  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.5k Aufrufe 45 Beobachtet
  • B biker1602
    @ciddi89 said in Test Adapter zigbee2mqtt:
    @biker1602 was fürn raspberry ist das? 0, 1 oder höher?
    Raspi 4 ohne SD-Karte, sondern mit SSD Festplatte.
    #223
    @biker1602 wie sieht die config aus?
    sudo nano /etc/systemd/system/zigbee2mqtt.service
      biker1602
      #224
      @ciddi89
      [Unit]
      Description=zigbee2mqtt
      After=network.target
      [Service]
      ExecStart=/usr/local/bin/npm start
      WorkingDirectory=/opt/zigbee2mqtt
      StandardOutput=inherit
      # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
      StandardError=inherit
      Restart=always
      RestartSec=10s
      User=pi
      [Install]
      WantedBy=multi-user.target
      • B biker1602
        @ciddi89
        [Unit]
        [Service]
        Restart=always
        RestartSec=10s
        User=pi
        [Install]
        #225
        @biker1602 da fehlt eine Zeile.
        [Unit]
        [Service]
        Environment=NODE_ENV=production
        ExecStart=/usr/bin/npm start
        Restart=always
        RestartSec=10s
        User=pi
        [Install]
        Danach
        sudo systemctl start zigbee2mqtt
        Und Ergebnis von
        systemctl status zigbee2mqtt.service
          [Unit]
          [Service]
          Restart=always
          RestartSec=10s
          User=pi
          [Install]
          Danach
          Und Ergebnis von
          biker1602
          #226
          @ciddi89
          permitted by applicable law.
          Last login: Tue Dec 20 08:45:59 2022 from 192.168.57.120
          #pi@raspberrypi:~ $ sudo systemctl enable zigbee2mqtt.service
          pi@raspberrypi:~ $ sudo nano /etc/systemd/system/zigbee2mqtt.service
          pi@raspberrypi:~ $ sudo systemctl start zigbee2mqtt
          Warning: The unit file, source configuration file or drop-ins of zigbee2mqtt.service changed on disk. Run 'systemctl daemon-reload' to reload units.
          pi@raspberrypi:~ $ systemctl status zigbee2mqtt.service
          ● zigbee2mqtt.service - zigbee2mqtt
             Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
             Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:07:18 CET; 10s ago
            Process: 5532 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
           Main PID: 5532 (code=exited, status=203/EXEC)
          pi@raspberrypi:~ $
          • B biker1602
            @ciddi89
            pi@raspberrypi:~ $
            #227
            @biker1602
            Mach mal
            Und dann noch mal
            Und Ergebnis von
              @biker1602
              Mach mal
              Und dann noch mal
              Und Ergebnis von
              biker1602
              #228
              Authentication is required to reload the systemd state.
              Multiple identities can be used for authentication:
               1.  ,,, (pi)
               2.  root
              Choose identity to authenticate as (1-2): Failed to reload daemon: Method call timed out
              Was soll ich da nehmen 1 oder 2?
              • B biker1602
                 1.  ,,, (pi)
                 2.  root
                #229
                @biker1602 pi
                  @biker1602 pi
                  #230
                  @ciddi89 wenn das nicht geht dann mit sudo. Hatte ich vergessen.
                  sudo systemctl daemon-reload
                    biker1602
                    #231
                    @ciddi89
                       Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:21:49 CET; 7s ago
                      Process: 7179 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                     Main PID: 7179 (code=exited, status=203/EXEC)
                    pi@raspberrypi:~ $
                    • B biker1602
                      @ciddi89
                      pi@raspberrypi:~ $
                      #232
                      @biker1602 vielleicht bist du zu schnell 😬 da steht noch activating. Mach jetzt noch mal
                      B 2 Antworten Letzte Antwort
                        biker1602
                        #233
                        @ciddi89
                          Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC
                         Main PID: 8239 (code=exited, status=203/EXEC)
                        lines 1-5/5 (END)
                           Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:29:51 CET; 3s ago
                          Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                        crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                          biker1602
                          #234
                          @ciddi89
                          Bin mal kurz weg
                          • B biker1602
                            @ciddi89
                            Bin mal kurz weg
                            #235
                            @biker1602 ja irgendwie startet er den Dienst nicht. Vielleicht weiß @IdleBit noch was 🤔
                            • B biker1602
                              @ciddi89
                              lines 1-5/5 (END)
                              crunchipC Offline
                              crunchipC Offline
                              #236
                              @biker1602 sagte in Test Adapter zigbee2mqtt:
                              liegt das denn in dem Pfad?
                              • B biker1602
                                @ciddi89
                                lines 1-5/5 (END)
                                #237
                                @biker1602
                                Nodejs./npm-Installation prüfen.
                                Da scheinen mal wieder die falschen Pfade vorzuliegen (ergo falsch installiert).
                                  @biker1602
                                  biker1602
                                  #238
                                  Behebt er das mit dem Fixer?
                                  • B biker1602
                                    #239
                                    @biker1602
                                    Nein, der Fixer behebt keine krumme Installation von nodejs.
                                    Status jetzt ist?
                                    Mit
                                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    nachschauen.
                                      biker1602
                                      #240
                                      @crunchip said in Test Adapter zigbee2mqtt:
                                      Ich bin eben mal mit WinSCP auf das Verzeichnis gegangen und unter
                                      /usr/local/bin ist nichts drin
                                        @biker1602
                                        Status jetzt ist?
                                        Mit
                                        nachschauen.
                                        biker1602
                                        #241
                                        pi@raspberrypi:/opt/zigbee2mqtt $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                        pi@raspberrypi:/opt/zigbee2mqtt $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        armv7l
                                        Kein Docker
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.19.0
                                        v16.19.0
                                        8.19.3
                                        4.0.23
                                        pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                        tty
                                        /opt/zigbee2mqtt
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                        Reading package lists... Done
                                        Building dependency tree
                                        97 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                        nodejs:
                                        • B biker1602
                                          armv7l
                                          Kein Docker
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.19.0
                                          v16.19.0
                                          8.19.3
                                          4.0.23
                                          pi
                                          tty
                                          /opt/zigbee2mqtt
                                          nodejs:
                                          #242
                                          @biker1602
                                          Das ist nicht vollständig, dein Betriebssystem ist tot und es stehen 97 Updates in der Pipeline.
