  4. Script Hilfe für Abfrage Serielle Kommunikation gesucht!
    5.1k
192 Beiträge 15 Kommentatoren 39.7k Aufrufe 10 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    wendy2702
    #41
    Hi nochmal mein aktuell funktionierendes Script:
    Script zur Abfrage welches alle 3 minuten gestartet, gestoppt wird:
    createState('Waterkotte.Daten.Abfrage_Rohdaten');
    //createState('Waterkotte.Daten.Abfrage_Error');
    setState("javascript.2.Waterkotte.Daten.Abfrage_Error"/*Waterkotte.Daten.Abfrage_Error*/, false);
    // To use the `ByteLength` parser:
    const SerialPort = require('serialport');
    const ByteLength = SerialPort.parsers.ByteLength;
    var buffer = new Buffer(12);
    buffer[0] = 0x10;
    buffer[1] = 0x02;
    buffer[2] = 0x01;
    buffer[3] = 0x15;
    buffer[4] = 0x00;
    buffer[5] = 0x00;
    buffer[6] = 0x00;
    buffer[7] = 0xf3;
    buffer[8] = 0x10;
    buffer[9] = 0x03;
    buffer[10] = 0x7c;
    buffer[11] = 0x32;
    const port = new SerialPort("/dev/ttyUSB1", {
       baudRate: 9600,
       dataBits : 8,
       parity : 'none',
       stopBits: 1
    //  flowControl : false
    }, function (err) {
       if (err) {
    //        port.close();
           console.log('Error1: ', err.message);
           setState("javascript.2.Waterkotte.Daten.Abfrage_Error"/*Waterkotte.Daten.Abfrage_Error*/, true);
       const parser = port.pipe(new ByteLength({ length: 253 }));
       parser.on('data', function (data) {
       	console.log('Data received: ' + data.toString('hex'));
       	var daten = data.toString('hex');
       	setState('Waterkotte.Daten.Abfrage_Rohdaten', daten, true);
       	//port.close();
       // Flush input
       port.flush();
       // send Data
           port.write(buffer, function(err) {
       	    if (err) {
       		    return console.log('Error on write: ', err.message);
       	    console.log('Daten send');
    // 		    port.close();
    port.on('open', function() {
       console.log('Connected');
    port.on('error', function(err) {
       console.log('Error2: ', err.message);
    //	port.close();
    // close port if the script stopped (to be able to open it again)
    onStop(function (callback) {
       if (port && port.isOpen) {
       	port.close();
       	console.log('port closed');
    Scipt zur Auswertung der Abfrage, ist ständig aktiv:
    //createState('Waterkotte.Daten.Rohdaten');
    createState('Waterkotte.Daten.Version');
    createState('Waterkotte.Daten.Temp_Aussen_Ist');
    createState('Waterkotte.Daten.Temp_Aussen_24h');
    createState('Waterkotte.Daten.Temp_Aussen_1h');
    createState('Waterkotte.Daten.Temp_Ruecklauf_Soll');
    createState('Waterkotte.Daten.Temp_Ruecklauf_Ist');
    createState('Waterkotte.Daten.Temp_Vorlauf');
    createState('Waterkotte.Daten.Temp_WW_Soll');
    createState('Waterkotte.Daten.Temp_WW_Ist');
    createState('Waterkotte.Daten.Temp_Raum');
    createState('Waterkotte.Daten.Temp_Raum_1h');
    createState('Waterkotte.Daten.Temp_WQuelle_Ein');
    createState('Waterkotte.Daten.Temp_WQuelle_Aus');
    createState('Waterkotte.Daten.Temp_Verdampfer');
    createState('Waterkotte.Daten.Temp_Kondensator');
    createState('Waterkotte.Daten.Temp_Saugleitung');
    createState('Waterkotte.Daten.Temp_frei');
    createState('Waterkotte.Daten.Druck_Verdampfer');
    createState('Waterkotte.Daten.Druck_Kondensator');
    createState('Waterkotte.Daten.Status_Heizung');
    createState('Waterkotte.Daten.Status_Warmwasser');
    createState('Waterkotte.Daten.Status_Handabschaltung');
    createState('Waterkotte.Daten.Status_WPumpe');
    createState('Waterkotte.Daten.Mode_Heizung');
    createState('Waterkotte.Daten.Mode_Heizung_EIN_Normal');
    createState('Waterkotte.Daten.Mode_Heizung_EIN_Solar');
    createState('Waterkotte.Daten.Mode_Heizung_EIN_externe_Anhebung');
    createState('Waterkotte.Daten.Mode_Heizung_EIN_Schnellaufheizung');
    createState('Waterkotte.Daten.Mode_Heizung_AUS_Zeitprogramm');
    createState('Waterkotte.Daten.Mode_Heizung_AUS_Unterdrueckung');
    createState('Waterkotte.Daten.Mode_Heizung_AUS_kein_Bedarf');
    createState('Waterkotte.Daten.Mode_Heizung_AUS_wegen_Fuehlerfehler');
    createState('Waterkotte.Daten.Mode_Warmwasser');
    createState('Waterkotte.Daten.Mode_Warmwasser_EIN_Normal');
    createState('Waterkotte.Daten.Mode_Warmwasser_EIN_Solar');
    createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Zeitprogramm');
    createState('Waterkotte.Daten.Mode_Warmwasser_AUS_kein_Bedarf');
    createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterbrechung_wegen_Fuehlerfehler');
    createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterdrueckung');
    createState('Waterkotte.Daten.Mode_Warmwasser_Solar');
    createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Solarnutzung');
    createState('Waterkotte.Daten.Mode_Kuehlung_EIN_Normal');
    createState('Waterkotte.Daten.Mode_Kuehlung_AUS');
    createState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung');
    createState('Waterkotte.Daten.Mode_Kuehlung_AUS_kein_Bedarf');
    createState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung_wegen_Fuehlerfehler');
    createState('Waterkotte.Daten.DI_Motorschutz_Kompressor');
    createState('Waterkotte.Daten.DI_Niederdruck_Pressostat');
    createState('Waterkotte.Daten.DI_Hochdruck_Pressostat');
    createState('Waterkotte.Daten.DI_Pumpe_Quelle');
    createState('Waterkotte.Daten.DI_Externe_Sollwertbeeinflussung');
    createState('Waterkotte.Daten.DI_Externe_Abschaltung');
    createState('Waterkotte.Daten.DO_Magnetventil');
    createState('Waterkotte.Daten.DO_Kompressor1');
    createState('Waterkotte.Daten.DO_Sammelstoermeldung');
    createState('Waterkotte.Daten.DO_Umschaltventil_Kuehlung');
    createState('Waterkotte.Daten.DO_Umschaltventil_Stufe2');
    createState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Heizung');
    createState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Warmwasser');
    createState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Quelle');
    var id = 'javascript.2.Waterkotte.Daten.Abfrage_Rohdaten';
    var daten;
    var Satz;
    var inp;
    var out;
    var VersionsNr;
    var TempAussenIst;
    var TempAussen24h;
    var TempAussen1h;
    var TempRuecklaufSoll;
    var TempRuecklaufIst;
    var TempVorlauf;
    var TempWWSoll;
    var TempWWIst;
    var TempRaum;
    var TempRaum1h;
    var TempWQuelleEin;
    var TempWQuelleAus;
    var TempVerdampfer;
    var TempKondensator;
    var TempSaugleitung;
    var Tempfrei;
    var DruckVerdampfer;
    var DruckKondensator;
    var KuehlungTempRuecklaufSoll;
    var KuehlungTempRuecklaufIst;
    var TempWWIst;
    var Zeit;
    var Datum;
    var BetriebsstundenKompressor;
    var BetriebsstundenHeizung;
    var BetriebsstundenWW;
    var BetriebsstundenStufe2;
    var BetriebsStundenMessZeitKompressor;
    var BetriebsStundenMessDatumKompressor;
    var BetriebsStundenMessZeitWPumpe;
    var BetriebsStundenMessDatumWPumpe;
    var BetriebsStundenResetKompressor;
    var BetriebsStundenResetWPumpe;
    var Kennwort;
    var WerksEinstellungen;
    var ResetWPumpe;
    var CrcSumme;
    var NStart;
    var DisplayZeile1;
    var DisplayZeile2;
    var AusfallTime;
    var AusfallDate;
    var AusfallBetriebsZustaende;
    var AusfallDoBuffer;
    var AusfallDoMagnetventil;
    var AusfallDoKompressor1;
    var AusfallDoBufferBit3;
    var AusfallDoUmschaltventilKuehlung;
    var AusfallDoStufe2;
    var AusfallDoPumpeHeizung;
    var AusfallDoPumpeWarmwasser;
    var AusfallDoPumpeQuelle;
    var AusfallDiBuffer;
    var AusfallDiMotorschutzkompressor;
    var AusfallDiNiederdruckPressostat;
    var AusfallDiHochdruckPressostat;
    var AusfallDiPumpeQuelle;
    var AusfallDiSoleMinnimum;
    var AusfallDiBufferBit6;
    var AusfallDiExterneSollwertbeeinflussung;
    var AusfallDiExterneAbschaltung;
    var AusfallAiTempQuelleEin;
    var AusfallAiError;
    var AusfallAiDi;
    var AusfallAiTempAussen;
    var AusfallAiTempQuelleAus;
    var AusfallAiVerdampfung;
    var AusfallAiTempHeizEin;
    var AusfallAiTempHeizAus;
    var AusfallAiKondensation;
    var AusfallAiTempWWasser;
    var AusfallAuxAiError;
    var AusfallAuxAiDi;
    var AusfallAiTempRaum;
    var ClearAusfaelle;
    var Unterbrechung;
    var WarnungEingangsSeite;
    var WarnungAusgangsSeite;
    var WarnungSonstige;
    var Ausfall;
    var AiError;
    var AiDi;
    var AiCounter0;
    var AuxAiError;
    var AuxAiDi;
    var BetriebsZustaende;
    var DoBuffer;
    var DiBuffer;
    var GesStatus;
    var StatusVerriegelung;
    var StatusHeiz;
    var StatusKuehl;
    var StatusStufe2;
    var StatusWWasser;
    var StatusWPumpe;
    var ModeHeiz;
    var ModeHeizEINNormal;
    var ModeHeizEINSolar;
    var ModeHeizEinextAnhebung;
    var ModeHeizEINSchnellaufheidzung;
    var ModeHeizAUSZeitprogramm;
    var ModeHeizAUSUnterdrueckung;
    var ModeHeizAUSkeinBedarf;
    var ModeHeizAUSwFuehlerf;
    var ModeKuehl;
    var ModeKuehlEINNormal;
    var ModeKuehlAUS;
    var ModeKuehlAUSUnterdrueckung;
    var ModeKuehlAUSkeinBedarf;
    var ModeKuehlAUSUnterbrechwFuehlerf;
    var ModeWWasser;
    var ModeWWassserINNormal;
    var ModeWWasserEINSolar;
    var ModeWWasserAUSZeitprogramm;
    var ModeWWasserAUSkeinBedarf;
    var ModeWWasserAUSUnterbrwFuehlerf;
    var ModeWWasserAUSUnterdrueckung;
    var ModeWWasserSolar;
    var ModeWWasserAUSSolarNutzung;
    var LoggerError;
    var LoggerInitTime;
    var LoggerInitDate;
    var LoggerMaxRec;
    var LoggerActRec;
    var LoggerMaxActRec;
    var LoggerSizeOfData;
    var LoggerSizeOfDatenLoggerBuffer;
    var DiMotorschutzkompressor;
    var DiNiederdruckPressostat;
    var DiHochdruckPressostat;
    var DiPumpeQuelle;
    var DiSoleMinnimum;
    var DiBufferBit6;
    var DiExterneSollwertbeeinflussung;
    var DiExterneAbschaltung;
    var DoMagnetventil;
    var DoKompressor1;
    var DoSammelstoermeldung;
    var DoUmschaltventilKuehlung;
    var DoStufe2;
    var DoPumpeHeizung;
    var DoPumpeWarmwasser;
    var DoPumpeQuelle;
    var VerdampfungstemperaturNiedrig;
    var TempQuelleAustrittNiedrig;
    var DiffQuelleEinQuelleAusHoch;
    var DiffQuelleAusVerdampfungHoch;
    var KondensationstemperaturHoch;
    var DiffHzgVorlaufRuecklaufNiedrig;
    var DiffHzgVorlaufRuecklaufHoch;
    var DiffKondensationVorlaufHoch;
    var HzgRuecklauffuehlerdefekt;
    var HzgVorlauffuehlerdefekt;
    var Aussenwandfuehlerdefekt;
    var DoBufferHandstellung;
    var SolestandMinimum;
    var Handabschaltung;
    var HzgEinsatzzeitpunktSollwert;
    var HzgRuecklaufSollwertamEinsatzp;
    var HeizkennlineSteigungSoll;
    var HeizkennlineObereBegrenzung;
    var HeizgSollwertanhebung4kfuer24h;
    var PilotraumSollwert;
    var PilotraumFaktor;
    var ExterneAnhebung;
    var FreigabeHeizung;
    var SperrenHeizung;
    var SollwertaenderungEin;
    var SollwertaenderungAus;
    var St2KlObereBegrenzung;
    var KennlinieHysterese;
    var PumpenNachlaufzeit;
    var AbschaltungHeizung;
    var KuehlungEinsatzzeitpunkt;
    var RuecklauftempSollwertamEinsatzzeitp;
    var KuehlungKennlinieSteigungSoll;
    var KennlinieuntereBegrenzung;
    var AbschaltungWW;
    var WWZeitEin;
    var WWZeitAus;
    var WWSoll;
    var BeckenwasserTempSoll;
    var WarmwasserHysterese;
    var BeckenwasserHysterese;
    var ModemKlingelzeichen;
    var Fremdzugriff;
    var Schluesselnummer;
    var SetBetriebsMode;
    var HzgExterneFreigabe;
    var HzgExterneRuecklaufsteuerung;
    var St2TempQAusMin;
    var St2TempVerdMin;
    var EstrichAufheizen;
    var HzgExterneSteuerung;
    var St2beiEVUAbsch;
    var FrgBeckenwasser;
    var ScaleFaktor;
    var OffsetNiederdr;
    var OffsetHochdr;
    var DoHandkanal;
    var DoHandkanalEin;
    var UnterdrWarnAus;
    var UnterdrWarnSonst;
    var UnterdrWarnEin;
    var NeuStart;
    var RunFlag;
    on(id, function (obj) {
    //function myScript() {
    //Bitauswertung
    function bitauswertung(Adresse)
    //Bit 1
    inp = Woerter[Adresse];
    out = parseInt(inp,16);
    out &= 1;
    if (out == 1) { Bit1 = 1; }
     else { Bit1 = 0; }
    //Bit 2
    out &= 2;
    if (out == 2) { Bit2 = 1; }
     else { Bit2 = 0; }
    //Bit 3
    out &= 4;
    if (out == 4) { Bit3 = 1; }
     else { Bit3 = 0; }
    //Bit 4
    out &= 8;
    if (out == 8) { Bit4 = 1; }
     else { Bit4 = 0; }
    //Bit 5
    out &= 16;
    if (out == 16) { Bit5 = 1; }
     else { Bit5 = 0; }
    //Bit 6
    out &= 32;
    if (out == 32) { Bit6 = 1; }
     else { Bit6 = 0; }
    //Bit 7
    out &= 64;
    if (out == 64) { Bit7 = 1; }
     else { Bit7 = 0; }
    //Bit 8
    out &= 128;
    if (out == 128) { Bit8 = 1; }
     else { Bit8 = 0; }
    // Formatierung des Integerbereichs
    function dezInt(num,size,prefix)
     prefix=(prefix)?prefix:"0";
     var minus=(num<0)?"-":"", result=(prefix=="0")?minus:"";
     num=Math.abs(parseInt(num,10)); size-=(""+num).length;
     for(var i=1;i<=size;i++) { result+=""+prefix; }
     result+=((prefix!="0")?minus:"")+num; return result;
    //IEEE nach Hex umrechnen
    function IEEE754_Hex32ToDez(hexstr)
     var dez,bin1,bin2,bin3,bin4,bin,sign,expo,mant,nul8='00000000';
     bin1=nul8+parseInt(hexstr.substr(0,2),16).toString(2);
     bin2=nul8+parseInt(hexstr.substr(2,2),16).toString(2);
     bin3=nul8+parseInt(hexstr.substr(4,2),16).toString(2);
     bin4=nul8+parseInt(hexstr.substr(6,2),16).toString(2);
     bin1=bin1.substr(bin1.length-8,8);
     bin2=bin2.substr(bin2.length-8,8);
     bin3=bin3.substr(bin3.length-8,8);
     bin4=bin4.substr(bin4.length-8,8);
     bin=bin1+bin2+bin3+bin4;
     sign=parseInt(bin.charAt(0),2);    // Vorzeichen
     expo=parseInt(bin.substr(1,8),2);  // Exponent
     mant=parseInt(bin.substr(9,23),2); // Mantisse
     dez=(1-2*sign)*Math.pow(2,expo-127)*(1+mant/Math.pow(2,23));
       dez = dez*100;
       dez = Math.round(dez);
       dez = dez/100;
     return(dez);
    daten = getState("javascript.2.Waterkotte.Daten.Abfrage_Rohdaten").val;
    console.log('Daten:' + daten);
    i = 0;
    var Satz = [];
    while (i < daten.length) {
       var byte = daten.substr(i, 2);
       Satz = Satz + ' ' + byte;
       i=i+2;
    console.log('Daten split:' + Satz);
    //WP-Antwort auf 10 10 durchsuchen und durc 10 ersetzen
    Satz = Satz.replace(/10 10/g, "10");
    // WP-Antwort in einzelne Bytes zerlegen
    var Woerter = Satz.split(" ");
    // Versions-Nr. berechnen
    inp = Woerter[6]+ Woerter[7];
    out=parseInt(inp,16);
    VersionsNr = out;
    console.log('Daten split:' + inp);
    // Versions-Datum berechnen
    inp = Woerter[8];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[9];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[10];
    out =dezInt(out,2);
    Merker3 = out;
    VersionsDatum = Merker1+ "." +Merker2+ "." +Merker3;
    //Betriebsmode auslesen
    inp = Woerter[11];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[12];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[13];
    out =dezInt(out,2);
    Merker3 = out;
    Betriebsmode = Merker1+ "." +Merker2+ "." +Merker3;
    //Temp-Aussen-Ist auslesen
    TempAussenIst = IEEE754_Hex32ToDez(Woerter[17]+ Woerter[16]+ Woerter[15]+ Woerter[14]);
    //Temp-Aussen-24h auslesen
    TempAussen24h = IEEE754_Hex32ToDez(Woerter[21]+ Woerter[20]+ Woerter[19]+ Woerter[18]);
    //Temp-Aussen-1h auslesen
    TempAussen1h = IEEE754_Hex32ToDez(Woerter[25]+ Woerter[24]+ Woerter[23]+ Woerter[22]);
    //Temp-Ruecklauf Soll auslesen
    TempRuecklaufSoll = IEEE754_Hex32ToDez(Woerter[29]+ Woerter[28]+ Woerter[27]+ Woerter[26]);
    //Temp-Ruecklauf IST auslesen
    TempRuecklaufIst = IEEE754_Hex32ToDez(Woerter[33]+ Woerter[32]+ Woerter[31]+ Woerter[30]);
    //Temp-Vorlauf auslesen
    TempVorlauf = IEEE754_Hex32ToDez(Woerter[37]+ Woerter[36]+ Woerter[35]+ Woerter[34]);
    //Temp-WW Soll auslesen
    TempWWSoll = IEEE754_Hex32ToDez(Woerter[41]+ Woerter[40]+ Woerter[39]+ Woerter[38]);
    //Temp-WW Ist auslesen
    TempWWIst = IEEE754_Hex32ToDez(Woerter[45]+ Woerter[44]+ Woerter[43]+ Woerter[42]);
    //Temp-Raum auslesen
    TempRaum = IEEE754_Hex32ToDez(Woerter[49]+ Woerter[48]+ Woerter[47]+ Woerter[46]);
    //Temp-Raum-1h auslesen
    TempRaum1h = IEEE754_Hex32ToDez(Woerter[53]+ Woerter[52]+ Woerter[51]+ Woerter[50]);
    //Temp-WQuelle-Ein
    TempWQuelleEin = IEEE754_Hex32ToDez(Woerter[57]+ Woerter[56]+ Woerter[55]+ Woerter[54]);
    //Temp-WQuelle-Aus
    TempWQuelleAus = IEEE754_Hex32ToDez(Woerter[61]+ Woerter[60]+ Woerter[59]+ Woerter[58]);
    //Temp-Verdampfer
    TempVerdampfer= IEEE754_Hex32ToDez(Woerter[65]+ Woerter[64]+ Woerter[63]+ Woerter[62]);
    //Temp-Kondensator
    TempKondensator = IEEE754_Hex32ToDez(Woerter[69]+ Woerter[68]+ Woerter[67]+ Woerter[66]);
    //Temp-Saugleitung
    TempSaugleitung = IEEE754_Hex32ToDez(Woerter[73]+ Woerter[72]+ Woerter[71]+ Woerter[70]);
    //Temp-frei
    Tempfrei = IEEE754_Hex32ToDez(Woerter[77]+ Woerter[76]+ Woerter[75]+ Woerter[74]);
    //Druck-Verdampfer
    DruckVerdampfer = IEEE754_Hex32ToDez(Woerter[81]+ Woerter[80]+ Woerter[79]+ Woerter[78])
    //Druck-Kondensator
    DruckKondensator = IEEE754_Hex32ToDez(Woerter[85]+ Woerter[84]+ Woerter[83]+ Woerter[82]);
    TempRuecklaufSoll = IEEE754_Hex32ToDez(Woerter[89]+ Woerter[88]+ Woerter[87]+ Woerter[86]);
    //Temp-Ruecklauf Ist
    TempRuecklaufIst = IEEE754_Hex32ToDez(Woerter[93]+ Woerter[92]+ Woerter[91]+ Woerter[90]);
    //Kuehlung Temp Ruecklauf Soll
    KuehlungTempRuecklaufSoll = IEEE754_Hex32ToDez(Woerter[97]+ Woerter[96]+ Woerter[95]+ Woerter[94]);
    //Kuehlung Temp Ruecklauf Ist
    KuehlungTempRuecklaufIst = IEEE754_Hex32ToDez(Woerter[101]+ Woerter[100]+ Woerter[99]+ Woerter[98]);
    //Warmwasser Temp Ist
    TempWWIst = IEEE754_Hex32ToDez(Woerter[105]+ Woerter[104]+ Woerter[103]+ Woerter[102]);
    //Zeit
    inp = Woerter[108];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[107];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[106];
    out =dezInt(out,2);
    Merker3 = out;
    Zeit = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Datum
    inp = Woerter[109];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[110];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[111];
    out =dezInt(out,2);
    Merker3 = out;
    //Betriebsstunden Kompressor
    BetriebsstundenKompressor = IEEE754_Hex32ToDez(Woerter[115]+ Woerter[114]+ Woerter[113]+ Woerter[112]);
    //Betriebsstunden Heizung
    BetriebsstundenHeizung = IEEE754_Hex32ToDez(Woerter[119]+ Woerter[118]+ Woerter[117]+ Woerter[116]);
    //Betriebsstunden WW
    BetriebsstundenWW = IEEE754_Hex32ToDez(Woerter[123]+ Woerter[122]+ Woerter[121]+ Woerter[120]);
    //Betriebsstunden Stufe 2
    BetriebsstundenStufe2 = IEEE754_Hex32ToDez(Woerter[127]+ Woerter[126]+ Woerter[125]+ Woerter[124]);
    //BetriebsStunden MessZeit Kompressor
    inp = Woerter[128];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[129];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[130];
    out =dezInt(out,2);
    Merker3 = out;
    BetriebsStundenMessZeitKompressor = Merker1+ ":" +Merker2+ ":" +Merker3;
    //BetriebsStunden MessDatum Kompressor
    inp = Woerter[133];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[132];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[131];
    out =dezInt(out,2);
    Merker3 = out;
    BetriebsStundenMessDatumKompressor = Merker1+ "." +Merker2+ "." +Merker3;
    //BetriebsStunden MessZeit WPumpe
    inp = Woerter[134];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[135];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[136];
    out =dezInt(out,2);
    Merker3 = out;
    BetriebsStundenMessZeitWPumpe = Merker1+ ":" +Merker2+ ":" +Merker3;
    //BetriebsStunden MessDatum WPumpe
    inp = Woerter[139];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[138];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[137];
    out =dezInt(out,2);
    Merker3 = out;
    BetriebsStundenMessDatumWPumpe = Merker1+ "." +Merker2+ "." +Merker3;
    //BetriebsStunden Reset Kompressor
    inp = Woerter[140];
    BetriebsStundenResetKompressor = parseInt(inp,16);
    //BetriebsStunden Reset WPumpe
    inp = Woerter[141];
    BetriebsStundenResetWPumpe = parseInt(inp,16);
    //Kennwort
    inp = Woerter[142];
    Kennwort = parseInt(inp,16);
    //WerksEinstellungen
    inp = Woerter[143];
    WerksEinstellungen = parseInt(inp,16);
    //Reset WPumpe
    inp = Woerter[144];
    //Crc Summe
    inp = Woerter[145]+ Woerter[146];
    CrcSumme = parseInt(inp,16);
    //NStart
    inp = Woerter[147];
    NStart = parseInt(inp,16);
    //Display Zeile 1
    inp = Woerter[148]+ Woerter[149];
    DisplayZeile1 = parseInt(inp,16);
    //Display Zeile 2
    inp = Woerter[150];
    DisplayZeile2 = parseInt(inp,16);
    //AusfallTime
    inp = Woerter[153];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[152];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[151];
    out =dezInt(out,2);
    Merker3 = out;
    AusfallTime = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Ausfalldatum
    inp = Woerter[154];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[155];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[156];
    out =dezInt(out,2);
    Merker3 = out;
    AusfallDate = Merker1+ "." +Merker2+ "." +Merker3;
    //Ausfall BetriebsZustaende.dec
    inp = Woerter[157];
    out = out.toString(2);
    AusfallBetriebsZustaende = dezInt(out,8)
    //Ausfall DoBuffer.dec
    inp = Woerter[158];
    AusfallDoBuffer = dezInt(out,8)
    //Bitauswertung Ausfall DoBuffer
    bitauswertung(158);
    AusfallDoMagnetventil = Bit1;
    AusfallDoKompressor1 = Bit2;
    AusfallDoBufferBit3 = Bit3;
    AusfallDoUmschaltventilKuehlung = Bit4;
    AusfallDoStufe2 = Bit5;
    AusfallDoPumpeHeizung = Bit6;
    AusfallDoPumpeWarmwasser = Bit7;
    AusfallDoPumpeQuelle = Bit8;
    //Ausfall DiBuffer.dec
    inp = Woerter[159];
    AusfallDiBuffer = dezInt(out,8)
    // Bitauswertung Ausfall DiBuffer
    bitauswertung (159);
    AusfallDiMotorschutzkompressor = Bit1;
    AusfallDiNiederdruckPressostat = Bit2;
    AusfallDiHochdruckPressostat = Bit3;
    AusfallDiPumpeQuelle = Bit4;
    AusfallDiSoleMinnimum = Bit5;
    AusfallDiBufferBit6 = Bit6;
    AusfallDiExterneSollwertbeeinflussung = Bit7;
    AusfallDiExterneAbschaltung = Bit8;
    //AusfallAiError.dec
    inp = Woerter[160];
    AusfallAiError = dezInt(out,8);
    //AusfallAiDi.dec
    inp = Woerter[161];
    AusfallAiDi = dezInt(out,8);
    //AusfallAiTempAussen
    AusfallAiTempAussen = IEEE754_Hex32ToDez(Woerter[165]+ Woerter[164]+ Woerter[163]+ Woerter[162]);
    //AusfallAiTempQuelleEin
    AusfallAiTempQuelleEin = IEEE754_Hex32ToDez(Woerter[169]+ Woerter[168]+ Woerter[167]+ Woerter[166]);
    //AusfallAiTempQuelleAus
    AusfallAiTempQuelleAus = IEEE754_Hex32ToDez(Woerter[173]+ Woerter[172]+ Woerter[171]+ Woerter[170]);
    //AusfallAiVerdampfung
    AusfallAiVerdampfung = IEEE754_Hex32ToDez(Woerter[177]+ Woerter[176]+ Woerter[175]+ Woerter[174]);
    //AusfallAiTempHeizEin
    AusfallAiTempHeizEin = IEEE754_Hex32ToDez(Woerter[181]+ Woerter[180]+ Woerter[179]+ Woerter[178]);
    //AusfallAiTempHeizAus
    AusfallAiTempHeizAus = IEEE754_Hex32ToDez(Woerter[185]+ Woerter[184]+ Woerter[183]+ Woerter[182]);
    //AusfallAiKondensation
    AusfallAiKondensation = IEEE754_Hex32ToDez(Woerter[189]+ Woerter[188]+ Woerter[187]+ Woerter[186]);
    //AusfallAiTempWWasser
    AusfallAiTempWWasser = IEEE754_Hex32ToDez(Woerter[193]+ Woerter[192]+ Woerter[191]+ Woerter[190]);
    //AusfallAuxAiError.dec
    inp = Woerter[194];
    AusfallAuxAiError = dezInt(out,8);
    //AusfallAuxAiDi.dec
    inp = Woerter[195];
    AusfallAuxAiDi = dezInt(out,8);
    //AusfallAiTempRaum
    AusfallAiTempRaum = IEEE754_Hex32ToDez(Woerter[199]+ Woerter[198]+ Woerter[197]+ Woerter[196]);
    //ClearAusfaelle
    inp = Woerter[200];
    ClearAusfaelle = out
    //Unterbrechung.dec
    inp = Woerter[201];
    Unterbrechung = dezInt(out,8);
    //WarnungEingangsSeite.dec
    inp = Woerter[202];
    WarnungEingangsSeite = dezInt(out,8);
    //Bitauswertung WarnungEingangsSeite.dec
    bitauswertung(202);
    VerdampfungstemperaturNiedrig = Bit1;
    TempQuelleAustrittNiedrig = Bit2;
    DiffQuelleEinQuelleAusHoch = Bit3;
    DiffQuelleAusVerdampfungHoch = Bit4;
    //WarnungAusgangsSeite.dec
    inp = Woerter[203];
    WarnungAusgangsSeite = dezInt(out,8);
    //Bitauswertung WarnungAusgangsSeite.dec
    bitauswertung(203);
    KondensationstemperaturHoch = Bit2;
    DiffHzgVorlaufRuecklaufNiedrig = Bit3;
    DiffHzgVorlaufRuecklaufHoch = Bit4;
    DiffKondensationVorlaufHoch = Bit6;
    //WarnungSonstige.dec
    inp = Woerter[204];
    WarnungSonstige = dezInt(out,8);
    //Bitauswertung WarnungSonstige.dec
    bitauswertung(204);
    HzgRuecklauffuehlerdefekt = Bit1;
    HzgVorlauffuehlerdefekt = Bit2;
    Aussenwandfuehlerdefekt = Bit3;
    DoBufferHandstellung = Bit4;
    SolestandMinimum = Bit5;
    //Ausfall.dec
    inp = Woerter[205];
    Ausfall = dezInt(out,8);
    //AiError.dec
    inp = Woerter[206];
    //AiDi.dec
    inp = Woerter[207];
    //AiCounter0
    inp = Woerter[208]+ Woerter[209];
    AiCounter0 = out;
    //AuxAiError.dec
    inp = Woerter[210];
    //AuxAiDi.dec
    inp = Woerter[211];
    //BetriebsZustaende.dec
    inp = Woerter[212];
    BetriebsZustaende = dezInt(out,8);
    //DoBuffer.dec
    inp = Woerter[213];
    DoBuffer = dezInt(out,8);
    //Bitauswertung DoBuffer
    bitauswertung(213);
    DoSammelstoermeldung = Bit3;
    DoStufe2 = Bit5;
    //DiBuffer.dec
    inp = Woerter[214];
    DiBuffer = dezInt(out,8);
    //Bitauswertung DiBuffer
    bitauswertung(214);
    //GesStatus
    inp = Woerter[215];
    Merker1 = dezInt(out,8);
    inp = Woerter[216];
    Merker2 = dezInt(out,8);
    GesStatus = Merker1+ "&nbsp;" +Merker2;
    //StatusVerriegelung
    inp = Woerter[217];
    inp = Woerter[218];
    StatusVerriegelung = Merker1+ "&nbsp;" +Merker2;
    //StatusHeiz
    inp = Woerter[219];
    inp = Woerter[220];
    StatusHeiz = Merker1+ "&nbsp;" +Merker2;
    //StatusKuehl
    inp = Woerter[221];
    inp = Woerter[222];
    StatusKuehl = Merker1+ "&nbsp;" +Merker2;
    //StatusStufe2
    inp = Woerter[223];
    inp = Woerter[224];
    StatusStufe2 = Merker1+ "&nbsp;" +Merker2;
    //StatusWWasser
    inp = Woerter[225];
    inp = Woerter[226];
    StatusWWasser = Merker1+ "&nbsp;" +Merker2;
    //StatusWPumpe
    inp = Woerter[227];
    inp = Woerter[228];
    StatusWPumpe = Merker1+ "&nbsp;" +Merker2;
    //ModeHeiz.dec
    inp = Woerter[229];
    ModeHeiz = dezInt(out,8);
    //Bitauswertung ModeHeizung
    bitauswertung(229);
    ModeHeizEINNormal = Bit1;
    ModeHeizEINSolar = Bit2;
    ModeHeizEinextAnhebung = Bit3;
    ModeHeizEINSchnellaufheidzung = Bit4;
    ModeHeizAUSZeitprogramm = Bit5;
    ModeHeizAUSUnterdrueckung = Bit6;
    ModeHeizAUSkeinBedarf = Bit7;
    ModeHeizAUSwFuehlerf = Bit8;
    //ModeKuehl.dec
    inp = Woerter[230];
    ModeKuehl = dezInt(out,8);
    //Bitauswertung ModeKuehlen
    bitauswertung(230);
    ModeKuehlEINNormal = Bit1;
    ModeKuehlAUS = Bit2;
    ModeKuehlAUSUnterdrueckung = Bit3;
    ModeKuehlAUSkeinBedarf = Bit4;
    ModeKuehlAUSUnterbrechwFuehlerf = Bit5;
    //ModeWWasser
    inp = Woerter[231];
    ModeWWasser = dezInt(out,8);
    //Bitauswertung ModeWWasser
    bitauswertung(231);
    ModeWWassserINNormal = Bit1;
    ModeWWasserEINSolar = Bit2;
    ModeWWasserAUSZeitprogramm = Bit3;
    ModeWWasserAUSkeinBedarf = Bit4;
    ModeWWasserAUSUnterbrwFuehlerf = Bit5;
    ModeWWasserAUSUnterdrueckung = Bit6;
    ModeWWasserSolar = Bit7;
    ModeWWasserAUSSolarNutzung = Bit8;
    //LoggerError
    inp = Woerter[232];
    LoggerError = out;
    //LoggerInitTime
    inp = Woerter[235];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[234];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[233];
    out =dezInt(out,2);
    Merker3 = out;
    LoggerInitTime = Merker1+ ":" +Merker2+ ":" +Merker3;
    //LoggerInitDate
    inp = Woerter[236];
    out =dezInt(out,2);
    Merker1 = out;
    inp = Woerter[237];
    out =dezInt(out,2);
    Merker2 = out;
    inp = Woerter[238];
    out =dezInt(out,2);
    Merker3 = out;
    LoggerInitDate = Merker1+ "." +Merker2+ "." +Merker3;
    //LoggerMaxRec
    inp = Woerter[239]+ Woerter[240];
    LoggerMaxRec = out;
    //LoggerActRec
    inp = Woerter[241]+ Woerter[242];
    LoggerActRec = out;
    //LoggerMaxActRec
    inp = Woerter[243]+ Woerter[244];
    LoggerMaxActRec = out;
    //LoggerSizeOfData
    inp = Woerter[245]+ Woerter[246];
    LoggerSizeOfData = out;
    //LoggerSizeOfDatenLoggerBuffer
    inp = Woerter[247]+ Woerter[248];
    LoggerSizeOfDatenLoggerBuffer = out;
    //Handabschaltung
    inp = Woerter[249];
    Handabschaltung = out;
    //Hzg Einsatzzeitpunkt Sollwert
    //HzgEinsatzzeitpunktSollwert = IEEE754_Hex32ToDez(Woerter[253]+ Woerter[252]+ Woerter[251]+ Woerter[250]);
    //Hzg Ruecklauf Sollwert am Einsatzp.
    //HzgRuecklaufSollwertamEinsatzp = IEEE754_Hex32ToDez(Woerter[257]+ Woerter[256]+ Woerter[255]+ Woerter[254]);
    //Heizkennline Steigung Soll
    //HeizkennlineSteigungSoll = IEEE754_Hex32ToDez(Woerter[261]+ Woerter[260]+ Woerter[259]+ Woerter[258]);
    //Heizkennline Obere Begrenzung
    //HeizkennlineObereBegrenzung = IEEE754_Hex32ToDez(Woerter[265]+ Woerter[264]+ Woerter[263]+ Woerter[262]);
    //Heizung - Sollwertanhebung 4k fuer 24 Stunden
    inp = Woerter[266];
    HeizgSollwertanhebung4kfuer24h = out
    //Pilotraum Sollwert
    //PilotraumSollwert = IEEE754_Hex32ToDez(Woerter[270]+ Woerter[269]+ Woerter[268]+ Woerter[267]);
    //Pilotraum Faktor
    inp = Woerter[271];
    PilotraumFaktor = out;
    //Externe Anhebung
    //ExterneAnhebung = IEEE754_Hex32ToDez(Woerter[275]+ Woerter[274]+ Woerter[273]+ Woerter[272]);
    //Freigabe Heizung
    inp = Woerter[278];
    Merker1 = out;
    inp = Woerter[277];
    Merker2 = out;
    inp = Woerter[276];
    Merker3 = out;
    FreigabeHeizung = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Sperren Heizung
    inp = Woerter[281];
    Merker1 = out;
    inp = Woerter[280];
    Merker21 = out;
    inp = Woerter[279];
    Merker3 = out;
    SperrenHeizung = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Sollwertaenderung Ein
    inp = Woerter[284];
    Merker1 = out;
    inp = Woerter[283];
    Merker2 = out;
    inp = Woerter[282];
    Merker3 = out;
    SollwertaenderungEin = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Sollwertaenderung Aus
    inp = Woerter[287];
    Merker1 = out;
    inp = Woerter[286];
    Merker2 = out;
    inp = Woerter[285];
    Merker3 = out;
    SollwertaenderungAus = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Stufe 2 Kl. Obere Begrenzung
    //St2KlObereBegrenzung = IEEE754_Hex32ToDez(Woerter[291]+ Woerter[290]+ Woerter[289]+ Woerter[288]);
    //Kennlinie Hysterese
    //KennlinieHysterese = IEEE754_Hex32ToDez(Woerter[295]+ Woerter[294]+ Woerter[293]+ Woerter[292]);
    //Pumpen Nachlaufzeit
    inp = Woerter[296];
    PumpenNachlaufzeit = out;
    //Abschaltung Heizung
    inp = Woerter[297];
    AbschaltungHeizung = out;
    //Kuehlung Einsatzzeitpunkt
    //KuehlungEinsatzzeitpunkt = IEEE754_Hex32ToDez(Woerter[301]+ Woerter[300]+ Woerter[299]+ Woerter[298]);
    //Ruecklauftemp. Sollwert am Einsatzzeitp.
    //RuecklauftempSollwertamEinsatzzeitp = IEEE754_Hex32ToDez(Woerter[305]+ Woerter[304]+ Woerter[303]+ Woerter[302]);
    //Kuehlung Kennlinie Steigung Soll
    //KuehlungKennlinieSteigungSoll = IEEE754_Hex32ToDez(Woerter[309]+ Woerter[308]+ Woerter[307]+ Woerter[306]);
    //Kennlinie untere Begrenzung
    //KennlinieuntereBegrenzung = IEEE754_Hex32ToDez(Woerter[313]+ Woerter[312]+ Woerter[311]+ Woerter[310]);
    //Abschaltung Warmwasser
    inp = Woerter[314];
    AbschaltungWW = out;
    //Warmwasser Zeit ein
    inp = Woerter[317];
    Merker1 = out;
    inp = Woerter[316];
    Merker2 = out;
    inp = Woerter[315];
    Merker3 = out;
    WWZeitEin = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Warmwasser Zeit aus
    inp = Woerter[320];
    Merker1 = out;
    inp = Woerter[319];
    Merker2 = out;
    inp = Woerter[318];
    Merker3 = out;
    WWZeitAus = Merker1+ ":" +Merker2+ ":" +Merker3;
    //Warmwasser Soll
    //WWSoll = IEEE754_Hex32ToDez(Woerter[324]+ Woerter[323]+ Woerter[322]+ Woerter[321]);
    //Beckenwasser Temperatur Soll
    //BeckenwasserTempSoll = IEEE754_Hex32ToDez(Woerter[328]+ Woerter[327]+ Woerter[326]+ Woerter[325]);
    //Warmwasser Hysterese
    //WarmwasserHysterese = IEEE754_Hex32ToDez(Woerter[332]+ Woerter[331]+ Woerter[330]+ Woerter[329]);
    //Beckenwasser Hysterese
    //BeckenwasserHysterese = IEEE754_Hex32ToDez(Woerter[336]+ Woerter[335]+ Woerter[334]+ Woerter[333]);
    //Modem Klingelzeichen
    inp = Woerter[337];
    ModemKlingelzeichen = out;
    //Fremdzugriff
    inp = Woerter[338];
    Fremdzugriff = out;
    //Schluesselnummer
    inp = Woerter[339];
    Schluesselnummer = out;
    //SetBetriebsMode
    inp = Woerter[340];
    Merker1 = out;
    inp = Woerter[341];
    Merker2 = out;
    inp = Woerter[342];
    Merker3 = out;
    SetBetriebsMode = Merker1+ "." +Merker2+ "." +Merker3;
    //Hzg: Externe Freigabe
    inp = Woerter[343];
    HzgExterneFreigabe = out;
    //Hzg: Externe Ruecklaufsteuerung
    //HzgExterneRuecklaufsteuerung = IEEE754_Hex32ToDez(Woerter[347]+ Woerter[346]+ Woerter[345]+ Woerter[344]);
    //St2: TempQAus < Min
    //St2TempQAusMin = IEEE754_Hex32ToDez(Woerter[351]+ Woerter[350]+ Woerter[349]+ Woerter[348]);
    //St2: TempVerd < Min
    //St2TempVerdMin = IEEE754_Hex32ToDez(Woerter[355]+ Woerter[354]+ Woerter[353]+ Woerter[352]);
    //Estrich Aufheizen
    inp = Woerter[356];
    EstrichAufheizen = out;
    //Hzg: Externe Steuerung
    inp = Woerter[357];
    HzgExterneSteuerung = out;
    //St2 bei EVU Absch.
    inp = Woerter[358];
    St2beiEVUAbsch = out;
    //Frg. Beckenwasser
    inp = Woerter[359];
    FrgBeckenwasser = out;
    //Scale Faktor
    //ScaleFaktor = IEEE754_Hex32ToDez(Woerter[363]+ Woerter[362]+ Woerter[361]+ Woerter[360]);
    //Offset Niederdr.
    //OffsetNiederdr = IEEE754_Hex32ToDez(Woerter[367]+ Woerter[366]+ Woerter[365]+ Woerter[364]);
    //Offset Hochdr.
    //OffsetHochdr = IEEE754_Hex32ToDez(Woerter[371]+ Woerter[370]+ Woerter[369]+ Woerter[368]);
    //DO-Handkanal
    inp = Woerter[372];
    DoHandkanal = out
    //DO-Handkanal Ein
    inp = Woerter[373];
    DoHandkanalEin = out;
    //Unterdrückung Warnmeldungen Eingänge
    inp = Woerter[374];
    UnterdrWarnEin = dezInt(out,8);
    //Unterdrückung Warnmeldungen Ausgänge
    inp = Woerter[375];
    UnterdrWarnAus = dezInt(out,8);
    //Unterdrückung Warnmeldungen Sonstige
    inp = Woerter[376];
    UnterdrWarnSonst = dezInt(out,8);
    //Neu-Start
    inp = Woerter[377];
    NeuStart = out;
    //Run-Flag
    inp = Woerter[378];
    RunFlag = out;
    console.log('Temp aussen ist:' + TempAussenIst);
    setState('Waterkotte.Daten.Version', VersionsNr);
    setState('Waterkotte.Daten.Temp_Aussen_Ist', TempAussenIst);
    setState('Waterkotte.Daten.Temp_Aussen_24h', TempAussen24h);
    setState('Waterkotte.Daten.Temp_Aussen_1h', TempAussen1h);
    setState('Waterkotte.Daten.Temp_Ruecklauf_Soll', TempRuecklaufSoll);
    setState('Waterkotte.Daten.Temp_Ruecklauf_Ist', TempRuecklaufIst);
    setState('Waterkotte.Daten.Temp_Vorlauf', TempVorlauf);
    setState('Waterkotte.Daten.Temp_WW_Soll', TempWWSoll);
    setState('Waterkotte.Daten.Temp_WW_Ist', TempWWIst);
    setState('Waterkotte.Daten.Temp_Raum', TempRaum);
    setState('Waterkotte.Daten.Temp_Raum_1h', TempRaum1h);
    setState('Waterkotte.Daten.Temp_WQuelle_Ein', TempWQuelleEin);
    setState('Waterkotte.Daten.Temp_WQuelle_Aus', TempWQuelleAus);
    setState('Waterkotte.Daten.Temp_Verdampfer', TempVerdampfer);
    setState('Waterkotte.Daten.Temp_Kondensator', TempKondensator);
    setState('Waterkotte.Daten.Temp_Saugleitung', TempSaugleitung);
    setState('Waterkotte.Daten.Temp_frei', Tempfrei);
    setState('Waterkotte.Daten.Druck_Verdampfer', DruckVerdampfer);
    setState('Waterkotte.Daten.Druck_Kondensator', DruckKondensator);
    setState('Waterkotte.Daten.Status_Heizung', StatusHeiz);
    setState('Waterkotte.Daten.Status_Handabschaltung',Handabschaltung);
    setState('Waterkotte.Daten.Status_Warmwasser', StatusWWasser);
    setState('Waterkotte.Daten.Status_WPumpe', StatusWPumpe);
    setState('Waterkotte.Daten.Mode_Heizung', ModeHeiz);
    setState('Waterkotte.Daten.Mode_Heizung_EIN_Normal', ModeHeizEINNormal);
    setState('Waterkotte.Daten.Mode_Heizung_EIN_Solar', ModeHeizEINSolar);
    setState('Waterkotte.Daten.Mode_Heizung_EIN_externe_Anhebung', ModeHeizEinextAnhebung);
    setState('Waterkotte.Daten.Mode_Heizung_EIN_Schnellaufheizung', ModeHeizEINSchnellaufheidzung);
    setState('Waterkotte.Daten.Mode_Heizung_AUS_Zeitprogramm', ModeHeizAUSZeitprogramm);
    setState('Waterkotte.Daten.Mode_Heizung_AUS_Unterdrueckung', ModeHeizAUSUnterdrueckung);
    setState('Waterkotte.Daten.Mode_Heizung_AUS_kein_Bedarf', ModeHeizAUSkeinBedarf);
    setState('Waterkotte.Daten.Mode_Heizung_AUS_wegen_Fuehlerfehler', ModeHeizAUSwFuehlerf);
    setState('Waterkotte.Daten.Mode_Warmwasser', ModeWWasser);
    setState('Waterkotte.Daten.Mode_Warmwasser_EIN_Normal', ModeWWassserINNormal);
    setState('Waterkotte.Daten.Mode_Warmwasser_EIN_Solar', ModeWWasserEINSolar);
    setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Zeitprogramm', ModeWWasserAUSZeitprogramm);
    setState('Waterkotte.Daten.Mode_Warmwasser_AUS_kein_Bedarf', ModeWWasserAUSkeinBedarf);
    setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterbrechung_wegen_Fuehlerfehler', ModeWWasserAUSUnterbrwFuehlerf);
    setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterdrueckung', ModeWWasserAUSUnterdrueckung);
    setState('Waterkotte.Daten.Mode_Warmwasser_Solar', ModeWWasserSolar);
    setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Solarnutzung', ModeWWasserAUSSolarNutzung);
    setState('Waterkotte.Daten.Mode_Kuehlung_EIN_Normal', ModeKuehlEINNormal);
    setState('Waterkotte.Daten.Mode_Kuehlung_AUS', ModeKuehlAUS);
    setState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung', ModeKuehlAUSUnterdrueckung);
    setState('Waterkotte.Daten.Mode_Kuehlung_AUS_kein_Bedarf', ModeKuehlAUSkeinBedarf);
    setState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung_wegen_Fuehlerfehler', ModeKuehlAUSUnterbrechwFuehlerf);
    setState('Waterkotte.Daten.DI_Motorschutz_Kompressor', DiMotorschutzkompressor);
    setState('Waterkotte.Daten.DI_Niederdruck_Pressostat', DiNiederdruckPressostat);
    setState('Waterkotte.Daten.DI_Hochdruck_Pressostat', DiHochdruckPressostat);
    setState('Waterkotte.Daten.DI_Pumpe_Quelle', DiPumpeQuelle);
    setState('Waterkotte.Daten.DI_Externe_Sollwertbeeinflussung', DiExterneSollwertbeeinflussung);
    setState('Waterkotte.Daten.DI_Externe_Abschaltung', DiExterneAbschaltung);
    setState('Waterkotte.Daten.DO_Magnetventil', DoMagnetventil);
    setState('Waterkotte.Daten.DO_Kompressor1', DoKompressor1);
    setState('Waterkotte.Daten.DO_Sammelstoermeldung', DoSammelstoermeldung);
    setState('Waterkotte.Daten.DO_Umschaltventil_Kuehlung', DoUmschaltventilKuehlung);
    setState('Waterkotte.Daten.DO_Umschaltventil_Stufe2', DoStufe2);
    setState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Heizung', DoPumpeHeizung);
    setState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Warmwasser', DoPumpeWarmwasser);
    setState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Quelle', DoPumpeQuelle);
    Blockly Script zum Starten/Stoppen der Abfrage, ist immer aktiv:
     <variables>
       <variable type="cron" id="schedule1">schedule1</variable>
     </variables>
     <block type="schedule_create" id="U^a/a|R.Ag0SUHC5`R_X" x="-512" y="-63">
       <field name="NAME">schedule1</field>
       <value name="SCHEDULE">
         <shadow type="field_cron" id="RoVW,)EZwML}A7XD8Xc/">
           <field name="CRON">12 */3 * * * *</field>
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="debug" id=";E~}`cmu%ZUC50DV#p?Y">
           <value name="TEXT">
             <shadow type="text" id="0w!y-Pmlm,f`O0?~@jC@">
               <field name="TEXT">Abfrage_Waterkotte</field>
             </shadow>
           </value>
           <next>
             <block type="controls_if" id="WEoLFzJ0#-xub!Bwhv~H">
               <value name="IF0">
                 <block type="logic_operation" id="%[579SWxQ72Thpq|e}II" inline="false">
                   <field name="OP">AND</field>
                   <value name="A">
                     <block type="logic_compare" id=";I2G)sOC7K3E#aG*1^{n">
                       <field name="OP">EQ</field>
                       <value name="A">
                         <block type="get_value" id="2wot(2t*g8UEm.+2pLu@">
                           <field name="OID">javascript.2.scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_boolean" id="/w]{^LZ9,e*gI5Na*=AX">
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="B">
                     <block type="logic_operation" id="DFqv1XTuf5Jcd6~d4Pl9">
                       <value name="A">
                         <block type="logic_compare" id="Q%hn`r~GuwSiW|`lwXy4">
                           <value name="A">
                             <block type="get_value" id="=gAZ0qIl%Q2=a)w=}wsm">
                               <field name="OID">javascript.2.scriptEnabled.Waterkotte.WW_Temp_45</field>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_boolean" id="z(f3588pY)X5T1JY`L}o">
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_compare" id="QF-a*[%R+[u!Z(LIu]Nj">
                           <value name="A">
                             <block type="get_value" id="`P_T2QF-wSoJ!ZJN0:^y">
                               <field name="OID">javascript.2.scriptEnabled.Waterkotte.WW_Temp_60</field>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_boolean" id="nI4s86@mVMZfHAb+k9u+">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="debug" id="-twd|JK7:Q5Q6+M2lTmO">
                   <value name="TEXT">
                     <shadow type="text" id="e+uKa0:h7S7tL{x@5ZIM">
                       <field name="TEXT">Aktiviere Abfrage Waterkotte</field>
                     </shadow>
                   </value>
                   <next>
                     <block type="control" id="Hh@%xY%GsRI1g208b7ce">
                       <value name="VALUE">
                         <block type="logic_boolean" id="dJ]azVd7r~N1IN8Wdlr-">
                         </block>
                       </value>
                       <next>
                         <block type="control" id="S[V15.2;~h|N4vnsb3J0">
                           <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                           <field name="DELAY_MS">3</field>
                             <block type="logic_boolean" id="c`7aVan7RyUsJ=0=)={!">
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    So sieht das im log bei mir aus:
    javascript.2	2020-11-11 17:39:15.061	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: port closed
    javascript.2	2020-11-11 17:39:15.059	info	(24856) Stop script script.js.Waterkotte.Abfrage_Waterkotte_Test
    javascript.2	2020-11-11 17:39:12.527	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Temp aussen ist:12.57
    javascript.2	2020-11-11 17:39:12.522	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Daten split:1fbe
    javascript.2	2020-11-11 17:39:12.521	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Daten split: ff 10 02 00 17 1f be 12 0c 06 03 05 29 a8 2b 49 41 17 4c 4c 41 3d 4d 53 41 2b 5d a5 41 4a a4 c1 41 69 8e d4 41 23 00 34 42 8e 8d 35 42
    javascript.2	2020-11-11 17:39:12.519	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Daten:ff100200171fbe120c06030529a82b4941174c4c413d4d53412b5da5414aa4c141698ed441230034428e8d35425238dec200007041f919e540c5cf08419e970641dc93c841000
    javascript.2	2020-11-11 17:39:12.509	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: Data received: ff100200171fbe120c06030529a82b4941174c4c413d4d53412b5da5414aa4c141698ed441230034428e8d35425238dec200007041f919e540c5cf08419e970641
    javascript.2	2020-11-11 17:39:12.160	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: Daten send
    javascript.2	2020-11-11 17:39:12.153	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: Connected
    javascript.2	2020-11-11 17:39:12.147	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: registered 0 subscriptions and 0 schedules
    javascript.2	2020-11-11 17:39:12.085	info	(24856) Start javascript script.js.Waterkotte.Abfrage_Waterkotte_Test
    javascript.2	2020-11-11 17:39:12.016	info	(24856) script.js.Waterkotte.Restart_Abfrage_Waterkotte_Test: Aktiviere Abfrage Waterkotte
    javascript.2	2020-11-11 17:39:12.014	info	(24856) script.js.Waterkotte.Restart_Abfrage_Waterkotte_Test: Abfrage_Waterkotte
    So sehen die DP's aus:
    Axel KoenekeA 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      buffer[0] = 0x10;
      buffer[1] = 0x02;
      buffer[2] = 0x01;
      buffer[3] = 0x15;
      buffer[4] = 0x00;
      buffer[5] = 0x00;
      buffer[6] = 0x00;
      buffer[7] = 0xf3;
      buffer[8] = 0x10;
      buffer[9] = 0x03;
      buffer[10] = 0x7c;
      buffer[11] = 0x32;
         baudRate: 9600,
         dataBits : 8,
         parity : 'none',
         stopBits: 1
      }, function (err) {
         if (err) {
      //        port.close();
         	//port.close();
         // Flush input
         port.flush();
         // send Data
         	    if (err) {
      // 		    port.close();
      //	port.close();
         	port.close();
      var daten;
      var Satz;
      var inp;
      var out;
      var VersionsNr;
      var TempAussenIst;
      var TempAussen24h;
      var TempAussen1h;
      var TempVorlauf;
      var TempWWSoll;
      var TempWWIst;
      var TempRaum;
      var TempRaum1h;
      var TempWQuelleEin;
      var TempWQuelleAus;
      var TempVerdampfer;
      var Tempfrei;
      var TempWWIst;
      var Zeit;
      var Datum;
      var Kennwort;
      var ResetWPumpe;
      var CrcSumme;
      var NStart;
      var DisplayZeile1;
      var DisplayZeile2;
      var AusfallTime;
      var AusfallDate;
      var AusfallAiError;
      var AusfallAiDi;
      var AusfallAuxAiDi;
      var ClearAusfaelle;
      var Unterbrechung;
      var Ausfall;
      var AiError;
      var AiDi;
      var AiCounter0;
      var AuxAiError;
      var AuxAiDi;
      var DoBuffer;
      var DiBuffer;
      var GesStatus;
      var StatusHeiz;
      var StatusKuehl;
      var StatusStufe2;
      var StatusWWasser;
      var StatusWPumpe;
      var ModeHeiz;
      var ModeKuehl;
      var ModeKuehlAUS;
      var ModeWWasser;
      var LoggerError;
      var LoggerInitTime;
      var LoggerInitDate;
      var LoggerMaxRec;
      var LoggerActRec;
      var DiPumpeQuelle;
      var DiSoleMinnimum;
      var DiBufferBit6;
      var DoMagnetventil;
      var DoKompressor1;
      var DoStufe2;
      var DoPumpeHeizung;
      var DoPumpeQuelle;
      var SperrenHeizung;
      var AbschaltungWW;
      var WWZeitEin;
      var WWZeitAus;
      var WWSoll;
      var Fremdzugriff;
      var St2TempQAusMin;
      var St2TempVerdMin;
      var St2beiEVUAbsch;
      var ScaleFaktor;
      var OffsetNiederdr;
      var OffsetHochdr;
      var DoHandkanal;
      var DoHandkanalEin;
      var UnterdrWarnAus;
      var UnterdrWarnEin;
      var NeuStart;
      var RunFlag;
      //Bitauswertung
      //Bit 1
      out &= 1;
       else { Bit1 = 0; }
      //Bit 2
      out &= 2;
       else { Bit2 = 0; }
      //Bit 3
      out &= 4;
       else { Bit3 = 0; }
      //Bit 4
      out &= 8;
       else { Bit4 = 0; }
      //Bit 5
      out &= 16;
       else { Bit5 = 0; }
      //Bit 6
      out &= 32;
       else { Bit6 = 0; }
      //Bit 7
      out &= 64;
       else { Bit7 = 0; }
      //Bit 8
      out &= 128;
       else { Bit8 = 0; }
         dez = dez*100;
         dez = dez/100;
       return(dez);
      i = 0;
      var Satz = [];
         i=i+2;
      VersionsNr = out;
      inp = Woerter[8];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[9];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[10];
      out =dezInt(out,2);
      Merker3 = out;
      inp = Woerter[11];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[12];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[13];
      out =dezInt(out,2);
      Merker3 = out;
      //Temp-WQuelle-Ein
      //Temp-WQuelle-Aus
      //Temp-Verdampfer
      //Temp-Kondensator
      //Temp-Saugleitung
      //Temp-frei
      //Druck-Verdampfer
      //Druck-Kondensator
      //Zeit
      inp = Woerter[108];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[107];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[106];
      out =dezInt(out,2);
      Merker3 = out;
      //Datum
      inp = Woerter[109];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[110];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[111];
      out =dezInt(out,2);
      Merker3 = out;
      inp = Woerter[128];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[129];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[130];
      out =dezInt(out,2);
      Merker3 = out;
      inp = Woerter[133];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[132];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[131];
      out =dezInt(out,2);
      Merker3 = out;
      inp = Woerter[134];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[135];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[136];
      out =dezInt(out,2);
      Merker3 = out;
      inp = Woerter[139];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[138];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[137];
      out =dezInt(out,2);
      Merker3 = out;
      inp = Woerter[140];
      inp = Woerter[141];
      //Kennwort
      inp = Woerter[142];
      inp = Woerter[143];
      //Reset WPumpe
      inp = Woerter[144];
      //Crc Summe
      //NStart
      inp = Woerter[147];
      //Display Zeile 1
      //Display Zeile 2
      inp = Woerter[150];
      //AusfallTime
      inp = Woerter[153];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[152];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[151];
      out =dezInt(out,2);
      Merker3 = out;
      //Ausfalldatum
      inp = Woerter[154];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[155];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[156];
      out =dezInt(out,2);
      Merker3 = out;
      inp = Woerter[157];
      inp = Woerter[158];
      bitauswertung(158);
      inp = Woerter[159];
      inp = Woerter[160];
      //AusfallAiDi.dec
      inp = Woerter[161];
      inp = Woerter[194];
      inp = Woerter[195];
      //AusfallAiTempRaum
      //ClearAusfaelle
      inp = Woerter[200];
      //Unterbrechung.dec
      inp = Woerter[201];
      inp = Woerter[202];
      bitauswertung(202);
      inp = Woerter[203];
      bitauswertung(203);
      inp = Woerter[204];
      bitauswertung(204);
      //Ausfall.dec
      inp = Woerter[205];
      //AiError.dec
      inp = Woerter[206];
      //AiDi.dec
      inp = Woerter[207];
      //AiCounter0
      AiCounter0 = out;
      //AuxAiError.dec
      inp = Woerter[210];
      //AuxAiDi.dec
      inp = Woerter[211];
      inp = Woerter[212];
      //DoBuffer.dec
      inp = Woerter[213];
      bitauswertung(213);
      DoStufe2 = Bit5;
      //DiBuffer.dec
      inp = Woerter[214];
      bitauswertung(214);
      //GesStatus
      inp = Woerter[215];
      inp = Woerter[216];
      inp = Woerter[217];
      inp = Woerter[218];
      //StatusHeiz
      inp = Woerter[219];
      inp = Woerter[220];
      //StatusKuehl
      inp = Woerter[221];
      inp = Woerter[222];
      //StatusStufe2
      inp = Woerter[223];
      inp = Woerter[224];
      //StatusWWasser
      inp = Woerter[225];
      inp = Woerter[226];
      //StatusWPumpe
      inp = Woerter[227];
      inp = Woerter[228];
      //ModeHeiz.dec
      inp = Woerter[229];
      bitauswertung(229);
      //ModeKuehl.dec
      inp = Woerter[230];
      bitauswertung(230);
      //ModeWWasser
      inp = Woerter[231];
      bitauswertung(231);
      //LoggerError
      inp = Woerter[232];
      LoggerError = out;
      //LoggerInitTime
      inp = Woerter[235];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[234];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[233];
      out =dezInt(out,2);
      Merker3 = out;
      //LoggerInitDate
      inp = Woerter[236];
      out =dezInt(out,2);
      Merker1 = out;
      inp = Woerter[237];
      out =dezInt(out,2);
      Merker2 = out;
      inp = Woerter[238];
      out =dezInt(out,2);
      Merker3 = out;
      //LoggerMaxRec
      LoggerMaxRec = out;
      //LoggerActRec
      LoggerActRec = out;
      //LoggerMaxActRec
      //LoggerSizeOfData
      //Handabschaltung
      inp = Woerter[249];
      inp = Woerter[266];
      //Pilotraum Faktor
      inp = Woerter[271];
      //Externe Anhebung
      //Freigabe Heizung
      inp = Woerter[278];
      Merker1 = out;
      inp = Woerter[277];
      Merker2 = out;
      inp = Woerter[276];
      Merker3 = out;
      //Sperren Heizung
      inp = Woerter[281];
      Merker1 = out;
      inp = Woerter[280];
      Merker21 = out;
      inp = Woerter[279];
      Merker3 = out;
      inp = Woerter[284];
      Merker1 = out;
      inp = Woerter[283];
      Merker2 = out;
      inp = Woerter[282];
      Merker3 = out;
      inp = Woerter[287];
      Merker1 = out;
      inp = Woerter[286];
      Merker2 = out;
      inp = Woerter[285];
      Merker3 = out;
      inp = Woerter[296];
      inp = Woerter[297];
      inp = Woerter[314];
      inp = Woerter[317];
      Merker1 = out;
      inp = Woerter[316];
      Merker2 = out;
      inp = Woerter[315];
      Merker3 = out;
      inp = Woerter[320];
      Merker1 = out;
      inp = Woerter[319];
      Merker2 = out;
      inp = Woerter[318];
      Merker3 = out;
      //Warmwasser Soll
      inp = Woerter[337];
      //Fremdzugriff
      inp = Woerter[338];
      Fremdzugriff = out;
      //Schluesselnummer
      inp = Woerter[339];
      //SetBetriebsMode
      inp = Woerter[340];
      Merker1 = out;
      inp = Woerter[341];
      Merker2 = out;
      inp = Woerter[342];
      Merker3 = out;
      inp = Woerter[343];
      //Estrich Aufheizen
      inp = Woerter[356];
      inp = Woerter[357];
      inp = Woerter[358];
      //Frg. Beckenwasser
      inp = Woerter[359];
      //Scale Faktor
      //Offset Niederdr.
      //Offset Hochdr.
      //DO-Handkanal
      inp = Woerter[372];
      DoHandkanal = out
      //DO-Handkanal Ein
      inp = Woerter[373];
      inp = Woerter[374];
      inp = Woerter[375];
      inp = Woerter[376];
      //Neu-Start
      inp = Woerter[377];
      NeuStart = out;
      //Run-Flag
      inp = Woerter[378];
      RunFlag = out;
       <variables>
       </variables>
           </shadow>
         </value>
             <value name="TEXT">
               </shadow>
             </value>
             <next>
                 <value name="IF0">
                     <value name="A">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                     <value name="B">
                         <value name="A">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                     <value name="TEXT">
                       </shadow>
                     </value>
                     <next>
                           </block>
                         </value>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </statement>
       </block>
      </xml>
      Axel KoenekeA Offline
      Axel Koeneke
      #42
      @wendy2702 Moin, es finktioniert leider immer noch nicht.
      Beim Blockly habe ich mal die UND-Verknüpfung entfernt. Vermutlich hast du da noch ein anderes Script mit drin.
      Die Instanzen habe ich überall bei mir auf ".0." gesetzt.
      Beim Aufruf musste ich das Abfrage-Script unter .common. ansprechen.
      Ich vermute ganz stark das an der Schnittstelle liegt. Kann ich die irgendwie unter iO prüfen?
      VG
      Axel
      • Axel KoenekeA Axel Koeneke
        VG
        Axel
        Axel Koeneke
        #43
        @Axel-Koeneke Juhu, habe es gefunden:
        Schnittstelle hat mich auf die Idee gebracht mal meine Instanzen zu checken.
        Das Problem war der Multihost Modus. Dies hatte ich dato noch nie berücksichtigen müssen.
        Also habe ich einen zweiten JS-Adapter installiert und dazu noch eine Instanz. Beides dem Client zugewiesen und dann noch den Scripten gesagt das sie auf dem Client laufen sollen. Evtl. sollte man die Doku dazu nochmal erweitern.
        Vielen Dank für das geile Script. Werde meine Visu demnächst mal posten.
        VG
        Axel
          VG
          Axel
          wendy2702W Offline
          wendy2702W Offline
          wendy2702
          #44
          @Axel-Koeneke Sorry... hättest du das mit dem Multihost mal erwähnt wären wir der Sache schneller auf die Schliche gekommen.
          Aber nun ist ja gut.
          Bin mal auf deine Visu gespannt.
            Axel Koeneke
            #45
            @wendy2702 Moin, leider habe noch ein kleines Problem: Die Werte wurden nur einmal übertragen. Ich sehe auch im Log keinen Fehler... Muss ich am Wochenende noch mal in Ruhe drüber schauen.
            Hier mal ein Screenshot:
            Ich kann morgen auch mal die View hochladen.
            VG
            Axel
              VG
              Axel
              wendy2702W Offline
              wendy2702W Offline
              wendy2702
              #46
              @Axel-Koeneke was heißt immer nur einmal?
              Ablauf bei mir ist so:
              Das Blockly Script aktiviert das Abfrage Script, nach 3 Sekunden wird es wieder deaktiviert damit der Com Port geschlossen wird. Langer string wird ausgelesen und vom auswerte Script entschlüsselt.
              Nach 3 Minuten beginnt das von vorne.
              Das die Werte nur einmal ausgelesen werden könnte daran liegen das der COM Port noch geschlossen wird. Das hatte ich zu Beginn als ich das anfrage Script per Cron gestartet/gestoppt hatte.
                Axel Koeneke
                #47
                @wendy2702 sagte in Script Hilfe für Abfrage Serielle Kommunikation gesucht!:
                Ich werde es morgen testen. Was mir noch aufgefallen ist, sehe ich auch den Status der Pumpe?
                Vielleicht erkenne ich es auch nicht, weil ich ja aktuell keine Änderung habe...
                  wendy2702W Offline
                  wendy2702W Offline
                  wendy2702
                  #48
                  @Axel-Koeneke gibt zwei DP's für Pumpe. Ich meine die Verändern sich auch bei mir je nach Status.
                    Axel Koeneke
                    #49
                    @wendy2702 Moin, läuft jetzt alles richtig gut. Abfrage machen ich alle 30 sek. Ich habe noch im Intervall Blockly einen zusätzlichen Datenpunkt für die Warmwasserpumpe erstellt. Außerdem färbe ich die Rohrleitung hinter dem 3-Wege-Ventil ein, damit ich sehe ob gerade Heizung oder Warmwassererzeugung läuft.
                    Dies habe ich schon lange vermisst, da ich in drei Kellerräumen Kovektorheizkörper habe, welche an der Wärmepumpe hängen und die Wärme mittels Ventilator abgeben. Wenn der Ventilator läuft, aber die WP keine Wärme erzeugt, bläst das eher unangenehm in den Raum. Jetzt kann ich bei Bedarf und wenn die WP auf Heizbetrieb ist, mittels Funksteckdose die Gebläse zuschalten.
                    Hier die View:
                    Waermepumpe.txt
                    Die Grafik als svg - Bitte Endung anpassen.
                    Waterkotte.svg.txt
                    VG
                    Axel
                    wendy2702W 2 Antworten Letzte Antwort
                      Hier die View:
                      Waermepumpe.txt
                      Waterkotte.svg.txt
                      VG
                      Axel
                      wendy2702W Offline
                      wendy2702W Offline
                      wendy2702
                      #50
                      @Axel-Koeneke Hi, kannst du mir sagen welche Widget Sätze du für den View verwendet hast und wo du das SVG abgelegt hast?
                      Und wieso hast du eine SVG Grafik hochgeladen? Laut deinem View Export benutzt du eine "png" ?
                      Wenn ich die SVG im Widget auswähle passen die Seitenverhältnisse nicht.
                      Kannst du das Bild bitte nochmal hochladen. Irgendwie kann ich das nur mit einem Browser öffnen und dann ist ein Teil davon abgeschnitten.
                      Danke!
                        Danke!
                        Axel Koeneke
                        #51
                        @wendy2702 Moin, ich benutze fast ausschließlich die InvenTwo Widgets.
                        In der View hast du richtig erkannt benutze ich die PNG Grafik. Die SVG habe ich hochgeladen, damit du sie z.B. mit Inkscape nach deinen Bedürfnissen anpassen kannst. Dazu einfach das ".TXT" an Ende entfernen und mit Inkscape bearbeiten. Ich werde mal mein Projekt aufräumen (Grafiken in vernünftige Ordnerstrukturen packen) und kann ich es als Projekt hochladen.
                        VG
                        Axel
                          Hier die View:
                          Waermepumpe.txt
                          Waterkotte.svg.txt
                          VG
                          Axel
                          wendy2702W Offline
                          wendy2702W Offline
                          wendy2702
                          #52
                          @axel-koeneke sagte in Script Hilfe für Abfrage Serielle Kommunikation gesucht!:
                          kannst du mir das mal kurz zeigen.
                            Axel Koeneke
                            schrieb am zuletzt editiert von Axel Koeneke
                            #53
                            Ich habe das zusammen mit dem Soll-, Istwert des Homematic Thermostaten gekoppelt.
                            Außerdem soll das nur passieren, wenn der PC in dem Raum läuft (IP)
                              wendy2702W Offline
                              wendy2702W Offline
                              wendy2702
                              #54
                              @axel-koeneke Hallo Axel,
                              Danke für die Antwort aber ich glaube wir haben uns missverstanden.
                              Du hast geschrieben das zu einen Datenpunkt erstellt hast, dein Blockly zeigt aber nur wie du nach Zeitplan etwas steuerst.
                              Icn deinem View benutzt du hier:
                              In dem Widget das den Grünen Kreis einblendet diesen DP:
                              Diesen Datenpunkt gibt es aber bei mir nicht und ich wollte wissen wie du diesen erstellt hast bzw. welcher wert aus den Rohdaten den befüllt.
                              Danke und Gruß
                                Danke und Gruß
                                Axel Koeneke
                                #55
                                @wendy2702 Okay siehe hier:
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  wendy2702
                                  #56
                                  @axel-koeneke Danke!
                                  E 1 Antwort Letzte Antwort
                                    etzeste13
                                    #57
                                    @wendy2702
                                    Hallo, dieser Post sieht sehr interessant aus, habe auch eine Waterkotte mit Resümat4 Steuerung im Betrieb und würde die Steuerung gerne in den ioBroker übernehmen. Eine grundlege Frage habe ich zu eurer Lösung: Ist mit eurer Lösung nur das Auslesen des aktuellen Status der WP möglich, oder könnt Ihr auch Sollwerte, wie die Basistemperatur oder WW-Temperatur ändern?
                                    vG
                                    Etze
                                    • E etzeste13
                                      @wendy2702
                                      vG
                                      Etze
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      wendy2702
                                      #58
                                      @etzeste13
                                      Sollwerte schreiben geht auch. Wegen Belegung der COM Schnittstelle minimal aufwendiger.
                                      Ich ändere zum Beispiel in Abhängigkeit von der PV Erzeugung die Wassertemperatur um Energie im Warmwasser zu speichern.
                                        Hi Franz,
                                        die Daten liegen jetzt mit diesem Script komplett im Datenpunkt: (funktioniert zumindest bei mir :D )
                                        ! // To use the ByteLength parser:
                                        ! var buffer = new Buffer(12);
                                        buffer[0] = 0x10;
                                        buffer[1] = 0x02;
                                        buffer[2] = 0x01;
                                        buffer[3] = 0x15;
                                        buffer[4] = 0x00;
                                        buffer[5] = 0x00;
                                        buffer[6] = 0x00;
                                        buffer[7] = 0xf3;
                                        buffer[8] = 0x10;
                                        buffer[9] = 0x03;
                                        buffer[10] = 0x7c;
                                        buffer[11] = 0x32;
                                        const port = new SerialPort("/dev/ttyUSB0", {
                                        baudRate: 9600,
                                        dataBits : 8,
                                        parity : 'none',
                                        stopBits: 1
                                        }, function (err) {
                                        if (err) {
                                        return console.log('Error1: ', err.message);
                                        ! const parser = port.pipe(new ByteLength({ length: 253 }));
                                        setState('Waterkotte.Daten.Rohdaten', daten, true);
                                        //port.close();
                                        ! // Flush input
                                        port.flush();
                                        ! // send Data
                                        if (err) {
                                        // port.close();
                                        ! port.on('open', function() {
                                        ! port.on('error', function(err) {
                                        // port.close();
                                        ! // close port if the script stopped (to be able to open it again)
                                        port.close();
                                        Jetzt kann man Theoretisch das Script per CRON alle paar Sekunden/Minuten neu starten.. finde ich nicht so schön und werde versuchen ob ich es schaffe das der Port aufbleiben kann und nur die Anfrage alle "30sek" neu gesendet wird. Oder ist der Intervall zu groß?
                                        EDIT_Script bisschen aufgeräumt
                                        Mirko
                                        Ich bekomme es nicht zum laufen - Error 1
                                        hier mal mein script:
                                        //! // To use the ByteLength parser:
                                        buffer[0] = 0x10;
                                        buffer[1] = 0x02;
                                        buffer[2] = 0x01;
                                        buffer[3] = 0x15;
                                        buffer[4] = 0x00;
                                        buffer[5] = 0x00;
                                        buffer[6] = 0x00;
                                        buffer[7] = 0xf3;
                                        buffer[8] = 0x10;
                                        buffer[9] = 0x03;
                                        buffer[10] = 0x7c;
                                        buffer[11] = 0x32;
                                        baudRate: 9600,
                                        dataBits : 8,
                                        parity : 'none',
                                        stopBits: 1
                                        }, function (err) {
                                        if (err) {
                                        //port.close();
                                         // Flush input
                                        port.flush();
                                         // send Data
                                        if (err) {
                                        // port.close();
                                        // port.close();
                                        port.close();
                                        Das script hier im Fred ist ja schon etwas älter, evtl. muss hier noch etwas angepasst werden.
                                        Außerdem sieht das hier seltsam aus:
                                        Warum streicht es das Buffer durch?
                                        Habt ihr noch eine Idee?
                                        VG
                                        Axel
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #59
                                        Der Konstruktor new Buffer ist deprecated. Stattdessen sollte Buffer.from verwendet werden:
                                        https://nodejs.org/api/buffer.html#buffer_new_buffer_array
                                          @etzeste13
                                          etzeste13
                                          #60
                                          @wendy2702
                                          Danke für die Schnelle Antwort. Das ist genau auch die Anwendung die ich bräuchte....;-)
                                          Kannst du mir die nötigen Skripte dafür zusenden, dann versuche ich das auch mal bei mir.
                                          Vielen Dank im Voraus und lG!!
