  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.9k Aufrufe 153 Beobachtet
  • B Bockwurst19
    @tombox Danke für den Tipp.
    Verbindung ist aufgebaut.
    jetzt habe Ich diese Meldung im Log
    homeconnect.0
    2022-10-09 08:16:05.348 error Start relogin in 10min
    homeconnect.0
    2022-10-09 08:16:05.347 error {"error":"invalid_client","error_description":"client has limited user list - user not assigned to client"}
    homeconnect.0
    2022-10-09 08:16:05.345 error AxiosError: Request failed with status code 401
    homeconnect.0
    2022-10-09 08:16:05.343 error refresh token failed
    homeconnect.0
    2022-10-09 08:16:05.254 info Token abgelaufen
    homeconnect.0
    2022-10-09 08:16:05.252 error Start Event Stream Error: {"type":"error","status":401,"message":"Unauthorized"}
    homeconnect.0
    2022-10-09 08:16:05.250 error 401 Unauthorized
    homeconnect.0
    2022-10-09 08:16:05.182 error {"error":{"key":"invalid_token","description":"The access token expired"}}
    homeconnect.0
    2022-10-09 08:16:05.180 error AxiosError: Request failed with status code 401
    homeconnect.0
    2022-10-09 08:16:05.103 error Start relogin in 10min
    homeconnect.0
    2022-10-09 08:16:05.101 error {"error":"invalid_client","error_description":"client has limited user list - user not assigned to client"}
    homeconnect.0
    2022-10-09 08:16:05.100 error AxiosError: Request failed with status code 401
    homeconnect.0
    2022-10-09 08:16:05.097 error refresh token failed
    tombox
    #881
    @bockwurst19 Sehr eigenartig würde ich den auth Ordner löschen und erneut probieren
    B 1 Antwort Letzte Antwort
    • T tombox
      @bockwurst19 Bitte die GitHub version probieren da ist das gelöst mit singlekey login
      sigi234S Online
      sigi234S Online
      sigi234
      #882
      @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
      Läuft bei mir einwandfrei! 👍
      host.Medion
      2022-10-09 09:21:29.357	info	instance system.adapter.homeconnect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      homeconnect.0
      2022-10-09 09:21:35.022	info	401010522278007458/programs/active: There is no program active.
      homeconnect.0
      2022-10-09 09:21:34.146	info	401010522278007458/programs/active/options: There is no program active.
      homeconnect.0
      2022-10-09 09:21:33.601	info	Found 1 devices
      homeconnect.0
      2022-10-09 09:21:33.228	info	starting. Version 1.1.0 in C:/ioBroker/node_modules/iobroker.homeconnect, node: v16.17.1, js-controller: 4.0.23
      homeconnect.0
      2022-10-09 09:21:28.786	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      homeconnect.0
      2022-10-09 09:21:28.786	info	terminating
      homeconnect.0
      2022-10-09 09:21:28.784	info	Got terminate signal TERMINATE_YOURSELF
      Immer Daten sichern!
      • T tombox
        Bockwurst19
        #883
        @tombox
        Ordner gelöscht. Und erneut probiert. Kommt diese Meldung.
        homeconnect.0
        2022-10-09 09:29:21.441 info Wait 10 seconds to retry
        homeconnect.0
        2022-10-09 09:29:21.440 error {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
        homeconnect.0
        2022-10-09 09:29:21.440 error https://api.home-connect.com/security/oauth/device_verify?user_code=W6BH-ZR3S
        homeconnect.0
        2022-10-09 09:29:21.439 error Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
        homeconnect.0
        2022-10-09 09:29:21.437 error Please check username and password or visit this site for manually login:
        • B Bockwurst19
          @tombox
          homeconnect.0
          homeconnect.0
          homeconnect.0
          homeconnect.0
          homeconnect.0
          thomassch
          schrieb am zuletzt editiert von thomassch
          #884
          @bockwurst19
          bei mir auch genau das selbe, erst war die Instanz mit gelben Ausrufezeichen, dann habe ich mich manuell https://api.home-connect.com/security/oauth/device_verify?user_code=64U8-UM6R ausgeführt und dort nochmals bestätigt und dann wurde die Instanz grün.
          Leider kommt trotzdem alle 10 sek diese Meldung im Log und ich kann auch nicht nochmals über api-home-connect bestätigen da die user_code abgelaufen ist.
          homeconnect.0
          2022-10-09 09:41:48.018 info Wait 10 seconds to retry
          homeconnect.0
          2022-10-09 09:41:48.018 error {"error":"expired_token","error_description":"Device authorization session not found, expired or blocked"}
          homeconnect.0
          2022-10-09 09:41:48.018 error https://api.home-connect.com/security/oauth/device_verify?user_code=64U8-UM6R
          homeconnect.0
          2022-10-09 09:41:48.018 error Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          homeconnect.0
          2022-10-09 09:41:48.018 error Please check username and password or visit this site for manually login:
          ******* iobroker auf Intel PC, Raspberry PI4 + Homematic CCU *******
            Bockwurst19
            #885
            Verbindung ist aufgebaut und kein Fehler merh im Log.
            Habe Adapter nochmal komplett gelöscht und die Github Version 1.1.0 Installiert.
            Jetzt läuft es ohne Fehler. Danke Euch.
            Jetzt bin Ich am Überlegen wegen dem Bosch Serie 8 Kaffeevollautomat.
            Jemand erfahrung damit. Und kann Feddback geben Was möglich ist.
            Z.B. Kaffee morgen von alleine machen soweit Ich ihm Bad bin :-)
            oberfraggerO 1 Antwort Letzte Antwort
            • T thomassch
              @bockwurst19
              homeconnect.0
              homeconnect.0
              homeconnect.0
              homeconnect.0
              homeconnect.0
              thomassch
              #886
              @thomassch
              spassig, ich habe den Adapter nochmals gestoppt und dann wieder gestartet und siehe da nun hat er alle Daten vom Gerät und läuft :-)
              • B Bockwurst19
                oberfraggerO Offline
                oberfragger
                #887
                @bockwurst19 Ja. Habe auch die Kaffeemaschine eingebunden.
                Unter anderem eine Ansage welcher Kaffe gerade fertig ist (zusammen mit Alexa).
                • oberfraggerO Offline
                  oberfragger
                  #888
                  Hat hier jemand schon auf die (in der APP) beworbene SingleKey ID umgestellt. Habe Angst- wenn ich das tue, wars das mit dem Adapter un ich muss alles igendwie neu machen.
                    tombox
                    schrieb am zuletzt editiert von tombox
                    #889
                    @oberfragger
                    1.1.0 kann singleKey id.
                    Sollte eigentlich funktionieren
                    Ich bin aber für live tests immer offen
                    • T tombox
                      @oberfragger
                      oberfragger
                      #890
                      @tombox Danke für die Rückmeldung. Hab das auch gerade im Update Log gesehen.
                      Dann teste ich die Tage mal.
                        maniac
                        #891
                        Moin.
                        Nächste Woche bekomme ich eine Bosch HC Waschmaschine.
                        Ich wollte jetzt schon mal den Adapter soweit fertig machen und installiere, bekomme ihn aber nicht grün.
                        Die Suche hat leider keine passenden Ergebnisse geliefert.
                        Im Log steht:
                        homeconnect.0
                        	2022-10-21 11:38:57.704	error	No verification_uri_complete in device_authorization
                        homeconnect.0
                        	2022-10-21 11:38:57.704	error	"Illegal query: Invalid input ' ', expected part, '&' or 'EOI' (line 1, column 11): client_id= HIER IST DIE CLIENT ID&scope=IdentifyAppliance%20Monitor%20Settings%20Control\n ^"
                        homeconnect.0
                        	2022-10-21 11:38:57.703	error	AxiosError: Request failed with status code 400
                        Ich habe soweit alles nach Anleitung gemacht. Developer Acc angelegt, Client ID eingetragen usw.
                        Ich habe in der App einfach mal eine DemoMaschine genommen.
                        Kann es sein, dass es ohne echtes Gerät nicht funktioniert, oder deutet der Fehler auf was anderes hin?
                        Nicht dass ich mir jetzt am Wochenende einen Wolf suche.
                        Gruß Frank…
                        T M 2 Antworten Letzte Antwort
                        • M maniac
                          Moin.
                          Im Log steht:
                          homeconnect.0
                          homeconnect.0
                          homeconnect.0
                          tombox
                          #892
                          @maniac Wurde nie mit einem account ohne echte Maschine getestet
                          • T tombox
                            maniac
                            #893
                            @tombox OK, dann gedulde ich mich noch etwas. Danke.
                            Gruß Frank…
                            • H Online
                              H Online
                              Happyuser20
                              #894
                              Guten Morgen in die Runde
                              Kann man mit dem Adapter bei einem Siemens Backofen den aktuellen Stromverbrauch auslesen?
                              Eine Neuanschaffung steht an. :)
                              • K Offline
                                Kopfii
                                #895
                                Hallo Zusammen,
                                danke schon mal für den Adapter hat alles super Funktioniert mit dem Verbinden.
                                Leider ist mein Lieblingsprogramm vom Geschirrspüler "Quick 45°C" nicht zum auswählen unter "BSH_Common_Root_SelectedProgramm".
                                Weis wer ob ich das selber ändern kann oder muss das der Entwickler vom Adapter machen?
                                Ich hab mal versucht die 2 Fehlenden Programme einzufügen aber speichern ging leider nicht.
                                Ich häng da mal 2 Fotos an vielleicht kann mir wer weiterhelfen bitte.
                                Viele Grüße :)
                                Bildschirmfoto 2022-11-01 um 12.46.53.png Bildschirmfoto 2022-11-01 um 12.42.03.png
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #896
                                  @kopfii so einfach ist es nicht.. das muss man im Source ändern..
                                  aber..
                                  die werden Dynamisch erzeugt.also ausgelesen aus dem was das Gerät kann.. siehst du denn die 2 in der app ??
                                  K 1 Antwort Letzte Antwort
                                  • K Kopfii
                                    Hallo Zusammen,
                                    Viele Grüße :)
                                    tombox
                                    #897
                                    @kopfii Es werden nicht alle Programme in der API angeboten
                                    Hier eine Übersicht
                                    https://api-docs.home-connect.com/programs-and-options?#washer
                                    Änderungswünsche an Homeconnect
                                    https://developer.home-connect.com/support/contact
                                    Merlin123M K 2 Antworten Letzte Antwort
                                    • T tombox
                                      Hier eine Übersicht
                                      Merlin123M Offline
                                      Merlin123M Offline
                                      Merlin123
                                      #898
                                      Seit heute spinnt der Adapter bei mir "etwas"....
                                      Er wirft mir diesen Fehler nach einem Neustart
                                      homeconnect.0
                                      2022-11-02 14:17:24.005	error	Start Event Stream Error: {"type":"error","status":401,"message":"Unauthorized"}
                                      homeconnect.0
                                      2022-11-02 14:17:24.005	error	401 Unauthorized
                                      homeconnect.0
                                      2022-11-02 14:17:18.931	error	{"error":{"key":"SDK.Error.504.GatewayTimeout","description":"Timeout on Home Connect subsystem. Please try it again."}}
                                      homeconnect.0
                                      2022-11-02 14:17:18.930	error	AxiosError: Request failed with status code 504
                                      danach im Minutentakt:
                                      homeconnect.0
                                      2022-11-02 14:18:34.388	error	Start Event Stream Error: {"type":"error","status":401,"message":"Unauthorized"}
                                      homeconnect.0
                                      2022-11-02 14:18:34.388	error	401 Unauthorized
                                      Hab jetzt nochmal die Client ID geprüft, nen neuen Token erzeugen lassen und dann über den Link im Protokoll aktiviert, aber irgendwie will das nicht mehr....
                                      Mein Account bei Homeconnect wurde jetzt auf Singlekey umgestellt. Nach der Umstellung lief es aber problemlos.
                                      Hat jemand ne Idee?
                                      Beta-Tester
                                      • Merlin123M Merlin123
                                        homeconnect.0
                                        homeconnect.0
                                        homeconnect.0
                                        homeconnect.0
                                        homeconnect.0
                                        homeconnect.0
                                        Hat jemand ne Idee?
                                        tombox
                                        #899
                                        @merlin123 Probleme bei homeconnect bitte einfach warten
                                        Merlin123M sigi234S 2 Antworten Letzte Antwort
                                        • T tombox
                                          Merlin123M Offline
                                          Merlin123M Offline
                                          Merlin123
                                          #900
                                          Ok. Dank Dir :) Mich hat nur gewundert, dass diese Meldung nur beim Start des Adapters kommt und danach nur noch der Unauthoized.
                                          Beta-Tester
