    @homoran Aber vielleicht hilft es ja....
    2021-11-09 18:23:52.550 - debug: shuttercontrol.0 (22409) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: true
    2021-11-09 18:23:52.557 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter conversion is:false
    2021-11-09 18:23:52.607 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger drive-up is:35
    2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger change is:upDown
    2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) #1 save trigger height: 0% for device Wohnzimmer Klein
    2021-11-09 18:23:52.608 - debug: shuttercontrol.0 (22409) #1 save trigger action: down for device Wohnzimmer Klein
    2021-11-09 18:23:52.609 - info: shuttercontrol.0 (22409) #1 Set ID: Wohnzimmer Klein value: 35%
    2021-11-09 18:23:52.657 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - window is still open -> driving now to :35
    2021-11-09 18:23:52.674 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
    2021-11-09 18:23:52.675 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
    2021-11-09 18:23:59.731 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
    2021-11-09 18:23:59.732 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 35. automatic is active
    2021-11-09 18:24:07.162 - debug: shuttercontrol.0 (22409) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: false
    2021-11-09 18:24:07.164 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter conversion is:false
    2021-11-09 18:24:07.211 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter current state.val is:35
    2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter current Height is:35
    2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Height is:0
    2021-11-09 18:24:07.212 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Action is:down
    2021-11-09 18:24:07.213 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Change is:upDown
    2021-11-09 18:24:07.213 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein - shutter trigger Action is:35
    2021-11-09 18:24:07.261 - info: shuttercontrol.0 (22409) Window is still closed -> drive to last height: 0% for device: Wohnzimmer Klein
    2021-11-09 18:24:07.262 - debug: shuttercontrol.0 (22409) save back trigger action: down for device: Wohnzimmer Klein
    2021-11-09 18:24:07.312 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 0. automatic is active
    2021-11-09 18:24:07.314 - debug: shuttercontrol.0 (22409) Shutter state changed: Wohnzimmer Klein old value = 0 new value = 35
    2021-11-09 18:24:07.315 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein drived manually to 35. Old value = 0. New value = 35
    2021-11-09 18:24:07.315 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Updated trigger action to Manu_Mode to prevent moving after window close
    2021-11-09 18:24:14.151 - debug: shuttercontrol.0 (22409) Wohnzimmer Klein Old value = 0. New value = 0. automatic is active
    simatecS Offline
    simatecS Offline
    simatec
    #3829
    @noah3112 sagte in Test Adapter shuttercontrol v1.3.x:
    Set ID
    Aber auch hier sehe ich nicht, dass dein Rollladen wieder runterfährt.
    Da müsste „ Set ID“ im Log dann zweimal sein.
    Für die Config mit einem reinen Fensterkontakt ohne Kippstellung hat sich nix geändert.
    Bitte poste doch mal deine komplette Config als json File.
    Kannst du im Adapter Menü über die Pfeile runterladen.
    So wie du in meinem Gif gesehen hast, habe ich nix anderes gemacht, als den Fensterkontakt von false auf true (Rollladen geht auf 35%) und danach wieder auf false (Rollladen schließt auf 0%).
    Was geht denn bei dir nicht?
    Ich hatte doch genau deine Config übernommen und die exakt identische Version getestet.
    Kann es sein, dass deine shellys eventuell den Wert nochmal ändern und du nach x Sekunden eine erneute Statusabfrage in shuttercontrol aktivieren musst.
    Wie gesagt, zeige mal die Config.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    ? 2 Antworten Letzte Antwort
    • simatecS simatec
      Set ID
      #3830
      @simatec Meinst du dieses Menü?
      Wenn ja wo finde ich die heruntergeladene Datei?
      Bin ich hier richtig?
      • BostilB Offline
        BostilB Offline
        Bostil
        schrieb am zuletzt editiert von Bostil
        #3831
        Möchte es nicht mal bug nennen, hatte aber folgendes Problem: für das Herunterfahren per Lichtsensor bei Unterschreiten eines Schwellenwertes hatte ich schon länger einen Sensor definiert, der keine Daten mehr lieferte (disconnected). Jedes Mal wenn ich "auto_all" anwählte fuhren alle Rolladen herunter. Habe nun den Sensor entfernt und hoffe, dass dies die Problemlösung ist.
        BostilB 1 Antwort Letzte Antwort
        • Jens16J Offline
          Jens16J Offline
          Jens16
          #3832
          Unter Instanzen Shuttercontrol rechts oben die Pfeile
          • Jens16J Jens16
            #3833
            @jens16 Gefunden Danke :-)
            • simatecS simatec
              Set ID
              #3834
              @simatec system.adapter.shuttercontrol.0.json
              Ich hoffe das hilft weiter...
                simatecS Offline
                simatecS Offline
                simatec
                #3835
                @noah3112
                Jetzt mache mal das Fenster auf und schaue, was für ein Wert in dem shelly Objekt steht.
                • simatecS simatec
                  @noah3112
                  #3836
                  • simatecS simatec
                    @noah3112
                    #3837
                    @simatec Das Rollo ist gerade geschlossen.
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #3838
                      @noah3112
                      Bitte im offenen Zustand
                      • simatecS simatec
                        @noah3112
                        #3839
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #3840
                          @noah3112
                          Ich verstehe nicht was du da machst. Laut deinen Einstellungen muss der Rollladen bei geöffnetem Fenster auf 35% stehen
                          HomoranH ? 4 Antworten Letzte Antwort
                          • simatecS simatec
                            @noah3112
                            #3841
                            @simatec sagte in Test Adapter shuttercontrol v1.3.x:
                            @noah3112
                            Laut seiner Aussage klappt das ja auch mit der alten und der neuen Version, nur mit der neuen zurück nicht mehr
                            @simatec Das auffahren auf 35% funktioniert. Leider passiert nichts wenn ich das Fenster wieder schließe.
                            • simatecS simatec
                              @noah3112
                              #3842
                              @simatec Ach falsch verstanden ich hab das Teil einfach einmal hoch bzw runter gefahren. Sorry mein Fehler. Kommt gleich...
                              • simatecS simatec
                                @noah3112
                                #3843
                                @simatec Fenster geöffnet...
                                • simatecS simatec
                                  @noah3112
                                  #3844
                                  @simatec Keine Veränderung beim schließen...
                                    #3845
                                    dann funktioniert nichts mehr!
                                    manuelles Verstellen schaltet die Automatik aus
                                      #3846
                                      @homoran Verstehe ich nicht. Ich muss zB im Badezimmer nach dem duschen das Fenster ankippen um die Feuchtigkeit zu reduzieren. Ich mach das Fenster wieder zu und die Rollos fuhren bis jetzt automatisch wieder zu ohne die "Automatik" zu beeinflussen. Oder habe ich jetzt deinen Kommentar falsch verstanden?
                                      HomoranH simatecS 2 Antworten Letzte Antwort
                                        #3847
                                        ja!
                                        das ist korrekt!
                                        ABER.. Wenn du
                                        hast, ist das ein manueller Eingriff, der die weitere Automatik ausschaltet
                                        danach befindet sich dein Rolladen im manuMode
                                        Nachzusehen unter
                                        shuttercontrol.0.shutters.autoState
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #3848
                                          @noah3112
                                          Ich glaube wir reden aneinander vorbei.
                                          Jetzt mache mal folgendes…
                                          Öffne das Fenster warte dann mal etwas länger als eine Minute und schließe es wieder.
                                          Und genau diesen Log von beiden Aktionen bitte posten
                                          ? HomoranH 3 Antworten Letzte Antwort
