  4. Test Adapter zoneminder v0.3.x
zonemindermotioncamera
206 Beiträge 23 Kommentatoren 45.4k Aufrufe 26 Beobachtet
  • coyoteC Offline
    coyoteC Offline
    coyote
    schrieb am zuletzt editiert von coyote
    #101
    @Meistertr gerade mal Version 0.3 installiert, leider werden keine DP's angelegt außer info und der Adapter bleibt gelb.
    Log:
    zoneminder.0	2019-10-25 07:08:27.098	debug	(28674) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Connected"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","14.29"],
    zoneminder.0	2019-10-25 07:08:27.097	debug	(28674) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Connected"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","14.29"],
    zoneminder.0	2019-10-25 07:08:27.095	debug	(28674) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam
    zoneminder.0	2019-10-25 07:08:27.094	debug	(28674) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
    zoneminder.0	2019-10-25 07:08:27.093	debug	(28674) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
    zoneminder.0	2019-10-25 07:08:27.091	debug	(28674) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_
    zoneminder.0	2019-10-25 07:08:27.090	debug	(28674) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],
    zoneminder.0	2019-10-25 07:08:27.089	debug	(28674) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],
    zoneminder.0	2019-10-25 07:08:27.087	debug	(28674) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.
    zoneminder.0	2019-10-25 07:08:27.085	debug	(28674) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],
    zoneminder.0	2019-10-25 07:08:27.084	debug	(28674) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],
    zoneminder.0	2019-10-25 07:08:27.080	debug	(28674) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.
    zoneminder.0	2019-10-25 07:08:27.074	debug	(28674) REQUEST: Video_Options {"method":"GET","uri":"http://192.168.66.184/zm/index.php?mode=mp4&eid=594&view=view_video&null","headers":{"user-agent":"@nodeminder-api","Cookie":";"}}
    zoneminder.0	2019-10-25 07:08:27.071	debug	(28674) REQUEST: Get data
    zoneminder.0	2019-10-25 07:08:27.052	debug	(28674) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api","Cookie":";"},"resolveWithFullResponse":true}
    zoneminder.0	2019-10-25 07:08:27.051	debug	(28674) REQUEST: Post before object
    zoneminder.0	2019-10-25 07:08:27.051	debug	(28674) SetStates
    zoneminder.0	2019-10-25 07:08:22.501	info	(28674) check user admin pw ioboker: true
    zoneminder.0	2019-10-25 07:08:22.156	debug	(28674) reposerrTypeError: Cannot read property 'forEach' of undefined
    zoneminder.0	2019-10-25 07:08:22.147	debug	(28674) REQUEST: Get data
    zoneminder.0	2019-10-25 07:08:22.144	info	(28674) undefined__testVariable___[object Object]
    zoneminder.0	2019-10-25 07:08:22.126	info	(28674) check group user admin group admin: false
    zoneminder.0	2019-10-25 07:08:22.034	debug	(28674) REQUEST: Options {"method":"POST","uri":"http://192.168.66.184/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-len
    zoneminder.0	2019-10-25 07:08:22.034	debug	(28674) REQUEST: Post before object
    zoneminder.0	2019-10-25 07:08:22.033	debug	(28674) data: {"user":"admin","password":"admin","host":"http://192.168.66.184/zm","zmEvent":false}
    zoneminder.0	2019-10-25 07:08:21.989	info	(28674) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.16.3
    host.debian	2019-10-25 07:08:20.371	info	instance system.adapter.zoneminder.0 started with pid 28674
    javascript.0	2019-10-25 07:08:19.719	debug	(6355) system.adapter.admin.0: logging true
    javascript.0	2019-10-25 07:08:19.715	debug	(6355) system.adapter.admin.0: logging true
    parser.0	2019-10-25 07:08:19.708	debug	(25043) system.adapter.admin.0: logging true
    host.debian	2019-10-25 07:08:18.932	info	instance system.adapter.zoneminder.0 terminated with code 156 (156)
    zoneminder.0	2019-10-25 07:08:17.866	info	(28599) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zoneminder.0	2019-10-25 07:08:17.864	info	(28599) terminating
    zoneminder.0	2019-10-25 07:08:17.863	info	(28599) cleaned everything up...
    zoneminder.0	2019-10-25 07:08:17.862	info	(28599) Got terminate signal TERMINATE_YOURSELF
    host.debian	2019-10-25 07:08:17.858	info	stopInstance system.adapter.zoneminder.0 send kill signal
    host.debian	2019-10-25 07:08:17.857	info	stopInstance system.adapter.zoneminder.0
    ZM Version: 1.32.3
    • MeistertrM Meistertr
      die 0.3.0 ist fertig:
      *Alarme werden nun erkannt und mit bild und video bereitgestellt (ZMEvent vorrausgesetzt)
      *Funktion der Monitore lässt sich nun einstellen
      *Monitore lassen sich aus und anstellen
      Bitte alle Zoneminder objekte Löschen und dann adapter starten, da einige states geändert wurden.
      mikiline
      schrieb am zuletzt editiert von mikiline
      #102
      @Meistertr
      Hi nochmals....bezüglich dem Login in der höheren version bekomme ich eine solche Rückmeldung
      Abfrage:
      curl -XPOST -d "user=ZMuser&pass=ZMpass" http://192.168.xx.xxx/zm/api/host/login.json
      Rückmeldung
      {"access_token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMDExMzIyLCJleHAiOjE1NzIwMTQ5MjIsInVzZXIiOiJaTWlvQnJva2VyIiwidHlwZSI6ImFjY2VzcyJ9.lDrJrgPAuvDNP9w0iFll5dhy5zEeInF0u9DhHuybDQU","access_token_expires":3600,"refresh_token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMDExMzIyLCJleHAiOjE1NzIwOTc3MjIsInVzZXIiOiJaTWlvQnJva2VyIiwidHlwZSI6InJlZnJlc2gifQ.E_r4vSJ2KbUq27CE39bYf7XXQeliMCxq3A-D0e7pKIY","refresh_token_expires":86400,"credentials":"auth=13d6a5a03f15104026d7c79a9ec47749","append_password":0,"version":"1.33.14","apiversion":"2.0"}
      Ist es möglich dies in den Adapter einzubauen?
      ich denke auch in späteren Versionen wird das Loginprozedere dann so aussehen.....
      MeistertrM 2 Antworten Letzte Antwort
      • M mikiline
        @Meistertr
        Abfrage:
        Rückmeldung
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        #103
        @mikiline der login Prozess ist identisch. Für die API Nutzung ist nur der der Auth key erforderlich und den gibt es bei beiden Versionen. Habe selber die 2.0 schon getestet und konnte sie ohne Probleme mit dem Adapter nutzen.
        coyoteC 1 Antwort Letzte Antwort
          coyoteC Offline
          coyoteC Offline
          coyote
          #104
          @Meistertr hast du ne Idee, warum die 3.0 bei mir nicht mehr will?
          • coyoteC coyote
            MeistertrM Offline
            MeistertrM Offline
            Meistertr
            #105
            @coyote bin dran
            • coyoteC coyote
              MeistertrM Offline
              MeistertrM Offline
              Meistertr
              #106
              @coyote bitte nochmal die version von git laden und den logauszug posten, hab ein bisschen mehr log einträge hinzugefügt
              • M mikiline
                @Meistertr
                Abfrage:
                Rückmeldung
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                #107
                @mikiline hab mich nochmal eingehender mit der Api auseinandergesetzt, werde die v2 am we noch integrieren. aber. egal welche Versionen, es sollte trotzdem auch so gehen. Insgesamt gibt es drei Möglichkeiten die Daten zu bekommen, zwei davon nutzt der Adapter jetzt schon., die dritte ist der access token.
                Wichtig ist das bei AUTH_HASH_SECRET ein beliebiger Schlüssel eingetragen wurde und OPT_USE_LEGACY_API_AUTH eingeschaltet ist (nur v2) Ansonsten wird der Login nicht erfolgreich sein.
                  coyoteC Offline
                  coyoteC Offline
                  coyote
                  #108
                  @Meistertr hier das Log.
                  Aber was soll ich sagen, Adapter ist jetzt grün und Objekte wurden angelegt.👍
                  zoneminder.0	2019-10-25 22:50:43.430	debug	(14437) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["z
                  zoneminder.0	2019-10-25 22:50:43.428	debug	(14437) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["z
                  zoneminder.0	2019-10-25 22:50:43.412	debug	(14437) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam
                  zoneminder.0	2019-10-25 22:50:43.409	debug	(14437) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
                  zoneminder.0	2019-10-25 22:50:43.403	debug	(14437) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
                  zoneminder.0	2019-10-25 22:50:43.390	debug	(14437) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_
                  zoneminder.0	2019-10-25 22:50:43.386	debug	(14437) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],
                  zoneminder.0	2019-10-25 22:50:43.380	debug	(14437) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],
                  zoneminder.0	2019-10-25 22:50:43.355	debug	(14437) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.
                  zoneminder.0	2019-10-25 22:50:43.350	debug	(14437) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],
                  zoneminder.0	2019-10-25 22:50:43.349	debug	(14437) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],
                  zoneminder.0	2019-10-25 22:50:43.347	debug	(14437) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.
                  zoneminder.0	2019-10-25 22:50:43.299	debug	(14437) REQUEST: Video_Options {"method":"GET","uri":"http://192.168.66.184/zm/index.php?mode=mp4&eid=594&view=view_video&null","headers":{"user-agent":"@nodeminder-api"}}
                  zoneminder.0	2019-10-25 22:50:43.292	debug	(14437) REQUEST: Get data[object Object]
                  zoneminder.0	2019-10-25 22:50:42.824	debug	(14437) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
                  zoneminder.0	2019-10-25 22:50:42.823	debug	(14437) REQUEST: Post before object
                  zoneminder.0	2019-10-25 22:50:42.823	debug	(14437) SetStates
                  zoneminder.0	2019-10-25 22:50:41.155	debug	(14437) CAM_ids: ["zoneminder.0.cam_1","zoneminder.0.cam_2","zoneminder.0.cam_3","zoneminder.0.cam_4"]
                  zoneminder.0	2019-10-25 22:50:41.148	debug	(14437) found states:_[["zoneminder.0.cam_4.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_4.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_4.zmEvent","Name","text","INIT"],["z
                  zoneminder.0	2019-10-25 22:50:41.134	debug	(14437) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam
                  zoneminder.0	2019-10-25 22:50:41.115	debug	(14437) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["z
                  zoneminder.0	2019-10-25 22:50:41.114	debug	(14437) Monitor_3 o.Monitor_Status = [object Object]
                  zoneminder.0	2019-10-25 22:50:41.114	debug	(14437) Monitor_3 o.Monitor = [object Object]
                  zoneminder.0	2019-10-25 22:50:41.112	debug	(14437) found states:_[["zoneminder.0.cam_3.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_3.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_3.zmEvent","Name","text","INIT"],["z
                  zoneminder.0	2019-10-25 22:50:41.109	debug	(14437) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_
                  zoneminder.0	2019-10-25 22:50:41.108	debug	(14437) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],
                  zoneminder.0	2019-10-25 22:50:41.107	debug	(14437) Monitor_2 o.Monitor_Status = [object Object]
                  zoneminder.0	2019-10-25 22:50:41.107	debug	(14437) Monitor_2 o.Monitor = [object Object]
                  zoneminder.0	2019-10-25 22:50:41.098	debug	(14437) found states:_[["zoneminder.0.cam_2.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_2.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_2.zmEvent","Name","text","INIT"],["z
                  zoneminder.0	2019-10-25 22:50:41.077	debug	(14437) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.
                  zoneminder.0	2019-10-25 22:50:41.071	debug	(14437) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],
                  zoneminder.0	2019-10-25 22:50:41.068	debug	(14437) Monitor_1 o.Monitor_Status = [object Object]
                  zoneminder.0	2019-10-25 22:50:41.068	debug	(14437) Monitor_1 o.Monitor = [object Object]
                  zoneminder.0	2019-10-25 22:50:41.059	debug	(14437) found states:_[["zoneminder.0.cam_1.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_1.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_1.zmEvent","Name","text","INIT"],["z
                  zoneminder.0	2019-10-25 22:50:41.044	debug	(14437) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.
                  zoneminder.0	2019-10-25 22:50:41.021	debug	(14437) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],
                  zoneminder.0	2019-10-25 22:50:41.019	debug	(14437) Monitor_0 o.Monitor_Status = [object Object]
                  zoneminder.0	2019-10-25 22:50:41.018	debug	(14437) Monitor_0 o.Monitor = [object Object]
                  zoneminder.0	2019-10-25 22:50:40.552	debug	(14437) REQUEST: Get data[object Object]
                  zoneminder.0	2019-10-25 22:50:40.518	debug	(14437) found states:_[["zoneminder.0.history.LastzmEvent","MonitorId","default_num","0"],["zoneminder.0.history.LastzmEvent","EventId","default_num","000"],["zoneminder.0.history.LastzmEvent","Name",
                  zoneminder.0	2019-10-25 22:50:40.504	debug	(14437) [{"Monitor":{"Id":"1","Name":"Garage","ServerId":null,"StorageId":"1","Type":"Ffmpeg","Function":"Modect","Enabled":"1","LinkedMonitors":null,"Triggers":"","Device":"/dev/video0","Channel":"0"
                  zoneminder.0	2019-10-25 22:50:40.502	debug	(14437) REQUEST: Get data[object Object]
                  zoneminder.0	2019-10-25 22:50:39.738	debug	(14437) zmEventServer disabled
                  zoneminder.0	2019-10-25 22:50:39.736	debug	(14437) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
                  zoneminder.0	2019-10-25 22:50:39.736	debug	(14437) REQUEST: Post before object
                  zoneminder.0	2019-10-25 22:50:39.735	debug	(14437) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
                  zoneminder.0	2019-10-25 22:50:39.734	debug	(14437) REQUEST: Post before object
                  zoneminder.0	2019-10-25 22:50:39.733	debug	(14437) Connected to Api
                  zoneminder.0	2019-10-25 22:50:39.732	debug	(14437) AUTH: get cookies null
                  zoneminder.0	2019-10-25 22:50:39.723	debug	(14437) REQUEST: Get data[object Object]
                  zoneminder.0	2019-10-25 22:50:38.666	info	(14437) check user admin pw ioboker: true
                  zoneminder.0	2019-10-25 22:50:38.023	info	(14437) undefined__testVariable___[object Object]
                  zoneminder.0	2019-10-25 22:50:37.988	info	(14437) check group user admin group admin: false
                  zoneminder.0	2019-10-25 22:50:37.804	debug	(14437) REQUEST: Options {"method":"POST","uri":"http://192.168.66.184/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-len
                  zoneminder.0	2019-10-25 22:50:37.802	debug	(14437) REQUEST: Post before object
                  zoneminder.0	2019-10-25 22:50:37.801	debug	(14437) data: {"user":"admin","password":"admin","host":"http://192.168.66.184/zm","zmEvent":false}
                  zoneminder.0	2019-10-25 22:50:37.692	info	(14437) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.16.3
                  Gibts irgendwo eine Anleitung von ZMEvent? Oder hast du es nach der ZMEvent Wiki Seite installiert?
                    mikiline
                    #109
                    @Meistertr
                    super das du dies versuchst zu integrieren daumenhoch
                    ist beides bei mir angehakt und es nutzt den token, also die 3. möglichkeit wie von dir beschrieben
                    mal sehen ob es klappt wenn es integriert ist. danke dir ;)
                    MeistertrM 1 Antwort Letzte Antwort
                    • M mikiline
                      @Meistertr
                      MeistertrM Offline
                      MeistertrM Offline
                      Meistertr
                      #110
                      @mikiline so ich hab jetzt alle 3 varianten drin aber scheinbar gibt es von der 1.30 bis 1.33 Probleme mit der API. ein endgültigen stand wird es erst mit der 1.34 geben die in naher Zukunft kommt.
                      Probier mal ob es nun klappt. un schick mal einen log
                        mikiline
                        #111
                        @Meistertr
                        Guten Morgen, soeben versucht. Adapter wird zwar grün, jedoch kommen folgende Meldungen
                        zoneminder.0	2019-10-27 08:02:06.521	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
                        zoneminder.0	2019-10-27 08:02:06.510	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
                        zoneminder.0	2019-10-27 08:02:06.510	debug	(12561) REQUEST: Post before string
                        zoneminder.0	2019-10-27 08:02:06.509	debug	(12561) SetStates
                        zoneminder.0	2019-10-27 08:02:01.526	warn	(12561) No monitors found, please configure monitors in your zoneminder!
                        zoneminder.0	2019-10-27 08:02:01.526	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
                        zoneminder.0	2019-10-27 08:02:01.508	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
                        zoneminder.0	2019-10-27 08:02:01.508	debug	(12561) REQUEST: Post before string
                        zoneminder.0	2019-10-27 08:02:01.508	debug	(12561) SetStates
                        zoneminder.0	2019-10-27 08:01:56.521	warn	(12561) No monitors found, please configure monitors in your zoneminder!
                        zoneminder.0	2019-10-27 08:01:56.521	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
                        zoneminder.0	2019-10-27 08:01:56.509	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
                        zoneminder.0	2019-10-27 08:01:56.508	debug	(12561) REQUEST: Post before string
                        zoneminder.0	2019-10-27 08:01:56.508	debug	(12561) SetStates
                        zoneminder.0	2019-10-27 08:01:51.522	warn	(12561) No monitors found, please configure monitors in your zoneminder!
                        zoneminder.0	2019-10-27 08:01:51.522	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
                        zoneminder.0	2019-10-27 08:01:51.508	debug	(12561) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMTU5NzA2LCJleHAiOjE1NzIxNj
                        zoneminder.0	2019-10-27 08:01:51.508	debug	(12561) REQUEST: Post before string
                        zoneminder.0	2019-10-27 08:01:51.508	debug	(12561) SetStates
                        zoneminder.0	2019-10-27 08:01:46.753	debug	(12561) WEBSOCKET: {"status":"Success","reason":"","version":"4.4","type":"","event":"auth"}'
                        zoneminder.0	2019-10-27 08:01:46.671	debug	(12561) WEBSOCKET Client Connected
                        zoneminder.0	2019-10-27 08:01:46.666	warn	(12561) No monitors found, please configure monitors in your zoneminder!
                        zoneminder.0	2019-10-27 08:01:46.665	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
                        zoneminder.0	2019-10-27 08:01:46.662	warn	(12561) No monitors found, please configure monitors in your zoneminder!
                        zoneminder.0	2019-10-27 08:01:46.662	debug	(12561) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fr
                        zoneminder.0	2019-10-27 08:01:46.647	debug	(12561) system.adapter.admin.0: logging true
                        zoneminder.0	2019-10-27 08:01:45.860	debug	(12561) States connected to redis: 127.0.0.1:9000
                        zoneminder.0	2019-10-27 08:01:45.810	debug	(12561) statesDB connected
                        zoneminder.0	2019-10-27 08:01:45.802	debug	(12561) Redis States: Use Redis connection: 127.0.0.1:9000
                        zoneminder.0	2019-10-27 08:01:45.801	debug	(12561) objectDB connected
                        zoneminder.0	2019-10-27 08:01:45.796	debug	(12561) Objects connected to redis: 127.0.0.1:9001
                        zoneminder.0	2019-10-27 08:01:45.744	debug	(12561) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        host.nuc-ubuntu	2019-10-27 08:01:45.078	info	instance system.adapter.zoneminder.0 started with pid 12561
                        host.nuc-ubuntu	2019-10-27 08:01:42.700	info	instance system.adapter.zoneminder.0 terminated with code 156 (156)
                        ich denke du solltest hier nicht deine Zeit "verschwenden" es scheint irgendwie nicht zu gehen und wir warten auf die 1.34
                        Trotz allem herzlichen Dank für die Mühe. Falls etwas benötigt wird zum Testen, gerne melden
                        • Lenny.CBL Lenny.CB
                          @Berchemer sagte in [Aufruf] Zoneminder 0.2.0 Testen:
                          Habe nämlich alles Kameras mit je einem High- und einem Low-Monitor eingestellt. Low-Monitor ist nur zur Bewegungserkennung bei bestimmten Kameras und High-Monitor für die dazugehörige Aufnahme nach Bewegungserkennung.
                          @Berchemer kannst Du das mal etwas näher ausführen? Besonders interessieren würde mich warum Du das so machst.
                          Was ich bis dato an den Einstellungen verstanden habe, werden bei Bewegungserkennung Bilder aufgenommen. Bei mir ist es momentan so, dass sich auf den Bildern/Videos "Schlieren" bilden. Also es scheint als würde ein Schatten der Bewegung in die nächsten Frame´s gezogen. Kann man das mit deiner Methode umgehen?
                          Deine Methode interpretiere ich so:
                          Im LOW-Monitor ist ein CAM-Stream mit schmaler Bandbreite/Qualität, dieser erkennt die Bewegung.
                          IM HIGH-Monitor ist ein CAM-Stream mit hoher Auflösung und unter "Linked Monitors" ist der LOW-Monitor eingetragen.
                          Wenn der LOW-Monitor eine Bewegung erkennt, wird der HIGH-Monitor angetriggert und nimmt auf.
                          Richtig?
                          Berchemer
                          #112
                          @Lenny-CB sagte in Test Adapter zoneminder v0.3.x:
                          Richtig?
                          Ja Lenny-CB. So ist es gedacht und funktioniert auch soweit ganz gut, weil ich auch Videoaufnahmen mit Sound haben möchte, wenn ein Event stattfindet und die Kamera auch Audio unterstützt.
                          Die LOW-Kamera nimmt den zweiten Stream der jeweiligen Kamera im Graustufenmodus und niedriger Auflösung zum Erkennen von Bewegung ind den definierten Zonen. Durch die Verknüpfung wird bei Bewegungserkennung der High-Monitor gestartet und nimmt die Szene im höheren ersten Stream der jeweiligen Kamera auf.
                          Der Low-Monitor ist mit MOCORD konfiguriert und der High-Monitor mit NODECT.
                          Somit brauche ich auch nur die Streams der HIGH-Monitore, die aufnehmen oder nur als MOTION eingestellt sind.
                          Und jetzt muss ich mich mal mit dem zmeventmanager beschäftigen, weil ich ja auch in ioBroker erkennen möchte, ob gerade ein Monitor einen Alarm meldet oder nicht. Obwohl das, wie ich verstanden habe über die normale API mit (curl http://server/zm/api/monitors/alarm/id:1/command:status.json) und ausgelesen werden könnte, wie in der ZM-Doku unter https://zoneminder.readthedocs.io/en/stable/api.html#arm-disarm-monitors beschrieben.
                          • B Berchemer
                            Richtig?
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #113
                            @Berchemer da hast du recht, das will ich auch noch einbauen , hier muss dann aber jede sekunde der wert aller monitore abgefragt werden. was etwas unwirtschaftlich ist. daher ist die lösung über zmevent besser.
                            B 1 Antwort Letzte Antwort
                            • XsevX Offline
                              XsevX Offline
                              Xsev
                              schrieb am zuletzt editiert von Xsev
                              #114
                              Bei mir läuft der neue Adpter soweit sehr gut, abgesehen von den Events die werden bei mir nicht aktualisiert und bei gesetzdem Häkchen im Adpater bekomme ich folgende Fehlermeldung: ZM Version 1.32.2
                              oneminder.0	2019-10-27 21:09:45.251	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                              host.Homeserver	2019-10-27 21:09:45.250	error	States 192.168.13.100:46216 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                              zoneminder.0	2019-10-27 21:08:45.249	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                              host.Homeserver	2019-10-27 21:08:45.249	error	States 192.168.13.100:45482 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                              web.0	2019-10-27 21:08:27.723	info	(26815) <==Disconnect system.user.admin from ::ffff:192.168.13.165 vis.0
                              web.0	2019-10-27 21:08:27.722	info	(26815) <==Disconnect system.user.admin from ::ffff:192.168.13.165 flot
                              zoneminder.0	2019-10-27 21:07:45.246	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                              host.Homeserver	2019-10-27 21:07:45.246	error	States 192.168.13.100:44740 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                              zoneminder.0	2019-10-27 21:06:45.244	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                              host.Homeserver	2019-10-27 21:06:45.243	error	States 192.168.13.100:44004 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                              zoneminder.0	2019-10-27 21:05:45.242	error	(29387) WEBSOCKET: Error: Error: Client network socket disconnected before secure TLS connection was established
                              host.Homeserver	2019-10-27 21:05:45.239	error	States 192.168.13.100:43244 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                              Ansonsten Top Arbeit!!
                              P.s. Kann mir jemand sagen wie ich die Funktion (Motion, Modect etc.) zum Umschalten, einfach in Vis bekomme als Drop Down oder Button?
                                djsirius
                                #115
                                @Meistertr
                                So, der Adapter ist auf 0.3.1 und der Login funktioniert!
                                Vielen Dank und super Arbeit! 👍
                                djsirius
                                • D djsirius
                                  @Meistertr
                                  mikiline
                                  #116
                                  @djsirius
                                  bei mir leider noch nicht....
                                  zoneminder.0	2019-10-29 09:36:23.341	warn	(4286) No monitors found, please configure monitors in your zoneminder!
                                  zoneminder.0	2019-10-29 09:36:23.341	debug	(4286) reposerrStatusCodeError: 404 - "<!DOCTYPE html>\n<html>\n<head>\n\t<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\" />\t<title>\n\t\tCakePHP: the rapid development php fra
                                  zoneminder.0	2019-10-29 09:36:23.330	debug	(4286) REQUEST: Options {"method":"GET","uri":"http://192.168.77.125/zm/api/monitors.json&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNTcyMzM4MTY4LCJleHAiOjE1NzIzNDE
                                  zoneminder.0	2019-10-29 09:36:23.329	debug	(4286) REQUEST: Post before string
                                  zoneminder.0	2019-10-29 09:36:23.329	debug	(4286) SetStates
                                    djsirius
                                    schrieb am zuletzt editiert von djsirius
                                    #117
                                    Mein Adapter geht zwar auf grün, aber das Log sagt mir auch "No monitors found, please configure monitors in your zoneminder!"
                                    djsirius
                                    • MeistertrM Offline
                                      MeistertrM Offline
                                      Meistertr
                                      #118
                                      @mikiline @djsirius aber die zmninja app geht ohne probleme?
                                      coyoteC M 2 Antworten Letzte Antwort
                                        coyoteC Offline
                                        coyoteC Offline
                                        coyote
                                        #119
                                        @Meistertr habe heute endlich zmeventnotification installiert und im Adapter aktiviert.
                                        Läuft scheinbar so wie es soll, Snap und Video URL werden angezeigt, History wird auch gefüllt.
                                        Danke👍
                                        Jetzt muss ich nur die Motion in Zoneminder mal noch anständig einstellen
                                        XsevX 1 Antwort Letzte Antwort
                                          mikiline
                                          #120
                                          @Meistertr
                                          ja, es läuft alles ohne Probleme. Nur die Anmeldung mit dem Adapter geht nicht.
                                          Eventnotification mit ZMNinja und alles geht auch einwandfrei
