  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 757.6k Aufrufe 95 Beobachtet
    @kueppert ja du bist doch nicht der einzige. Werde nachher mal air Fehlersuche gehen. Gestern konnte ich es noch nicht reproduzieren :man-shrugging:
    W Offline
    W Offline
    watcherkb
    #1097
    @ciddi89 hi, gibt es schon eine Lösung zu dem Problem:
    device-watcher.0
    2023-02-26 15:48:30.320	warn	State "device-watcher.0.devices.linkQualityList" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:30.270	warn	State "device-watcher.0.devices.listAllRawJSON" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:30.221	warn	State "device-watcher.0.devices.listAll" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:19.931	warn	State "device-watcher.0.devices.linkQualityList" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:19.880	warn	State "device-watcher.0.devices.listAllRawJSON" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:19.838	warn	State "device-watcher.0.devices.listAll" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:09.656	warn	State "device-watcher.0.devices.linkQualityList" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:09.600	warn	State "device-watcher.0.devices.listAllRawJSON" has no existing object, this might lead to an error in future versions
    device-watcher.0
    2023-02-26 15:48:09.555	warn	State "device-watcher.0.devices.listAll" has no existing object, this might lead to an error in future versions
    CC2538+CC2592 PA-Zigbee-Funkmodul
    • W watcherkb
      device-watcher.0
      device-watcher.0
      device-watcher.0
      device-watcher.0
      device-watcher.0
      device-watcher.0
      device-watcher.0
      device-watcher.0
      device-watcher.0
      #1098
      @watcherkb Hi,
      Betrifft das nur den Listen von den Geräten? Sind Geräte/Dienste zu Beobachtung ausgewählt? Bisher kam der Fehler nur bei sehr wenigen Usern für die Instanzen die die Instanzen beobachten nicht aktiviert hatten. Habe oft versucht den Fehler zu reproduzieren aber habe es nur einmal geschafft. Meine Vermutung ist das er die Config nicht richtig gelesen hat. Da nach einem neu start alles wieder ok war.
      Hast du schon versucht:
      • Instanz neu zu starten
      • Instanz zu löschen / neu erstellen
      • Instanz Ordner 0 vom Device-Watcher gelöscht und Instanz neu eingeschaltet?
      Es wird später am Abend ein neues Update geben. Vielleicht ist es dann auch weg.
      • W Offline
        W Offline
        watcherkb
        #1099
        @ciddi89
        Was meinst du mit "Instanzen beobachten"? Wo finde ich diese Einstellungen?
        @ciddi89 sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
        ja, ohne Erfolg
        nein noch nicht versucht Aufgrund von Zeitmangel
        ja, ohne Erfolg
        ? da_WoodyD 2 Antworten Letzte Antwort
        • W watcherkb
          @ciddi89
          ja, ohne Erfolg
          ja, ohne Erfolg
          #1100
          @watcherkb
          Betrifft dich noch nicht. Gibt es erst in einer späteren Version.
          Versuch das mal. Vielleicht auch Adapter löschen und neu installieren. Ich weiss wirklich nicht warum er das macht. Bissher sind mir nur drei Meldungen bekannt von fast 1000 Usern. Oder warte bis später/morgen ein neues Update angezeigt wird. Evtl. hat er bei der installation was verschluckt und vll ist es dann auch weg.
          • W watcherkb
            @ciddi89
            ja, ohne Erfolg
            ja, ohne Erfolg
            da_WoodyD Online
            da_WoodyD Online
            #1101
            @watcherkb sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
            nebenbei: ver 2.2.2?
            wenn du auf stable bist, dauerts halt bis einige funktionen dann klappen...
            ? W 2 Antworten Letzte Antwort
            • da_WoodyD da_Woody
              #1102
              @da_woody nein ich meinte das:
              • JB_SullivanJ JB_Sullivan
                Nochmal eine Frage zu der Instanz Überwachung. Laut Datenpunkt sind drei Instanz Updates verfügbar - das stimmt auch soweit mit der Ausgabe auf ioB Admin Ebene überein. Kann man aus der Liste irgendwie erkennen, welche Adapter/Instanzen das Update bekommen sollen?
                Eines der drei Updates wäre z.B. der snmp Adapter. In der Liste schreibt er, Instanz OK ich hätte jetzt an dieser Stelle einen Hinweis auf das verfügbare Update erwartet - oder ist ein Hinweis auf das zur Verfügung stehende Update in der Listenansicht nicht vorgesehen?
                Das wäre schade, da ich ja dann doch den PC anschmeißen muss um zu sehen, ob es sich lohnt dieses Adapter Update durchzuführen. Ich sehe zwar das 3 Updates zur Verfügung stehen, weiß aber nicht, ob dies für mich wichtige Adapter betrifft.
                #1103
                @jb_sullivan habe eine Spalte mit reingenommen die anzeigt ob ein Update Verfügbar ist und wenn ja, welche Version. Wird im nächsten Update mit drin sein.
                  @rookie50 in GitHub melden reicht. macht das ganze Übersichtlicher ;) Ich weiss über die Besonderheit von den Thermostat bescheid, mit lowbat hat aber noch keiner gemeldet. Daher danke für die Information und ich werde es sobald wie möglich mit aufnehmen. :)
                  Rookie50
                  #1104
                  @ciddi89 Hi ciddi89, ich wollte nur kurz danke sagen. Die Batterie Unterstützung der alten Thermostate funktioniert nun!!
                  • R Rookie50
                    #1105
                    @rookie50 Super das freut mich! :)
                      W Offline
                      W Offline
                      watcherkb
                      #1106
                      @da_woody
                      @da_woody sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                      jap. Wusste nicht das die neue Funktion noch nicht stable ist.
                        Malz1902
                        #1107
                        Gilt die Blacklist auch für Instanzen?
                        • M Malz1902
                          #1108
                          @malz1902 ja wenn auf der ersten Seite Instanzen/Dienste beobachten ausgewählt ist kommt auf der Blacklist Seite eine neue Tabelle dafür.
                            Malz1902
                            #1109
                            @ciddi89 super, vielen Dank. Echt ein super Adapter und die Auflistung als json ein Traum.
                            Welchen Datenpunkt muss ich denn angeben? system.0.adapter name oder adaptername.0.info?
                            • M Malz1902
                              #1110
                              @malz1902 Ähm eigentlich sollte ein drop-down da sein wo du die jeweilige Instanz auswählen kannst 🤔
                                Malz1902
                                #1111
                                @ciddi89 cool, dann versuch ich das gleich mal. Bin noch unterwegs aber kam mir gerade in den kopf, da die vw connect instanz sich heute schon 5mal gemeldet hat das keine Verbindung da ist, weil der vw Server mal wieder spinnt
                                • M Malz1902
                                  #1112
                                  @malz1902 ja sieht dann so aus. Sry für die Handy Screenshots 😃 aber dann kann man wählen ob in Listen oder Benachrichtigung ignoriert werden sollen. :)
                                  E662DA9B-3A10-4BAD-8BE3-CAE3689D77C9.jpeg 7263BEE7-824D-413E-85EA-3FA5C4A04935.jpeg
                                  • David G.D Online
                                    David G.D Online
                                    David G.
                                    #1113
                                    (Ich mache jetzt einfach mal einen Doppelpost. Hab die Tabelle auch in dem Link aus meiner Signatur gepostet. Denke aber, hier ist es auch ganz Sinnig)
                                    ich habe nochmal eine neue Tabelle erstellt.
                                    Dieses mal für den Device-Watcher.
                                    In den Bildern seht Ihr fast alle Möglichkeiten wie die Spalten dargestellt werden können.
                                    Ihr könnt aber für jede Spalte separat auswählen, welche Ansicht Ihr haben möchtet (habe jetzt nicht von allen Möglichkeiten einen Screenshot gemacht).
                                    Zusätzlich könnt Ihr noch einige Kleinigkeiten ein- und ausblenden.
                                    Dazu gehören:
                                    • Die Pfeile für die Informationen, wann ein Gerät zuletzt online war
                                    • Die Überschrift mit der Anzahl der Geräte
                                    • Die Möglichkeit alle Gerate der Adapter aus- oder ausgeklappt darzustellen
                                    • Helle und dunkle Icons
                                    • Ob die Bilder der Adapter in der Überschrift anzuzeigen
                                    • Die Farbe für gute und schlechte Werte zu definieren, in den Bildern grün und rot (damit es zu Visu passt)
                                    Wie gewohnt, könnt Ihr alle Settings im oberen Bereich über Variablen einstellen.
                                    Anbei das Blockly
                                    tebelle_device_watcher.txt
                                    Danke an @ciddi89
                                    Er hat extra eine weitere json in den Adapter mit allen für die Tabelle benötigen Werten eingebaut.
                                      @chrisxy was für eine offline Zeit steht denn unter Experten Einstellungen?
                                      ChrisXY
                                      #1114
                                      @ciddi89 200 in Minuten .. das komische ist es kommt dann die offline meldung und danach direkt wieder ist wieder Online ..
                                      Eine coole Funktion wäre die "Nachtruhe" Eine Zeit zum einstellen von bis wäre mega für die Benachrichtigungen.
                                      • C ChrisXY
                                        #1115
                                        @chrisxy um welche Art von Gerät/Service handelt es sich? Schon versucht 200min zu erhöhen was dann passiert?
                                        Feature requests Bitte wenn möglich in GitHub eröffnen. Das geht hier sonst unter bei den ganzen Beiträgen. Ich danke. :)
                                          socke85
                                          #1116
                                          @ciddi89 : Gibt es für die Instanzen also z.B. für "device-watcher.0.adapterAndInstances.listAllInstances" auch eine html die ich einfach per marsdown card in der Lovelace UI einfügen kann?
                                          Danke für den coolen Adapter!
                                          David G.D ? 2 Antworten Letzte Antwort
