  4. iobroker mit Docker: Kann keine Ports mehr durchschleifen
100 Beiträge 10 Kommentatoren 12.3k Aufrufe 5 Beobachtet
  • P pingo
    @glasfaser said in iobroker mit Docker: Kann keine Ports mehr durchschleifen:
    curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    <Skript v.2023-01-02
    *** BASE SYSTEM ***
    Architecture: x86_64
    Docker: false
    Virtualization: Unknown (buanet/Synology?)
    diag.sh: line 66: lsb_release: command not found
    cat: /etc/os-release: No such file or directory
    Systemuptime and Load:
    15:19:58 up 1 day, 20:09, 1 user, load average: 0.88, 0.86, 0.69 [IO: 0.71, 0.57, 0.37 CPU: 0.17, 0.27, 0.27]
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Mar 19 14:19:58 UTC 2023
    Sun Mar 19 15:19:58 CET 2023
    CET +0100
    cat: /etc/timezone: No such file or directory
    *** User and Groups ***
    root
    /root
    diag.sh: line 83: groups: command not found
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal:
    Boot Target: syno-bootup-done.target
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 3.8G 2.0G 120M 22M 1.6G 1.5G
    Swap: 4.3G 554M 3.8G
    Total: 8.1G 2.6G 3.9G
    diag.sh: line 100: vmstat: command not found
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/md0 ext4 2.3G 2.0G 252M 89% /
    devtmpfs devtmpfs 1.9G 0 1.9G 0% /dev
    tmpfs tmpfs 1.9G 2.2M 1.9G 1% /dev/shm
    tmpfs tmpfs 1.9G 17M 1.9G 1% /run
    tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
    tmpfs tmpfs 1.9G 1.7M 1.9G 1% /tmp
    /dev/mapper/cachedev_0 ext4 28T 22T 6.0T 78% /volume1
    /dev/usb1p1 hfsplus 1.9T 206G 1.7T 12% /volumeUSB1/usbshare
    none aufs 28T 22T 6.0T 78% /volume1/@docker/aufs/mnt/f63aaf1ee160276583588147957dc0ab8ed509048905b85f90e0d8804b430cc2
    Messages in dmesg:
    [Fri Mar 17 19:11:01 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Mar 17 19:11:01 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Mar 17 19:11:02 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Mar 17 19:11:02 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Mar 17 19:11:02 2023] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Mar 17 19:11:02 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Mar 17 19:11:06 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Mar 17 19:11:06 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Mar 17 19:11:07 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Fri Mar 17 19:11:07 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Fri Mar 17 19:11:26 2023] EXT4-fs (dm-2): barriers disabled
    [Fri Mar 17 19:11:27 2023] EXT4-fs (dm-2): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl
    [Fri Mar 17 19:11:34 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    diag.sh: line 109: findmnt: command not found
    /var:
    168M /var/
    79M /var/db
    77M /var/db/geoip-database
    49M /var/log
    21M /var/lib
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
    find: `/opt/iobroker/iobroker-data': No such file or directory
    *** NodeJS-Installation ***
    diag.sh: line 132: nodejs: command not found
    /usr/local/bin/node v12.22.12
    /usr/local/bin/npm 6.14.16
    diag.sh: line 135: npx: command not found
    diag.sh: line 137: apt-cache: command not found
    find: `/opt/iobroker/node_modules': No such file or directory
    *** ioBroker-Installation ***
    ioBroker Status
    diag.sh: line 152: iobroker: command not found
    Core adapters versions
    diag.sh: line 155: iob: command not found
    js-controller:
    diag.sh: line 156: iob: command not found
    admin:
    diag.sh: line 157: iob: command not found
    javascript:
    diag.sh: line 159: cd: /opt/iobroker: No such file or directory
    Adapters from github:
    Adapter State
    diag.sh: line 162: iob: command not found
    diag.sh: line 165: iob: command not found
    ioBroker-Repositories
    diag.sh: line 168: iob: command not found
    Installed ioBroker-Instances
    diag.sh: line 171: iob: command not found
    Objects and States
    Objects: 0
    States: 0
    sudo: apt-get: command not found
    diag.sh: line 182: apt-get: command not found
    Pending Updates:
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 127.0.0.1:143 0.0.0.0:* LISTEN 0 96027 20977/dovecot
    tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 39198 6000/nginx: worker
    tcp 0 0 0.0.0.0:2001 0.0.0.0:* LISTEN 0 10414849 722/docker-proxy
    tcp 0 0 0.0.0.0:8081 0.0.0.0:* LISTEN 0 10415616 679/docker-proxy
    tcp 0 0 0.0.0.0:8082 0.0.0.0:* LISTEN 0 10416312 658/docker-proxy
    tcp 0 0 127.0.0.1:914 0.0.0.0:* LISTEN 0 90667 5917/fcgi-pm
    tcp 0 0 127.0.0.1:915 0.0.0.0:* LISTEN 0 89594 6179/httpd24
    tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN 0 38790 11463/ftpd
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 23450 8452/sshd: /usr/bin
    tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN 0 42711 11868/cupsd
    tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 0 10411894 762/docker-proxy
    tcp 0 0 0.0.0.0:8088 0.0.0.0:* LISTEN 0 10411822 640/docker-proxy
    tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 55 66882 14817/postgres
    tcp 0 0 0.0.0.0:2010 0.0.0.0:* LISTEN 0 10416341 699/docker-proxy
    tcp 0 0 0.0.0.0:8282 0.0.0.0:* LISTEN 0 10416297 620/docker-proxy
    tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 0 10415672 743/docker-proxy
    tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 39200 6000/nginx: worker
    tcp 0 0 0.0.0.0:8284 0.0.0.0:* LISTEN 0 10415537 601/docker-proxy
    tcp 0 0 127.0.0.1:4700 0.0.0.0:* LISTEN 0 40096 11551/cnid_metad
    tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 41343 11450/smbd
    tcp 0 0 0.0.0.0:4190 0.0.0.0:* LISTEN 0 95984 20977/dovecot
    tcp 0 0 127.0.0.1:512 0.0.0.0:* LISTEN 0 98185 21178/termd
    tcp 0 0 0.0.0.0:12001 0.0.0.0:* LISTEN 0 10416267 546/docker-proxy
    tcp 0 0 127.0.0.1:161 0.0.0.0:* LISTEN 0 36329 11020/snmpd
    tcp 0 0 0.0.0.0:12002 0.0.0.0:* LISTEN 0 10411751 526/docker-proxy
    tcp 0 0 0.0.0.0:3493 0.0.0.0:* LISTEN 0 101790 21460/upsd
    tcp 0 0 0.0.0.0:50022 0.0.0.0:* LISTEN 0 23454 8452/sshd: /usr/bin
    tcp 0 0 0.0.0.0:44871 0.0.0.0:* LISTEN 0 10415415 506/docker-proxy
    tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 0 10415504 582/docker-proxy
    tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 0 39194 6000/nginx: worker
    tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 0 10411780 564/docker-proxy
    tcp 0 0 0.0.0.0:5001 0.0.0.0:* LISTEN 0 39196 6000/nginx: worker
    tcp 0 0 0.0.0.0:3307 0.0.0.0:* LISTEN 66 1700649 5364/mysqld
    tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 41344 11450/smbd
    tcp 0 0 0.0.0.0:5357 0.0.0.0:* LISTEN 0 39377 6000/nginx: worker
    tcp6 0 0 :::80 :::* LISTEN 0 39199 6000/nginx: worker
    tcp6 0 0 :::21 :::* LISTEN 0 38791 11463/ftpd
    tcp6 0 0 :::22 :::* LISTEN 0 23452 8452/sshd: /usr/bin
    tcp6 0 0 :::631 :::* LISTEN 0 42712 11868/cupsd
    tcp6 0 0 :::443 :::* LISTEN 0 39201 6000/nginx: worker
    tcp6 0 0 :::3261 :::* LISTEN 0 44823 -
    tcp6 0 0 :::445 :::* LISTEN 0 41341 11450/smbd
    tcp6 0 0 :::4190 :::* LISTEN 0 95985 20977/dovecot
    tcp6 0 0 :::3263 :::* LISTEN 0 44821 -
    tcp6 0 0 :::3264 :::* LISTEN 0 46116 -
    tcp6 0 0 :::3265 :::* LISTEN 0 48499 12581/scsi_plugin_s
    tcp6 0 0 :::515 :::* LISTEN 0 39882 1/init
    tcp6 0 0 :::548 :::* LISTEN 0 40185 11550/afpd
    tcp6 0 0 :::50022 :::* LISTEN 0 23456 8452/sshd: /usr/bin
    tcp6 0 0 :::5000 :::* LISTEN 0 39195 6000/nginx: worker
    tcp6 0 0 :::6281 :::* LISTEN 0 81032 17419/img_backupd
    tcp6 0 0 :::5001 :::* LISTEN 0 39197 6000/nginx: worker
    tcp6 0 0 :::139 :::* LISTEN 0 41342 11450/smbd
    tcp6 0 0 :::5357 :::* LISTEN 0 39378 6000/nginx: worker
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 0 73684 16976/avahi-daemon:
    udp 0 0 0.0.0.0:44343 0.0.0.0:* 0 73686 16976/avahi-daemon:
    udp 0 0 0.0.0.0:3702 0.0.0.0:* 99 34843 10620/synowsdiscove
    udp 0 0 0.0.0.0:9997 0.0.0.0:* 0 26087 8468/findhostd
    udp 0 0 0.0.0.0:9998 0.0.0.0:* 0 26086 8468/findhostd
    udp 0 0 0.0.0.0:9999 0.0.0.0:* 0 26085 8468/findhostd
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 78468 17664/minissdpd
    udp 0 0 0.0.0.0:36787 0.0.0.0:* 0 1704353 11830/synorelayd
    udp 213248 0 0.0.0.0:68 0.0.0.0:* 0 30841 9763/dhclient
    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 24988 8145/dhclient
    udp 0 0 172.18.0.1:123 0.0.0.0:* 87 10417186 8459/ntpd
    udp 0 0 192.168.178.144:123 0.0.0.0:* 87 34195 8459/ntpd
    udp 0 0 127.0.0.1:123 0.0.0.0:* 0 23387 8459/ntpd
    udp 0 0 0.0.0.0:123 0.0.0.0:* 0 23383 8459/ntpd
    udp 0 0 192.168.178.255:137 0.0.0.0:* 0 76335 17172/nmbd
    udp 0 0 192.168.178.144:137 0.0.0.0:* 0 76334 17172/nmbd
    udp 0 0 0.0.0.0:137 0.0.0.0:* 0 78007 17172/nmbd
    udp 0 0 192.168.178.255:138 0.0.0.0:* 0 76337 17172/nmbd
    udp 0 0 192.168.178.144:138 0.0.0.0:* 0 76336 17172/nmbd
    udp 0 0 0.0.0.0:138 0.0.0.0:* 0 78008 17172/nmbd
    udp 0 0 127.0.0.1:161 0.0.0.0:* 0 36328 11020/snmpd
    udp6 0 0 :::5353 :::* 0 73685 16976/avahi-daemon:
    udp6 0 0 :::3702 :::* 99 34845 10620/synowsdiscove
    udp6 0 0 fe80::e44e:4aff:fe3:123 :::* 87 10417192 8459/ntpd
    udp6 0 0 fe80::42:7aff:fea0::123 :::* 87 10417190 8459/ntpd
    udp6 0 0 fe80::9209:d0ff:fe0:123 :::* 87 34198 8459/ntpd
    udp6 0 0 ::1:123 :::* 0 23389 8459/ntpd
    udp6 0 0 :::123 :::* 0 23380 8459/ntpd
    udp6 0 0 :::52099 :::* 0 73687 16976/avahi-daemon:
    tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
    iob diag has finished.
    v.2023-01-02
    diag.sh: line 215: lsb_release: command not found
    Operatingsystem:
    Installation:
    Timezone:
    User-ID: 0
    X-Server: false
    Pending OS-Updates:
    diag.sh: line 239: nodejs: command not found
    Nodejs-Installation:
    diag.sh: line 242: npx: command not found
    diag.sh: line 244: iob: command not found
    ioBroker Core: js-controller
    diag.sh: line 245: iob: command not found
    admin
    diag.sh: line 247: iobroker: command not found
    ioBroker Status:
    Status admin:
    diag.sh: line 251: iobroker: command not found
    diag.sh: line 253: iob: command not found
    Pending iob updates: 0
    diag.sh: line 255: iob: command not found
    Objects: 0
    States: 0
    Size of iob-Database:
    find: /opt/iobroker/iobroker-data': No such file or directory find: /opt/iobroker/iobroker-data': No such file or directory
    =================== END OF SUMMARY ====================>
    Der Portainerversuch ist m.E. gescheitert:
    <root@Diskstation920:~# docker run -d -p 9000:9000 --name portainer --restart always -v /var/run/docker.sock:/var/run/docker.sock -v /volume1/docker/portainer_data:/data portainer/portainer-ce
    Unable to find image 'portainer/portainer-ce:latest' locally
    latest: Pulling from portainer/portainer-ce
    772227786281: Pull complete
    96fd13befc87: Pull complete
    b733663f020c: Pull complete
    9fbfa87be55d: Pull complete
    Digest: sha256:9fa1ec78b4e29d83593cf9720674b72829c9cdc0db7083a962bc30e64e27f64e
    Status: Downloaded newer image for portainer/portainer-ce:latest
    42538ba0f62d1644098d8eeea2b54c57c1bc3a0d2a7fb1a30f81e5e521d44c4d
    docker: Error response from daemon: driver failed programming external connectivity on endpoint portainer (3728dc0bcf157c19a93766fef7892f83600fcb8f8baa191899ab809a8fe199ad): Bind for 0.0.0.0:9000 failed: port is already allocated.>
    @pingo
    Nodejs falsch installiert, irgendwas ist mit den mounts und das Kommando 'iobroker' bzw. 'iob' wird auch nicht richtig gefunden.
    So viel zum 'einwandfrei laufenden ioBroker'
    Setz die Kiste neu und gescheit auf.
    • P pingo
      *** BASE SYSTEM ***
      Docker: false
      CPU threads: 4
      CET +0100
      root
      /root
      X-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      168M /var/
      79M /var/db
      49M /var/log
      21M /var/lib
      ioBroker Status
      js-controller:
      admin:
      javascript:
      Adapter State
      Objects and States
      Objects: 0
      States: 0
      Pending Updates:
      v.2023-01-02
      Operatingsystem:
      Installation:
      Timezone:
      User-ID: 0
      X-Server: false
      Pending OS-Updates:
      admin
      ioBroker Status:
      Status admin:
      Objects: 0
      States: 0
      GlasfaserG Offline
      GlasfaserG Offline
      @pingo
      Kurzfassung
      Dein ioBroker Container ist schrott ( nicht gepflegt )
      und was mich auch wunder ist
      /docker-proxy
      P 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @pingo
        Kurzfassung
        /docker-proxy
        pingo
        @glasfaser : Ja ok. Ich werde versuche mit Deinem Vorschlag alles neu aufzusetzen. Hoffentlich geht es gut
        • P pingo
          pingo
          Leider beginnt nun der Alptraum. Beim Neuaufsetzen kommt dieselbe Fehlermeldung:
          Und nun?
          • P pingo
            Und nun?
            pingo
            Ich erinnere mich an die damaligen Installationsprobleme: link text
            Das hilft diesmal leider auch nicht. 😠
            • P pingo
              GlasfaserG Offline
              GlasfaserG Offline
              @pingo
              Hast du auch das Paket Docker gelöscht / neu installiert
              Eventuell auch mal die Syn neu starten !?
              @pingo sagte in iobroker mit Docker: Kann keine Ports mehr durchschleifen:
              OK .. da war mal was mit deinem Webstation Zugang ...
              • P Offline
                pingo
                genau. Die Webstation brauche ich.
                Mag sich vielleicht mal jemand hier aufschalten. Ich denke schon, dass dann die Fehlersuche schneller und einfacher wird? Ich bin mittlerweile echt verzweifelt. Iobroker weg und nix funktioniert, wie früher.😠
                F 1 Antwort Letzte Antwort
                • P pingo
                  *** BASE SYSTEM ***
                  Docker: false
                  CPU threads: 4
                  CET +0100
                  root
                  /root
                  X-Server: false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  *** FILESYSTEM ***
                  Messages in dmesg:
                  /var:
                  168M /var/
                  79M /var/db
                  49M /var/log
                  21M /var/lib
                  ioBroker Status
                  js-controller:
                  admin:
                  javascript:
                  Adapter State
                  Objects and States
                  Objects: 0
                  States: 0
                  Pending Updates:
                  v.2023-01-02
                  Operatingsystem:
                  Installation:
                  Timezone:
                  User-ID: 0
                  X-Server: false
                  Pending OS-Updates:
                  admin
                  ioBroker Status:
                  Status admin:
                  Objects: 0
                  States: 0
                  GlasfaserG Offline
                  GlasfaserG Offline
                  nginx
                  ist in deinem Protokoll , hast du das Installiert !?
                  und wie ich schon schrieb :
                  @glasfaser sagte in iobroker mit Docker: Kann keine Ports mehr durchschleifen:
                  /docker-proxy
                  • P Offline
                    pingo
                    nginx
                    /docker-proxy
                    Nginx ist nicht installiert.
                    Ich habe jetzt mal die Host-Variante ausprobiert und die konnte ich tatsächlich installieren.
                    • P pingo
                      fastfoot
                      wer hat Dir eig. beigebracht tonnenweise Ports anzugeben? Profi-Tipp: Verklagen!
                      Du gibst (erstmal!) maximal 8081:8081 und evtl. noch 8082:8082 an und los gehts!
                      • F fastfoot
                        pingo
                        schrieb am zuletzt editiert von pingo
                        @fastfoot : Das kam aus einer Anleitung, nach der ich vorgegangen bin. Aktuell läuft aber nur die Host-Installationsvariante.
                        Nun wollte ich mein Google Drive Backup einspielen, aber es nicht zu finden, obwohl alle Backups damals durchgelaufen sind und ich auch die Dateien gesehen hatte. Ich fürchte, dass ich nun wieder komplett von vorne anfangen muss. Das ist der Supergau, den ich vermeiden wollte
                        F GlasfaserG 2 Antworten Letzte Antwort
                        • P pingo
                          fastfoot
                          @pingo Um etwas einzuspielen müsste der Ccontainer ja laufen, lt. deinen Posts scheitert es aber doch an den Ports. Ja was denn nun?
                          • P pingo
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Nun wollte ich mein Google Drive Backup einspielen, aber es nicht zu finden.
                            Neuen Container erstellen ... Mounte ein Ordner , lege ein aktuelles Backup dort rein , starte den Container dann erst
                              pingo
                              @glasfaser Ich finde leider keine Backupdatei, obwohl ich lokale und google drive Backupdateien hatte
                              • P pingo
                                GlasfaserG Offline
                                GlasfaserG Offline
                                auch nicht Online im Google Drive Konto !?
                                  pingo
                                  @glasfaser Nein, obwohl mir vor dem Löschen des Containers alle Dateien angezeigt wurden. Habt Ihr noch einen Tipp wo ich suchen kann oder wie die Dateien heißen?
                                  • F Offline
                                    fastfoot
                                    der 'alte' Mountpfad existiert doch noch?
                                    • P pingo
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      wer soll den Online deine Backups jetzt gelöscht haben !?
                                      ? Hääh
                                      Hast du eventuell ein Mount vom Ordner zuvor gemacht
                                      opt/iobroker
                                      Beispiel :
                                      • F fastfoot
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @fastfoot sagte in iobroker mit Docker: Kann keine Ports mehr durchschleifen:
                                        Schau mal hier von Ihm .. da ist alles durcheinander bzw. nicht vorhanden ...
                                        habe ich noch nie so gesehn :
                                        https://forum.iobroker.net/post/965560
                                          fastfoot
                                          @glasfaser wahrscheinlich das curl auf dem Host ausgeführt:-)
