  4. Test Adapter ioBroker.backitup v3.1.x
    6.6k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • P passuff
    ich habe eingestellt, dass die backups auf google drive gespeichert werden sollen. Bekomme seit eniger Zeit folgende Fehlermeldung:
    2020-07-20 02:00:21.482 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-07-20 02:00:21.572 - error: backitup.0 (23926) unhandled promise rejection: Rate Limit Exceeded
    2020-07-20 02:00:21.815 - error: backitup.0 (23926) Error: Rate Limit Exceeded
    at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:108:15)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:342:22)
    2020-07-20 02:00:21.817 - info: backitup.0 (23926) cleaned everything up...
    2020-07-20 02:00:21.928 - info: backitup.0 (23926) terminating
    2020-07-20 02:00:21.931 - info: backitup.0 (23926) Terminated (NO_ERROR): Without reason
    2020-07-20 02:00:22.469 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: Error: Rate Limit Exceeded
    2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:108:15)
    2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: at runMicrotasks ()
    2020-07-20 02:00:22.471 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-07-20 02:00:22.471 - error: host.iobroker Caught by controller[1]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:342:22)
    2020-07-20 02:00:22.471 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2020-07-20 02:00:22.471 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
    Das tritt nicht bei jedem backup auf. Manchmal funktioniert es auch. Hat jemand eine Idee?
    passuff
    #551
    @passuff sagte in Test Adapter Backitup v1.6.x:
    at runMicrotasks ()
    Gibts dazu schon was neues?
    • K Kueppert
      @simatec ich wundere mich schon länger, arum mein MySQL-Backup immer nur 0 kb groß ist. Hab mit phpmyadmin mal in die SQL reingeschaut - da sind jede Menge werte vorhanden. Also mal auf die VM gegangen und geschaut, ob das file überhaupt exitiert (mysqldump) - JA, das gibt es.
      Hab dann mal ins LOG geschaut und folgenden Eintrag gefunden:
      [ERROR] [mysql] - [IGNORED] Error: Command failed: /usr/bin/mysqldump  -u iobroker -p**** iobroker -h 192.168.178.73 -P 3306 > /opt/iobroker/backups/mysql_2020_08_04-09_31_43_backupiobroker.sql
      /bin/sh: 1: /usr/bin/mysqldump: not found
      (habe den Ordner zu der mysqldump eingetragen; vorher hatte ich aber den gleichen Fehler). Backitup findet die Datei nicht? Vorhanden ist sie aber...
      Im Adapter habe ich den User für die Datenbank eingetragen - ist es möglich, dass dieser user die Datei ggf. nicht ausführen darf wegen fehlender Rechte? Im backitup-Adapter hab ich die Konfig vom MySQL-Adapter übernommen (der User für die DB ist korrekt).
      Wenn ich Infos vergessen habe, die für eine ANalyse notwendig sind, teilt mir das bitte mit.
      Die MySQL-DB läuft auf einer VM unter Proxmox (und wird problemlos beschrieben).
      Danke euch und vG, Thorsten
      simatecS Offline
      simatecS Offline
      simatec
      #552
      @Kueppert so wie ich das sehe, läuft deine sql nicht auf dem gleichen System wie dein iobroker.
      mysqdump muss also auf deinem iobroker System auch installiert sein.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • P passuff
        at runMicrotasks ()
        simatecS Offline
        simatecS Offline
        simatec
        #553
        @passuff
        Eventuell mal deinen Token erneuern ... Kann auf allen Testsystemen den Fehler nicht nachstellen
        P 1 Antwort Letzte Antwort
        • simatecS simatec
          @passuff
          passuff
          #554
          @simatec habe extra einen neuen google Account für backitup erstellt. Hat aber auch nichts geholfen. Habe sogar ein Testsystem aufgesetzt - leider mit dem selben Ergebnis.
          • P passuff
            simatecS Offline
            simatecS Offline
            simatec
            #555
            @passuff
            Eventuell wurde bei einem Update von node, js-controller oder sonstiges auch was beschädigt.
            Lösche mal die Instanz und im Anschluss den Adapter von Backitup und installiere diesen nach einem Neustart mal neu.
            • simatecS simatec
              Kueppert
              #556
              @simatec ahaaaa, danke für den Hinweis ;)
              Für alle, die das gleiche Setup haben (Debian 10) hier der Code-Schnipsel für die Installation:
              apt-get install default-mysql-client
              Nun geht das Backup auch. Danke und vG, Thorsten
              • simatecS simatec
                @passuff
                passuff
                #557
                @simatec
                Habe den Adapter gelöscht und neu aufgesetzt. Da ich aber auf meinem Testsystem die selbe Fehlermeldung erhalte, glaube ich nicht dass sich etwas ändert. Ich bekomme die Fehlemeldung mittlerwele bei jedem zeitgesteuerten Start- bei manueller Auslösung aber nie.
                Welches Setup (node, js-controller..) nutzt du?
                • P passuff
                  @simatec
                  passuff
                  #558
                  @simatec
                  Wie erwartet bleibt alles beim alten. Der zeitgesteuerte Upload auf gdrive funktioniert nicht! Manuell weiterhin ohne Probleme möglich. Biete mich gerne zum debugging an, falls du das bei dir nicht nachstellen kannst.
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    #559
                    Ab sofort steht die Version 1.6.1 zum testen auf Github und in kürze auch im latest zur Verfügung.
                    Changelog
                    1.6.1 (24.08.2020)
                    • (Apollon77) several fixes and optimizations
                    • P passuff
                      @simatec
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #560
                      @passuff
                      Teste mal bitte die Version 1.6.1
                      • simatecS simatec
                        @passuff
                        passuff
                        schrieb am zuletzt editiert von passuff
                        #561
                        @simatec
                        Danke dir. Habe gerade installiert. Jedoch frage ich mich gerade, wie man eine zeitgesteuerte Auslösung triggert, wenn diese heute bereits gelaufen ist?
                        Notfalls muss ich erst 24h warten (02:00) bevor wir schlauer sind...
                        • P passuff
                          @simatec
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #562
                          @passuff
                          Einfach die Zeit auf einen Wert in der Zukunft wählen
                          • simatecS simatec
                            @passuff
                            passuff
                            #563
                            @simatec sagte in Test Adapter Backitup v1.6.x:
                            @passuff
                            Nja.. So einfach ist es natürlich nicht. Wie gesagt, heute Nacht um 2 ist der Adapter gelaufen - d.h. frühestens um 2 Uhr läuft er wieder. Wenn ich jetzt... 14:14 Uhr eingebe, wird das eiskalt ignoriert ...
                            harrymH simatecS 2 Antworten Letzte Antwort
                            • P passuff
                              @passuff
                              harrymH Offline
                              harrymH Offline
                              harrym
                              #564
                              den jeweiligen Datenpunkt auf true setzen.
                              ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                              • harrymH harrym
                                passuff
                                #565
                                @harrym wofür genau? Manuelle Auslösung?
                                harrymH 1 Antwort Letzte Antwort
                                • P passuff
                                  harrymH Offline
                                  harrymH Offline
                                  harrym
                                  #566
                                  @passuff genau.
                                  • P passuff
                                    @passuff
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #567
                                    @passuff
                                    Nein wird es nicht ... so teste ich auch immer ... du kannst die Zeit nach deinen Wünschen eingeben.... wichtig, die Zeit muss in der Zukunft liegen
                                    • harrymH harrym
                                      @passuff genau.
                                      passuff
                                      #568
                                      @harrym sagte in Test Adapter Backitup v1.6.x:
                                      @passuff genau.
                                      Das hat bisher immer funktioniert. Es geht tatsächlich um die zeitgesteuerte Auslösung die Probleme macht. Da hilft mir die manuelle nix... Danke dennoch!
                                      • simatecS simatec
                                        @passuff
                                        passuff
                                        #569
                                        @simatec Zeit liegt immer in der Zukunft ... und auch in der Vergagenheit. Was von beidem weiß nur das Datum...
                                        Habe ich getestet, sonst würde ich nicht sowas schreiben...
                                        • P passuff
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #570
                                          @passuff
                                          also dein Problem ist für mich überhaupt nicht nachvollziehbar. backitup setzt ein schedule und das geht ohne Probleme auch mehrmals am Tag. Vorraussetzung ist dass der Wert in der Zukunft liegt. Prüfe mal deine Zeiteinstellungen deines IOB's
                                          Backup heute 11:29
                                          Backup heute 14:23
