  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
    @mcu
    Dann hast du dir irgendwas irgendwie am Paketmanager vorbei ins System geprügelt.
    Sauber sähe das so aus:
    echad@chet:/opt/iobroker $ apt policy influxdb*
    influxdb2-cli:
      Installed: (none)
      Candidate: 2.3.0
      Version table:
         2.3.0 500
            500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
    influxdb-client:
      Installed: (none)
      Candidate: 1.6.7~rc0-1+b5
      Version table:
         1.6.7~rc0-1+b5 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    influxdb-dev:
      Installed: (none)
      Candidate: (none)
      Version table:
    influxdb:
      Installed: (none)
      Candidate: 1.8.10-1
      Version table:
         1.8.10-1 500
         1.6.7~rc0-1+b5 500
    influxdb2:
      Installed: (none)
      Candidate: 2.3.0-1
      Version table:
         2.3.0-1 500
    MCU
    #2029
    wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.3.0-linux-amd64.tar.gz
    --2022-07-10 19:41:36--  https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.3.0-linux-amd64.tar.gz
    Resolving dl.influxdata.com (dl.influxdata.com)... 54.230.206.23, 54.230.206.30, 54.230.206.53, ...
    Connecting to dl.influxdata.com (dl.influxdata.com)|54.230.206.23|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 5350662 (5.1M) [application/x-gzip]
    Saving to: 'influxdb2-client-2.3.0-linux-amd64.tar.gz'
    influxdb2-client-2.3.0-linux-amd64.tar.gz  100%[=======================================================================================>]   5.10M  --.-KB/s    in 0.1s
    2022-07-10 19:41:36 (34.4 MB/s) - 'influxdb2-client-2.3.0-linux-amd64.tar.gz' saved [5350662/5350662]
    prox@influxdb:~$ tar xvzf ./influxdb2-client-2.3.0-linux-amd64.tar.gz
    influxdb2-client-2.3.0-linux-amd64/LICENSE
    influxdb2-client-2.3.0-linux-amd64/README.md
    influxdb2-client-2.3.0-linux-amd64/influx
    prox@influxdb:~$ sudo cp influxdb2-client-2.3.0-linux-amd64/influx /usr/local/bin/
    We trust you have received the usual lecture from the local System
    Administrator. It usually boils down to these three things:
        #1) Respect the privacy of others.
        #2) Think before you type.
        #3) With great power comes great responsibility.
    [sudo] password for prox:
    prox@influxdb:~$
    Thomas BraunT simatecS 2 Antworten Letzte Antwort
    • M MCU
      prox@influxdb:~$
      #2030
      @mcu
      Macht man ja auch nicht so.
        @mcu
        MCU
        #2031
        @thomas-braun Steht aber so dort:
        https://docs.influxdata.com/influxdb/v2.3/tools/influx-cli/?t=Linux
        Wie sonst?
        • M MCU
          Wie sonst?
          #2032
          @mcu
          Da steht aber auch, wie man sich deren Repo anlacht.
          Software unter Debian wird (zu 99,9%) IMMER über den Paketmanager installiert. Auch influx.
          • M MCU
            prox@influxdb:~$
            simatecS Offline
            simatecS Offline
            simatec
            #2033
            @mcu leg die mal in /usr/bin
            Bei einigen Systemen wird usr/local/bin nicht richtig erkannt
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • simatecS simatec
              MCU
              #2034
              @simatec Bringt keinen Unterschied.
                @mcu
                simatecS Offline
                simatecS Offline
                simatec
                #2035
                @thomas-braun Kannst du mal bitte in Backitup ein Issue anlegen, wie man über Paketmanager die influx-cli installiert
                Also speziell für influxdb2.
                Dann passe ich die Doku an.
                Damals gab es noch kein offizielles Paket
                • M MCU
                  #2036
                  @mcu
                  https://docs.influxdata.com/influxdb/v1.8/introduction/install/
                  Leg dir das Repo an, da ist auch influxdb2 drin. Und dann installierst du das sauber.
                  Und kratz das wieder aus /usr/local/bin raus.
                  • M MCU
                    Wie sonst?
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #2037
                    @mcu
                    Was kommt denn, wenn du influx in der Konsole aufrufst?
                    • simatecS simatec
                      @mcu
                      MCU
                      #2038
                      @simatec
                      influx
                      NAME:
                         influx - Influx Client
                      USAGE:
                         influx [command]
                      COMMANDS:
                         version              Print the influx CLI version
                         write                Write points to InfluxDB
                         bucket               Bucket management commands
                         completion           Generates completion scripts
                         query                Execute a Flux query
                         config               Config management commands
                         org, organization    Organization management commands
                         delete               Delete points from InfluxDB
                         user                 User management commands
                         task                 Task management commands
                         telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
                         dashboards           List Dashboard(s).
                         export               Export existing resources as a template
                         secret               Secret management commands
                         v1                   InfluxDB v1 management commands
                         auth, authorization  Authorization management commands
                         apply                Apply a template to manage resources
                         stacks               List stack(s) and associated templates. Subcommands manage stacks.
                         template             Summarize the provided template
                         bucket-schema        Bucket schema management commands
                         ping                 Check the InfluxDB /health endpoint
                         setup                Setup instance with initial user, org, bucket
                         backup               Backup database
                         restore              Restores a backup directory to InfluxDB
                         remote               Remote connection management commands
                         replication          Replication stream management commands
                         server-config        Display server config
                         help, h              Shows a list of commands or help for one command
                      GLOBAL OPTIONS:
                         --help, -h  show help
                      • M MCU
                        @simatec
                        influx
                        NAME:
                        USAGE:
                           influx [command]
                        COMMANDS:
                        GLOBAL OPTIONS:
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #2039
                        @mcu na geht doch.
                        Dan sollte es auch in Backitup gehen.
                        Falls die influx aus irgend einem Grund von Backitup nicht gefunden wird, trage den kompletten Pfad in der Config ein
                        • simatecS simatec
                          @mcu na geht doch.
                          MCU
                          #2040
                          @simatec So?
                          • M MCU
                            @simatec So?
                            #2041
                            @mcu
                            Ich würde es über den Paketmanager machen. Das fällt dir früher oder später sonst wieder auf die Füße.
                              @mcu
                              MCU
                              #2042
                              @thomas-braun Da fehlt mir das Wissen. Wie gehe ich über den Paketmanager?
                              • M MCU
                                #2043
                                @mcu
                                Repo anlegen:
                                wget -q https://repos.influxdata.com/influxdb.key
                                echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
                                echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                Dann das übliche Installations-Prozedere:
                                sudo apt update
                                sudo apt install PAKETNAME
                                  @mcu
                                  Repo anlegen:
                                  sudo apt update
                                  MCU
                                  #2044
                                  @thomas-braun Das habe ich doch bei der Installation von influxdb2 schon so gemacht?
                                  apt install sudo curl gpg gnupg2 wget -y
                                  sudo apt-get update && sudo apt-get install influxdb2
                                  • M MCU
                                    #2045
                                    @mcu
                                    Und warum installierst du dann den client nicht auch daraus?
                                    Stattdessen verhunzt du dir die dpkg-Datenbank.
                                    apt policy influxdb2-cli
                                    bringt?
                                      @mcu
                                      bringt?
                                      MCU
                                      #2046
                                      @thomas-braun So?
                                      sudo apt update && sudo apt install influxdb2-cli
                                      Get:1 http://security.debian.org bullseye-security InRelease [44.1 kB]
                                      Get:2 http://ftp.debian.org/debian bullseye InRelease [116 kB]
                                      Get:3 https://repos.influxdata.com/debian stable InRelease [4645 B]
                                      Get:4 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
                                      Get:5 http://security.debian.org bullseye-security/main amd64 Packages [164 kB]
                                      Get:6 https://repos.influxdata.com/debian stable/main amd64 Packages [1263 B]
                                      Get:7 http://security.debian.org bullseye-security/main Translation-en [103 kB]
                                      Get:8 http://ftp.debian.org/debian bullseye/main amd64 Packages [8182 kB]
                                      Get:9 http://ftp.debian.org/debian bullseye/main Translation-en [6243 kB]
                                      Get:10 http://ftp.debian.org/debian bullseye/contrib amd64 Packages [50.6 kB]
                                      Get:11 http://ftp.debian.org/debian bullseye/contrib Translation-en [46.9 kB]
                                      Fetched 15.0 MB in 2s (7736 kB/s)
                                      Reading package lists... Done
                                      12 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                      N: Repository 'http://ftp.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.3' to '11.4'
                                      influxdb2-cli is already the newest version (2.3.0).
                                      0 upgraded, 0 newly installed, 0 to remove and 12 not upgraded.
                                      influxdb2-cli:
                                        Installed: 2.3.0
                                        Candidate: 2.3.0
                                        Version table:
                                       *** 2.3.0 500
                                              500 https://repos.influxdata.com/debian stable/main amd64 Packages
                                      • M MCU
                                        @thomas-braun So?
                                        influxdb2-cli:
                                          Installed: 2.3.0
                                          Candidate: 2.3.0
                                          Version table:
                                         *** 2.3.0 500
                                        #2047
                                        @mcu sagte in Test Adapter ioBroker.backitup v2.4.x:
                                        ist also bereits installiert.
                                        which influx
                                        liefert?
                                        Hau die 12 Updates rein...
                                          which influx
                                          liefert?
                                          MCU
                                          #2048
                                          sudo apt update
                                          Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                          Hit:2 http://security.debian.org bullseye-security InRelease
                                          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                          Hit:4 https://repos.influxdata.com/debian stable InRelease
                                          All packages are up to date.
                                          which influx
                                          /usr/local/bin/influx
