  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.8k Aufrufe 153 Beobachtet
  • frana120500F frana120500
    @karacho magst du das script vielleicht zur verfügung stellen?
    K Online
    K Online
    Karacho
    schrieb am zuletzt editiert von Karacho
    #875
    @frana120500
    here it is
      <variables>
        <variable type="timeout" id="timeout2">timeout2</variable>
        <variable type="timeout" id="timeout">timeout</variable>
      </variables>
      <block type="on" id="=EI[P$3d[ib4/E[]qTX3" x="-538" y="-1388">
        <field name="OID">homeconnect.0.BOSCH-SMV68TX06E-68A40E0869E8.status.BSH_Common_Status_RemoteControlStartAllowed</field>
        <statement name="STATEMENT">
          <block type="timeouts_wait" id="-WH}/45^BS2g5C1=6Xyh">
            <field name="DELAY">15</field>
            <next>
              <block type="controls_if" id="A-jAjhjdA.2P9k/^:kNn">
                <value name="IF0">
                  <block type="logic_operation" id="EaMdkJm/87Aqeg[Vnr@-" inline="false">
                    <field name="OP">AND</field>
                    <value name="A">
                      <block type="logic_compare" id="{F*aph}D-rUiM:biJlIQ">
                        <field name="OP">EQ</field>
                        <value name="A">
                          <block type="get_value" id="xf$j/jK-wX_F[ej*Yq?u">
                            <field name="OID">homeconnect.0.BOSCH-SMV68TX06E-68A40E0869E8.status.BSH_Common_Status_OperationState</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="text" id=",ID^WV;lNe./J78xG;`G">
                            <field name="TEXT">BSH.Common.EnumType.OperationState.Run</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="T(]5gJdYZPG{;Z=*ON)Z">
                        <value name="A">
                          <block type="get_value" id="r|aJg6_qa5vJW,h-ZE5O">
                            <field name="OID">0_userdata.0.Geschirrspüler_Einschalt_Logik</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="dKGJB{U;(DHJ1O.1xoP~">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="control" id="2aD:`yfy$77s2ePc6t-2">
                    <field name="OID">homeconnect.0.BOSCH-SMV68TX06E-68A40E0869E8.settings.BSH_Common_Setting_PowerState</field>
                    <value name="VALUE">
                      <block type="text" id="D{OCAjnPRFzbEm{))Exc">
                        <field name="TEXT">BSH.Common.EnumType.PowerState.Off</field>
                      </block>
                    </value>
                  </block>
                </statement>
                <next>
                  <block type="update" id="7#5t/t6vpX8Bx8;}+b]`">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                    <field name="DELAY_MS">10</field>
                      <block type="logic_boolean" id="/eW|EAVP9)ElNE!JwPT;">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
        <next>
          <block type="comment" id="LAGlYNmQyZrwK#S%W.?E">
            <field name="COMMENT">Start bei Überschuss Solar</field>
            <next>
              <block type="on" id="QTovZ4ZkHP_?mn$#1AkV">
                <field name="OID">solarlog.0.status.pac</field>
                  <block type="comment" id="hP:)Ji(05X0G8x];bui[">
                    <field name="COMMENT">Start bei Überschreiten Wert</field>
                    <next>
                      <block type="controls_if" id="9=ZM~}[,@;uLNJs|gWS.">
                        <value name="IF0">
                          <block type="logic_operation" id="Cn)Ey+~s;~~/HPhD:RHK" inline="false">
                            <value name="A">
                              <block type="logic_compare" id="oG_5RH5:sT{o:TmfO:UU">
                                <field name="OP">GT</field>
                                <value name="A">
                                  <block type="convert_tonumber" id="(rvt,:Lz]wi!6wn,AOr9">
                                      <block type="on_source" id="NfEKMc(.|`/`ceV+Xc(x">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="9:pYzKpedF,G+ZQhr*Zb">
                                    <field name="NUM">1500</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_operation" id="BV;$I3scoiIgfyQZS:EI" inline="false">
                                <value name="A">
                                  <block type="logic_compare" id="Sau(8t/Rr*PXdM*`Jz!k">
                                    <value name="A">
                                      <block type="get_value" id="]6E@yrt2ZS^d,D;ik7Ft">
                                        <field name="OID">0_userdata.0.Geschirrspüler_Ueberschuss_Start_Push</field>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="logic_boolean" id="Oa*OIa0#r_hb,xHl0Xq_">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="logic_compare" id=",rcqOV}z,qF3+ott{gS7">
                                    <value name="A">
                                      <block type="get_value" id="G5t)rQbgseV+]DgB*Nd2">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="logic_boolean" id="]R`R-X.(}+.pd8r978,O">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="control" id="$J-6tu.kk$Qj0XU4XQXy">
                              <block type="text" id="BZt8?ng9|R_g`w@gIdIf">
                                <field name="TEXT">BSH.Common.EnumType.PowerState.On</field>
                              </block>
                            </value>
                            <next>
                              <block type="pushover" id="~UI=Q}W/,4+i13S6:oha">
                                <field name="SOUND">siren</field>
                                <field name="PRIORITY">1</field>
                                <field name="LOG"></field>
                                <value name="MESSAGE">
                                  <shadow type="text">
                                    <field name="TEXT">Temperatur CPU &gt;70°. Sehr Kritisch !!!!</field>
                                  </shadow>
                                  <block type="text" id="{s.^9Dx.eR.us|~u5xbd">
                                    <field name="TEXT">Geschirrspüler Solar Überschuß gestartet!</field>
                                  </block>
                                </value>
                                <next>
                                  <block type="update" id="5_.`JPw~HMwxefal:/be">
                                    <field name="DELAY_MS">15</field>
                                      <block type="logic_boolean" id="*^e-,n+Mlz+ohsYz(7!~">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="timeouts_settimeout" id="Dv1U_d!#QzBfIzRb}^aq">
                                        <field name="DELAY">300</field>
                                        <field name="UNIT">min</field>
                                          <block type="update" id="A;+5l[buM5vg[P:yXP^9">
                                              <block type="logic_boolean" id="_cU]Yt-ceHWU1VkQY/v1">
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </statement>
                <next>
                  <block type="comment" id="]Y|nGr/HGp.%NeCKo1?j">
                    <field name="COMMENT">Alternativ Start zur Uhrzeit</field>
                    <next>
                      <block type="schedule" id="u=ZNG?~q}/*4?~k4)Ri0">
                        <field name="SCHEDULE">45 11 * * *</field>
                          <block type="controls_if" id="ej9`tgAVvEGbSa4GfTaO">
                            <value name="IF0">
                              <block type="logic_compare" id="{^3tB$4XLz6x,CEoi4/e">
                                <value name="A">
                                  <block type="get_value" id="?bFJk)v@nD3M~ngisiCJ">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="logic_boolean" id="*Vn:EaZl;,uMD.%3D{ZP">
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="control" id="m_{MI:p?0bpcq{u=-7(f">
                                  <block type="text" id="X1%vMYrj,vEGqMh{jCx~">
                                  </block>
                                </value>
                                <next>
                                  <block type="pushover" id="-MmTLoZlX2-4SSzJ]U]0">
                                      <shadow type="text" id="tj=Q6,rH?K:HjrowMoW.">
                                      </shadow>
                                      <block type="text" id="H3j(?H)Cj/|{uPY?0{$;">
                                        <field name="TEXT">Geschirrspüler Klassisch gestartet!</field>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </statement>
                        <next>
                          <block type="timeouts_settimeout" id="xI=iO2h2F[2jDFQwa_7s">
                            <field name="NAME">timeout2</field>
                              <block type="update" id="nrNd;)PxF`4V8BV;$E%x">
                                  <block type="logic_boolean" id="u$,0!UB^Bc]Yg1Qe$Ba^">
                                  </block>
                                </value>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    Bin kein Profi... vielleicht zu umständlich.....
    Der Geschirrspüler hat Bedienfeld verdeckt in der Klappe. Er muss nur ganz normal bedient werden.
    Starten - Programm wählen - Fernstarte aktivieren - Starten - zumachen
    Wollte das nicht über ein Ipad oder so realisieren....
    Gruss
    Karacho
    MasterofKungfu9999M 1 Antwort Letzte Antwort
    • R RicoGesch
      @great-sun Hat sich erledigt, habs hinbekommen.... Manchmal sieht man den Wald vor lauter Bäumen nicht :-)
      Trotzdem Danke
      dskrt
      #876
      @ricogesch Was war denn das Problem ? ich steh auf dem gleichen Schlauch und kriege den Adapter nicht grün...
      • M MaxPower 0
        Ach okay - da wird das Problem liegen - hab dort diesen Single Sign On - damit geht's nicht?
        dskrt
        #877
        @maxpower-0 Was war denn jetzt die Lösung dieses Problems ? ich habe das Gleiche und komme nicht weiter...
          Bockwurst19
          #878
          Guten Tag.
          Habe auch adapter Installiert und bin nach Anleitung gegangen.
          Bekomme aber keine Verbindung aufgebaut.
          Fehler im Log steht:
          homeconnect.0
          2022-10-08 09:03:36.669 info Wait 10 seconds to retry
          homeconnect.0
          2022-10-08 09:03:36.669 error {"error":"expired_token","error_description":"Device authorization session not found, expired or blocked"}
          homeconnect.0
          2022-10-08 09:03:36.668 error https://api.home-connect.com/security/oauth/device_verify?user_code=U646-CI2D
          homeconnect.0
          2022-10-08 09:03:36.663 error Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          homeconnect.0
          2022-10-08 09:03:36.662 error Please check username and password or visit this site for manually login:
          Kann mir da einer weiterhelfen
          • B Bockwurst19
            Guten Tag.
            homeconnect.0
            homeconnect.0
            homeconnect.0
            homeconnect.0
            homeconnect.0
            tombox
            #879
            @bockwurst19 Bitte die GitHub version probieren da ist das gelöst mit singlekey login
            B sigi234S 2 Antworten Letzte Antwort
            -1
            • T tombox
              Bockwurst19
              #880
              @tombox Danke für den Tipp.
              Verbindung ist aufgebaut.
              jetzt habe Ich diese Meldung im Log
              homeconnect.0
              2022-10-09 08:16:05.348 error Start relogin in 10min
              homeconnect.0
              2022-10-09 08:16:05.347 error {"error":"invalid_client","error_description":"client has limited user list - user not assigned to client"}
              homeconnect.0
              2022-10-09 08:16:05.345 error AxiosError: Request failed with status code 401
              homeconnect.0
              2022-10-09 08:16:05.343 error refresh token failed
              homeconnect.0
              2022-10-09 08:16:05.254 info Token abgelaufen
              homeconnect.0
              2022-10-09 08:16:05.252 error Start Event Stream Error: {"type":"error","status":401,"message":"Unauthorized"}
              homeconnect.0
              2022-10-09 08:16:05.250 error 401 Unauthorized
              homeconnect.0
              2022-10-09 08:16:05.182 error {"error":{"key":"invalid_token","description":"The access token expired"}}
              homeconnect.0
              2022-10-09 08:16:05.180 error AxiosError: Request failed with status code 401
              homeconnect.0
              2022-10-09 08:16:05.103 error Start relogin in 10min
              homeconnect.0
              2022-10-09 08:16:05.101 error {"error":"invalid_client","error_description":"client has limited user list - user not assigned to client"}
              homeconnect.0
              2022-10-09 08:16:05.100 error AxiosError: Request failed with status code 401
              homeconnect.0
              2022-10-09 08:16:05.097 error refresh token failed
              • B Bockwurst19
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                homeconnect.0
                tombox
                #881
                @bockwurst19 Sehr eigenartig würde ich den auth Ordner löschen und erneut probieren
                • T tombox
                  sigi234S Online
                  sigi234S Online
                  #882
                  @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                  Läuft bei mir einwandfrei! 👍
                  host.Medion
                  2022-10-09 09:21:29.357	info	instance system.adapter.homeconnect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  homeconnect.0
                  2022-10-09 09:21:35.022	info	401010522278007458/programs/active: There is no program active.
                  homeconnect.0
                  2022-10-09 09:21:34.146	info	401010522278007458/programs/active/options: There is no program active.
                  homeconnect.0
                  2022-10-09 09:21:33.601	info	Found 1 devices
                  homeconnect.0
                  2022-10-09 09:21:33.228	info	starting. Version 1.1.0 in C:/ioBroker/node_modules/iobroker.homeconnect, node: v16.17.1, js-controller: 4.0.23
                  homeconnect.0
                  2022-10-09 09:21:28.786	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  homeconnect.0
                  2022-10-09 09:21:28.786	info	terminating
                  homeconnect.0
                  2022-10-09 09:21:28.784	info	Got terminate signal TERMINATE_YOURSELF
                  • T tombox
                    Bockwurst19
                    #883
                    @tombox
                    Ordner gelöscht. Und erneut probiert. Kommt diese Meldung.
                    homeconnect.0
                    2022-10-09 09:29:21.441 info Wait 10 seconds to retry
                    homeconnect.0
                    2022-10-09 09:29:21.440 error {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
                    homeconnect.0
                    2022-10-09 09:29:21.440 error https://api.home-connect.com/security/oauth/device_verify?user_code=W6BH-ZR3S
                    homeconnect.0
                    2022-10-09 09:29:21.439 error Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
                    homeconnect.0
                    2022-10-09 09:29:21.437 error Please check username and password or visit this site for manually login:
                    • B Bockwurst19
                      @tombox
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      homeconnect.0
                      thomassch
                      schrieb am zuletzt editiert von thomassch
                      #884
                      @bockwurst19
                      bei mir auch genau das selbe, erst war die Instanz mit gelben Ausrufezeichen, dann habe ich mich manuell https://api.home-connect.com/security/oauth/device_verify?user_code=64U8-UM6R ausgeführt und dort nochmals bestätigt und dann wurde die Instanz grün.
                      Leider kommt trotzdem alle 10 sek diese Meldung im Log und ich kann auch nicht nochmals über api-home-connect bestätigen da die user_code abgelaufen ist.
                      homeconnect.0
                      2022-10-09 09:41:48.018 info Wait 10 seconds to retry
                      homeconnect.0
                      2022-10-09 09:41:48.018 error {"error":"expired_token","error_description":"Device authorization session not found, expired or blocked"}
                      homeconnect.0
                      2022-10-09 09:41:48.018 error https://api.home-connect.com/security/oauth/device_verify?user_code=64U8-UM6R
                      homeconnect.0
                      2022-10-09 09:41:48.018 error Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
                      homeconnect.0
                      2022-10-09 09:41:48.018 error Please check username and password or visit this site for manually login:
                      ******* iobroker auf Intel PC, Raspberry PI4 + Homematic CCU *******
                        Bockwurst19
                        #885
                        Verbindung ist aufgebaut und kein Fehler merh im Log.
                        Habe Adapter nochmal komplett gelöscht und die Github Version 1.1.0 Installiert.
                        Jetzt läuft es ohne Fehler. Danke Euch.
                        Jetzt bin Ich am Überlegen wegen dem Bosch Serie 8 Kaffeevollautomat.
                        Jemand erfahrung damit. Und kann Feddback geben Was möglich ist.
                        Z.B. Kaffee morgen von alleine machen soweit Ich ihm Bad bin :-)
                        oberfraggerO 1 Antwort Letzte Antwort
                        • T thomassch
                          @bockwurst19
                          homeconnect.0
                          homeconnect.0
                          homeconnect.0
                          homeconnect.0
                          homeconnect.0
                          thomassch
                          #886
                          @thomassch
                          spassig, ich habe den Adapter nochmals gestoppt und dann wieder gestartet und siehe da nun hat er alle Daten vom Gerät und läuft :-)
                          • B Bockwurst19
                            oberfraggerO Offline
                            oberfragger
                            #887
                            @bockwurst19 Ja. Habe auch die Kaffeemaschine eingebunden.
                            Unter anderem eine Ansage welcher Kaffe gerade fertig ist (zusammen mit Alexa).
                            • oberfraggerO Offline
                              oberfragger
                              #888
                              Hat hier jemand schon auf die (in der APP) beworbene SingleKey ID umgestellt. Habe Angst- wenn ich das tue, wars das mit dem Adapter un ich muss alles igendwie neu machen.
                                tombox
                                #889
                                @oberfragger
                                1.1.0 kann singleKey id.
                                Sollte eigentlich funktionieren
                                Ich bin aber für live tests immer offen
                                • T tombox
                                  @oberfragger
                                  oberfragger
                                  #890
                                  @tombox Danke für die Rückmeldung. Hab das auch gerade im Update Log gesehen.
                                  Dann teste ich die Tage mal.
                                    maniac
                                    #891
                                    Moin.
                                    Nächste Woche bekomme ich eine Bosch HC Waschmaschine.
                                    Ich wollte jetzt schon mal den Adapter soweit fertig machen und installiere, bekomme ihn aber nicht grün.
                                    Die Suche hat leider keine passenden Ergebnisse geliefert.
                                    Im Log steht:
                                    homeconnect.0
                                    	2022-10-21 11:38:57.704	error	No verification_uri_complete in device_authorization
                                    homeconnect.0
                                    	2022-10-21 11:38:57.704	error	"Illegal query: Invalid input ' ', expected part, '&' or 'EOI' (line 1, column 11): client_id= HIER IST DIE CLIENT ID&scope=IdentifyAppliance%20Monitor%20Settings%20Control\n ^"
                                    homeconnect.0
                                    	2022-10-21 11:38:57.703	error	AxiosError: Request failed with status code 400
                                    Ich habe soweit alles nach Anleitung gemacht. Developer Acc angelegt, Client ID eingetragen usw.
                                    Ich habe in der App einfach mal eine DemoMaschine genommen.
                                    Kann es sein, dass es ohne echtes Gerät nicht funktioniert, oder deutet der Fehler auf was anderes hin?
                                    Nicht dass ich mir jetzt am Wochenende einen Wolf suche.
                                    Gruß Frank…
                                    T M 2 Antworten Letzte Antwort
                                    • M maniac
                                      Moin.
                                      Im Log steht:
                                      homeconnect.0
                                      homeconnect.0
                                      homeconnect.0
                                      tombox
                                      #892
                                      @maniac Wurde nie mit einem account ohne echte Maschine getestet
                                      • T tombox
                                        maniac
                                        #893
                                        @tombox OK, dann gedulde ich mich noch etwas. Danke.
                                        Gruß Frank…
                                        • H Offline
                                          Happyuser20
                                          #894
                                          Guten Morgen in die Runde
                                          Kann man mit dem Adapter bei einem Siemens Backofen den aktuellen Stromverbrauch auslesen?
                                          Eine Neuanschaffung steht an. :)
