  4. Test Adapter Log Parser 1.1.x Latest
    1.0k
logparseradapterlogvis
60 Beiträge 14 Kommentatoren 13.0k Aufrufe 23 Beobachtet
  • NashraN Nashra
    Hi, des öfteren bzw. immer wenn der Alexa-Adapter oder Javascript-Adapter neu gestartet werden
    kommt diese Fehlermeldung. Es gibt auch ein Issue dazu aber es sieht so aus als wenn @Mic
    nicht mehr aktiv ist. Aber vllt kann ja hier jemand helfen.
    2023-01-11 11:01:03.589 - info: host.ioBroker instance system.adapter.alexa2.0 started with pid 3843862
    2023-01-11 11:01:04.813 - info: alexa2.0 (3843862) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
    2023-01-11 11:01:04.846 - info: alexa2.0 (3843862) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2023-01-11 11:01:08.134 - info: alexa2.0 (3843862) Initialize all Device states ...
    2023-01-11 11:01:42.951 - error: javascript.0 (1155755) Error in callback: SyntaxError: Unexpected end of JSON input
    2023-01-11 11:01:42.951 - error: javascript.0 (1155755) at JSON.parse ()
    2023-01-11 11:01:42.952 - error: javascript.0 (1155755) at Object. (script.js.Allerlei.Alexa-History-LogParser:35:31)
    2023-01-11 11:01:42.952 - error: javascript.0 (1155755) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2023-01-11 11:01:42.952 - error: javascript.0 (1155755) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2023-01-11 11:01:42.952 - error: javascript.0 (1155755) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2023-01-11 11:01:42.952 - error: javascript.0 (1155755) at processImmediate (node:internal/timers:466:21)
    Das Skript dazu
     * JavaScript Adapter Script for Log-Parser-Adapter: https://github.com/Mic-M/ioBroker.logparser
     * Purpose: Get the history of all spoken Alexa commands into the log
     *          Required: Alexa adapter - https://github.com/Apollon77/ioBroker.alexa2
     * Source:  https://github.com/Mic-M/ioBroker.logparser
     * Autor:   Mic-M (Github) | Mic (ioBroker)
     * Change Log:
     *  1.0.0  Mic-M   * Adoption to Log Parser Adapter
     *  0.1.0  Mic-M   * Initial release (for Log Script - https://github.com/Mic-M/iobroker.logfile-script).
     * Script Settings
    // **Capitalize First Letters**
    // The spoken command to Alexa is being returned in lowercase, like "turn on kitchen light".
    // With this option set to true, the output will be "Turn On Kitchen Light" (so capitalized first letter of each word)
    const g_capFirstLetters = true;
     * End of Script Settings. Please do not change anything below here.
    main();
    function main() {
        // All Alexa adapter instances, so alexa2.0.History.json, alexa2.1.History.json, alexa2.2.History.json, etc.
        on({id: /^alexa2\.\d\.History\.json$/, change:'any'}, function(obj) {
            // obj.state.val: JSON string of oject.
            // Like: {"name":"Alexa Flur","serialNumber":"xxxxxxxxxx","summary":"Wohnlicht an","creationTime":1582843794820, ... }
            let objHistory = JSON.parse(obj.state.val);
            // ignore alexa keywords or empty value.
            if(! (['', 'alexa','echo','computer'].includes(objHistory['summary']) )) {
                // ignore "sprich mir nach"
                if (!(objHistory['summary'].includes('sprich mir nach '))) {
                    log('[Alexa-Log-Script] ##{"message":"' + formatAlexaSummary(objHistory['summary']) + '", "from":"' + objHistory['name'] + '"}##');
     * Formats the Alexa summary text accordingly.
     * @param {string} summaryText   The summary text
     * @return {string} the formatted summary
    function formatAlexaSummary(summaryText) {
        if (g_capFirstLetters) summaryText = summaryText.replace(/(^|\s)\S/g, l => l.toUpperCase()); // Capitalize if set. https://stackoverflow.com/questions/2332811/
        return summaryText;
    @nashra wegen deinem oben genannten Fehler, könntest du mal mit dem Script testen ob es weg ist? Hab’s bei mir getestet und da war dann gut.
    https://github.com/iobroker-community-adapters/ioBroker.logparser/blob/devBranch_ciddi89/accessories/alexa-history.js
    NashraN 2 Antworten Letzte Antwort
      NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      @ciddi89 sagte in Test Adapter Log Parser 1.1.x Latest:
      Moin, mache ich sofort heute Nachmittag, muß jetzt zur Arbeit.
      Gruß Ralf
      • NashraN Nashra
        @nashra alles gut, hat Zeit :)
        • sigi234S sigi234
          @mcm57
          Hallo, wird er weiter Entwickelt?
          mcm1957M Offline
          mcm1957M Offline
          mcm1957
          @sigi234
          Danke der Nachfrage und Sorry dass es so lange gedauert hat. Wollte zuerst die überfällige nächste snmp Release rausbringen.
          Ja wie @ciddi89 bereits geschrieben hat wird weiterentwickelt. Ich hab den Adaptercode zwischenzeitlich in den community Bereich verschoben und Umgebung und Pakete auf aktuellen Stand gebracht. ciddi89 kümmert sich zur Zeit drum die offenen Probleme zu fixen bzw. Feature Requests zu klären und ggF umzusetzen. Ein ganz herzliches DANKE dafür. Geplant ist auch die Umstellung auf aktuelle json Config.
          Ich werde sobald npm für die community Gruppe friegegeben ist mal eine (hoffentlich :-) ) unveränderte erste Release ins latest entlassen damit Freiwillige die migrierte Version testen können. Das gefixte Alaex Script kommt da oder in einer nachfolgenden Release sicher relativ rasch mit. Eine größere Release (jsonCofnig etc.) wird aber noch dauern.
          Bitte allfällige Probleme / Wünsche nur mehr im neuen Repository https://github.com/iobroker-community-adapters/ioBroker.logparser deponieren.
          McM
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
            NashraN Offline
            NashraN Offline
            Nashra
            Bis jetzt alles OK d.h. alexa- und javascript-Adapter neu gestartet, keine Fehlermeldung vom Skript
            sowie bei Sprachbefehlen. Container mal neu gestartet, auch alles OK. Dürfte dann gut sein, beobachte aber weiter.
            Gruß Ralf
            • NashraN Nashra
              @nashra ok super danke für deine Rückmeldung. Falls was sein sollte einfach bei mir melden. :)
              • mcm1957M mcm1957
                @sigi234
                McM
                sigi234S Online
                sigi234S Online
                @mcm57
                Hallo, kann man V 1.2.1 schon installieren?
                • sigi234S sigi234
                  @mcm57
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  @sigi234
                  Hi
                  Wie hast du die denn schon gesehn :-)
                  Im Prinzip klannst du die 1.2.1 installieren. Sie sollte dem Stand der 1.1.0 entsprechen nur mit aktualisiereten dependencies (und natürlcih migriert in oiobroker-community.
                  Der Fix des Alexa Scripts ist noch NICHT drinnen. Kommt sobald ein Problem mit der github deploy action / sentry behoben ist.
                  Aber wenn du testwillig bist kannst du die 1.2.1 gerne installieren und berichten ob was nicht mehr geht
                  (Ich mach nen neuen TestThread auf sobald sentry integration ok und Alexa fix drinnen ist)
                  sigi234S 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    @sigi234
                    Hi
                    sigi234S Online
                    sigi234S Online
                    @mcm57 sagte in Test Adapter Log Parser 1.1.x Latest:
                    Bis jetzt alles OK , keine Fehlermeldung vom Skript
                    • mcm1957M mcm1957
                      @sigi234
                      Hi
                      sigi234S Online
                      sigi234S Online
                      @mcm57
                      Hallo, man kommt hier noch auf die "Alte Seite"
                      • sigi234S sigi234
                        @mcm57
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @sigi234
                        Danke f.d. Info. Das ist offensichtlich im Code reinkodiert - und der ist (noch) unverändert. Ciddi ist da dran.
                        Mach bitte ein issue auf damit das nicht untergeht wenn zu Zeit hast.
                        DANKE
                        Seh grad das betrifft die Iobroker Seite. Da gab es meiner Erinnerung nach einige Probleme. Zumindest wird die nur in größeren Abständen aktualisisert wenn ich eine Antwort von @Bluefox richtig im Kopf habe. Ich würd hier mal abwarten - insbesondere bis der Adapter auch im Stable aktualisiert wurde. Wenns dann noch immer nicht stimmt werd ich mal im Telegramm nachfragen falls hier nicht schon wer geklärt hat was zu tun ist.
                        McM
                        mcm1957M ? 2 Antworten Letzte Antwort
                        • mcm1957M mcm1957
                          @sigi234
                          DANKE
                          McM
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          Für die Version 2.2.x gibts einen neune Thread:
                          https://forum.iobroker.net/topic/63322/test-adapter-log-parser-1-2-x-latest
                          Bitte die Diskussion die neue Version dorthin übersiedeln
                          McM
                          • mcm1957M mcm1957
                            @sigi234
                            DANKE
                            McM
                            @mcm57 Ja ich glaube die wird nur dann irgendwann aktualisiert wenn die im Stable ist wenn ich das richtig im Kopf habe.
                            Habe aber erstmal alle Links in den Readme's und admin angepasst und push das gleich auf GitHub.
                            • NashraN Offline
                              NashraN Offline
                              Nashra
                              Moin, nach einem Neustart von IOB wird die Uhrzeit neben dem Datum nicht mehr angezeigt d.h. einmal den Haken raus,
                              speichern, dann Haken wieder rein und speichern/schließen. Dann geht es wieder bzw. wird es wieder angezeigt
                              Gruß Ralf
