  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • M MCU
    wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.3.0-linux-amd64.tar.gz
    --2022-07-10 19:41:36--  https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.3.0-linux-amd64.tar.gz
    Resolving dl.influxdata.com (dl.influxdata.com)... 54.230.206.23, 54.230.206.30, 54.230.206.53, ...
    Connecting to dl.influxdata.com (dl.influxdata.com)|54.230.206.23|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 5350662 (5.1M) [application/x-gzip]
    Saving to: 'influxdb2-client-2.3.0-linux-amd64.tar.gz'
    influxdb2-client-2.3.0-linux-amd64.tar.gz  100%[=======================================================================================>]   5.10M  --.-KB/s    in 0.1s
    2022-07-10 19:41:36 (34.4 MB/s) - 'influxdb2-client-2.3.0-linux-amd64.tar.gz' saved [5350662/5350662]
    prox@influxdb:~$ tar xvzf ./influxdb2-client-2.3.0-linux-amd64.tar.gz
    influxdb2-client-2.3.0-linux-amd64/LICENSE
    influxdb2-client-2.3.0-linux-amd64/README.md
    influxdb2-client-2.3.0-linux-amd64/influx
    prox@influxdb:~$ sudo cp influxdb2-client-2.3.0-linux-amd64/influx /usr/local/bin/
    We trust you have received the usual lecture from the local System
    Administrator. It usually boils down to these three things:
        #1) Respect the privacy of others.
        #2) Think before you type.
        #3) With great power comes great responsibility.
    [sudo] password for prox:
    prox@influxdb:~$
    #2030
    @mcu
    Macht man ja auch nicht so.
      @mcu
      MCU
      #2031
      @thomas-braun Steht aber so dort:
      https://docs.influxdata.com/influxdb/v2.3/tools/influx-cli/?t=Linux
      Wie sonst?
      Thomas BraunT simatecS 2 Antworten Letzte Antwort
      • M MCU
        Wie sonst?
        #2032
        @mcu
        Da steht aber auch, wie man sich deren Repo anlacht.
        Software unter Debian wird (zu 99,9%) IMMER über den Paketmanager installiert. Auch influx.
        • M MCU
          prox@influxdb:~$
          simatecS Offline
          simatecS Offline
          simatec
          #2033
          @mcu leg die mal in /usr/bin
          Bei einigen Systemen wird usr/local/bin nicht richtig erkannt
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • simatecS simatec
            MCU
            #2034
            @simatec Bringt keinen Unterschied.
              @mcu
              simatecS Offline
              simatecS Offline
              simatec
              #2035
              @thomas-braun Kannst du mal bitte in Backitup ein Issue anlegen, wie man über Paketmanager die influx-cli installiert
              Also speziell für influxdb2.
              Dann passe ich die Doku an.
              Damals gab es noch kein offizielles Paket
              • M MCU
                #2036
                @mcu
                https://docs.influxdata.com/influxdb/v1.8/introduction/install/
                Leg dir das Repo an, da ist auch influxdb2 drin. Und dann installierst du das sauber.
                Und kratz das wieder aus /usr/local/bin raus.
                • M MCU
                  Wie sonst?
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #2037
                  @mcu
                  Was kommt denn, wenn du influx in der Konsole aufrufst?
                  • simatecS simatec
                    @mcu
                    MCU
                    #2038
                    @simatec
                    influx
                    NAME:
                       influx - Influx Client
                    USAGE:
                       influx [command]
                    COMMANDS:
                       version              Print the influx CLI version
                       write                Write points to InfluxDB
                       bucket               Bucket management commands
                       completion           Generates completion scripts
                       query                Execute a Flux query
                       config               Config management commands
                       org, organization    Organization management commands
                       delete               Delete points from InfluxDB
                       user                 User management commands
                       task                 Task management commands
                       telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
                       dashboards           List Dashboard(s).
                       export               Export existing resources as a template
                       secret               Secret management commands
                       v1                   InfluxDB v1 management commands
                       auth, authorization  Authorization management commands
                       apply                Apply a template to manage resources
                       stacks               List stack(s) and associated templates. Subcommands manage stacks.
                       template             Summarize the provided template
                       bucket-schema        Bucket schema management commands
                       ping                 Check the InfluxDB /health endpoint
                       setup                Setup instance with initial user, org, bucket
                       backup               Backup database
                       restore              Restores a backup directory to InfluxDB
                       remote               Remote connection management commands
                       replication          Replication stream management commands
                       server-config        Display server config
                       help, h              Shows a list of commands or help for one command
                    GLOBAL OPTIONS:
                       --help, -h  show help
                    • M MCU
                      @simatec
                      influx
                      NAME:
                      USAGE:
                         influx [command]
                      COMMANDS:
                      GLOBAL OPTIONS:
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #2039
                      @mcu na geht doch.
                      Dan sollte es auch in Backitup gehen.
                      Falls die influx aus irgend einem Grund von Backitup nicht gefunden wird, trage den kompletten Pfad in der Config ein
                      • simatecS simatec
                        @mcu na geht doch.
                        MCU
                        #2040
                        @simatec So?
                        • M MCU
                          @simatec So?
                          #2041
                          @mcu
                          Ich würde es über den Paketmanager machen. Das fällt dir früher oder später sonst wieder auf die Füße.
                            @mcu
                            MCU
                            #2042
                            @thomas-braun Da fehlt mir das Wissen. Wie gehe ich über den Paketmanager?
                            • M MCU
                              #2043
                              @mcu
                              Repo anlegen:
                              wget -q https://repos.influxdata.com/influxdb.key
                              echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                              echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                              Dann das übliche Installations-Prozedere:
                              sudo apt update
                              sudo apt install PAKETNAME
                                @mcu
                                Repo anlegen:
                                sudo apt update
                                MCU
                                #2044
                                @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
                                apt install sudo curl gpg gnupg2 wget -y
                                sudo apt-get update && sudo apt-get install influxdb2
                                • M MCU
                                  #2045
                                  @mcu
                                  Und warum installierst du dann den client nicht auch daraus?
                                  Stattdessen verhunzt du dir die dpkg-Datenbank.
                                  apt policy influxdb2-cli
                                  bringt?
                                    @mcu
                                    bringt?
                                    MCU
                                    #2046
                                    @thomas-braun So?
                                    sudo apt update && sudo apt install influxdb2-cli
                                    Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
                                    Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
                                    Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
                                    Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
                                    Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
                                    Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
                                    Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
                                    Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
                                    Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
                                    Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
                                    Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
                                    Fetched 15.0 MB in 2s (7736 kB/s)
                                    Reading package lists... Done
                                    12 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
                                    influxdb2-cli is already the newest version (2.3.0).
                                    0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
                                    influxdb2-cli:
                                      Installed: 2.3.0
                                      Candidate: 2.3.0
                                      Version table:
                                     *** 2.3.0 500
                                            500 https://repos.influxdata.com/debian stable/main amd64 Packages
                                    • M MCU
                                      @thomas-braun So?
                                      influxdb2-cli:
                                        Installed: 2.3.0
                                        Candidate: 2.3.0
                                        Version table:
                                       *** 2.3.0 500
                                      #2047
                                      @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
                                      ist also bereits installiert.
                                      which influx
                                      liefert?
                                      Hau die 12 Updates rein...
                                        which influx
                                        liefert?
                                        MCU
                                        #2048
                                        sudo apt update
                                        Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                        Hit:2 http://security.debian.org bullseye-security InRelease
                                        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                                        All packages are up to date.
                                        which influx
                                        /usr/local/bin/influx
                                        • M MCU
                                          sudo apt update
                                          which influx
                                          #2049
                                          sudo rm /usr/local/bin/influx
                                          exit
                                          Wieder einloggen und dann nochmal
                                          which influx
                                          Und warum hast du nodejs nicht als Repo? Das ist wichtig! (Ah, das ist nicht die Dose mit dem ioBroker...)
