  4. Test Adapter vis 2.0 (Alpha)
    6.6k
780 Beiträge 108 Kommentatoren 350.9k Aufrufe 140 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #112
    energy
    dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-energy
    added 1 package in 12s
    163 packages are looking for funding
      run `npm fund` for details
    dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-energy
    host.iobroker install adapter vis-2-widgets-energy
    upload [0] vis-2-widgets-energy.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/admin/vis-2-widgets-energy.png vis-2-widgets-energy.png image/png
    INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/www" was not found! Nothing was uploaded or deleted.
    Adapter "system.adapter.vis.0" restarted.
    Adapter "system.adapter.vis-2-beta.0" restarted.
    host.iobroker object system.adapter.vis-2-widgets-energy created/updated
    host.iobroker create instance vis-2-widgets-energy
    host.iobroker object system.adapter.vis-2-widgets-energy.0 created
    Danke.
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #113
      gauges
      dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-gauges
      dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-gauges
      host.iobroker install adapter vis-2-widgets-gauges
      upload [0] vis-2-widgets-gauges.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/admin/vis-2-widgets-gauges.png vis-2-widgets-gauges.png image/png
      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/www" was not found! Nothing was uploaded or deleted.
      host.iobroker object system.adapter.vis-2-widgets-gauges created/updated
      host.iobroker create instance vis-2-widgets-gauges
      host.iobroker object system.adapter.vis-2-widgets-gauges.0 created
      Danke.
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #114
        Und irgendwie hab ich diese material jetzt 4 x bei den Instanzen.
        Kann doch nicht stimmen.
        Edit:
        Habe 3 x gelöscht.
        Danke.
        • bahnuhrB bahnuhr
          Edit:
          Habe 3 x gelöscht.
          #115
          @bahnuhr Naja das "add" darfste am ende nur einmal pro adapter ausführen weil es sonst immer eine neue Instanz anlegt.
          • apollon77A apollon77
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #116
            @apollon77 sagte in Test Adapter vis 2.0 (Alpha):
            Jo, hab ich dann auch gemerkt.
            Danke.
            • bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #117
              So, ganz adhoc was mir aufgefallen ist.
              Die ca. 50 views in meiner main hat er wohl komplett übernommen.
              Es war aber nur 1 sichtbar.
              Links oben konnte man dann die einzelnen wieder sichtbar machen.
              Bei vis.1 konnte man mit dem Mausrädchen in den views nach rechts oder links fahren:
              Dies geht nun nicht mehr.
              Wie kommt man nun an die rechten views ?
              Nachtrag:
              Das geht so gar nicht.
              Damit kann man nicht mehr vernünftig arbeiten.
              (oder ich habs nicht gerafft)
              Danke.
              bahnuhrB apollon77A 2 Antworten Letzte Antwort
              • bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #118
                auch wurden keine css Befehle übernommen.
                Ich hatte da in vis1 jede Menge drin.
                In vis2 steht gar nichts.
                Danke.
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #119
                  auch stehen jetzt überall die widget Nr.
                  Wo kann man dies ausschalten.
                  Danke.
                  liv-in-skyL apollon77A 3 Antworten Letzte Antwort
                  • bahnuhrB bahnuhr
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #120
                    @bahnuhr
                    da :-)
                    • bahnuhrB bahnuhr
                      Nachtrag:
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #121
                      @bahnuhr sagte in Test Adapter vis 2.0 (Alpha):
                      Nachtrag:
                      Nochmal. Es kann doch nicht sein, dass ich erst 30 Views ausschalten muss um an die rechten Views zu kommen !
                      Überseh ich irgendwas ?
                      Danke.
                      • bahnuhrB bahnuhr
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #122
                        @bahnuhr
                        dafür weiß ich nicht, wie man den roten balken wegbekommt - zeigt wohl die breite der seite an
                        bahnuhrB crunchipC 2 Antworten Letzte Antwort
                        • liv-in-skyL Offline
                          liv-in-skyL Offline
                          #123
                          wie schauen eure hintergründe aus ?
                          etwas seltsam bei mir
                          bahnuhrB 1Topf1 2 Antworten Letzte Antwort
                          • FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #124
                            Schau einmal, ob dir dieses issue weiterhilft und wenn es thematisch passt gerne dort einen Daumen hoch oder es ergänzen
                            https://github.com/ioBroker/ioBroker.vis/issues/579
                            • FeuersturmF Feuersturm
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #125
                              @feuersturm
                              Ja, habe auch meinen Text dort hin geschrieben.
                              Daumen hoch habe ich nicht gefunden, wo ist dies ?
                              Danke.
                              • liv-in-skyL liv-in-sky
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #126
                                @liv-in-sky sagte in Test Adapter vis 2.0 (Alpha):
                                Bei mir steht da black. Und so ist es auch.
                                Danke.
                                  @bahnuhr
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #127
                                  @bahnuhr
                                  roten Balken hab ich nicht.
                                  Danke.
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #128
                                    nochwas; hab ja eben vis-2 widgets installiert:
                                    Aber müsste ich diese nicht auch in vis-2 finden ?
                                    Alle 3 sind nicht in der Liste.
                                    Danke.
                                    apollon77A H 2 Antworten Letzte Antwort
                                      @bahnuhr
                                      crunchipC Offline
                                      crunchipC Offline
                                      #129
                                      @liv-in-sky wird wohl ein widget sein
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #130
                                        @crunchip könnte sein, da es nur auf dieser seite ist
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #131
                                          @crunchip du hast recht - ist ein image widget mit sichtbarkeit und einem binding in der css klasse
