              MyMeyer
                              #234
                              Läuft jetzt...habe mal alle Objekte gelöscht und neue eingelesen. Jetzt sind ist alles da.
                              Danke.
                              MyMeyer
                              • M MyMeyer
                                crunchipC Offline
                                crunchipC Offline
                                #235
                                @MyMeyer achte mal auf die IP!
                                dein .92 steht auf true, im script hast du .25
                                  MyMeyer
                                  #236
                                  @crunchip sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                                  .92 ist von @liv-in-sky nicht von mir :-) Aber jetzt läuft es ja wieder Danke für die Hilfe...
                                  MyMeyer
                                  • M MyMeyer
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #237
                                    @MyMeyer du weißt, du kannst die überschriften ohne geräte wegbekommen, wenn du sie deaktivierst im setting ?
                                      MyMeyer
                                      #238
                                      @liv-in-sky Jo...👍 bekannt.
                                      MyMeyer
                                      • ChaotC Chaot
                                        @liv-in-sky
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        liv-in-sky
                                        #239
                                        @Chaot im ersten post ist jetzt ein script mit verschiedenen farben pro zeile
                                          ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          #240
                                          @liv-in-sky
                                          Danke für deine Mühe.
                                          Aber irgendwie scheint das nicht zu klappen.
                                          Das ist doch in dem Block hier oder:
                                          //FELDER UND RAHMEN
                                          const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
                                          const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                          const htmlFarbTableColorGradient1="#1c1c1c";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                          const htmlFarbTableColorGradient2="#1c1c1c";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                          const htmlFarbTableBorderColor="gray";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                          let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                          Farbverlauf (Zeile 5 und 6 ) kann ich einstellen, aber unterschideliche Zeilen (Zeile 3 und 4) bekome ich nicht zustande
