  4. Test Adapter ioBroker.backitup v3.1.x
    6.1k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • simatecS simatec
    @pk68
    Das ist nicht gewollt. Bitte poste mal den Debug Log
    pk68
    #541
    @simatec
    2020-07-12 02:00:10.027 - debug: backitup.0 (26881) Backup has started ...
    2020-07-12 02:00:12.428 - debug: backitup.0 (26881) [iobroker/iobroker] host.Raspi4-iob 2778 states saved
    2020-07-12 02:00:12.462 - debug: backitup.0 (26881) [iobroker/iobroker] host.Raspi4-iob 3071 objects saved
    2020-07-12 02:00:14.989 - debug: backitup.0 (26881) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_07_12-02_00_10_backupiobroker.tar.gz
    2020-07-12 02:00:16.031 - debug: backitup.0 (26881) [iobroker/iobroker] done
    2020-07-12 02:00:16.677 - debug: backitup.0 (26881) [iobroker/historyDB] done
    2020-07-12 02:00:16.679 - debug: backitup.0 (26881) [iobroker/zigbee] found zigbee database: zigbee.0
    2020-07-12 02:00:16.680 - debug: backitup.0 (26881) [iobroker/zigbee] done
    2020-07-12 02:00:16.687 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_07_03-02_00_10_backupiobroker.tar.gz
    2020-07-12 02:00:16.688 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_07_02-02_00_10_backupiobroker.tar.gz
    2020-07-12 02:00:16.690 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2020_07_03-02_00_15_backupiobroker.tar.gz
    2020-07-12 02:00:16.691 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2020_07_02-02_00_16_backupiobroker.tar.gz
    2020-07-12 02:00:16.692 - debug: backitup.0 (26881) [iobroker/clean] done
    2020-07-12 02:00:16.698 - debug: backitup.0 (26881) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
    2020-07-12 02:00:16.699 - debug: backitup.0 (26881) [iobroker/telegram] done
    2020-07-12 02:00:16.704 - debug: backitup.0 (26881) [iobroker] exec: done
    2020-07-12 02:00:16.708 - debug: backitup.0 (26881) [iobroker/history] backitup.0.history.html
    2020-07-12 02:00:16.709 - debug: backitup.0 (26881) [iobroker] exec: done
    2020-07-12 02:00:16.710 - debug: backitup.0 (26881) [iobroker/history] backitup.0.history.json
    2020-07-12 02:00:16.712 - debug: backitup.0 (26881) [iobroker] exec: done
    • simatecS simatec
      @pk68
      Jan1
      #542
      @simatec
      ist mir auch schon aufgefallen
      • GarganoG Offline
        GarganoG Offline
        Gargano
        #543
        Bei mir ist unter dem wiederherstellen Google nur der iobroker Pfad, der CCU Pfad fehlt. Backup CCU machen kann ich , der Pfad existiert auch in Google Drive, nur angezeigt wird er nicht. Wie kann ich denn da ein Restore der ccu machen ?
        • GarganoG Gargano
          simatecS Offline
          simatecS Offline
          simatec
          #544
          @Gargano
          Bitte Doku des Adapters lesen (Bereich Wiederherstellung)
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
            passuff
            #545
            ich habe eingestellt, dass die backups auf google drive gespeichert werden sollen. Bekomme seit eniger Zeit folgende Fehlermeldung:
            2020-07-20 02:00:21.482 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2020-07-20 02:00:21.572 - error: backitup.0 (23926) unhandled promise rejection: Rate Limit Exceeded
            2020-07-20 02:00:21.815 - error: backitup.0 (23926) Error: Rate Limit Exceeded
            at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:108:15)
            at runMicrotasks ()
            at processTicksAndRejections (internal/process/task_queues.js:97:5)
            at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:342:22)
            2020-07-20 02:00:21.817 - info: backitup.0 (23926) cleaned everything up...
            2020-07-20 02:00:21.928 - info: backitup.0 (23926) terminating
            2020-07-20 02:00:21.931 - info: backitup.0 (23926) Terminated (NO_ERROR): Without reason
            2020-07-20 02:00:22.469 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: Error: Rate Limit Exceeded
            2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:108:15)
            2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: at runMicrotasks ()
            2020-07-20 02:00:22.471 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2020-07-20 02:00:22.471 - error: host.iobroker Caught by controller[1]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:342:22)
            2020-07-20 02:00:22.471 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            2020-07-20 02:00:22.471 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
            Das tritt nicht bei jedem backup auf. Manchmal funktioniert es auch. Hat jemand eine Idee?
            simatecS P 2 Antworten Letzte Antwort
            • P passuff
              at runMicrotasks ()
              simatecS Offline
              simatecS Offline
              simatec
              #546
              @passuff
              Welche Version von backitup ist installiert und welche node, nodejs, npm und js-controller Versionen hast du laufen?
                passuff
                #547
                installiert habe ich Backitup in der Version 1.5.8.
                root@iobroker:~# iobroker info
                Platform       : linux
                os             : linux
                Architecture   : x64
                CPUs           : 1
                Speed          : 1699 MHz
                Model          : Common KVM processor
                RAM            : 3.8 GB
                System uptime  : 23d. 13:42:14
                Node.js        : v12.18.0
                Disk size      : 27.4 GiB
                Disk free      : 25.0 GiB
                adapters count : 355
                NPM            : v6.14.5
                • simatecS Offline
                  simatecS Offline
                  simatec
                  #548
                  Ab sofort ist die Version 1.5.9 auf Github und in Kürze auch im latest verfügbar ...
                  Changelog
                  1.5.9 (21.07.2020)
                  • (simatec) small fixes on mysql backup
                  • (simatec) next bugfixs errorhandling sentry.io
                  • (simatec) updated dependencies
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    #549
                    Ab sofort ist die Version 1.6.0 auf Github und in Kürze auch im latest verfügbar ...
                    Changelog
                    1.6.0 (03.08.2020)
                    • (Jey-Cee/simatec) adapter configuration revised
                    K 1 Antwort Letzte Antwort
                    • simatecS simatec
                      Changelog
                      1.6.0 (03.08.2020)
                      Kueppert
                      #550
                      @simatec ich wundere mich schon länger, arum mein MySQL-Backup immer nur 0 kb groß ist. Hab mit phpmyadmin mal in die SQL reingeschaut - da sind jede Menge werte vorhanden. Also mal auf die VM gegangen und geschaut, ob das file überhaupt exitiert (mysqldump) - JA, das gibt es.
                      Hab dann mal ins LOG geschaut und folgenden Eintrag gefunden:
                      [ERROR] [mysql] - [IGNORED] Error: Command failed: /usr/bin/mysqldump  -u iobroker -p**** iobroker -h 192.168.178.73 -P 3306 > /opt/iobroker/backups/mysql_2020_08_04-09_31_43_backupiobroker.sql
                      /bin/sh: 1: /usr/bin/mysqldump: not found
                      (habe den Ordner zu der mysqldump eingetragen; vorher hatte ich aber den gleichen Fehler). Backitup findet die Datei nicht? Vorhanden ist sie aber...
                      Im Adapter habe ich den User für die Datenbank eingetragen - ist es möglich, dass dieser user die Datei ggf. nicht ausführen darf wegen fehlender Rechte? Im backitup-Adapter hab ich die Konfig vom MySQL-Adapter übernommen (der User für die DB ist korrekt).
                      Wenn ich Infos vergessen habe, die für eine ANalyse notwendig sind, teilt mir das bitte mit.
                      Die MySQL-DB läuft auf einer VM unter Proxmox (und wird problemlos beschrieben).
                      Danke euch und vG, Thorsten
                      • P passuff
                        at runMicrotasks ()
                        passuff
                        #551
                        @passuff sagte in Test Adapter Backitup v1.6.x:
                        at runMicrotasks ()
                        Gibts dazu schon was neues?
                        • K Kueppert
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #552
                          @Kueppert so wie ich das sehe, läuft deine sql nicht auf dem gleichen System wie dein iobroker.
                          mysqdump muss also auf deinem iobroker System auch installiert sein.
                          • P passuff
                            at runMicrotasks ()
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #553
                            @passuff
                            Eventuell mal deinen Token erneuern ... Kann auf allen Testsystemen den Fehler nicht nachstellen
                            P 1 Antwort Letzte Antwort
                            • simatecS simatec
                              @passuff
                              passuff
                              #554
                              @simatec habe extra einen neuen google Account für backitup erstellt. Hat aber auch nichts geholfen. Habe sogar ein Testsystem aufgesetzt - leider mit dem selben Ergebnis.
                              • P passuff
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #555
                                @passuff
                                Eventuell wurde bei einem Update von node, js-controller oder sonstiges auch was beschädigt.
                                Lösche mal die Instanz und im Anschluss den Adapter von Backitup und installiere diesen nach einem Neustart mal neu.
                                • simatecS simatec
                                  Kueppert
                                  #556
                                  @simatec ahaaaa, danke für den Hinweis ;)
                                  Für alle, die das gleiche Setup haben (Debian 10) hier der Code-Schnipsel für die Installation:
                                  apt-get install default-mysql-client
                                  Nun geht das Backup auch. Danke und vG, Thorsten
                                  • simatecS simatec
                                    @passuff
                                    passuff
                                    #557
                                    @simatec
                                    Habe den Adapter gelöscht und neu aufgesetzt. Da ich aber auf meinem Testsystem die selbe Fehlermeldung erhalte, glaube ich nicht dass sich etwas ändert. Ich bekomme die Fehlemeldung mittlerwele bei jedem zeitgesteuerten Start- bei manueller Auslösung aber nie.
                                    Welches Setup (node, js-controller..) nutzt du?
                                    • P passuff
                                      @simatec
                                      passuff
                                      #558
                                      @simatec
                                      Wie erwartet bleibt alles beim alten. Der zeitgesteuerte Upload auf gdrive funktioniert nicht! Manuell weiterhin ohne Probleme möglich. Biete mich gerne zum debugging an, falls du das bei dir nicht nachstellen kannst.
                                      • simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #559
                                        Ab sofort steht die Version 1.6.1 zum testen auf Github und in kürze auch im latest zur Verfügung.
                                        Changelog
                                        1.6.1 (24.08.2020)
                                        • (Apollon77) several fixes and optimizations
                                        • P passuff
                                          @simatec
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #560
                                          @passuff
                                          Teste mal bitte die Version 1.6.1
