  4. INTEL NUC Kit NUC8i5BEK Proxmox+Debian VM kein Onboard BT
189 Beiträge 18 Kommentatoren 32.6k Aufrufe 10 Beobachtet
    Superdad
    #141
    Ausgabe von dmesg in Proxmox.
    root@pve:~# dmesg | grep tooth
    [    5.428947] Bluetooth: Core ver 2.22
    [    5.428965] Bluetooth: HCI device and connection manager initialized
    [    5.428995] Bluetooth: HCI socket layer initialized
    [    5.428999] Bluetooth: L2CAP socket layer initialized
    [    5.429003] Bluetooth: SCO socket layer initialized
    [    5.433876] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [    8.031647] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    8.031649] Bluetooth: BNEP filters: protocol multicast
    [    8.031652] Bluetooth: BNEP socket layer initialized
    [   12.070350] Bluetooth: hci0: urb 000000008df1e450 failed to resubmit (2)
    [  164.403866] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [  256.967089] Bluetooth: hci0: urb 000000003ff3f2ed failed to resubmit (2)
    [  930.768975] Modules linked in: tcp_diag inet_diag nfsv3 nfs_acl nfs lockd grace fscache veth ip_set ip6table_filter ip6_tables iptable_filter cmac bnep softdog nfnetlink_log nfnetlink nls_iso8859_1 dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c snd_hda_codec_hdmi intel_rapl x86_pkg_temp_thermal intel_powerclamp coretemp snd_hda_codec_realtek snd_hda_codec_generic kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel aes_x86_64 crypto_simd glue_helper cryptd snd_soc_skl snd_soc_skl_ipc snd_hda_ext_core snd_soc_sst_dsp snd_soc_sst_ipc snd_soc_acpi i915 snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine wmi_bmof intel_wmi_thunderbolt drm_kms_helper drm intel_cstate i2c_algo_bit fb_sys_fops btusb btrtl btbcm btintel iwlmvm bluetooth mac80211 rtsx_pci_ms
    [ 2094.425954] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 2195.809396] Bluetooth: hci0: urb 00000000f2205b5e failed to resubmit (2)
    [ 4613.078873] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 4616.769724] Bluetooth: hci0: urb 000000001b52b7b8 failed to resubmit (2)
    [ 4767.795902] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9174.243886] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9177.776850] Bluetooth: hci0: urb 00000000dc56a48b failed to resubmit (2)
    [ 9262.249870] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9290.733310] Bluetooth: hci0: urb 000000002a962bfd failed to resubmit (2)
    [ 9586.752868] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9607.213728] Bluetooth: hci0: urb 00000000c3d97bb3 failed to resubmit (2)
    [10153.768841] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [10253.982889] Bluetooth: hci0: urb 00000000fc0a1aee failed to resubmit (2)
    [11506.075844] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [11561.341543] Bluetooth: hci0: urb 000000006e2e8cd1 failed to resubmit (2)
    [12533.847878] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [12536.773457] Bluetooth: hci0: urb 000000006e2719f4 failed to resubmit (2)
    CCU3
    iOBroker auf IntelNUC Proxmox
    unltdnetworxU 1 Antwort Letzte Antwort
      Superdad
      #142
      root@iOBrokerNUC:~# rfkill list
      -bash: rfkill: Kommando nicht gefunden.
      CCU3
      • S Superdad
        unltdnetworxU Offline
        unltdnetworx
        #143
        @Superdad
        Ich hoffe ohne die 17-2??!
        Gruß, Michael
        Weitere Infos im Profil.
        Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
          Superdad
          schrieb am zuletzt editiert von Superdad
          #144
          Muss ich schauen.
          Ups! Die waren drin.
          Habs sie jetzt rausgenommen und neu rebootet.
          CCU3
          • S Superdad
            Muss ich schauen.
            crunchipC Offline
            crunchipC Offline
            #145
            @Superdad na sieht nicht so aus, da stimmt was nicht mit deiner Firmware...so kann auch nix in IoBroker laufen
            • unltdnetworxU Offline
              unltdnetworx
              #146
              Ich tippe darauf, dass die 17-2 Version drin ist. Die hat wie bereits geschrieben nicht funktioniert.
              Gruß, Michael
                Superdad
                #147
                Habe jetzt alle 17er drin gelassen, außer die 17-2er.
                Rebootet und ble bleibt trotzdem gelb.
                CCU3
                  Superdad
                  #148
                  Das kommt bei gestoppter VM:
                  root@pve:~# dmesg |grep iwlwifi
                  [    5.096398] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
                  [    5.120563] iwlwifi 0000:00:14.3: loaded firmware version 34.3125811985.0 op_mode iwlmvm
                  [    5.183248] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
                  [    5.349523] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
                  [    5.349531] iwlwifi 0000:00:14.3: Not valid error log pointer 0x00000000 for Init uCode
                  [    5.349568] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x3, CPU2 Status: 0x2458
                  [    5.349571] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -5
                  [    5.361808] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
                  [  405.231295]  fb_sys_fops zavl(PO) iwlwifi snd_hda_codec syscopyarea intel_rapl_perf memstick ecdh_generic sysfillrect icp(PO) sysimgblt snd_hda_core wmi_bmof mei_me intel_wmi_thunderbolt snd_hwdep mei snd_pcm snd_timer snd cfg80211 soundcore pcspkr intel_pch_thermal shpchp wmi video mac_hid acpi_pad zcommon(PO) znvpair(PO) spl(O) vhost_net vhost tap ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi sunrpc ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq rtsx_pci_sdmmc e1000e(O) ptp pps_core i2c_i801 rtsx_pci ahci libahci
                  und
                  root@pve:~# lsusb -t
                  /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 10000M
                  /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
                      |__ Port 10: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M
                      |__ Port 10: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M
                  CCU3
                  • S Superdad
                    crunchipC Offline
                    crunchipC Offline
                    #149
                    @Superdad lösch mal dein durchgereichtes Bluetooth Gerät in der VM und beende diese
                    dann schaust auf deinem Host
                    hciconfig -a
                    und dann
                    hciconfig hci0 up
                      Superdad
                      #150
                      root@pve:~# hciconfig -a
                      hci0:   Type: Primary  Bus: USB
                              BD Address: D8:F2:CA:31:D5:2A  ACL MTU: 1021:4  SCO MTU: 96:6
                              UP RUNNING
                              RX bytes:745 acl:0 sco:0 events:51 errors:0
                              TX bytes:2187 acl:0 sco:0 commands:51 errors:0
                              Features: 0xbf 0xfe 0x0f 0xfe 0xdb 0xff 0x7b 0x87
                              Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
                              Link policy: RSWITCH SNIFF
                              Link mode: SLAVE ACCEPT
                              Class: 0x000104
                              Service Classes: Unspecified
                              Device Class: Computer, Desktop workstation
                              HCI Version:  (0x9)  Revision: 0x100
                              LMP Version:  (0x9)  Subversion: 0x100
                              Manufacturer: Intel Corp. (2)
                      root@pve:~# hciconfig hci0 up
                      root@pve:~#
                      CCU3
                      • S Superdad
                                UP RUNNING
                                Class: 0x000104
                        root@pve:~#
                        unltdnetworx
                        #151
                        @Superdad
                        Auch im Host keine 17-2?
                        Gruß, Michael
                        • S Superdad
                          und
                          crunchipC Offline
                          crunchipC Offline
                          #152
                          @Superdad sagte in INTEL NUC Kit NUC8i5BEK Proxmox+Debian VM kein Onboard BT:
                          im Netz hab ich was von einer
                          Firmware-Version 46.3
                          gelesen
                            Superdad
                            #153
                            Ich habe die Dateien nur im Host.
                            Im iobroker (VM) gibt es ja keinen Firmware-Ordner.
                            CCU3
                            • unltdnetworxU unltdnetworx
                              @Superdad
                              crunchipC Offline
                              crunchipC Offline
                              #154
                              @unltdnetworx nein, raus damit
                                Superdad
                                #155
                                Die sind ja raus im Host.
                                CCU3
                                  unltdnetworx
                                  #156
                                  Die Ordner mal erstellen?
                                  Gruß, Michael
                                    crunchipC Offline
                                    crunchipC Offline
                                    #157
                                    @unltdnetworx nö
                                      @unltdnetworx nö
                                      unltdnetworx
                                      #158
                                      @crunchip
                                      War nur eine Idee. Wie gesagt, Ubuntu und grün
                                      Gruß, Michael
                                        Superdad
                                        #159
                                        Das kommt in der VM:
                                        root@iOBrokerNUC:~# lsusb -t
                                        /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
                                        /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                        /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                        /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                            |__ Port 1: Dev 2, If 0, Class=Wireless, Driver=, 12M
                                            |__ Port 1: Dev 2, If 1, Class=Wireless, Driver=, 12M
                                        /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                            |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                                        CCU3
                                        • S Superdad
                                          crunchipC Offline
                                          crunchipC Offline
                                          #160
                                          @Superdad was zeigt auf der VM
                                          hciconfig dev
