  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • M MCU
    @thomas-braun Steht aber so dort:
    https://docs.influxdata.com/influxdb/v2.3/tools/influx-cli/?t=Linux
    Wie sonst?
    simatecS Offline
    simatecS Offline
    simatec
    #2037
    @mcu
    Was kommt denn, wenn du influx in der Konsole aufrufst?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      @mcu
      MCU
      #2038
      @simatec
      influx
      NAME:
         influx - Influx Client
      USAGE:
         influx [command]
      COMMANDS:
         version              Print the influx CLI version
         write                Write points to InfluxDB
         bucket               Bucket management commands
         completion           Generates completion scripts
         query                Execute a Flux query
         config               Config management commands
         org, organization    Organization management commands
         delete               Delete points from InfluxDB
         user                 User management commands
         task                 Task management commands
         telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
         dashboards           List Dashboard(s).
         export               Export existing resources as a template
         secret               Secret management commands
         v1                   InfluxDB v1 management commands
         auth, authorization  Authorization management commands
         apply                Apply a template to manage resources
         stacks               List stack(s) and associated templates. Subcommands manage stacks.
         template             Summarize the provided template
         bucket-schema        Bucket schema management commands
         ping                 Check the InfluxDB /health endpoint
         setup                Setup instance with initial user, org, bucket
         backup               Backup database
         restore              Restores a backup directory to InfluxDB
         remote               Remote connection management commands
         replication          Replication stream management commands
         server-config        Display server config
         help, h              Shows a list of commands or help for one command
      GLOBAL OPTIONS:
         --help, -h  show help
      • M MCU
        @simatec
        influx
        NAME:
        USAGE:
           influx [command]
        COMMANDS:
        GLOBAL OPTIONS:
        simatecS Offline
        simatecS Offline
        simatec
        #2039
        @mcu na geht doch.
        Dan sollte es auch in Backitup gehen.
        Falls die influx aus irgend einem Grund von Backitup nicht gefunden wird, trage den kompletten Pfad in der Config ein
        • simatecS simatec
          @mcu na geht doch.
          MCU
          #2040
          @simatec So?
          Thomas BraunT simatecS 2 Antworten Letzte Antwort
          • M MCU
            @simatec So?
            #2041
            @mcu
            Ich würde es über den Paketmanager machen. Das fällt dir früher oder später sonst wieder auf die Füße.
              @mcu
              MCU
              #2042
              @thomas-braun Da fehlt mir das Wissen. Wie gehe ich über den Paketmanager?
              • M MCU
                #2043
                @mcu
                Repo anlegen:
                wget -q https://repos.influxdata.com/influxdb.key
                echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                Dann das übliche Installations-Prozedere:
                sudo apt update
                sudo apt install PAKETNAME
                  @mcu
                  Repo anlegen:
                  sudo apt update
                  MCU
                  #2044
                  @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
                  apt install sudo curl gpg gnupg2 wget -y
                  sudo apt-get update && sudo apt-get install influxdb2
                  • M MCU
                    #2045
                    @mcu
                    Und warum installierst du dann den client nicht auch daraus?
                    Stattdessen verhunzt du dir die dpkg-Datenbank.
                    apt policy influxdb2-cli
                    bringt?
                      @mcu
                      bringt?
                      MCU
                      #2046
                      @thomas-braun So?
                      sudo apt update && sudo apt install influxdb2-cli
                      Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
                      Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
                      Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
                      Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
                      Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
                      Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
                      Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
                      Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
                      Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
                      Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
                      Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
                      Fetched 15.0 MB in 2s (7736 kB/s)
                      Reading package lists... Done
                      12 packages can be upgraded. Run 'apt list --upgradable' to see them.
                      N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
                      influxdb2-cli is already the newest version (2.3.0).
                      0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
                      influxdb2-cli:
                        Installed: 2.3.0
                        Candidate: 2.3.0
                        Version table:
                       *** 2.3.0 500
                              500 https://repos.influxdata.com/debian stable/main amd64 Packages
                      • M MCU
                        @thomas-braun So?
                        influxdb2-cli:
                          Installed: 2.3.0
                          Candidate: 2.3.0
                          Version table:
                         *** 2.3.0 500
                        #2047
                        @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
                        ist also bereits installiert.
                        which influx
                        liefert?
                        Hau die 12 Updates rein...
                          which influx
                          liefert?
                          MCU
                          #2048
                          sudo apt update
                          [sudo] password for prox:
                          Hit:1 http://ftp.debian.org/debian bullseye InRelease
                          Hit:2 http://security.debian.org bullseye-security InRelease
                          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                          Hit:4 https://repos.influxdata.com/debian stable InRelease
                          All packages are up to date.
                          which influx
                          /usr/local/bin/influx
                          • M MCU
                            sudo apt update
                            which influx
                            #2049
                            sudo rm /usr/local/bin/influx
                            exit
                            Wieder einloggen und dann nochmal
                            which influx
                            Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
                            • M MCU
                              @simatec So?
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #2050
                              @mcu nich influxd … nur influx
                                exit
                                which influx
                                MCU
                                #2051
                                which influx
                                /usr/bin/influx
                                • simatecS simatec
                                  MCU
                                  #2052
                                  @simatec
                                  • M MCU
                                    @simatec
                                    #2053
                                    @mcu
                                    rm influxdb2*
                                    apt policy influxdb*
                                      @mcu
                                      rm influxdb2*
                                      MCU
                                      #2054
                                      @thomas-braun sagte in Test Adapter ioBroker.backitup v2.4.x:
                                      rm influxdb2*
                                      rm influxdb2*
                                      rm: cannot remove 'influxdb2-client-2.3.0-linux-amd64': Is a directory
                                      mit sudo?
                                      N: Unable to locate package influxdb.key
                                      N: Couldn't find any package by glob 'influxdb.key'
                                      N: Unable to locate package influxdb2-client-2.3.0-linux-amd64
                                      N: Couldn't find any package by glob 'influxdb2-client-2.3.0-linux-amd64'
                                      • M MCU
                                        rm influxdb2*
                                        rm influxdb2*
                                        mit sudo?
                                        #2055
                                        @mcu
                                        ls -la
                                        Und bitte vollständige Ein- wie Ausgabezeilen inkl. LogIn-Prompt, damit ich sehe wo du da im Tree stehst.
                                          @mcu
                                          ls -la
                                          MCU
                                          #2056
                                          ls -la
                                          prox@influxdb:~$ ls -la
                                          total 32
                                          drwxr-xr-x 3 prox prox 4096 Jul 10 20:41 .
                                          drwxr-xr-x 3 root root 4096 Jun 26 07:23 ..
                                          -rw------- 1 prox prox 1297 Jul 10 20:37 .bash_history
                                          -rw-r--r-- 1 prox prox  220 Jun 26 07:23 .bash_logout
                                          -rw-r--r-- 1 prox prox 3526 Jun 26 07:23 .bashrc
                                          -rw-r--r-- 1 prox prox  807 Jun 26 07:23 .profile
                                          -rw-r--r-- 1 prox prox 3108 May  4  2021 influxdb.key
                                          drwxr-xr-x 2 prox prox 4096 Jul 10 19:42 influxdb2-client-2.3.0-linux-amd64
                                          prox@influxdb:~$
