  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
    @mcu
    Repo anlegen:
    wget -q https://repos.influxdata.com/influxdb.key
    echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
    echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    Dann das übliche Installations-Prozedere:
    sudo apt update
    sudo apt install PAKETNAME
    MCU
    #2044
    @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
    apt install sudo curl gpg gnupg2 wget -y
    sudo apt-get update && sudo apt-get install influxdb2
    • M MCU
      #2045
      @mcu
      Und warum installierst du dann den client nicht auch daraus?
      Stattdessen verhunzt du dir die dpkg-Datenbank.
      apt policy influxdb2-cli
      bringt?
        @mcu
        bringt?
        MCU
        #2046
        @thomas-braun So?
        sudo apt update && sudo apt install influxdb2-cli
        Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
        Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
        Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
        Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
        Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
        Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
        Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
        Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
        Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
        Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
        Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
        Fetched 15.0 MB in 2s (7736 kB/s)
        Reading package lists... Done
        12 packages can be upgraded. Run 'apt list --upgradable' to see them.
        N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
        influxdb2-cli is already the newest version (2.3.0).
        0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
        influxdb2-cli:
          Installed: 2.3.0
          Candidate: 2.3.0
          Version table:
         *** 2.3.0 500
                500 https://repos.influxdata.com/debian stable/main amd64 Packages
        • M MCU
          @thomas-braun So?
          influxdb2-cli:
            Installed: 2.3.0
            Candidate: 2.3.0
            Version table:
           *** 2.3.0 500
          #2047
          @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
          ist also bereits installiert.
          which influx
          liefert?
          Hau die 12 Updates rein...
            which influx
            liefert?
            MCU
            #2048
            sudo apt update
            [sudo] password for prox:
            Hit:1 http://ftp.debian.org/debian bullseye InRelease
            Hit:2 http://security.debian.org bullseye-security InRelease
            Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
            Hit:4 https://repos.influxdata.com/debian stable InRelease
            All packages are up to date.
            which influx
            /usr/local/bin/influx
            • M MCU
              sudo apt update
              which influx
              #2049
              sudo rm /usr/local/bin/influx
              exit
              Wieder einloggen und dann nochmal
              which influx
              Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
              • M MCU
                @simatec So?
                simatecS Offline
                simatecS Offline
                simatec
                #2050
                @mcu nich influxd … nur influx
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                  exit
                  which influx
                  MCU
                  #2051
                  which influx
                  /usr/bin/influx
                  • simatecS simatec
                    MCU
                    #2052
                    @simatec
                    • M MCU
                      @simatec
                      #2053
                      @mcu
                      rm influxdb2*
                      apt policy influxdb*
                        @mcu
                        rm influxdb2*
                        MCU
                        #2054
                        @thomas-braun sagte in Test Adapter ioBroker.backitup v2.4.x:
                        rm influxdb2*
                        rm influxdb2*
                        rm: cannot remove 'influxdb2-client-2.3.0-linux-amd64': Is a directory
                        mit sudo?
                        N: Unable to locate package influxdb.key
                        N: Couldn't find any package by glob 'influxdb.key'
                        N: Unable to locate package influxdb2-client-2.3.0-linux-amd64
                        N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64'
                        • M MCU
                          rm influxdb2*
                          rm influxdb2*
                          mit sudo?
                          #2055
                          @mcu
                          ls -la
                          Und bitte vollständige Ein- wie Ausgabezeilen inkl. LogIn-Prompt, damit ich sehe wo du da im Tree stehst.
                            @mcu
                            ls -la
                            MCU
                            #2056
                            ls -la
                            prox@influxdb:~$ ls -la
                            total 32
                            drwxr-xr-x 3 prox prox 4096 Jul 10 20:41 .
                            drwxr-xr-x 3 root root 4096 Jun 26 07:23 ..
                            -rw------- 1 prox prox 1297 Jul 10 20:37 .bash_history
                            -rw-r--r-- 1 prox prox  220 Jun 26 07:23 .bash_logout
                            -rw-r--r-- 1 prox prox 3526 Jun 26 07:23 .bashrc
                            -rw-r--r-- 1 prox prox  807 Jun 26 07:23 .profile
                            -rw-r--r-- 1 prox prox 3108 May  4  2021 influxdb.key
                            drwxr-xr-x 2 prox prox 4096 Jul 10 19:42 influxdb2-client-2.3.0-linux-amd64
                            prox@influxdb:~$
                            • M MCU
                              ls -la
                              total 32
                              prox@influxdb:~$
                              #2057
                              @mcu
                              rm -rf influx*
                                @mcu
                                rm -rf influx*
                                MCU
                                #2058
                                @thomas-braun Geht nur mit sudo rm influx*. OK?
                                Oder so:
                                ls -la
                                total 24
                                drwxr-xr-x 2 prox prox 4096 Jul 10 20:47 .
                                • M MCU
                                  Oder so:
                                  ls -la
                                  total 24
                                  #2059
                                  @mcu
                                  Nein, das muss auch mit dem user prox funktionieren, dem gehört der Sums ja.
                                  rm -rf influx*
                                    @mcu
                                    rm -rf influx*
                                    MCU
                                    #2060
                                    influxdb2-cli:
                                      Installed: 2.3.0
                                      Candidate: 2.3.0
                                      Version table:
                                     *** 2.3.0 500
                                    influxdb-client:
                                      Installed: (none)
                                      Candidate: 1.6.7~rc0-1+b5
                                      Version table:
                                         1.6.7~rc0-1+b5 500
                                            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                    influxdb-dev:
                                      Installed: (none)
                                      Candidate: (none)
                                      Version table:
                                    influxdb:
                                      Installed: (none)
                                      Candidate: 1.8.10-1
                                      Version table:
                                         1.8.10-1 500
                                         1.6.7~rc0-1+b5 500
                                    influxdb2:
                                      Installed: 2.3.0-1
                                      Candidate: 2.3.0-1
                                      Version table:
                                     *** 2.3.0-1 500
                                    • M MCU
                                      Oder so:
                                      ls -la
                                      total 24
                                      #2061
                                      @mcu
                                      bringt nun?
                                      • M MCU
                                        influxdb2-cli:
                                          Installed: 2.3.0
                                          Candidate: 2.3.0
                                          Version table:
                                         *** 2.3.0 500
                                        influxdb-client:
                                          Installed: (none)
                                          Version table:
                                             1.6.7~rc0-1+b5 500
                                        influxdb-dev:
                                          Installed: (none)
                                          Candidate: (none)
                                          Version table:
                                        influxdb:
                                          Installed: (none)
                                          Candidate: 1.8.10-1
                                          Version table:
                                             1.8.10-1 500
                                             1.6.7~rc0-1+b5 500
                                        influxdb2:
                                          Installed: 2.3.0-1
                                          Candidate: 2.3.0-1
                                          Version table:
                                         *** 2.3.0-1 500
                                        #2062
                                        @mcu @simatec
                                        Muss der client auf dem System mit dem ioBroker installiert sein?
                                        Mir war so.
                                        M simatecS 2 Antworten Letzte Antwort
                                          @mcu @simatec
                                          Mir war so.
                                          MCU
                                          #2063
                                          @thomas-braun Also das auf dem ioBroker-System?
