  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • simatecS simatec
    @mcu
    Was kommt denn, wenn du influx in der Konsole aufrufst?
    MCU
    #2038
    @simatec
    influx
    NAME:
       influx - Influx Client
    USAGE:
       influx [command]
    COMMANDS:
       version              Print the influx CLI version
       write                Write points to InfluxDB
       bucket               Bucket management commands
       completion           Generates completion scripts
       query                Execute a Flux query
       config               Config management commands
       org, organization    Organization management commands
       delete               Delete points from InfluxDB
       user                 User management commands
       task                 Task management commands
       telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
       dashboards           List Dashboard(s).
       export               Export existing resources as a template
       secret               Secret management commands
       v1                   InfluxDB v1 management commands
       auth, authorization  Authorization management commands
       apply                Apply a template to manage resources
       stacks               List stack(s) and associated templates. Subcommands manage stacks.
       template             Summarize the provided template
       bucket-schema        Bucket schema management commands
       ping                 Check the InfluxDB /health endpoint
       setup                Setup instance with initial user, org, bucket
       backup               Backup database
       restore              Restores a backup directory to InfluxDB
       remote               Remote connection management commands
       replication          Replication stream management commands
       server-config        Display server config
       help, h              Shows a list of commands or help for one command
    GLOBAL OPTIONS:
       --help, -h  show help
    • M MCU
      @simatec
      influx
      NAME:
      USAGE:
         influx [command]
      COMMANDS:
      GLOBAL OPTIONS:
      simatecS Offline
      simatecS Offline
      simatec
      #2039
      @mcu na geht doch.
      Dan sollte es auch in Backitup gehen.
      Falls die influx aus irgend einem Grund von Backitup nicht gefunden wird, trage den kompletten Pfad in der Config ein
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        @mcu na geht doch.
        MCU
        #2040
        @simatec So?
        Thomas BraunT simatecS 2 Antworten Letzte Antwort
        • M MCU
          @simatec So?
          #2041
          @mcu
          Ich würde es über den Paketmanager machen. Das fällt dir früher oder später sonst wieder auf die Füße.
            @mcu
            MCU
            #2042
            @thomas-braun Da fehlt mir das Wissen. Wie gehe ich über den Paketmanager?
            • M MCU
              #2043
              @mcu
              Repo anlegen:
              wget -q https://repos.influxdata.com/influxdb.key
              echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
              echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
              Dann das übliche Installations-Prozedere:
              sudo apt update
              sudo apt install PAKETNAME
                @mcu
                Repo anlegen:
                sudo apt update
                MCU
                #2044
                @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
                apt install sudo curl gpg gnupg2 wget -y
                sudo apt-get update && sudo apt-get install influxdb2
                • M MCU
                  #2045
                  @mcu
                  Und warum installierst du dann den client nicht auch daraus?
                  Stattdessen verhunzt du dir die dpkg-Datenbank.
                  apt policy influxdb2-cli
                  bringt?
                    @mcu
                    bringt?
                    MCU
                    #2046
                    @thomas-braun So?
                    sudo apt update && sudo apt install influxdb2-cli
                    Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
                    Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
                    Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
                    Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
                    Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
                    Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
                    Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
                    Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
                    Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
                    Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
                    Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
                    Fetched 15.0 MB in 2s (7736 kB/s)
                    Reading package lists... Done
                    12 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
                    influxdb2-cli is already the newest version (2.3.0).
                    0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
                    influxdb2-cli:
                      Installed: 2.3.0
                      Candidate: 2.3.0
                      Version table:
                     *** 2.3.0 500
                            500 https://repos.influxdata.com/debian stable/main amd64 Packages
                    • M MCU
                      @thomas-braun So?
                      influxdb2-cli:
                        Installed: 2.3.0
                        Candidate: 2.3.0
                        Version table:
                       *** 2.3.0 500
                      #2047
                      @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
                      ist also bereits installiert.
                      which influx
                      liefert?
                      Hau die 12 Updates rein...
                        which influx
                        liefert?
                        MCU
                        #2048
                        sudo apt update
                        [sudo] password for prox:
                        Hit:1 http://ftp.debian.org/debian bullseye InRelease
                        Hit:2 http://security.debian.org bullseye-security InRelease
                        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                        All packages are up to date.
                        which influx
                        /usr/local/bin/influx
                        • M MCU
                          sudo apt update
                          which influx
                          #2049
                          sudo rm /usr/local/bin/influx
                          exit
                          Wieder einloggen und dann nochmal
                          which influx
                          Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
                          • M MCU
                            @simatec So?
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #2050
                            @mcu nich influxd … nur influx
                              exit
                              which influx
                              MCU
                              #2051
                              which influx
                              /usr/bin/influx
                              • simatecS simatec
                                MCU
                                #2052
                                @simatec
                                • M MCU
                                  @simatec
                                  #2053
                                  @mcu
                                  rm influxdb2*
                                  apt policy influxdb*
                                    @mcu
                                    rm influxdb2*
                                    MCU
                                    #2054
                                    @thomas-braun sagte in Test Adapter ioBroker.backitup v2.4.x:
                                    rm influxdb2*
                                    rm influxdb2*
                                    rm: cannot remove 'influxdb2-client-2.3.0-linux-amd64': Is a directory
                                    mit sudo?
                                    N: Unable to locate package influxdb.key
                                    N: Couldn't find any package by glob 'influxdb.key'
                                    N: Unable to locate package influxdb2-client-2.3.0-linux-amd64
                                    N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64'
                                    • M MCU
                                      rm influxdb2*
                                      rm influxdb2*
                                      mit sudo?
                                      #2055
                                      @mcu
                                      ls -la
                                      Und bitte vollständige Ein- wie Ausgabezeilen inkl. LogIn-Prompt, damit ich sehe wo du da im Tree stehst.
                                        @mcu
                                        ls -la
                                        MCU
                                        #2056
                                        ls -la
                                        prox@influxdb:~$ ls -la
                                        total 32
                                        drwxr-xr-x 3 prox prox 4096 Jul 10 20:41 .
                                        drwxr-xr-x 3 root root 4096 Jun 26 07:23 ..
                                        -rw------- 1 prox prox 1297 Jul 10 20:37 .bash_history
                                        -rw-r--r-- 1 prox prox  220 Jun 26 07:23 .bash_logout
                                        -rw-r--r-- 1 prox prox 3526 Jun 26 07:23 .bashrc
                                        -rw-r--r-- 1 prox prox  807 Jun 26 07:23 .profile
                                        -rw-r--r-- 1 prox prox 3108 May  4  2021 influxdb.key
                                        drwxr-xr-x 2 prox prox 4096 Jul 10 19:42 influxdb2-client-2.3.0-linux-amd64
                                        prox@influxdb:~$
                                        • M MCU
                                          ls -la
                                          total 32
                                          prox@influxdb:~$
                                          #2057
                                          @mcu
                                          rm -rf influx*
