  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.6k Aufrufe 45 Beobachtet
  • B biker1602
    @ciddi89
    [Unit]
    Description=zigbee2mqtt
    After=network.target
    [Service]
    ExecStart=/usr/local/bin/npm start
    WorkingDirectory=/opt/zigbee2mqtt
    StandardOutput=inherit
    # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
    StandardError=inherit
    Restart=always
    RestartSec=10s
    User=pi
    [Install]
    WantedBy=multi-user.target
    #225
    @biker1602 da fehlt eine Zeile.
    [Unit]
    [Service]
    Environment=NODE_ENV=production
    ExecStart=/usr/bin/npm start
    Restart=always
    RestartSec=10s
    User=pi
    [Install]
    Danach
    sudo systemctl start zigbee2mqtt
    Und Ergebnis von
    systemctl status zigbee2mqtt.service
      [Unit]
      [Service]
      Restart=always
      RestartSec=10s
      User=pi
      [Install]
      Danach
      Und Ergebnis von
      biker1602
      #226
      @ciddi89
      permitted by applicable law.
      Last login: Tue Dec 20 08:45:59 2022 from 192.168.57.120
      #pi@raspberrypi:~ $ sudo systemctl enable zigbee2mqtt.service
      pi@raspberrypi:~ $ sudo nano /etc/systemd/system/zigbee2mqtt.service
      pi@raspberrypi:~ $ sudo systemctl start zigbee2mqtt
      Warning: The unit file, source configuration file or drop-ins of zigbee2mqtt.service changed on disk. Run 'systemctl daemon-reload' to reload units.
      pi@raspberrypi:~ $ systemctl status zigbee2mqtt.service
      ● zigbee2mqtt.service - zigbee2mqtt
         Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
         Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:07:18 CET; 10s ago
        Process: 5532 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
       Main PID: 5532 (code=exited, status=203/EXEC)
      pi@raspberrypi:~ $
      • B biker1602
        @ciddi89
        pi@raspberrypi:~ $
        #227
        @biker1602
        Mach mal
        Und dann noch mal
        Und Ergebnis von
          @biker1602
          Mach mal
          Und dann noch mal
          Und Ergebnis von
          biker1602
          #228
          @ciddi89 said in Test Adapter zigbee2mqtt:
          Authentication is required to reload the systemd state.
          Multiple identities can be used for authentication:
           1.  ,,, (pi)
           2.  root
          Choose identity to authenticate as (1-2): Failed to reload daemon: Method call timed out
          Was soll ich da nehmen 1 oder 2?
          • B biker1602
             1.  ,,, (pi)
             2.  root
            #229
            @biker1602 pi
              @biker1602 pi
              #230
              @ciddi89 wenn das nicht geht dann mit sudo. Hatte ich vergessen.
              sudo systemctl daemon-reload
                biker1602
                #231
                @ciddi89
                   Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:21:49 CET; 7s ago
                  Process: 7179 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                 Main PID: 7179 (code=exited, status=203/EXEC)
                pi@raspberrypi:~ $
                • B biker1602
                  @ciddi89
                  pi@raspberrypi:~ $
                  #232
                  @biker1602 vielleicht bist du zu schnell 😬 da steht noch activating. Mach jetzt noch mal
                  B 2 Antworten Letzte Antwort
                    biker1602
                    #233
                    @ciddi89
                      Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC
                     Main PID: 8239 (code=exited, status=203/EXEC)
                    lines 1-5/5 (END)
                       Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:29:51 CET; 3s ago
                      Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                    crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                      biker1602
                      #234
                      @ciddi89
                      Bin mal kurz weg
                      • B biker1602
                        @ciddi89
                        Bin mal kurz weg
                        #235
                        @biker1602 ja irgendwie startet er den Dienst nicht. Vielleicht weiß @IdleBit noch was 🤔
                        • B biker1602
                          @ciddi89
                          lines 1-5/5 (END)
                          crunchipC Offline
                          crunchipC Offline
                          #236
                          @biker1602 sagte in Test Adapter zigbee2mqtt:
                          liegt das denn in dem Pfad?
                          • B biker1602
                            @ciddi89
                            lines 1-5/5 (END)
                            #237
                            @biker1602
                            Nodejs./npm-Installation prüfen.
                            Da scheinen mal wieder die falschen Pfade vorzuliegen (ergo falsch installiert).
                              @biker1602
                              biker1602
                              #238
                              Behebt er das mit dem Fixer?
                              • B biker1602
                                #239
                                @biker1602
                                Nein, der Fixer behebt keine krumme Installation von nodejs.
                                Status jetzt ist?
                                Mit
                                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                nachschauen.
                                  biker1602
                                  #240
                                  @crunchip said in Test Adapter zigbee2mqtt:
                                  Ich bin eben mal mit WinSCP auf das Verzeichnis gegangen und unter
                                  /usr/local/bin ist nichts drin
                                    @biker1602
                                    Status jetzt ist?
                                    Mit
                                    nachschauen.
                                    biker1602
                                    #241
                                    pi@raspberrypi:/opt/zigbee2mqtt $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                    pi@raspberrypi:/opt/zigbee2mqtt $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    armv7l
                                    Kein Docker
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.19.0
                                    v16.19.0
                                    8.19.3
                                    4.0.23
                                    pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                    tty
                                    /opt/zigbee2mqtt
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                    Reading package lists... Done
                                    Building dependency tree
                                    97 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    nodejs:
                                    • B biker1602
                                      armv7l
                                      Kein Docker
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.19.0
                                      v16.19.0
                                      8.19.3
                                      4.0.23
                                      pi
                                      tty
                                      /opt/zigbee2mqtt
                                      nodejs:
                                      #242
                                      @biker1602
                                      Das ist nicht vollständig, dein Betriebssystem ist tot und es stehen 97 Updates in der Pipeline.
                                        @biker1602
                                        biker1602
                                        #243
                                        @thomas-braun said in Test Adapter zigbee2mqtt:
                                        @biker1602
                                        Verzeihung da fehlte noch etwas
                                        armv7l
                                        Kein Docker
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.19.0
                                        v16.19.0
                                        8.19.3
                                        4.0.23
                                        pi
                                        tty
                                        /opt/zigbee2mqtt
                                        nodejs:
                                          Installed: 16.19.0-deb-1nodesource1
                                          Candidate: 16.19.0-deb-1nodesource1
                                          Version table:
                                         *** 16.19.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                             10.24.0~dfsg-1~deb10u2 500
                                        • B biker1602
                                          @biker1602
                                          armv7l
                                          Kein Docker
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.19.0
                                          v16.19.0
                                          8.19.3
                                          4.0.23
                                          pi
                                          tty
                                          /opt/zigbee2mqtt
                                          nodejs:
                                            Version table:
                                          #244
                                          @biker1602
                                          Dann reduziert es sich auf:
