7.5k Beiträge 335 Kommentatoren 11.5m Aufrufe 254 Beobachtet
    @simatec
    2021-11-09 16:25:32.804 - debug: shuttercontrol.0 (12762) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: true
    2021-11-09 16:25:32.817 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter conversion is:false
    2021-11-09 16:25:32.866 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger drive-up is:35
    2021-11-09 16:25:32.867 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger change is:upDown
    2021-11-09 16:25:32.867 - debug: shuttercontrol.0 (12762) #1 save trigger height: 0% for device Wohnzimmer Klein
    2021-11-09 16:25:32.868 - debug: shuttercontrol.0 (12762) #1 save trigger action: Manu_Mode for device Wohnzimmer Klein
    2021-11-09 16:25:32.869 - info: shuttercontrol.0 (12762) #1 Set ID: Wohnzimmer Klein value: 35%
    2021-11-09 16:25:32.918 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - window is still open -> driving now to :35
    2021-11-09 16:25:32.940 - debug: shuttercontrol.0 (12762) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
    2021-11-09 16:25:32.941 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
    2021-11-09 16:25:33.305 - debug: shuttercontrol.0 (12762) Brightness sensor value: 721
    2021-11-09 16:25:33.306 - debug: shuttercontrol.0 (12762) Lightsensor changed: zigbee.0.04cf8cdf3c7cc445.illuminance Value: 721
    2021-11-09 16:25:33.329 - debug: shuttercontrol.0 (12762) Brightness sensor value: 721
    2021-11-09 16:25:33.329 - debug: shuttercontrol.0 (12762) Lightsensor changed: zigbee.0.04cf8cdf3c7cc445.illuminance Value: 721
    2021-11-09 16:25:33.983 - debug: shuttercontrol.0 (12762) save current height after State Check: 0% from Wohnzimmer Klein
    2021-11-09 16:25:33.984 - debug: shuttercontrol.0 (12762) Shutter Wohnzimmer Klein was moved manually to: 0% while window was open - prevent trigger from driving back
    2021-11-09 16:25:39.846 - debug: shuttercontrol.0 (12762) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
    2021-11-09 16:25:39.847 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein drived manually to 35. Old value = 0. New value = 35
    2021-11-09 16:25:39.848 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein Updated trigger action to Manu_Mode to prevent moving after window close
    2021-11-09 16:25:40.853 - debug: shuttercontrol.0 (12762) save current height after State Check: 35% from Wohnzimmer Klein
    2021-11-09 16:25:40.854 - debug: shuttercontrol.0 (12762) Shutter Wohnzimmer Klein was moved manually to: 35% while window was open - prevent trigger from driving back
    2021-11-09 16:25:46.078 - debug: shuttercontrol.0 (12762) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: false
    2021-11-09 16:25:46.085 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter conversion is:false
    2021-11-09 16:25:46.131 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter current state.val is:35
    2021-11-09 16:25:46.132 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter current Height is:35
    2021-11-09 16:25:46.133 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger Height is:35
    2021-11-09 16:25:46.133 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger Action is:Manu_Mode
    2021-11-09 16:25:46.134 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter trigger Change is:upDown
    2021-11-09 16:25:46.135 - debug: shuttercontrol.0 (12762) #1 shutter trigger released Wohnzimmer Klein already in place: 35%
    2021-11-09 16:25:46.135 - debug: shuttercontrol.0 (12762) save back trigger action: Manu_Mode for device Wohnzimmer Klein
    Mod-Edit: Code in </> Code-Tag gepackt!
    simatecS Offline
    simatecS Offline
    simatec
    #3821
    @noah3112
    Und wo ist der Log für das schließen?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      @noah3112
      #3822
      @simatec sagte in Test Adapter shuttercontrol v1.3.x:
      ist es nicht das?
      opened=false
      @noah3112 sagte in Test Adapter shuttercontrol v1.3.x:
      ? 2 Antworten Letzte Antwort
        ist es nicht das?
        opened=false
        #3823
        @homoran Sorry aber ich kann nicht mehr folgen. Alles mal ganz langsam und zum verstehen. Mit den Einstellungen und den gleichen Sensoren bin ich von der Version 1.2.1 auf die Version 1.3.2 bzw jetzt auf 1.3.3. Was hat sich den grundsätzlich geändert das ich jetzt einen Fehler in meiner Einstellung bzw Sensorik suchen muss? Wie gesagt das gleiche Verhalten bei weiteren 12 Rollos. Die Aktoren sind übrigens Shellys 2.5. Bin nur Anwender und ganz leicht überfordert.
          ist es nicht das?
          opened=false
          #3824
          @homoran Bin gerade nochmal zurück auf Version 1.2.1 und es funzt wieder alles. Ist mir echt zu hoch...
            #3825
            das nutzt uns aber nichts wenn wir den "Bug" finden wollen
            war auch nicht für dich sondern für @simatec
            ? 1 Antwort Letzte Antwort
              #3826
              @homoran Bin gerade mal dran einen Log von der Version 1.2.1 zu erstellen. Uno momento...
                #3827
                das brauchen wir nicht - der "Bug" soll doch in der neuen Version drin sein
                  #3828
                  @homoran Aber vielleicht hilft es ja....
                  2021-11-09 18:23:52.550 - debug: shuttercontrol.0 (22409) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: true
                  2021-11-09 18:23:52.557 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter conversion is:false
                  2021-11-09 18:23:52.607 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger drive-up is:35
                  2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger change is:upDown
                  2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) #1 save trigger height: 0% for device Wohnzimmer Klein
                  2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) #1 save trigger action: down for device Wohnzimmer Klein
                  2021-11-09 18:23:52.609 - info: shuttercontrol.0 (22409) #1 Set ID: Wohnzimmer Klein value: 35%
                  2021-11-09 18:23:52.657 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - window is still open -> driving now to :35
                  2021-11-09 18:23:52.674 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
                  2021-11-09 18:23:52.675 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
                  2021-11-09 18:23:59.731 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
                  2021-11-09 18:23:59.732 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
                  2021-11-09 18:24:07.162 - debug: shuttercontrol.0 (22409) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: false
                  2021-11-09 18:24:07.164 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter conversion is:false
                  2021-11-09 18:24:07.211 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter current state.val is:35
                  2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter current Height is:35
                  2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Height is:0
                  2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Action is:down
                  2021-11-09 18:24:07.213 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Change is:upDown
                  2021-11-09 18:24:07.213 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Action is:35
                  2021-11-09 18:24:07.261 - info: shuttercontrol.0 (22409) Window is still closed -> drive to last height: 0% for device: Wohnzimmer Klein
                  2021-11-09 18:24:07.262 - debug: shuttercontrol.0 (22409) save back trigger action: down for device: Wohnzimmer Klein
                  2021-11-09 18:24:07.312 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 0. automatic is active
                  2021-11-09 18:24:07.314 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
                  2021-11-09 18:24:07.315 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein drived manually to 35. Old value = 0. New value = 35
                  2021-11-09 18:24:07.315 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-11-09 18:24:14.151 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 0. automatic is active
                    simatecS Offline
                    simatecS Offline
                    simatec
                    schrieb am zuletzt editiert von simatec
                    #3829
                    Set ID
                    Aber auch hier sehe ich nicht, dass dein Rollladen wieder runterfährt.
                    Da müsste „ Set ID“ im Log dann zweimal sein.
                    Für die Config mit einem reinen Fensterkontakt ohne Kippstellung hat sich nix geändert.
                    Bitte poste doch mal deine komplette Config als json File.
                    Kannst du im Adapter Menü über die Pfeile runterladen.
                    So wie du in meinem Gif gesehen hast, habe ich nix anderes gemacht, als den Fensterkontakt von false auf true (Rollladen geht auf 35%) und danach wieder auf false (Rollladen schließt auf 0%).
                    Was geht denn bei dir nicht?
                    Ich hatte doch genau deine Config übernommen und die exakt identische Version getestet.
                    Kann es sein, dass deine shellys eventuell den Wert nochmal ändern und du nach x Sekunden eine erneute Statusabfrage in shuttercontrol aktivieren musst.
                    Wie gesagt, zeige mal die Config.
                    • simatecS simatec
                      Set ID
                      #3830
                      @simatec Meinst du dieses Menü?
                      Wenn ja wo finde ich die heruntergeladene Datei?
                      Bin ich hier richtig?
                      • BostilB Offline
                        BostilB Offline
                        Bostil
                        schrieb am zuletzt editiert von Bostil
                        #3831
                        Möchte es nicht mal bug nennen, hatte aber folgendes Problem: für das Herunterfahren per Lichtsensor bei Unterschreiten eines Schwellenwertes hatte ich schon länger einen Sensor definiert, der keine Daten mehr lieferte (disconnected). Jedes Mal wenn ich "auto_all" anwählte fuhren alle Rolladen herunter. Habe nun den Sensor entfernt und hoffe, dass dies die Problemlösung ist.
                        BostilB 1 Antwort Letzte Antwort
                        • Jens16J Offline
                          Jens16J Offline
                          Jens16
                          #3832
                          Unter Instanzen Shuttercontrol rechts oben die Pfeile
                          • Jens16J Jens16
                            #3833
                            @jens16 Gefunden Danke :-)
                            • simatecS simatec
                              Set ID
                              #3834
                              @simatec system.adapter.shuttercontrol.0.json
                              Ich hoffe das hilft weiter...
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #3835
                                @noah3112
                                Jetzt mache mal das Fenster auf und schaue, was für ein Wert in dem shelly Objekt steht.
                                • simatecS simatec
                                  @noah3112
                                  #3836
                                  • simatecS simatec
                                    @noah3112
                                    #3837
                                    @simatec Das Rollo ist gerade geschlossen.
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #3838
                                      @noah3112
                                      Bitte im offenen Zustand
                                      • simatecS simatec
                                        @noah3112
                                        #3839
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #3840
                                          @noah3112
                                          Ich verstehe nicht was du da machst. Laut deinen Einstellungen muss der Rollladen bei geöffnetem Fenster auf 35% stehen
                                          HomoranH ? 4 Antworten Letzte Antwort
