  4. Test Adapter fb-checkpresence v0.1.x
    6.0k
fb-checkpresence adapter
346 Beiträge 30 Kommentatoren 73.7k Aufrufe 25 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    #221
    @afuerhoff
    auch mit 0.0.6 hat sich das Problem nicht verändert.
    Vielleicht hilft dir das Log etwas.
    Ist vom Start des Adapters!
    Es steht auch in Zeile 30 was mit error: Invalid date
    fb-checkpresence.0	2019-11-02 01:11:40.463	debug	state fb-checkpresence.0.Laura.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-red-bg mdui-state mdui-card">abwesend<
    fb-checkpresence.0	2019-11-02 01:11:40.462	debug	state fb-checkpresence.0.Laura.history changed: [{"Active":"false","Date":"01.11.YYYY 06:05:11"},{"Active":"false","Date":"02.11.YYYY 12:52:49"},{"Active":"true","Date":"02.11.YYYY 12:52:53"},{"Active
    fb-checkpresence.0	2019-11-02 01:11:40.459	debug	state fb-checkpresence.0.Laura.absent.sum_day changed: 55 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.457	debug	state fb-checkpresence.0.Laura.present.sum_day changed: 17 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.432	debug	state fb-checkpresence.0.presence changed: true (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.432	debug	state fb-checkpresence.0.presenceAll changed: true (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.432	debug	state fb-checkpresence.0.html changed: <table class="mdui-table"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>Lisi</td><td><div class="mdui-green-bg md
    fb-checkpresence.0	2019-11-02 01:11:40.432	debug	state fb-checkpresence.0.json changed: [{"Name":"Lisi","Active":"true","Kommt":"02.11.YYYY 12:52:53","Geht":"02.11.YYYY 12:52:49"},{"Name":"Laura","Active":"true","Kommt":"02.11.YYYY 01:03:01","Geht":
    fb-checkpresence.0	2019-11-02 01:11:40.432	debug	sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-11-02 01:11:40.432	debug	checkPresence first run
    fb-checkpresence.0	2019-11-02 01:11:40.431	debug	sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-11-02 01:11:40.397	debug	state fb-checkpresence.0.Laura.absent.since changed: 0 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.397	debug	state fb-checkpresence.0.Laura.present.since changed: 9 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.397	debug	state fb-checkpresence.0.Lisi.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-red-bg mdui-state mdui-card">abwesend</
    fb-checkpresence.0	2019-11-02 01:11:40.396	debug	state fb-checkpresence.0.Lisi.history changed: [{"Active":"false","Date":"01.11.YYYY 06:05:11"},{"Active":"true","Date":"02.11.YYYY 12:48:30"},{"Active":"false","Date":"02.11.YYYY 12:52:49"},{"Active"
    fb-checkpresence.0	2019-11-02 01:11:40.392	debug	state fb-checkpresence.0.Lisi.absent.sum_day changed: 48 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.386	debug	state fb-checkpresence.0.Lisi.present.sum_day changed: 24 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.372	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:B
    fb-checkpresence.0	2019-11-02 01:11:40.361	debug	sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-11-02 01:11:40.350	debug	sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-11-02 01:11:40.334	debug	state fb-checkpresence.0.Lisi.absent.since changed: 0 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.332	debug	state fb-checkpresence.0.Lisi.present.since changed: 19 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.323	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:B
    fb-checkpresence.0	2019-11-02 01:11:40.144	debug	state fb-checkpresence.0.Nega.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-red-bg mdui-state mdui-card">abwesend</
    fb-checkpresence.0	2019-11-02 01:11:40.144	debug	state fb-checkpresence.0.Nega.history changed: [{"Active":"false","Date":"01.11.YYYY 05:59:59"},{"Active":"true","Date":"02.11.YYYY 12:48:28"}] (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.142	debug	state fb-checkpresence.0.Nega.absent.sum_day changed: 48 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.138	debug	state fb-checkpresence.0.Nega.present.sum_day changed: 24 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.115	debug	sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-11-02 01:11:40.098	debug	sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-11-02 01:11:40.086	error	error: Invalid date
    fb-checkpresence.0	2019-11-02 01:11:40.079	debug	state fb-checkpresence.0.Nega.absent.since changed: 0 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.075	debug	state fb-checkpresence.0.Nega.present.since changed: 23 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.066	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:H
    fb-checkpresence.0	2019-11-02 01:11:40.051	debug	state fb-checkpresence.0.guest changed: false (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.049	debug	state fb-checkpresence.0.activeDevices changed: 44 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.049	debug	state fb-checkpresence.0.guest.count changed: 0 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.047	debug	state fb-checkpresence.0.guest.listJson changed: [] (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:40.043	debug	state fb-checkpresence.0.guest.listHtml changed: <table class="mdui-table"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></body></table> (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:39.603	debug	url: http://10.0.1.1:49000/devicehostlist.lua?sid=6274da6e70531621
    fb-checkpresence.0	2019-11-02 01:11:39.602	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:H
    fb-checkpresence.0	2019-11-02 01:11:39.570	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:H
    fb-checkpresence.0	2019-11-02 01:11:39.570	debug	state fb-checkpresence.0.info.lastUpdate changed: 2019-11-02T00:11:39.464Z (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:39.570	debug	state fb-checkpresence.0.info.connection changed: true (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:39.569	debug	state fb-checkpresence.0.devices changed: 77 (ack = true)
    fb-checkpresence.0	2019-11-02 01:11:39.549	debug	hostNo: 77
    fb-checkpresence.0	2019-11-02 01:11:39.547	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:B
    fb-checkpresence.0	2019-11-02 01:11:39.498	debug	sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-11-02 01:11:39.498	debug	createMemberObjects Laura
    fb-checkpresence.0	2019-11-02 01:11:39.498	debug	createMemberObjects Lisi
    fb-checkpresence.0	2019-11-02 01:11:39.498	debug	createMemberObjects Nega
    fb-checkpresence.0	2019-11-02 01:11:39.498	debug	createGlobalObjects
    fb-checkpresence.0	2019-11-02 01:11:39.497	info	start fb-checkpresence: ip-address: 10.0.1.1 polling interval: 1 (*/1 * * * *)
    fb-checkpresence.0	2019-11-02 01:11:39.352	info	starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.17.0
    fb-checkpresence.0	2019-11-02 01:11:35.765	info	cleaned everything up...
    fb-checkpresence.0	2019-11-02 01:11:35.755	info	cleaned everything up...
    ° Fixer ---> iob fix
    afuerhoffA 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      @afuerhoff
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      #222
      @Negalein
      Was für ein Datumsformat hast du eingestellt. Da scheint etwas nicht zu passen.
      • sigi234S sigi234
        @afuerhoff sagte in [Neuer Adapter] iobroker.fb-checkpresence:
        ich habe noch den Fehler bzgl. der html und json Tabellen behoben. Version 0.0.6 ist auf Github veröffentlicht.
        Datum Anzeige, kann man die ändern?
        Sat Nov 02 2019 00:35:00 GMT+0100 (Mitteleuropäische Normalzeit)
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #223
        @sigi234 sagte in [Neuer Adapter] iobroker.fb-checkpresence:
        Im Post 191 steht dazu etwas.
          @afuerhoff
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #224
          @Negalein sagte in [Neuer Adapter] iobroker.fb-checkpresence:
          @afuerhoff
          Laut Log werden Daten übertragen. Das Log passt aber nicht zum vorher geposteten Bild. Was ich schon mal hatte war, dass die Daten in ioBroker nicht aktualisiert angezeigt wurden. Hab die Url dann neu geladen.
          Mit dem Invalid Date kann ich im Moment noch nicht zuordnen.
          • afuerhoffA afuerhoff
            @Negalein
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #225
            dd.mm.YYYY hh:MM:ss
            Welche URL meinst du?
            afuerhoffA 1 Antwort Letzte Antwort
              dd.mm.YYYY hh:MM:ss
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              schrieb am zuletzt editiert von afuerhoff
              #226
              @Negalein
              im Date Format müssen die YYYY durch yyyy ersetzt werden.
              siehe auch hier https://www.npmjs.com/package/dateformat.
              Mit Url meinte ich die ioBroker Objekte Seite. Einfach mal neu laden.
                @Negalein
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #227
                @Negalein
                Ah ok. Ich habe YYYY genommen, da dies im Adapter auch als YYYY geschrieben aufscheint.
                Hab ich bestimmt schon 50x gemacht.
                • NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #228
                  @afuerhoff
                  Hab jetzt das Format auf dd.mm.yyyy hh:MM:ss geändert.
                  Der Error: Invalid Date bleibt bestehen (glaube ist entstanden, als fb-checkpresence.0.Nega.history neu angelegt wurde.
                  fb-checkpresence.0	2019-11-02 22:49:12.237	error	error: Invalid date
                  fb-checkpresence.0	2019-11-02 22:49:12.233	debug	state fb-checkpresence.0.Nega.comming changed: 2019-11-02T18:15:01.092Z (ack = true)
                  fb-checkpresence.0	2019-11-02 22:49:12.229	debug	state fb-checkpresence.0.Nega.absent.since changed: 0 (ack = true)
                  fb-checkpresence.0	2019-11-02 22:49:12.227	debug	state fb-checkpresence.0.Nega.present.since changed: 214 (ack = true)
                  Ich hab mal den kompletten Adapter gestoppt, fb-checkpresence.0.Nega gelöscht, Adapter neu gestartet.
                  Ändert auch nichts.
                  Komisch ist, dass in fb-checkpresence.0.Nega.history die Ausgabe zT stimmt.
                  FALSCH (um 12:48:28 war ich heute nicht daheim)
                  [{"Active":"false","Date":"01.11.2019 05:59:59"},{"Active":"true","Date":"02.11.2019 12:48:28"},
                  zT RICHTIG (um 9:34:00 bin auch abwesend geworden; aber nicht um 7:15:01 heim gekommen, sondern um 19:15)
                  {"Active":"false","Date":"02.11.2019 09:34:00"},{"Active":"true","Date":"02.11.2019 07:15:01"}]
                    @afuerhoff
                    Ändert auch nichts.
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #229
                    @Negalein
                    Im Datumsformat musst du hh gegen HH austauschen. Am Invalid Date bin ich dran. Hat mit der initialen Anlage eines Familienmitglieds zu tun.
                    Es hat dann noch kein Wechsel von Anwesend und Abwesend stattgefunden.
                      ich arbeite gerade an einem Adapter, der über die MAC-Adresse abfragt, ob das Device in der Fritzbox registriert ist. So kann man z.B. die Anwesenheit von Familienmitgliedern abfragen. Über den für jedes Familienmitglied angelegten Datenpunkt können dann z.B. Aktionen gesteuert werden.
                      Bitte testet den Adapter und gebt Feedback, ob bei euch alles stabil läuft.
                      Getestet habe ich den Adapter mit einer Fritzbox 7490.
                      Hier noch der Link: (ALT) ~~https://github.com/afuerhoff/ioBroker.checkpresence~~
                      (NEU) https://github.com/afuerhoff/ioBroker.fb-checkpresence
                      (NEU) Den Titel des Themas habe ich noch an den neuen Adapter Namen angepasst.
                      Hier mal zwei Bilder zum Konfigurationsdialog:
                      sigi234S Online
                      sigi234S Online
                      sigi234
                      #230
                      @afuerhoff
                      Hallo, wie kann ich das anpassen? (historyHtml)
                      Oder kann man für jedes Mitglied einen DP machen der nur Kommt und Geht als DP hat?
                      Ich brauche einfach nur
                      Kommt: 2.11.2019 15:10
                      Geht: 1.11.2019 20:15
                      Immer Daten sichern!
                      • sigi234S sigi234
                        @afuerhoff
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #231
                        @sigi234
                        Anpassen ist im Moment nicht vorgesehen. Ich hatte schon mal über eine Anpassung über den Konfigurationsdialog nachgedacht. Evtl. kannst du es per Javascript anpassen. Bei Änderung des Datenpunkts eine Formatierung laufen lassen und in einem neuen Datenpunkt speichern.
                          @Negalein
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #232
                          @Negalein
                          Ok, das hab ich geändert!
                          Am eigentlichen Problem hat sich trotz Abwesenheit und wieder Anwesenheit nichts geändert.
                          Problem ist aber eben nur, dass in fb-checkpresence.0.Nega kein true/false aufscheint.
                          In fb-checkpresence.0.Nega.history sieht man, dass kommen/gehen erkannt wird und auch aufgezeichnet wird.
                          • kxnK Offline
                            kxnK Offline
                            kxn
                            schrieb am zuletzt editiert von kxn
                            #233
                            Leider hast du @apollon77 Frage noch nicht beantwortet!
                            Hier mein Video mit dem TR-064 Adapter.
                            Vorallem braucht der kein extra Zeitplaner!
                            YouTube Video über Anwesenheit von kxn
                            • kxnK kxn
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #234
                              @kxn sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                              ???? welche Frage von Appollon?
                              Hast du dich eventuell im Thread vertan?
                              • apollon77A apollon77
                                @afuerhoff Hi, super einen neuen Entwickler willkommen heissen zu können.
                                Ich würde ich allerdings gern der Frage anschliessen was Dir an den bisherigen Adaptern die diese Funktion bereitstellen können (tr-064 bzw die community-variante macht exakt das was Dein Adapter tut und mehr darüber hinaus, radar2 liefert ähnlich Funktion etwas anders) nicht ausgereicht hat das dich dazu bewogen hat diesen Adapter zu entwickeln?
                                Ich gebe zu mit tr-064 gab es Probleme aber die neue Community-Version sollte das lösen und bietet ggf auch die Basis fehlende Features dort einzubauen. radar2 ist auch sehr Aktiv in Entwicklung.
                                Bitte versteh mich nicht falsch, ich würde nur deine Beweggründe besser verstehen. Wir sind immer daran interessiert neue Adapter zu haben und freuen uns auch immer über Zuwachs in der Entwicklerschaft, allerdings ist es auch wichtig das die vielen tausend ioBroker User es verstehen und mehrere Adapter für "das gleiche" sind schwierig.
                                Beim Namen bitte ich dich allerdings in jedem Fall nochmal zu ändern: Der Adapter funktioniert nur für die Fritzbox, das wird im Namen aber nicht klar und sorgt damit für falsche Erwartungen. Bitte berücksichtige das im Namen ... Es sei denn dein Plan ist ein "allumfassender Presenzerkennungs-Adapter" (das ist eine Mega Challenge) ... :-)
                                Danke, Ingo
                                kxnK Offline
                                kxnK Offline
                                kxn
                                #235
                                @apollon77 said in [Neuer Adapter] iobroker.fb-checkpresence:
                                Danke, Ingo
                                Diesen Post meinte ich.
                                • kxnK kxn
                                  Danke, Ingo
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #236
                                  und etwas weiter unten findest du die Antwort von @afuerhoff an @apollon77
                                  Hallo Ingo,
                                  erstmal allen ioBroker Machern ein dickes Lob für das was sie geschaffen haben. Hut ab.
                                  Ich habe nach einiger Zeit der Anwendung von ioBroker mir die Frage gestellt, wie aufwändig ist eigentlich die Entwicklung eines eigenen Adapters. Da ich mich noch nie im Vorfeld mit Javascript beschäftigt hatte wollte ich erstmal einen einfachen Adapter entwickeln. Die eigentliche Funktion hatte ich schon auf der CCU2 als script am Laufen. Ich denke, die Neugierde auf etwas Neues und Spaß am programmieren ist der einzige Grund zur Entwicklung dieses Adapters.
                                  Die Lösung ist, wie du beschrieben hast, auf die Fritzbox zugeschnitten. Den Namen werde ich noch ändern und den Radar2 Adapter muss ich mir mal anschauen.
                                  Es gibt immer viele Wege zum Ziel. Wichtig ist aus meiner Sicht, das man die Möglichkeit hat, diese Wege auch auszuprobieren, was mit ioBroker auch super gegeben ist. Es muss ja nicht jeder neue Adapter auch offiziell übernommen werden. Das wäre nicht mein Anspruch.
                                  Danke für das Feedback, Achim
                                  kxnK 1 Antwort Letzte Antwort
                                    Hallo Ingo,
                                    kxnK Offline
                                    kxnK Offline
                                    kxn
                                    #237
                                    @Negalein Sorry hab ich micht gewusst das apollon77 Ingo heißt und daum dieses nicht als Antwort erkannt.
                                    👍 weiter so
                                    • afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #238
                                      Hallo, ich habe gerade Version 0.0.7 veröffentlicht.
                                      Änderungen:
                                      • Invalid Date Fehler behoben. Es werden jetzt beim ersten Anlegen der Objekte comming und going die States auf das aktuelle Datum gesetzt.
                                      • Falls ein Member nicht auf true oder false steht, sollte jetzt der Wert richtig gesetzt werden.
                                      • Debug Informationen hinzugefügt
                                        Änderungen:
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #239
                                        habe ich gerade installiert! Danke für das schnelle Update! :)
                                        bis jetzt nicht mehr aufgetreten! :)
                                        Welcher Wert ist da gemeint?
                                        Denn, bei einem Member hab ich weder true noch false.
                                        Ich hab bevor ich 0.0.7 installiert habe, den ganzen fb-checkpresence.0 Baum gelöscht.
                                        0.0.7 installiert, mit dem Button "aus Liste hinzufügen" 3 Member hinzugefügt. Bis 0.0.6 funktionierte der Button nicht. Jetzt klappt das super.
                                        Alle 3 Member wurden gleich in den Objekten angelegt.
                                        Bei fb-checkpresence.0.Handy-Nega und fb-checkpresence.0.Handy-Lisi ist auch gleich true erschienen.
                                        Nur bei fb-checkpresence.0.Handy-Laura steht weder true noch false dort.
                                        Aber die History passt trotzdem.
                                        Was könnte ich noch testen, bzw. was wäre dir zur Ursachenforschung hilfreich?
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #240
                                          @Negalein
                                          Kannst du die Instanz mal auf debug stellen und den Log posten.
