  4. Test Adapter vis 2.0 (Alpha)
    6.6k
780 Beiträge 108 Kommentatoren 350.8k Aufrufe 140 Beobachtet
  • bahnuhrB bahnuhr
    material:
    dieter@iobroker:~$ cd /opt/iobroker
    dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-material
    [sudo] Passwort für dieter:
    removed 228 packages in 17s
    163 packages are looking for funding
      run `npm fund` for details
    dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-material
    INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-material/www" was not found! Nothing was uploaded or deleted.
    Adapter "system.adapter.vis.0" restarted.
    Adapter "system.adapter.vis-2-beta.0" restarted.
    host.iobroker create instance vis-2-widgets-material
    host.iobroker object system.adapter.vis-2-widgets-material.3 created
    #111
    @bahnuhr Und ds hier sieht voll ok aus ... die "INFO" ist was es sagt eine "INFO" :-)
    • bahnuhrB Offline
      bahnuhrB Offline
      bahnuhr
      #112
      energy
      dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-energy
      added 1 package in 12s
      dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-energy
      host.iobroker install adapter vis-2-widgets-energy
      upload [0] vis-2-widgets-energy.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/admin/vis-2-widgets-energy.png vis-2-widgets-energy.png image/png
      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/www" was not found! Nothing was uploaded or deleted.
      host.iobroker object system.adapter.vis-2-widgets-energy created/updated
      host.iobroker create instance vis-2-widgets-energy
      host.iobroker object system.adapter.vis-2-widgets-energy.0 created
      Danke.
      • bahnuhrB Offline
        bahnuhrB Offline
        bahnuhr
        #113
        gauges
        dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-gauges
        dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-gauges
        host.iobroker install adapter vis-2-widgets-gauges
        upload [0] vis-2-widgets-gauges.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/admin/vis-2-widgets-gauges.png vis-2-widgets-gauges.png image/png
        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/www" was not found! Nothing was uploaded or deleted.
        host.iobroker object system.adapter.vis-2-widgets-gauges created/updated
        host.iobroker create instance vis-2-widgets-gauges
        host.iobroker object system.adapter.vis-2-widgets-gauges.0 created
        Danke.
        • bahnuhrB Offline
          bahnuhrB Offline
          bahnuhr
          #114
          Und irgendwie hab ich diese material jetzt 4 x bei den Instanzen.
          Kann doch nicht stimmen.
          Edit:
          Habe 3 x gelöscht.
          Danke.
          • bahnuhrB bahnuhr
            Edit:
            Habe 3 x gelöscht.
            #115
            @bahnuhr Naja das "add" darfste am ende nur einmal pro adapter ausführen weil es sonst immer eine neue Instanz anlegt.
            • apollon77A apollon77
              bahnuhrB Offline
              bahnuhrB Offline
              bahnuhr
              #116
              @apollon77 sagte in Test Adapter vis 2.0 (Alpha):
              Jo, hab ich dann auch gemerkt.
              Danke.
              • bahnuhrB Offline
                bahnuhrB Offline
                bahnuhr
                #117
                So, ganz adhoc was mir aufgefallen ist.
                Die ca. 50 views in meiner main hat er wohl komplett übernommen.
                Es war aber nur 1 sichtbar.
                Links oben konnte man dann die einzelnen wieder sichtbar machen.
                Bei vis.1 konnte man mit dem Mausrädchen in den views nach rechts oder links fahren:
                Dies geht nun nicht mehr.
                Wie kommt man nun an die rechten views ?
                Nachtrag:
                Das geht so gar nicht.
                Damit kann man nicht mehr vernünftig arbeiten.
                (oder ich habs nicht gerafft)
                Danke.
                bahnuhrB apollon77A 2 Antworten Letzte Antwort
                • bahnuhrB Offline
                  bahnuhrB Offline
                  bahnuhr
                  #118
                  auch wurden keine css Befehle übernommen.
                  Ich hatte da in vis1 jede Menge drin.
                  In vis2 steht gar nichts.
                  Danke.
                  • bahnuhrB Offline
                    bahnuhrB Offline
                    bahnuhr
                    #119
                    auch stehen jetzt überall die widget Nr.
                    Wo kann man dies ausschalten.
                    Danke.
                    liv-in-skyL apollon77A 3 Antworten Letzte Antwort
                    • bahnuhrB bahnuhr
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #120
                      @bahnuhr
                      da :-)
                      • bahnuhrB bahnuhr
                        Nachtrag:
                        bahnuhrB Offline
                        bahnuhrB Offline
                        bahnuhr
                        #121
                        @bahnuhr sagte in Test Adapter vis 2.0 (Alpha):
                        Nachtrag:
                        Nochmal. Es kann doch nicht sein, dass ich erst 30 Views ausschalten muss um an die rechten Views zu kommen !
                        Überseh ich irgendwas ?
                        Danke.
                        • bahnuhrB bahnuhr
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #122
                          @bahnuhr
                          dafür weiß ich nicht, wie man den roten balken wegbekommt - zeigt wohl die breite der seite an
                          bahnuhrB crunchipC 2 Antworten Letzte Antwort
                          • liv-in-skyL Offline
                            liv-in-skyL Offline
                            #123
                            wie schauen eure hintergründe aus ?
                            etwas seltsam bei mir
                            bahnuhrB 1Topf1 2 Antworten Letzte Antwort
                            • FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #124
                              Schau einmal, ob dir dieses issue weiterhilft und wenn es thematisch passt gerne dort einen Daumen hoch oder es ergänzen
                              https://github.com/ioBroker/ioBroker.vis/issues/579
                              • FeuersturmF Feuersturm
                                bahnuhrB Offline
                                bahnuhrB Offline
                                bahnuhr
                                #125
                                @feuersturm
                                Ja, habe auch meinen Text dort hin geschrieben.
                                Daumen hoch habe ich nicht gefunden, wo ist dies ?
                                Danke.
                                • liv-in-skyL liv-in-sky
                                  bahnuhrB Offline
                                  bahnuhrB Offline
                                  bahnuhr
                                  #126
                                  @liv-in-sky sagte in Test Adapter vis 2.0 (Alpha):
                                  Bei mir steht da black. Und so ist es auch.
                                  Danke.
                                    @bahnuhr
                                    bahnuhrB Offline
                                    bahnuhrB Offline
                                    bahnuhr
                                    #127
                                    @bahnuhr
                                    roten Balken hab ich nicht.
                                    Danke.
                                    • bahnuhrB Offline
                                      bahnuhrB Offline
                                      bahnuhr
                                      #128
                                      nochwas; hab ja eben vis-2 widgets installiert:
                                      Aber müsste ich diese nicht auch in vis-2 finden ?
                                      Alle 3 sind nicht in der Liste.
                                      Danke.
                                      apollon77A H 2 Antworten Letzte Antwort
                                        @bahnuhr
                                        crunchipC Offline
                                        crunchipC Offline
                                        #129
                                        @liv-in-sky wird wohl ein widget sein
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #130
                                          @crunchip könnte sein, da es nur auf dieser seite ist
