  4. Test Adapter onvif-alt v0.1.x
    5.6k
onvif
271 Beiträge 33 Kommentatoren 50.8k Aufrufe 37 Beobachtet
  • SegwayS Segway
    @Jey-Cee
    Moin ich hänge mich hier auch rein.
    Hab die 0.0.2 Version installiert.
    Habe eine Scricam SP007 die nur einen rtsp stream liefert ohne benutzername und passwort.
    Leider findet der Adapter nichts:
    onvif.0	2020-01-01 12:18:12.756	debug	(5942) stateChange onvif.0.discoveryRunning {"val":false,"ack":true,"ts":1577877492727,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1577877486238}
    onvif.0	2020-01-01 12:18:12.754	debug	(5942) startCameras: []
    onvif.0	2020-01-01 12:18:12.716	debug	(5942) startCameras
    onvif.0	2020-01-01 12:18:12.679	info	(5942) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.onvif, node: v12.14.0
    onvif.0	2020-01-01 12:18:08.143	debug	(2292) system.adapter.admin.0: logging true
    onvif.0	2020-01-01 12:18:08.083	info	(2292) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    onvif.0	2020-01-01 12:18:08.082	info	(2292) terminating
    onvif.0	2020-01-01 12:18:08.081	debug	(2292) cleaned everything up...
    onvif.0	2020-01-01 12:18:08.078	info	(2292) Got terminate signal TERMINATE_YOURSELF
    onvif.0	2020-01-01 12:18:06.248	debug	(2292) startCameras: []
    onvif.0	2020-01-01 12:18:06.242	debug	(2292) stateChange onvif.0.discoveryRunning {"val":false,"ack":true,"ts":1577877486238,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1577877486238}
    onvif.0	2020-01-01 12:18:06.236	debug	(2292) sendTo "discovery" to system.adapter.admin.0 from system.adapter.onvif.0
    onvif.0	2020-01-01 12:18:06.235	debug	(2292) Discovery finished
    onvif.0	2020-01-01 12:18:06.233	debug	(2292) startCameras
    onvif.0	2020-01-01 12:17:56.209	debug	(2292) stateChange onvif.0.discoveryRunning {"val":true,"ack":true,"ts":1577877476192,"q":0,"from":"system.adapter.onvif.0","user":"system.user.admin","lc":1577877476192}
    onvif.0	2020-01-01 12:17:56.190	debug	(2292) a.b.c.d 554
    onvif.0	2020-01-01 12:17:56.188	debug	(2292) Received "discovery" event
    onvif.0	2020-01-01 12:17:42.237	debug	(2292) system.adapter.admin.0: logging false
    onvif.0	2020-01-01 12:17:35.228	debug	(2292) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.onvif.0
    über vlc kommt der stream per
    rtsp://a.b.c.d:554/onvif1
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #41
    @Segway Sorry die 0.0.2 ist nicht von mir, das ist eine von 2 Versionen die nicht mehr Weiterentwickelt wird und von meiner ersetzt werden soll. Die Version 0.1.0 ist eine Komplette neu Entwicklung.
    Deshalb kann ich dir da nicht weiterhelfen.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    SegwayS 2 Antworten Letzte Antwort
    • Jey CeeJ Jey Cee
      SegwayS Offline
      SegwayS Offline
      Segway
      #42
      @Jey-Cee
      Oh, okay, verstanden. installiere das mal über die Katze / Github Link ! Melde mich :-)
      Gruß Dirk
      • Jey CeeJ Jey Cee
        SegwayS Offline
        SegwayS Offline
        Segway
        #43
        @Jey-Cee
        okay, hat meine Kamera gefunden - und was nun ?
        Gruß Dirk
        • SegwayS Segway
          @Jey-Cee
          Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          #44
          @Segway Benutzername und passwort der Kamera eingeben, Speicherund Schließen, dann holt er sich alles an Infos von der Cam was er kriegen kann. Da sollte auch der rtsp Stream Link dabei sein.
          • Jey CeeJ Jey Cee
            SegwayS Offline
            SegwayS Offline
            Segway
            #45
            @Jey-Cee
            Jo habe ich ja, aber die Cam hat keinen Benutzernamen und Passwort. Brauche ich in dem VLC Link wo es geht auch nicht eingeben.
            Als Objekte werden nur folgende angelegt:
            Gruß Dirk
            • KnallochseK Knallochse
              @Jey-Cee
              @Knallochse kannst du mir mal die Objekte für den Drucker Exportieren? Das Objekt vom Drucker Anklicken und dann oben bei den Buttons den ganz rechten Pfeil Klicken.
              Das dann hier posten.
              Klar, kein Problem
                "onvif.0._003.system.reboot": {
                  "type": "state",
                  "common": {
                    "name": "Reboot ",
                    "type": "boolean",
                    "role": "button",
                    "read": false,
                    "write": true
                  "native": {},
                  "from": "system.adapter.onvif.0",
                  "user": "system.user.admin",
                  "ts": 1577873649242,
                  "_id": "onvif.0._003.system.reboot",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                    "owner": "system.user.admin",
                "onvif.0._003.logs.getlogs": {
                  "type": "state",
                  "common": {
                    "name": "Get Logs from camera",
                    "type": "boolean",
                    "role": "button",
                    "read": false,
                    "write": true
                  "native": {},
                  "_id": "onvif.0._003.logs.getlogs",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "onvif.0._003.logs.systemlog": {
                  "type": "state",
                  "common": {
                    "name": "System Log ",
                    "type": "string",
                    "role": "text",
                    "read": true,
                    "write": false
                  "native": {},
                  "_id": "onvif.0._003.logs.systemlog",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "onvif.0._003.logs.accesslog": {
                  "type": "state",
                  "common": {
                    "name": "Access Log ",
                    "type": "string",
                    "role": "text",
                    "read": true,
                    "write": false
                  "native": {},
                  "_id": "onvif.0._003.logs.accesslog",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "onvif.0._003": {
                  "type": "device",
                  "common": {
                    "name": "SamsungDrucker",
                    "role": "camera"
                  "native": {
                    "user": "",
                    "password": "",
                    "ip": "192.168.178.23",
                    "urn": "urn:uuid:16a65700-007c-1000-bb49-30cda7aa23f1",
                    "service": "http://192.168.178.23:8018/wsd",
                    "hardware": "",
                    "location": "",
                    "types": [
                      "wsdp:Device",
                      "wprt:PrintDeviceType",
                      "wscn:ScanDeviceType"
                    "scopes": [
                    "port": ""
                  "ts": 1577873900661,
                  "_id": "onvif.0._003",
                  "acl": {
                    "object": 1636,
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #46
              @Knallochse Danke, der Drucker benutzt das gleiche Protokoll um gefunden zu werden. Hab jetzt einen Filter eingebaut damit wirklich nur Kameras gefunden werden.
              • KnallochseK Offline
                KnallochseK Offline
                Knallochse
                schrieb am zuletzt editiert von Knallochse
                #47
                @Jey-Cee könnte man über onvif die RSSI Werte der WLAN Verbindung der Kameras auslesen?
                Meine Kameras verbinden sich manchmal mit dem falschen Repeater (Sch... Mesh).
                So könnte man auf Grund von schlechten Verbindungswerten einen Reboot starten.
                HM&HMIP über 100 Geräte + IoBroker auf DS918+ uvm.
                ? Jey CeeJ 2 Antworten Letzte Antwort
                  #48
                  @Knallochse hast du AVM Kisten?
                  Hatte mit dem "Mesh" auch so meine Probleme.. schau mal, so gehts bei mir sehr gut :
                  hab permanent zwischen 245 und 300 Geräte im Netz..
                  KnallochseK 1 Antwort Letzte Antwort
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    #49
                    @Knallochse sagte in Test Adapter onvif v0.1.x:
                    Es gibt tatsächlich die Möglichkeit per onvif WLAN Informationen ab zu rufen, aber ich weis nicht ob RSSI Werte auch dabei sind. Zumindest sollte es möglich sein nach WLANs in Reichweite zu scannen wenn die Kamera das Unterstützt.
                      KnallochseK Offline
                      KnallochseK Offline
                      Knallochse
                      #50
                      @ilovegym ja, Fitzbox 7580+3 AVM Repeater.
                      Ich habe mal deine Einstellungen übernommen. Jetzt beobachte ich das Verhalten der WLAN Geräte .
                      Vielen Dank und ein gesundes neues Jahr 👍
                      ? 1 Antwort Letzte Antwort
                        #51
                        @Knallochse Danke, auch frohes neues !
                        Hab 18 Kameras, und seitdem ist Ruhe, da das Mesh versucht hat, die Streams woanders hin zu connecten, was zu abrissen führte..
                        • Jey CeeJ Jey Cee
                          KnallochseK Offline
                          KnallochseK Offline
                          Knallochse
                          #52
                          @Jey-Cee sagte in Test Adapter onvif v0.1.x:
                          Bei meinen Kameras kann man über das WebUI einen Suchlauf anleiern, und es werden alle erkannten Netzwerke aufgelistet.
                          • C Offline
                            ChrisXY
                            #53
                            hm was ist wenn die cams unterschiedliche Logins haben ? Es wurden 3 gefunden auch mit Bild. Ohne Zugangsdaten. Schön wäre wenn man draufklicken kann und die Speziellen Login Daten der gefunden Cam einzutragen
                            • C ChrisXY
                              Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              #54
                              @ChrisXY sagte in Test Adapter onvif v0.1.x:
                              Du meinst wenn eine Cam mehrere Logins hat? Das macht für mich keinen Sinn, ioBroker ist in meinen Cams der Administrator und kann damit alles machen. Warum sollte ich mehrere Benutzer anlegen wenn es auch einer tut.
                              Vielleicht bau ich das irgendwann ein, aber das hat sehr niedrige Priorität.
                              C 1 Antwort Letzte Antwort
                                @Dr-Bakterius hast du den Adapter neu gestartet?
                                Falls ja geht es wohl so nicht oder irgendwas stimmt nicht.
                                Nicht nur einmal! 😕
                                Zusammengefasst: onvif ist aktiviert, die Cams sind vom Broker aus erreichbar (im selben Subnetz) und mit anderer Software (von einem anderen Rechner) klappt auch die onvif-Verbindung. Cams, ioBroker und Adapter wurden mehrfach neu gestartet und das Log wirft keine Fehler aus. Trotzdem wird keine der drei Cams vom Adapter gefunden.
                                Noch Ideen?
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                #55
                                @Dr-Bakterius
                                Test mal hier , was als Log Ausgabe folgt .
                                In der Instanz JavaScript , das Modul node-onvif eintragen
                                JavaScript :
                                /// ONVIF Ausgabe ioBroker 01.01.2020 Glasfaser
                                const onvif = require('node-onvif');//
                                console.log('Start the discovery process.');
                                // Find the ONVIF network cameras.
                                // It will take about 3 seconds.
                                onvif.startProbe().then((device_info_list) => {
                                  console.log(device_info_list.length + ' devices were found.');
                                  // Show the device name and the URL of the end point.
                                  device_info_list.forEach((info) => {
                                    console.log('- ' + info.urn);
                                    console.log('  - ' + info.name);
                                    console.log('  - ' + info.xaddrs[0]);
                                }).catch((error) => {
                                  console.error(error);
                                So sieht es dann aus :
                                Dr. BakteriusD 1 Antwort Letzte Antwort
                                • Jey CeeJ Jey Cee
                                  @Glasfaser sagte in Test Adapter onvif v0.1.x:
                                  Laut Doku von onvif-nvt ,
                                  Auf die habe ich gehört, deswegen hat es auch nicht funktioniert. Die Doku sagt callback geht und so hatte ich es versucht, aber tatsächlich geht nur der Promise weg.
                                  Hab heute nacht noch viel probiert, aber auf das bin ich erst heute morgen gekommen.
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #56
                                  Habe sonst dieses Script für eine Cam genutzt , was auch gut funktioniert.
                                  (War hier aus dem Forum)
                                  Dort wird Preset auch angesprochen , vielleicht kannst du damit etwas anfangen !???
                                  Instanz Javascript Modul eintragen : node-onvif
                                  Ab Zeile 219 anpassen // Create an OnvifDevice object
                                  xaddr :http://deineIP/onvif/device_service
                                  user :
                                  pass :
                                  const fC = false;
                                  const logging = false;
                                  const pfad = 'javascript.' + instance + '.VIS.Kamera.1.PTZ.';
                                  const idSpeed     = pfad + 'Geschwindigkeit';
                                  const idStoppzeit = pfad + 'Stoppzeit';
                                  const idStopp =     pfad + 'Stopp';
                                  const idRechts =    pfad + 'rechts';
                                  const idLinks =     pfad + 'links';
                                  const idHoch =      pfad + 'hoch';
                                  const idRunter =    pfad + 'runter';
                                  const idZoomIn =    pfad + 'ZoomIn';
                                  const idZoomOut =   pfad + 'ZoomOut';
                                  const idGotoPreset =   pfad + 'gotoPreset';
                                  const fs = require('fs');
                                  createState(idSpeed, 1, fC, {
                                    def: 1,
                                    min: 0,
                                    max: 1,
                                    name: 'Kamera 1 PTZ Geschwindkeit bei Bewegung',
                                    desc: 'Geschwindigkeit von 0-1 bei der Bewegung',
                                    type: 'number'
                                  createState(idStoppzeit, 1, fC, {
                                    def: 0,
                                    min: 0,
                                    name: 'Kamera 1 PTZ Stoppzeit',
                                    desc: 'Dauer in Sekunden bis zum Stopp der Bewegung',
                                    type: 'number',
                                    unit: 's'
                                  createState(idStopp, false, fC, {
                                    def: false,
                                    name: 'Kamera 1 PTZ Stopp',
                                    desc: 'Sofortiger Stopp der Bewegung',
                                    type: 'boolean',
                                    role: 'switch'
                                  createState(idRechts, false, fC, {
                                    def: false,
                                    name: 'Kamera 1 PTZ rechts',
                                    desc: 'Bewegung nach rechts',
                                    type: 'boolean',
                                    role: 'switch'
                                  createState(idLinks, false, fC, {
                                    def: false,
                                    name: 'Kamera 1 PTZ links',
                                    desc: 'Bewegung nach links',
                                    type: 'boolean',
                                    role: 'switch'
                                  createState(idHoch, false, fC, {
                                    def: false,
                                    name: 'Kamera 1 PTZ oben',
                                    desc: 'Bewegung nach oben',
                                    type: 'boolean',
                                    role: 'switch'
                                  createState(idRunter, false, fC, {
                                    def: false,
                                    name: 'Kamera 1 PTZ unten',
                                    desc: 'Bewegung nach unten',
                                    type: 'boolean',
                                    role: 'switch'
                                  createState(idZoomIn, false, fC, {
                                    def: false,
                                    name: 'Kamera 1 PTZ Zoom in',
                                    desc: 'Bild vergößern',
                                    type: 'boolean',
                                    role: 'switch'
                                  createState(idZoomOut, false, fC, {
                                    def: false,
                                    name: 'Kamera 1 PTZ Zoom out',
                                    desc: 'Bild verkleinern',
                                    type: 'boolean',
                                    role: 'switch'
                                  createState(idGotoPreset, 0, fC, {
                                    def:  0,
                                    name: 'Kamera 1 PTZ Preset Wähler',
                                    desc: 'Preset auswählen (Zahlen von 1 bis X)',
                                    type: 'number'
                                  //Find the ONVIF network cameras
                                  onvif.startDiscovery((info) => {
                                  // Stop the discovery process in 3 seconds
                                  setTimeout(() => {
                                  onvif.stopDiscovery(() => {
                                    log('Stopped the discovery process.');
                                  {1}
                                  }, 3000);
                                  const device = new onvif.OnvifDevice({
                                    xaddr: 'http://deineIP/onvif/device_service',
                                    user : 'xxxxxxxxx',
                                    pass : 'xxxxxxxxx'
                                  function movePTZ (ptz_x, ptz_y, ptz_z, stoptime) {
                                    // https://github.com/futomi/node-onvif#ptzmoveparams-callback
                                    device.init((error) => {
                                        if (error) {
                                            log('[ERROR] ' + error.message);
                                            return;
                                        } else {
                                            // +++ CONTROL via PTZ
                                            var ptzlog = '';
                                            ptz_x = (ptz_x <=1 && ptz_x >=-1) ? ptz_x : 0;
                                            ptz_y = (ptz_y <=1 && ptz_y >=-1) ? ptz_y : 0;
                                            ptz_z = (ptz_z <=1 && ptz_z >=-1) ? ptz_z : 0;
                                            if (ptz_x > 0) ptzlog = 'Schwenk nach rechts';
                                            if (ptz_x < 0) ptzlog = 'Schwenk nach links';
                                            if (ptz_y > 0) ptzlog = 'Schwenk nach oben';
                                            if (ptz_y < 0) ptzlog = 'Schwenk nach unten';
                                            if (ptz_z > 0) ptzlog = 'Zoom in';
                                            if (ptz_z < 0) ptzlog = 'Zoom out';
                                            ptzlog += ' für ' + stoptime + 's';
                                            if (logging) log(ptzlog);
                                            // Create the parameters
                                            var params = {
                                                'speed': {
                                                    x: ptz_x, // Speed of pan (in the range of -1 to 1.0)
                                                    y: ptz_y, // Speed of tilt (in the range of -1 to 1.0)
                                                    z: ptz_z  // Speed of zoom (in the range of -1 to 1.0)
                                                'timeout': 30 // seconds
                                            // Move the camera
                                            device.ptzMove(params, (error) => {
                                                if (error) {
                                                    log(error.message, 'error');
                                                } else {
                                                    log('Camera moved!');
                                            // Stop to the PTZ in X seconds
                                            setTimeout(() => {
                                                device.ptzStop((error) => {
                                                    if (error) {
                                                    } else {
                                                        log('Succeeded to stop after ' + stoptime + ' seconds.');
                                            }, stoptime * 1000);  // stopzeit
                                  function stopMoving () {
                                        if (error) {
                                        } else {
                                            log('Succeeded to stop.');
                                  // https://github.com/futomi/node-onvif#gotopresetparams-callback-method
                                  function gotoPreset (presetNumber) { // 1,2,3 kommt als ganze Zahl
                                    if (presetNumber > 0) {
                                            if (error) {
                                                log('[ERROR] ' + error.message, 'error');
                                                return;
                                            } /*else {*/
                                            // The OnvifServicePtz object
                                            var ptz = device.services.ptz;
                                            if (ptz) {
                                                var profile = device.getCurrentProfile(); // debug
                                                log(JSON.stringify(profile, null, '  ')); // debug log
                                                var params = {
                                                    'ProfileToken': profile['token'],
                                                    'PresetToken' : presetNumber.toString(),
                                                    'Speed'       : {'x': 1, 'y': 1, 'z': 1}
                                                device.services.ptz.gotoPreset(params, (error, result) => {
                                                    if (error) {
                                                    } else {
                                                        if (logging) log('Preset: ' + JSON.stringify(result.data, null, '  ')); // statt result.['data']
                                                        log('Camera moved to Preset #' + presetNumber.toString());
                                            } else {
                                                log('[ERROR] Your ONVIF network camera does not support the PTZ service.');
                                    } else {
                                        log('Preset für Kamera 1 kein valider Preset-Wert'); // debug log
                                  // Links
                                  on({id: idLinks, val: true},function (obj) {
                                    if (!obj.state.ack && obj.state.val) {
                                       var stoppzeit = getState(idStoppzeit).val;
                                       var speed = getState(idSpeed).val;
                                       movePTZ(-1 * speed , 0, 0, stoppzeit);
                                       setStateDelayed(idLinks, false, 500); // ggf , 500 + (stoppzeit * 1000)
                                  // rechts
                                  on({id: idRechts, val: true}, function (obj) {
                                       movePTZ(1 * speed , 0, 0, stoppzeit);
                                       setStateDelayed(idRechts, false, 500);
                                  // oben
                                  on({id: idHoch, val: true}, function (obj) {
                                       movePTZ(0, 1 * speed, 0, stoppzeit);
                                       setStateDelayed(idHoch, false, 500, 500);
                                  // runter
                                  on({id: idRunter, val: true}, function (obj) {
                                       movePTZ(0, -1 * speed, 0, stoppzeit);
                                       setStateDelayed(idRunter, false, 500);
                                  // vergrößern
                                  on({id: idZoomIn, val: true}, function (obj) {
                                       movePTZ(0, 0, 1 * speed, stoppzeit);
                                       setStateDelayed(idZoomIn, false, 500);
                                  // verkleinern
                                  on({id:idZoomOut, val: true}, function (obj) {
                                       movePTZ(0, 0, -1 * speed, stoppzeit);
                                       setStateDelayed(idZoomOut, false, 500);
                                  // sofortiger Stopp
                                  on(idStopp, function (obj) {
                                       stopMoving();
                                       setStateDelayed(idStopp, false, 500);
                                       setState(idGotoPreset, 0);
                                  on({
                                    id: [idStopp, idZoomOut, idZoomIn, idRunter, idHoch, idRechts, idLinks],
                                    change: 'any'
                                  }, function (obj) {
                                  // zum bereits gespeicherten Preset X fahren (Ganze Zahl, kommt aus VIS, Scenes oder Script)
                                  on(idGotoPreset, function (obj) {
                                       gotoPreset(parseInt(obj.state.val,10)); // vorher 10 wird später zu einem String gewandelt
                                       setStateDelayed(idGotoPreset, 0, 500); // reset
                                  /// Test hochrechts
                                  const idHochRechts = pfad + 'hochrechts';
                                  createState(idHochRechts, false, fC, {def: false,name: 'Kamera 1 PTZ obenrechts',desc: 'Bewegung nach obenrechts',type: 'boolean',role: 'switch'});
                                  on(idHochRechts, function (obj) {
                                       setStateDelayed(idHochRechts, false, 500);
                                    steimi
                                    #57
                                    @Jey-Cee kannst du die Objekt-Struktur dahingehend anpassen, dass statt IPC-model_xxx die IP-Adresse in Form von 192_168_1_1 verwenden wird? Steigert mMn die Übersichtlichkeit. Und wäre es möglich im Adapter die Liste der Cam sortierbar zu machen?
                                    Thx Steimi
                                    • S steimi
                                      Thx Steimi
                                      Jey CeeJ Online
                                      Jey CeeJ Online
                                      Jey Cee
                                      #58
                                      @steimi Also die IP zu nutzen ist sicher keine gute Idee, die kann sich ändern. Alternativ kann ich die urn benutzen, die ändert sich nicht: 88d87a05-d7f77e45-b1e9-00626E51E215
                                      @steimi sagte in Test Adapter onvif v0.1.x:
                                      Ich werde es mir merken, ist aber gerade niedrige Priorität.
                                      Edit: Wonach soll denn Sortiert werden können?
                                        steimi
                                        #59
                                        Wie oft ändern man den die IP-Adresse der Cam's? Beim 'wiffi-wz'-Adapter funktioniert dies ganz gut. Vlt geht aber auch ein frei vergebbarer Name für den Objektbaum.
                                        Es muss nicht sortierbar sein, allerdings sollte zumindest nach der Erkennen nach etwas sortiert sein (IP-Adresse?).
                                        • S steimi
                                          Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          #60
                                          Naja vielleicht nicht so oft, aber ändere sie einmal an 20 Stellen in Skripten die du vor einem Jahr geschrieben hast. Das kann ziemlich anstrengend sein und fehler verursachen.
                                          Jedenfalls ändere ich es jetzt auf die Serial des Gerätes, das ist auch Programmtechnisch stabiler.
                                          Ne, aber du kannst doch den Namen beliebig ändern. Und das sogar in der Konfiguration.
