  5. Shelly 1 pm, Influx und Grafana Logging Unterbrechung
    apollon77A
blocklymonitoring
78 Beiträge 6 Kommentatoren 14.2k Aufrufe 3 Beobachtet
  • R
    R
    rebel85
    schrieb am zuletzt editiert von rebel85
    hallo,
    ich habe hier ein shelly 1 pm der mir im account die werte anders anzeigt als im shelly adapter vom iobroker.
    wie bekomme ich das hin das fortlaufend mein pv erzeugnis gezählt wird und das ohne unterbrechung .. ?
    R crunchipC 2 Antworten Letzte Antwort
    • R rebel85
      hallo,
      R
      R
      rebel85
      @rebel85 und schonwieder eine influx unterbrechung
      javascript.0
      	2022-08-18 07:15:00.011	info	received all objects
      javascript.0
      	2022-08-18 07:14:59.968	info	received all states
      javascript.0
      	2022-08-18 07:14:59.132	info	requesting all objects
      javascript.0
      	2022-08-18 07:14:59.131	info	requesting all states
      javascript.0
      	2022-08-18 07:14:58.526	info	found 0 vulnerabilities
      javascript.0
      	2022-08-18 07:14:58.524	info	10 packages are looking for funding run `npm fund` for details
      javascript.0
      	2022-08-18 07:14:58.496	info	+ request-promise-native@1.0.9added 4 packages from 3 contributors and audited 96 packages in 0.948s
      javascript.0
      	2022-08-18 07:14:57.841	error	npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      javascript.0
      	2022-08-18 07:14:57.271	info	npm install request-promise-native --omit=dev (System call)
      javascript.0
      	2022-08-18 07:14:57.257	info	found 0 vulnerabilities
      javascript.0
      	2022-08-18 07:14:57.257	info	10 packages are looking for funding run `npm fund` for details
      javascript.0
      	2022-08-18 07:14:57.234	info	+ url@0.11.0added 3 packages from 3 contributors and audited 92 packages in 0.869s
      javascript.0
      	2022-08-18 07:14:56.898	error	deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      javascript.0
      	2022-08-18 07:14:56.897	error	npm WARN
      hängt das zusammen?
      die JS meldung habe ich per zufall abgefangen gehabt, kann diese aber nciht direkt zuordnen
      komisch ist die uhrzeit des resets
      HomoranH apollon77A 3 Antworten Letzte Antwort
      • R rebel85
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        hängt das zusammen?
        @rebel85
        was ist das für ein Datenpunkt?
        was misst der?
        ist das ein kumulierter Wert?
        für welchn Zeitraum?
        wie sieht die Datenreihe aus?
        R 2 Antworten Letzte Antwort
          @rebel85
          was misst der?
          R
          R
          rebel85
          anbei 2 screenshots.
          es ist der datenpunkt für energymessung eines balkon kraftwerks.
          im shelly selber ist die maximal erzeugte energy sichtbar nur im DP nicht.
          • R rebel85
            @rebel85 sagte in Shelly 1 pm, Influx und Grafana Logging Unterbrechung:
            kann ich leider am Handy nicht entziffern!
            kannst du bitte einfach die Fragen beantworten?
            • R rebel85
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              hängt das zusammen?
              die sind aber sehr seltsam.
              ich sehe sa gar keinen Zusammenhang zu javascript.
              R 1 Antwort Letzte Antwort
              • R rebel85
                hallo,
                crunchipC
                crunchipC
                Developer Global Moderator Most Active Forum Testing
                shelly 1 pm
                den normalen oder den plus?
                Strom mal kurz weg gewesen?
                in der cloud, nicht im shelly, sonst hättest ja den DP
                HomoranH R 2 Antworten Letzte Antwort
                  shelly 1 pm
                  @crunchip sagte in Shelly 1 pm, Influx und Grafana Logging Unterbrechung:
                  das war auch meine Vermutung. deswegen meine Nachfragen
                    shelly 1 pm
                    R
                    R
                    rebel85
                    @crunchip
                    der normale shelly 1 pm
                    kann ich das umstellen?
                    und die cloud ist doch nur für die steuerung da um von außen auf den schelly zu zu greifen.
                    gibts es eine andere methode um die erzeugte gesammtleistung zu messen?
                    strom war meines wissen nicht weg, der 2. reset bis lang erfolgte direkt am nachmittag.
                    im grafana graphen wo ich die aktuelle momentan leistung sehe war ncihts zu sehen mit einem einbruch oder der gleichen
                    im influx oder history aufruf vom DP im shelly adapter kann ich ja die übermittelten daten sehen.
                    im shelly selber sehe ich die konstante und steigende erzeugte leistung ohne unterbrechung.
                    Unbenannt.JPG vom shelly
                    112.JPG reset 1
                    122.JPG reset 2
                    Unbenannt.JPG kompletter objekt baum
                      @rebel85
                      was misst der?
                      R
                      R
                      rebel85
                      @homoran sagte in Shelly 1 pm, Influx und Grafana Logging Unterbrechung:
                      @rebel85
                      DP vom shelly adapter
                      was misst der?
                      pv gesammt erzeugnis
                      vom shelly übermittelt
                      28.07.22 - dato
                        R
                        R
                        rebel85
                        haben die was mit dem shelly zu tuhn oder bedarf es eines eigenen threads?
                        • R rebel85
                          @rebel85
                          was misst der?
                          28.07.22 - dato
                          zeigen!
                          und?
                          • R rebel85
                            @crunchip
                            112.JPG reset 1
                            122.JPG reset 2
                            crunchipC
                            crunchipC
                            Da wirst du eine kurze Unterbrechung von ner Sek wohl kaum sehen, und wenn der Strom ne sek weg war, verliert der shelly seinen energy Wert und beginnt bei 0, deshal hab ich dafür auch ein extra script laufen.
                              R
                              R
                              rebel85
                              hi,
                              könntest du mir bitte das skript zukommen lassen?
                                zeigen!
                                und?
                                R
                                R
                                rebel85
                                siehe meine antwort auf crunchip dort ist ein screenshot davon vom DP
                                • R rebel85
                                  aber die Datenreihe sehe ich immer noch nicht!
                                  ist mir aber zwischenzeitlich auch egal!
                                  • R rebel85
                                    hi,
                                    crunchipC
                                    crunchipC
                                    @rebel85 https://www.kreyenborg.koeln/shelly-verbrauchs-historie-fuer-tag-woche-monat-jahr/
                                      R
                                      R
                                      rebel85
                                      @crunchip
                                      ist das normal das das skript nach erstellen und starten den iobroker ins stocken bringt?
                                      • R rebel85
                                        @crunchip
                                        crunchipC
                                        crunchipC
                                        @rebel85 was heisst ins stocken?
                                          R
                                          R
                                          rebel85
                                          @crunchip wie nen reboot und das skript ist wieder aus
                                          sobald das skript läuft, erst kommt der runde ladebalken und dann ne iobroker neu anmeldung.
                                          ist ja richtig das es in ein JS skript kommt oder?
                                          84.0k
