  4. Test Adapter tvprogram
    apollon77A
adaptertvprogramviswidget
938 Beiträge 51 Kommentatoren 391.9k Aufrufe 54 Beobachtet
  • OliverIOO OliverIO
    @damrak2022
    Ich zitiere aus der Hilfe. 2. Absatz
    Time
    This widget shows the current TV program on a timeline by TV channel.
    If the text behind the channel logos shows through, a background color must be selected in the widget. it is generally a good approach to choose an explicit foreground and background color for the view or at least for the widget. The Marker position ist updated every 15 seconds.
    Zu den Sendern sehe ich du hast bereits einige hinzugefügt (Burger menü oben links)
    Zu mehr Programmen gibt es in der verwendeten darenquelle keine Daten
    M
    M
    MCU
    #819
    @oliverio Hatte diese Meldung im Log? Muss ich was machen?
    tvprogram.0
    2022-06-30 04:40:03.041	warn	TypeError: Cannot read properties of undefined (reading 'processMessages') at Tvprogram.onMessage (/opt/iobroker/node_modules/iobroker.tvprogram/main.js:89:29) at Tvprogram.emit (node:events:527:28) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5301:34) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
    tvprogram.0
    2022-06-30 04:40:03.036	warn	States system pmessage io.messagebox.system.adapter.tvprogram.0 {"command":"getServerBroadcastDate","message":{"channelfilter":[1,6,7,22,30,39,11,26,18,43,13,16,12,20,29,14,35,38,9,28,25,3,10,24,32,5,15,4,19,33],"date":"06/30/2022 04:40:00"},"from":"system.adapter.javascript.0","callback":{"message":{"channelfilter":[1,6,7,22,30,39,11,26,18,43,13,16,12,20,29,14,35,38,9,28,25,3,10,24,32,5,15,4,19,33],"date":"06/30/2022 04:40:00"},"id":1,"ack":false,"time":1656556802907},"_id":46983024} Cannot read properties of undefined (reading 'processMessages')
    • M MCU
      tvprogram.0
      tvprogram.0
      OliverIOO
      OliverIOO
      OliverIO
      #820
      @mcu
      passiert das öfters oder war das nur was einmaliges?
      hattest du da gerade etwas gemacht?
      zum Hintergrund:
      An dieser Stelle übergibt iobroker an den Adapter die Information, das eine Nachricht über das Messaging-System ankommt (ist nochmal ein 2.Kommunikationsweg neben den Datenpunkten den der Adapter zur Kommunikation mit den widgets nutzt bzw umgekehrt).
      Genau an der Stelle an der der Fehler aufgetreten ist, wird die Information an die eigentliche Funktion weitergegeben, welche sich in einem eigenen Objekt befindet. Diese Objekt ist wohl nicht mehr existent.
      Allerdings wird dieses Objekt einmal bei Start des Adapters angelegt und beim beenden des Adapters wieder zerstört.
      d,h, dieser Fehler kann eigentlich nur vorkommen, wenn der Adapter gerade beendet wird und gerade noch eine Nachricht reinkommt.
      Kannst du da auch mal vor und nach diesem Zeitpunkt nach Hinweisen zum beenden des Adapters schauen?
      Meine Adapter und Widgets
      Links im Profil
        @mcu
        zum Hintergrund:
        M
        M
        MCU
        #821
        @oliverio Einmalig , beim Neustart vom RaspberryPI. Ist mir allerdings auch erst jetzt aufgefallen. Ich beobachte es mal, ob es auch unabhängig vom Neustart kommt. Melde mich dann wieder. Danke.
        Das kam auch vorher, also das scheint momentan immer mehr zu werden?
        2022-06-30 04:39:55.775 - warn: tvprogram.0 (2740) slow connection to states DB. Still waiting ...
        • M MCU
          OliverIOO
          OliverIOO
          OliverIO
          #822
          @mcu
          diese Warnung würde ich noch als akzeptabel einschätzen.
          es werden schon viele daten zwischen widget und adapter übertragen.
          bei mir sind es so ca 1.4MB für einen tag.
          ich cache zwar alles im browser und rufe sowenig im voraus ab, wie es geht.
          aber da denkt der iobroker dann schon mal, huch das dauert zu lange
          Links im Profil
            @mcu
            M
            M
            MCU
            #823
            @oliverio Fehler im TV-programm ?
            War anscheinend ein ungünstiger Zeitpunkt kurz vor 00:00 Uhr.
            • M MCU
              OliverIOO
              OliverIOO
              OliverIO
              #824
              @mcu
              Ging es denn dann nach einiger Zeit wieder?
              Was waren genau die Umstände?
              Hast du mir Hinweise wie ich das nachvollziehen kann?
              Sonst wird es schwierig.
              Welche Version verwendest du? Ich hab zwar nur mit den Zeilen bei github verglichen, aber die stimmen nicht so überein.
              Links im Profil
                @mcu
                M
                M
                MCU
                #825
                @oliverio
                Ja, ab 00:00 ging es wieder.
                Genaue Umstände: als iFrame in jarvis nur aufgerufen. Um 23:55 Uhr, dann kamen die Meldungen.
                Hinweise: keine
                Version:
                • M MCU
                  @oliverio
                  Hinweise: keine
                  Version:
                  OliverIOO
                  OliverIOO
                  OliverIO
                  #826
                  @mcu und es war der aktuelle Tag vor 0 Uhr eingestellt?
                  Ich Probier mal da was nachzustellen
                  Passiert das regelmäßig? Oder war es nur einmalig?
                  Links im Profil
                    M
                    M
                    MCU
                    #827
                    @oliverio
                    Ja aktueller Tag vor 00:00 Uhr (24:00)
                    Ist mir erstmalig aufgefallen.
                    • M MCU
                      @oliverio
                      OliverIOO
                      OliverIOO
                      OliverIO
                      #828
                      @mcu
                      Ich Probier mal. Aber wenn es nicht regelmäßig auftritt kann es schwierig werden.
                      0 Uhr ist eigentlich nicht problematisch. Der tageswechsel im Programm ist um 4 oder 5
                      Links im Profil
                        @mcu
                        M
                        M
                        MCU
                        #829
                        @oliverio Ich beobachte es weiter und melde mich dann, falls es weitere Vorfälle gibt.
                        • M
                          M
                          MCU
                          #830
                          @oliverio Ob es mit js-controller Update zusammenhängt?
                          Hab eine Fehlermeldung bzgl. info.js
                          • M MCU
                            OliverIOO
                            OliverIOO
                            OliverIO
                            #831
                            @mcu
                            In keinem meiner Adapter habe ich eine Datei Info.js
                            Aber du kannst da mal drauf drücken dann öffnet sich diese Datei im source tab. Anhand des Pfads siehst du dann zu welchem Adapter/Widget das gehört.
                            Links im Profil
                            • DJMarc75D
                              DJMarc75D
                              DJMarc75
                              #832
                              Gerade festgestellt:
                              Wenn ich in der VIS eine Sendung anklicke dann geht ja das zugehörige Popup auf:
                              Passt ja, aber wenn ich das Popup offen lasse und die View wechsle dann bleibt dieses in der anderen View sichtbar:
                              Gefällt mir rein optisch weniger gut 😁
                              Lehrling seit 1975 !!!
                              • DJMarc75D DJMarc75
                                OliverIOO
                                OliverIOO
                                OliverIO
                                #833
                                @djmarc75
                                Dann schließe das popup vor dem wechsel?
                                Ich nutze jquery für das popup.
                                Jquery legt ziemlich am Ende des html Baums ein html Element für das popup zum einblenden an. Dadurch liegt es automatisch über allen anderen Elementen. Man müsste jquery beibringen dieses platzhalterelement innerhalb der jeweiligen View anzulegen.
                                Dann würde es beim Wechsel verschwinden und beim zurückwechseln noch da sein.
                                Muss mal schauen ob sich da was ohne seiteneffekte ändern lässt.
                                Links im Profil
                                • M
                                  M
                                  MCU
                                  #834
                                  Bei Neuinstallation kam folgende Meldung:
                                  • M
                                    M
                                    McOnno
                                    schrieb am zuletzt editiert von McOnno
                                    #835
                                    Hallo, seit ein paar Tagen bekomme ich kein Programm angezeigt, obwohl laut Instanz eine Verbindung besteht! In der View steht nur: Datapoints loading...
                                    Es kommen aber keine Daten.
                                    Ein oder 2 Tage vorher war noch alles i.O. Habe keine Änderungen im Adapter vorgenommen, plötzlich kommen keine Daten mehr!?
                                    • M McOnno
                                      OliverIOO
                                      OliverIOO
                                      OliverIO
                                      #836
                                      @mconno
                                      bei mir funktioniert alles.
                                      aber wenn ich auf den screenshot schaute, da stimmt was nicht
                                      da steht 3x sowas wie val val val
                                      das ist nicht der richtige inhalt.
                                      erstelle mal in den adaptereinstellungen einen 2. fernseher
                                      und stelle die datenpunkte des widgets dann auf diese datenpunkte ein.
                                      hast du irgenwelche fehler im iobroker log?
                                      Links im Profil
                                        @mconno
                                        M
                                        M
                                        McOnno
                                        #837
                                        @oliverio
                                        @oliverio sagte in Test Adapter tvprogram:
                                        @mconno
                                        Vielen Dank für die schnelle Antwort Oli!
                                        Hab einen 2. TV eingestellt und nun läuft alles wieder!
                                        Super Support bietest du! 👍
                                        • M McOnno
                                          @oliverio
                                          @mconno
                                          OliverIOO
                                          OliverIOO
                                          OliverIO
                                          #838
                                          @mconno
                                          danke,
                                          dann kannst den ersten fernseher wieder löschen
                                          Links im Profil
                                          83.9k
