  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.2k Aufrufe 67 Beobachtet
  • BananaJoeB Offline
    BananaJoeB Offline
    BananaJoe
    #225
    Und noch ein Nachtrag: Ich hab die Version direkt von GitHub-Version, ok die ist anders. Aber die gleichen Probleme wie die anderen. Die midea-beautiful-air-cli in der Bash ausprobiert - wirft auch jede Menge Fehler, macht es dann aber doch (Hier "ausschalten" - das klappt also trotz der Fehlermeldungen:)
    iobroker@iobroker:~$ midea-beautiful-air-cli set --ip 192.168.1.29 --token 0CFD4E93FDECF6D0EF...99E6325C9886FFB9943C49 --key 37c4b6ef...3059e124a16 --running 0
    WARNING:midea_beautiful.lan:Error getting device capabilities for sn=0000000000000001A80000A1******** id=10000000034**** address=192.168***** version=3, cause Unable to send data after 3 retries, last error timed out for 0000000000000001A80000A1******** (10000000034****)
    Traceback (most recent call last):
      File "/usr/local/lib/python3.10/dist-packages/midea_beautiful/lan.py", line 809, in identify
        responses = self._status(cmd, cloud if use_cloud else None)
      File "/usr/local/lib/python3.10/dist-packages/midea_beautiful/lan.py", line 540, in _status
        responses = self.appliance_send(data)
      File "/usr/local/lib/python3.10/dist-packages/midea_beautiful/lan.py", line 685, in appliance_send
        return self._appliance_send_8370(data)
      File "/usr/local/lib/python3.10/dist-packages/midea_beautiful/lan.py", line 590, in _appliance_send_8370
        if packets := self._retry_send(original_data, response_buf):
      File "/usr/local/lib/python3.10/dist-packages/midea_beautiful/lan.py", line 670, in _retry_send
        packets = self.appliance_send(data)
      File "/usr/local/lib/python3.10/dist-packages/midea_beautiful/lan.py", line 675, in _retry_send
        raise MideaNetworkError(
    midea_beautiful.exceptions.MideaNetworkError: Unable to send data after 3 retries, last error timed out for 0000000000000001A80000A1******** (10000000034****)
    id 0000000000000001A80000A1E5B70000/14000000003615
      id      = 14000000003615
      addr    = 192.168.1.29
      s/n     = 0000000000000001A80000A1
      model   = Air conditioner
      ssid    = net_ac_E5B7
      online  = True
      name    = 14000000003615
      running = False
      target  = 22.0
      indoor  = 24.3
      outdoor = 10.1
      fan     = 101
      mode    = 1
      purify  = False
      eco     = False
      sleep   = False
      F       = False
      error   = 0
      supports= {'eco': 0, 'mode': 1, 'fan_swing': 1, 'electricity': 0, 'strong_fan': 1, 'fan_speed': 1, 'temperature0': 32, 'temperature1': 60, 'temperature2': 32, 'temperature3': 60, 'temperature4': 32, 'temperature5': 60, 'temperature6': 0}
      version = 3
    Da gibt es auch schon ein Ticket:
    https://github.com/nbogojevic/midea-beautiful-air/issues/19
    Ich bin auch der Meinung das es ein Timeout-Problem sein könnte. Ich habe an den Retry und Timeout-Werten in der ./midea_beautiful/lan.py rumspielt. Wenn man den Timeout erhöht dauert es länger, ändert aber nichts an der Fehlermeldung (und das es trotzdem funktioniert)
    • BananaJoeB BananaJoe
      @tombox ich habe nun auch eine Dimstal-Klimaanlage mit 2 Innengeräten.
      Der Adapter kann die Daten abfragen und legt die Datenpunkte an,
      wenn man versucht zu steuern kommt immer eine Meldung wie diese:
      2022-12-24 11:36:18.091  - info: midea.0 (2050642) Command was not accepted by device. Command wrong or device not reachable 145135534971917 The asyn reply does not exist
      2022-12-24 11:37:19.017  - info: midea.0 (2050642) Command was not accepted by device. Command wrong or device not reachable 145135534971917 The asyn reply does not exist
      Falls du Zugangsdaten zum testen brauchst schreib mich einfach an.
      Nachtrag: Die weiter oben erwähne "Lokales Netzwerk" Methode ( https://github.com/mac-zhou/midea-msmart) findet beide Geräte ... nur habe ich gerade keinen Schimmer was ich damit anfangen kann, sprich wie ich das in Steuersignale etc. umwandeln könnte:
      root@iobroker:~# midea-discover
      INFO:msmart.cli:msmart version: 0.2.5 Currently only supports ac devices, only support MSmartHome and 美的美居 APP.
      INFO:msmart.cloud:Using Midea cloud server: https://mp-prod.appsmb.com/mas/v5/app/proxy?alias= False
      INFO:msmart.lan:Got TCP key for 192.168.1.8:51796 -> 192.168.1.30:6444 retries: 0 time: 0.16 tcp_key: 561e467...a0c67eb661e
      INFO:msmart.lan:Got TCP key for 192.168.1.8:39394 -> 192.168.1.29:6444 retries: 0 time: 0.55 tcp_key: 5655b749b22fc7e5ed...6b813b2ceaa
      INFO:msmart.cli:*** Found a device: {'name': 'net_ac_E5B7', 'ssid': 'net_ac_E5B7', 'ip': '192.168.1.29', 'port': 6444, 'id': 144036023343615, 'version': 3, 'token': '0CFD4E93...C28D01079D4D1F25F952E94BC3A03597E69636DC40A74EBEAF4BD3D949ED931B02A99E6325C9886FFB9943C49', 'key': '37c4b6ef5b...9e124a16', 'type': 'ac', 'sn': '000P0000000Q1A8407DA1E5B70000', 'model': '00Q1A', 'support': True, 'run_test': True}
      INFO:msmart.cli:*** Found a device: {'name': 'net_ac_8C58', 'ssid': 'net_ac_8C58', 'ip': '192.168.1.30', 'port': 6444, 'id': 145135534971917, 'version': 3, 'token': 'BB2BDD19DB5B25C...3DD6D5F9B11A57C035B2A1520E096E4CD97CDDCE4A0AE', 'key': '65918b1dc16,,,f86b4af457791792864', 'type': 'ac', 'sn': '000P0000000Q1A8407D9C8C580000', 'model': '00Q1A', 'support': True, 'run_test': True}
      https://github.com/TA2k/ioBroker.midea/issues/186
      tombox
      #226
      @bananajoe Ich bin zur zeit unsicher wie es weiter gehen soll mit dem Adapter.
      https://github.com/nbogojevic/midea-beautiful-air Welches in 0.1.0 via python bridge integriert ist enthält bugs und wird nicht weiter entwickelt.
      Man könnte jetzt das Homebridge plugin integrieren was ziemlich einfach ist aber nur begrenzt gerate unterstützt.
      https://github.com/georgezhao2010/midea_ac_lan Ist sehr gut und unterstützt alle Geräte aber ist schwer in iobroker zu integrieren.
      BananaJoeB MatzebhvM T 3 Antworten Letzte Antwort
      • T tombox
        BananaJoeB Offline
        BananaJoeB Offline
        BananaJoe
        #227
        @tombox Also von den gelieferten Daten / Datenpunkten her ist die Version 0.0.7 top. Ich vermute das der Adapter die Daten noch nativ selbst holt?
        Das die Gegenrichtung nicht mehr funktioniert ... tja, da hat sich also etwas geändert. Ich vermute du hattest schon versucht das durch mitschneiden der App heraus zu finden?
        Heute beim warten auf dem Weihnachtsmann habe ich ein wenig rumgespielt - per midea-beautiful-air-cli bekomme ich die Steuerungsbefehle im lokalen LAN hin (ich habe die lan.py manipuliert so das keine Fehlermeldung mehr ausgeworfen wird),
        Die notwendigen Daten (Token + Key) habe ich per midea-discover herausbekommen.
        Der Adapter in der 1.0.0 Version der - wenn ich das richtig sehe - die midea-beautiful-air-cli unten drunter nutzt kann sich zwar die Daten holen, wirft dabei aber jede menge Python-Fehler aus und kann trotzdem nicht steuern. Der lokale Weg funktioniert nicht weil die lokale IP-Adresse wohl nicht im Adapter ankommt.
        Im Moment bin ich geneigt mir eine Zwischenlösung "zusammen zu pfuschen" - dein Adapter in der 0.0.7 also als Datenquelle. Und die Steuerung dann entweder über die midea-beautiful-air-cli oder per Infrarot-Sender (im Wohnzimmer steht sowieso schon ein Broadlink und durch einen Kauf hier im Marktplatz habe ich auch noch einen für das Schlafzimmer).
        Ich schaue mir ja auch immer gerne mal den Quellcode von Projekten an, nach einigen Anläufen verstehe ich ich ja auch immer mehr.
        Also, dein Adapter in 0.0.7 liefert die Quelldaten schon perfekt. midea-msmart findet im lokalen Netzwerk ohne Probleme die notwendigen Daten für die lokale Steuerung welche man Dank der Seriennummer oder ssid auch zuordnen kann.
        Und im midea-beautiful-air Projekt sind zwar Fehler, man kann sich aber abschauen wie man lokal die Steuerbefehle absetzen kann.
        Irgendwo hatte ich ich gelesen das es scheinbar mindestens eine alternative App zum Steuern der Klimageräte gibt, eventuell wäre auch das ein Ansatz. (AC Freedom?)
        Im Prinzip hätte man also alles um das Puzzle zusammen zu setzen. Ich bewundere deine Arbeit (du bist schon eine Adapter-Erstellungs-Maschine), würde aber verstehen wenn du den Aufwand scheust falls du nicht selbst eine solche Anlage besitzt. Mit den zuvor den aufgezählten Punkten wüsste ich mir ja zu helfen. Und ich habe auch erst einen halben Tag nach Lösungen gesucht.,
        Die Klimaanlage ist ein geplanter Teil meiner persönlichen Energiewende, die Dimstal hatte ich expliziert gewählt weil diese WLAN bietet und scheinbar in ein Smarthome eingebunden werden kann. Das ich diese per ioBroker steuern kann gehört unbedingt zu meinem Konzept.
        Dank deines Updates / Beitrag zum Tuya-Adapter läuft mein Klarstein-Luftentfeuchter nun auch ioBroker gesteuert und verbläst nicht ständig 300W sondern läuft nur wenn es nötig ist. Wenn jemand das Badezimmerfenster öffnet schaltet der sich ab (wie auch die Heizkörper sich schließen wenn das Fenster im Raum geöffnet wird). Für die Kinder habe ich deshalb eine Klarstein mobile Klimaanlage gekauft da ich diese auch perfekt steuern kann - dank dir.
        Die erste Frage meiner Frau zur Dimstal-Klimaanlage war: "Schaltet die auch ab wenn ich die Terrassentür öffne oder das Fenster auf mache?"
        Ja, ich habe die alle ziemlich verwöhnt hier im Haus ... Anfangs hieß es noch "was soll der Quatsch", inzwischen will niemand mehr missen was alles so im Hintergrund automatisch passiert.
        MatzebhvM 1 Antwort Letzte Antwort
          BananaJoeB Offline
          BananaJoe
          #228
          Nachtrag: Ich habe mir midea-msmart noch mal genauer angesehen - irgendwo muss stehen wie man damit arbeitet ...
          Jupp, da gibt es eine example.py die zumindest für meinen Anwendungsfalls Klimaanlage alles hat, die restlichen Parameter / möglichen Optionen muss man sich halt aus den Dateien raussuchen (Mögliche Parameter stehen in https://github.com/mac-zhou/midea-msmart/blob/master/msmart/device/AC/appliance.py)
          Das Beispiel müsste man noch optimieren, es holt sich erst was die Anlage kann (das dauert etwas), dann wie der aktuelle Status ist (geht schnell, funktioniert auch ohne sich vorher die vorherige Abfrage) und setzt dann Werte (Funktioniert auch dirket, spuckt aber Fehler aus wenn man sich nicht vorher die Fähigkeiten geholt hat)
          Optimal wäre die Rückgabe von device.get_capabilities() zwischenzuspeichern, sollte sich ja eigentlich nie ändern.
          Ich konnte meine Anlagen damit eben zumindest erfolgreich steuern. Prinzipiell könnte man sich damit ein Befehlszeilen-Tool zum steuern bauen.
          So, jetzt gebe ich aber erst einmal Ruhe, erst einmal muss die Solaranlage fertig werden, dann kümmere ich mich um die automatische Steuerung der Klimaanlagen.
          G 1 Antwort Letzte Antwort
          • T tombox
            MatzebhvM Offline
            MatzebhvM Offline
            Matzebhv
            #229
            @tombox sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
            Das Homebidge Plugin funktioniert mit den neuen Geräten leider auch nicht, hier kannst du genau wie bei dem Adapter nur lesen aber nicht steuern.
            draexlerD 1 Antwort Letzte Antwort
              MatzebhvM Offline
              MatzebhvM Offline
              Matzebhv
              #230
              @bananajoe sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
              Hier genau so, das funktioniert in unserer ( recht kleinen Hütte ) einwandfrei. Die Heizung ist bis jetzt auch bei -10°C aus geblieben. Das eine installierte Gerät bekommt die Hütte tatsächlich warm. Und das zu moderaten Energiekosten.
              • MatzebhvM Matzebhv
                BananaJoeB Offline
                BananaJoeB Offline
                BananaJoe
                #231
                @matzebhv sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
                Jepp, das Ding funktioniert wie blöd. Wohnzimmer ist innerhalb von wenigen Minuten angenehm warm. Klar, das Ding geht dann z.B. auf 2 kW - aber ja nur kurz.
                Ich habe testweise aber auch mit Lüfter am Heizkörper experimentiert, nicht mit diesen teuren fertigen Dingern sondern Eigenbau mit USB-Lüftern + 3D-Drucker. Und muss sagen, das bring auch schon spürbar was.
                  MatzebhvM Offline
                  MatzebhvM Offline
                  Matzebhv
                  #232
                  @bananajoe Das mit der Krücke mache ich derzeit tatsächlich genau so, lesend benutze ich den Adapter und zum steuern den Skill mit dem Alexa-Adapter. Ist blöd, geht ja aber derzeit nicht anders.
                  @tomtom Könnte man nicht midea-beautifull-air forken und dann fixen? Auf der Shell funktioniert die Steuerung der Anlage ja schon. Es werden zwar Fehler geworfen, das Gerät reagiert aber.
                  iobroker@iOBroker:~$ midea-beautiful-air-cli set --ip 192.168.178.87 --token  --key  --running 0
                  WARNING:midea_beautiful.lan:Error getting device capabilities for sn=000000P0000000Q104D6F458******** id=14293651167**** address=192.168.1***** version=3, cause Unable to send data after 3 retries, last error timed out for 000000P0000000Q104D6F458******** (14293651167****)
                    File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 809, in identify
                    File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 540, in _status
                    File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 685, in appliance_send
                    File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 590, in _appliance_send_8370
                    File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 670, in _retry_send
                    File "/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py", line 675, in _retry_send
                  midea_beautiful.exceptions.MideaNetworkError: Unable to send data after 3 retries, last error timed out for 000000P0000000Q104D6F458******** (14293651167****)
                  id 000000P0000000Q104
                    id      = 1429365
                    addr    = 192.168.178.87
                    s/n     = 000000P0000000Q10
                    ssid    = net_ac_7F5E
                    online  = True
                    name    = 14293651
                    running = False
                    target  = 21.0
                    indoor  = 24.4
                    outdoor = 5.3
                    fan     = 102
                    mode    = 4
                    purify  = False
                    eco     = False
                    sleep   = False
                    F       = False
                    error   = 0
                    supports= {'eco': 1, 'mode': 1, 'fan_swing': 1, 'electricity': 0, 'strong_fan': 1, 'fan_speed': 1, 'temperature0': 32, 'temperature1': 60, 'temperature2': 32, 'temperature3': 60, 'temperature4': 32, 'temperature5': 60, 'temperature6': 0}
                    version = 3
                    draexlerD Offline
                    draexlerD Offline
                    draexler
                    #233
                    Wie ich oben schon geschrieben habe funktioniert es mit dem MDDF-20DEN7-WF bei mir mit dem HAM Adapter und dem PlugIn wunderbar... Außer die Füllstandanzeige ;-)
                    clfberlinC 1 Antwort Letzte Antwort
                    • T tombox
                      toralt
                      #234
                      @tombox gibts bezüglich der LAN Integration schon irgendwelche news? Bisher macht Dein Adapter eigentlich keine Probleme, bin auch sehr zufrieden. Aber LAN Steuerung wäre natürlich schon sehr nice 🤘
                      << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
                      T H 2 Antworten Letzte Antwort
                      • T toralt
                        tombox
                        #235
                        @toralt Tja warte ab ob die Homebridge Anbindung ausgebaut wird oder die von hass.io leichter zu nutzen ist. aber ohne gerät ist es zu schwer das einzubauen
                        • T toralt
                          Hc-Yami
                          #236
                          @toralt hab mittlerweile Homeassistant laufen und die Klima dann über den ioBroker Adapter angebunden. Apollon gibt sich wirklich Mühe, zumindest mein Gerät, vernünftig einzubinden.
                          • draexlerD draexler
                            clfberlinC Offline
                            clfberlinC Offline
                            clfberlin
                            #237
                            @draexler
                            Na, dann bin ich ja genau richtig in dem Thread. Mein (Comfee) MDDF-20DEN7-WF Luftentfeuchter kommt morgen. Helft bitte nochmal einem alten Mann über die Straße: Welche App nehme ich denn am besten als Ausgangsbasis? NetHome? MSmartHome? Merci und Grüße, clfberlin
                            Synology DS918+ 16GB ### CC2652P Sonoff ZigBee 3.0. ### Docker ### DS420+ Speicher ### PV mit E3DC Hausbatterie ### Spieltrieb
                            • clfberlinC clfberlin
                              @draexler
                              BananaJoeB Offline
                              BananaJoeB Offline
                              BananaJoe
                              #238
                              @clfberlin NetHome Plus
                              • H Hc-Yami
                                toralt
                                #239
                                @hc-yami Danke für den Tipp, habe ich installiert. Läuft auch, aber zum Glück muss ich damit nichts machen. Finde HA schrecklich. Ich verstehe gar nichts :D
                                Aber wie gesagt, durchreichen in den ioBroker funktioniert, Verbindung scheint auch stabil. Ich werde das mal testen.
                                Danke!
                                  clfberlinC Offline
                                  clfberlinC Offline
                                  clfberlin
                                  schrieb am zuletzt editiert von clfberlin
                                  #240
                                  @bananajoe
                                  Hui, die NetHome Plus Übersetzungen sind ja ganz großes Kino. Nicht nur die Interpretation von Begriffen, auch die Nutzerführung ist eine kleine Rätselaufgabe. 😁
                                  Eingerichtet ist ein Comfee MDDF-20DEN7-WF. Ich habe mal beides ausprobiert.
                                  Der Midea-Adapter (0.0.7) legt bei mir Objekte an. Unter control sind die Werte [null]
                                  Unter general sind Werte wie id und sn befüllt, andere wie activeStatus hingegen nicht.
                                  Unter status wieder alles [null]
                                  Den HAM-Adapter nutze ich schon für ewelink. Wenn es erstmal läuft, ist es ok. Ein Problem bei mir: Installiere ich über die Adapter-Konfiguration homebridge-midea-air@1.7.0, kann ich hinterher keine Konfiguration aufrufen. Er rödelt und rödelt, öffnet aber nix. Das scheint bei mir ein generelles Problem zu sein.
                                  Installiere ich über den Homebridge-Bereich, bietet er mir bei der Suche midea air bis 1.5.2. Das kann ich installieren und auf 1.7.3 updaten. Das Ergebnis sind dann zwei Objektordner ham.0.Entfeuchter_8558.000000BC (mit Werten für Klimatisierung) und ham.0.Entfeuchter_8558.000000BD (mit Werten für Trocknung). Die Werte darin haben aber nichts mit dem tatsächlichen Zustand zu tun. Und steuern kann ich dort auch nichts.
                                  Bevor ich hier weiter teste: Es war die Rede von 1.7.0. Ist diese Version zwingend für das Funktionieren? Oder geht es generell mit 1.7.0+ (also ab der Version)?
                                  Merci, clfberlin
                                    @bananajoe
                                    Merci, clfberlin
                                    clfberlinC Offline
                                    clfberlinC Offline
                                    clfberlin
                                    #241
                                    Ergänzung: Ah, ne... Das hängt etwas vom Modus ab. In "Smart" gibt er keine aktuellen Werte aus. Ansonsten schon, allerdings nicht ganz zuverlässig, Wasserstand überhaupt nicht und steuern lässt sich auch nichts. Gerade Wasserstand wäre für mich eine interessante Info. Naja, mal schauen.
                                      clfberlinC Offline
                                      clfberlinC Offline
                                      clfberlin
                                      #242
                                      Und noch eine Sache beim HAM-Adapter.
                                      Es ist "interval": 30 eingestellt. Aber in den Logs fließen sekündlich Abfragen ein. 🤔
                                        mike2712
                                        schrieb am zuletzt editiert von mike2712
                                        #243
                                        [gelöst] Hallo, ich habe jetzt auf die Version 0.0.1 hochgerüstet, jetzt wird der Adapter selbst nicht mehr grün, mit den Meldungen kann ich nichts anfangen, was habe ich falsch gemacht?
                                        Warum auch immer, nach einigen Neustarts funktioniert es nun.
                                        midea.0
                                        2023-02-03 11:40:40.319	error	SyntaxError: Unexpected token F in JSON at position 445 at JSON.parse (<anonymous>) at Midea.getDeviceList (/opt/iobroker/node_modules/iobroker.midea/main.js:113:30) at processTicksAndRejections (node:internal/process/task_queues:96:5) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:76:5)
                                        midea.0
                                        2023-02-03 11:40:40.314	error	SyntaxError: Unexpected token F in JSON at position 445
                                        midea.0
                                        2023-02-03 11:40:31.092	error	*** PY *** Python Error Call to 'connect_to_cloud' failed:> const cloud = await this.midea_beautiful.connect_to_cloud$({ at Midea.login (/opt/iobroker/node_modules/iobroker.midea/main.js:87:21) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:75:18)... across the bridge ...> cloud.authenticate() at connect_to_cloud (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/__init__.py:87)> self._get_region() at authenticate (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:388)> response = self.api_request( at _get_region (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:371)> self.handle_api_error(int(payload[error_code_tag]), payload["msg"]) at api_request (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:302)> handler() at handle_api_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:645)> raise CloudError(error, message) at cloud_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:630)*** JS *** midea_beautiful.exceptions.CloudError: Midea cloud API error: user route does not exist (10004)
                                        ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
                                        • M mike2712
                                          midea.0
                                          midea.0
                                          midea.0
                                          clfberlinC Offline
                                          clfberlinC Offline
                                          clfberlin
                                          #244
                                          @mike2712
                                          Oh, ok. @Thomas-Braun schrieb mal:
                                          Genau genommen ist 0.0.7 die 'aktuelle' Version, die 0.1.0 aus git ist nur eine Alpha zum herumbasteln.
