  4. downgrade Admin v6
downgrade Admin v6
51 Beiträge 9 Kommentatoren 6.0k Aufrufe 3 Beobachtet
    @alfi84 sagte in Admin 6.0 - neu als Beta:
    Da klemmt es noch gewaltig...
    iobroker update deconz --debug
    VOLLSTÄNDIGE Ein- wie Ausgaben posten. Inklusive Eingabezeile.
    Alfi84
    @thomas-braun said in Admin 6.0 - neu als Beta:
    pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
    Used repository: deconz
    Error: unknown repository is active - "deconz". Known: stable, latest
    • A Alfi84
      iobroker start
      ist erledigt...
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 6.0.8
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
      Adapter    "denon"        : 1.13.4   , installed 1.12.1 [Updatable]
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
      Adapter    "heos"         : 1.10.0   , installed 1.9.2  [Updatable]
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "javascript"   : 5.7.0    , installed 5.5.4  [Updatable]
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "mqtt"         : 3.0.6    , installed 4.0.6
      Adapter    "openweathermap": 0.2.4   , installed 0.2.3  [Updatable]
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
      Adapter    "smartgarden"  : 2.0.0    , installed 1.0.5  [Updatable]
      Adapter    "socketio"     : 4.2.0    , installed 6.1.7
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
      Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.1.9  [Updatable]
      Adapter    "vis-icontwo"  : 0.87.0   , installed 0.86.0 [Updatable]
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.8  [Updatable]
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "web"          : 4.3.0    , installed 5.2.3
      Adapter    "ws"           : 1.3.0    , installed 2.1.2
      @alfi84 Versuch erstmal nochmal ein "iob upload admin".
      Formal war auch der "downgrade" befehel falsch weil "iob upgrade admin@5.3.8" richtig wäre ... die Standard iobroker befehle ohne "iobroker." im Namen. Sollte zwar meistens weggeschnitten werden, aber wer weiss
        @alfi84
        Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
        iob repo list
        sagt?
        [Edit:] Und ich habe Blödsinn geschrieben...
        iobroker upgrade deconz --debug
        muss das heißen.
        Alfi84
        Der Adapter ist nicht so wichtig, da ich ihn noch nicht nutze.
        Wichtig ist der downgrade von Admin.
        • A Alfi84
          Ich wollte die Fehlermeldungen aus der Aktion sehen.
          Dann halt die Meldungen zu
          iobroker upgrade admin@5.3.8 --debug
          crunchipC A 2 Antworten Letzte Antwort
            crunchipC Offline
            crunchipC Offline
            @thomas-braun aber admin vorher stoppen
            • Thomas BraunT Online
              @crunchip
              Joh, keine doofe Idee...
              @Alfi84
              iobroker stop admin
              iobroker start admin
                @alfi84
                iob repo list
                sagt?
                muss das heißen.
                Alfi84
                pi@raspberrypi4-iob:~ $ iob repo list
                latest        : http://download.iobroker.net/sources-dist-latest.json
                Active repo(s): stable
                  Alfi84
                  schrieb am zuletzt editiert von Alfi84
                  pi@raspberrypi4-iob:~ $ iobroker upgrade admin@5.3.8 --debug
                  BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                  Would you like to downgrade admin from @6.0.8 to @5.3.8 now? [(y)es, (n)o]: y
                  Update admin from @6.0.8 to @5.3.8
                  host.raspberrypi4-iob Adapter "system.adapter.admin.0" is stopped.
                  NPM version: 8.11.0
                  Installing iobroker.admin@5.3.8... (System call)
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                  npm ERR! builtins is not a function
                  npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T18_47_13_428Z-debug-0.log
                  upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                  upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
                  upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                  upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
                  upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
                  upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                  upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                  upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                  upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                  upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                  host.raspberrypi4-iob Adapter "system.adapter.admin.0" is started
                  das Problem liegt wohl an npm!?
                  • A Alfi84
                    NPM version: 8.11.0
                    liegt wohl an npm!?
                    Natürlich.
                    Ich möchte die Meldungen zu
                    iobroker update
                    bitte sehen.
                      liegt wohl an npm!?
                      Natürlich.
                      iobroker update
                      bitte sehen.
                      Alfi84
                      pi@raspberrypi4-iob:~ $ iobroker update
                      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                      pi@raspberrypi4-iob:~ $ iobroker update deconz --debug
                      pi@raspberrypi4-iob:~ $ iobroker upgrade deconz --debug
                      This upgrade of "deconz" will introduce the following changes:
                      -> 1.3.21:
                      added schedule to object definition
                      changed limit for duration to 999999
                      Would you like to upgrade deconz from @1.3.20 to @1.3.21 now? [(y)es, (n)o]: y
                      Update deconz from @1.3.20 to @1.3.21
                      NPM version: 8.11.0
                      Installing iobroker.deconz@1.3.21... (System call)
                      npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T19_00_48_897Z-debug-0.log
                      upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                      upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                      upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                      upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                      Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                      • A Alfi84
                        -> 1.3.21:
                        NPM version: 8.11.0
                        @alfi84
                        iobroker update
                        • A Alfi84
                          -> 1.3.21:
                          NPM version: 8.11.0
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Ich würde die Löschen und IoBroker neu starten .
                          • A Alfi84
                            -> 1.3.21:
                            NPM version: 8.11.0
                            package-lock.json
                            iobroker stop
                            sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lock.jsonalt
                            iobroker start
                              package-lock.json
                              iobroker stop
                              iobroker start
                              Alfi84
                              pi@raspberrypi4-iob:~ $ iobroker stop
                              pi@raspberrypi4-iob:~ $ sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lock.jsonalt
                              • A Alfi84
                                @alfi84
                                iobroker update
                                iobroker upgrade
                                  @alfi84
                                  iobroker update
                                  iobroker upgrade
                                  Alfi84
                                  This upgrade of "vis-inventwo" will introduce the following changes:
                                  -> 3.3.1:
                                  Bugfix
                                  -> 3.3.0:
                                  New widget: configurable colorpicker for HEX, RGB, HSL, HSV and CIE/XY
                                  Would you like to upgrade vis-inventwo from @3.2.8 to @3.3.1 now? [(y)es, (n)o]: y
                                  Update vis-inventwo from @3.2.8 to @3.3.1
                                  NPM version: 8.11.0
                                  Installing iobroker.vis-inventwo@3.3.1... (System call)
                                  Adapter "system.adapter.vis.0" restarted.
                                  Adapter "system.adapter.web.0" restarted.
                                  upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                                  upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                                  upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                                  upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                                  upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                                  upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                                  upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                                  upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                                  upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                                  upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                                  upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                                  upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                                  upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                                  upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                                  upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                                  upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                                  upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                                  upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
                                  upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
                                  upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                                  upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                                  This upgrade of "vis-icontwo" will introduce the following changes:
                                  -> 0.87.0:
                                  new icons added
                                  -> 0.86.2:
                                  Bugfix
                                  -> 0.86.1:
                                  Bugfix
                                  Would you like to upgrade vis-icontwo from @0.86.0 to @0.87.0 now? [(y)es, (n)o]: y
                                  Update vis-icontwo from @0.86.0 to @0.87.0
                                  NPM version: 8.11.0
                                  Installing iobroker.vis-icontwo@0.87.0... (System call)
                                  upload [1327] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png
                                  upload [1300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/home_error_red.png Alarm/home_error_red.png image/png
                                  upload [1250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Animated/Maps/map-waypoint.gif Animated/Maps/map-waypoint.gif image/gif
                                  upload [1200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/201.png Backgrounds/Seamless/201.png image/png
                                  upload [1150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/grafana.png Brands/grafana.png image/png
                                  upload [1100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Amazon_Echo/echo_flex.png Devices/Amazon_Echo/echo_flex.png image/png
                                  upload [1050] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Computers/pc_grafana.png Devices/Computers/pc_grafana.png image/png
                                  upload [1000] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Cooling/fan1_on1.png Devices/Cooling/fan1_on1.png image/png
                                  upload [950] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Network/hub2.png Devices/Network/hub2.png image/png
                                  upload [900] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Printers/3D_printer_new.png Devices/Printers/3D_printer_new.png image/png
                                  upload [850] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/laser_off.png Devices/laser_off.png image/png
                                  upload [800] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/Shutter/blinds2_30.png Doors_Windows/Shutter/blinds2_30.png image/png
                                  upload [750] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/window_open.png Doors_Windows/window_open.png image/png
                                  upload [700] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Electricity/switch2.png Electricity/switch2.png image/png
                                  upload [650] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Hobbies/Train/subway.png Hobbies/Train/subway.png image/png
                                  upload [600] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Letters/Rounded/q.png Letters/Rounded/q.png image/png
                                  upload [550] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Lights/light_dim_plus.png Lights/light_dim_plus.png image/png
                                  upload [500] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Misc/A.png Misc/A.png image/png
                                  upload [450] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Navigations/nav_cam1.png Navigations/nav_cam1.png image/png
                                  upload [400] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/41.png Numbers/Rounded/41.png image/png
                                  upload [350] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/87.png Numbers/Rounded/87.png image/png
                                  upload [300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Player/on.png Player/on.png image/png
                                  upload [250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/bedroom2_POWER_on.png Rooms/bedroom2_POWER_on.png image/png
                                  upload [200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/hallway_POWER_on.png Rooms/hallway_POWER_on.png image/png
                                  upload [150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/warehouse.png Rooms/warehouse.png image/png
                                  upload [100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Signs/delete.png Signs/delete.png image/png
                                  upload [90] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/exercise.png Spa_Fitness/exercise.png image/png
                                  upload [80] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/sun-lounger.png Spa_Fitness/sun-lounger.png image/png
                                  upload [70] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/avalanche_land.png Weather/Warning/avalanche_land.png image/png
                                  upload [60] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/volcano.png Weather/Warning/volcano.png image/png
                                  upload [50] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Wind_Speeds/wind_speed_38-42.png Weather/Wind_Speeds/wind_speed_38-42.png image/png
                                  upload [40] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/day.png Weather/day.png image/png
                                  upload [30] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/direction_w.png Weather/direction_w.png image/png
                                  upload [20] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/pressure_gauge2.png Weather/pressure_gauge2.png image/png
                                  upload [19] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain.png Weather/rain.png image/png
                                  upload [18] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain_value.png Weather/rain_value.png image/png
                                  upload [17] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rainy.png Weather/rainy.png image/png
                                  upload [16] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow.png Weather/snow.png image/png
                                  upload [15] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow2.png Weather/snow2.png image/png
                                  upload [14] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow3.png Weather/snow3.png image/png
                                  upload [13] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow_value.png Weather/snow_value.png image/png
                                  upload [12] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/storm.png Weather/storm.png image/png
                                  upload [11] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun.png Weather/sun.png image/png
                                  upload [10] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun_value.png Weather/sun_value.png image/png
                                  upload [9] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunrise.png Weather/sunrise.png image/png
                                  upload [8] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunset.png Weather/sunset.png image/png
                                  upload [7] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp.png Weather/temp.png image/png
                                  upload [6] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp2.png Weather/temp2.png image/png
                                  upload [5] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp3.png Weather/temp3.png image/png
                                  upload [4] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wet.png Weather/wet.png image/png
                                  upload [3] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind.png Weather/wind.png image/png
                                  upload [2] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind_value.png Weather/wind_value.png image/png
                                  upload [1] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windsock.png Weather/windsock.png image/png
                                  upload [0] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windy.png Weather/windy.png image/png
                                  upload [5] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [4] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/i1_150.png i1_150.png image/png
                                  upload [3] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/icontwo.png icontwo.png image/png
                                  upload [2] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/index_m.html index_m.html text/html
                                  upload [1] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/style.css style.css text/css
                                  upload [0] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/words.js words.js application/javascript
                                  This upgrade of "vis-hqwidgets" will introduce the following changes:
                                  -> 1.2.0:
                                  Removed deprecated method `load`
                                  Would you like to upgrade vis-hqwidgets from @1.1.9 to @1.2.0 now? [(y)es, (n)o]: y
                                  Update vis-hqwidgets from @1.1.9 to @1.2.0
                                  NPM version: 8.11.0
                                  Installing iobroker.vis-hqwidgets@1.2.0... (System call)
                                  INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                  upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                  upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                  This upgrade of "vis" will at least introduce the following changes:
                                  -> 1.4.15:
                                  Better check of the offline license
                                  -> 1.4.14:
                                  Corrected GUI bug
                                  -> 1.4.13:
                                  The group attributes will be replaced recursively
                                  -> 1.4.12:
                                  Fixed bug with the export of specific widgets
                                  -> 1.4.11:
                                  Removed ES6 commands to be supported by older browsers
                                  Fixed problem with update of grouped widgets
                                  Added web manifest to be able to handle vis as the web app
                                  -> 1.4.8:
                                  Added support for js-controller 4.x
                                  -> 1.4.7:
                                  Fixed subscribeOidAtRuntime if called with invalid IDs
                                  Added support of license manager
                                  Would you like to upgrade vis from @1.4.5 to @1.4.15 now? [(y)es, (n)o]: y
                                  Update vis from @1.4.5 to @1.4.15
                                  NPM version: 8.11.0
                                  Installing iobroker.vis@1.4.15... (System call)
                                  upload [948] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                  upload [900] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/table.png icon/table.png image/png
                                  upload [850] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/add.png js/fm/icon/actions/add.png image/png
                                  upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEdit.js js/visEdit.js application/javascript
                                  upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-1.10.3.dragdropsort.min.js lib/js/jquery-ui-1.10.3.dragdropsort.min.js application/javascript
                                  upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/js/bars.js widgets/bars/js/bars.js application/javascript
                                  upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micStarted.svg widgets/basic/img/micStarted.svg image/svg+xml
                                  upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/js/hqwidgets.js widgets/hqwidgets/js/hqwidgets.js application/javascript
                                  upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_100.png widgets/jqui-mfd/img/fts_shutter_100.png image/png
                                  upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/light_light_dim_60.svg widgets/jqui-mfd/img/light_light_dim_60.svg image/svg+xml
                                  upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/material/img/light_light_dim_50.png widgets/material/img/light_light_dim_50.png image/png
                                  upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/js/widgets/materialdesign.materialdesignicons.js widgets/materialdesign/js/widgets/materialdesign.materialdesignicons.js application/javascript
                                  upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                                  upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/21-1.png widgets/timeandweather/img/clock/21-1.png image/png
                                  upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/apm.png widgets/timeandweather/img/clock/apm.png image/png
                                  upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider1.gif widgets/vis-inventwo/img/Slider1.gif image/gif
                                  upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/checkbox-intermediate.png widgets/vis-material-advanced/img/checkbox-intermediate.png image/png
                                  upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/garage.png widgets/vis-material-advanced/img/garage.png image/png
                                  upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/light_light_dim_10.png widgets/vis-material-advanced/img/light_light_dim_10.png image/png
                                  upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/ma_checkbox_checked.png widgets/vis-material-advanced/img/ma_checkbox_checked.png image/png
                                  upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/pressure.png widgets/vis-material-advanced/img/pressure.png image/png
                                  upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/temp_verlauf_100.png widgets/vis-material-advanced/img/temp_verlauf_100.png image/png
                                  upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/temp_verlauf_60.png widgets/vis-material-advanced/img/temp_verlauf_60.png image/png
                                  upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/unchecked.png widgets/vis-material-advanced/img/unchecked.png image/png
                                  upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/watering_empty.png widgets/vis-material-advanced/img/watering_empty.png image/png
                                  upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListNumber/listNumber.js widgets/vis-material-advanced/js/ListNumber/listNumber.js application/javascript
                                  upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListOccupancy/listOccupancy.js widgets/vis-material-advanced/js/ListOccupancy/listOccupancy.js application/javascript
                                  upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListPresence/listPresence.js widgets/vis-material-advanced/js/ListPresence/listPresence.js application/javascript
                                  upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListPressure/listPressure.js widgets/vis-material-advanced/js/ListPressure/listPressure.js application/javascript
                                  upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListRegenRadar/listRegenRadar.js widgets/vis-material-advanced/js/ListRegenRadar/listRegenRadar.js application/javascript
                                  upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListTemp/listTemp.js widgets/vis-material-advanced/js/ListTemp/listTemp.js application/javascript
                                  upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListTempHumid/listTempHumid.js widgets/vis-material-advanced/js/ListTempHumid/listTempHumid.js application/javascript
                                  upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListText/listText.js widgets/vis-material-advanced/js/ListText/listText.js application/javascript
                                  upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListThermostat/listThermostat.js widgets/vis-material-advanced/js/ListThermostat/listThermostat.js application/javascript
                                  upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListValve/listValve.js widgets/vis-material-advanced/js/ListValve/listValve.js application/javascript
                                  upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListVolume/listVolume.js widgets/vis-material-advanced/js/ListVolume/listVolume.js application/javascript
                                  upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListWindow/listWindow.js widgets/vis-material-advanced/js/ListWindow/listWindow.js application/javascript
                                  upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListWindowShutter/listWindowShutter.js widgets/vis-material-advanced/js/ListWindowShutter/listWindowShutter.js application/javascript
                                  upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/TempIcon/TempIcon.js widgets/vis-material-advanced/js/TempIcon/TempIcon.js application/javascript
                                  upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/base.js widgets/vis-material-advanced/js/base.js application/javascript
                                  upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/do widgets/vis-material-advanced/js/do null
                                  upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/genTitleContainer.js widgets/vis-material-advanced/js/genTitleContainer.js application/javascript
                                  upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/list.js widgets/vis-material-advanced/js/list.js application/javascript
                                  upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/vis-material-advanced.js widgets/vis-material-advanced/js/vis-material-advanced.js application/javascript
                                  upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/words.js widgets/vis-material-advanced/js/words.js application/javascript
                                  upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced.html widgets/vis-material-advanced.html text/html
                                  upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                  upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                  upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                  upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                  This upgrade of "tr-064" will introduce the following changes:
                                  -> 4.2.16:
                                  Fix info logs on callee/caller
                                  Add special handling for potential broken external image links in phonebook
                                  Prevent some crash cases reported by Sentry
                                  Would you like to upgrade tr-064 from @4.2.15 to @4.2.16 now? [(y)es, (n)o]: y
                                  Update tr-064 from @4.2.15 to @4.2.16
                                  NPM version: 8.11.0
                                  Installing iobroker.tr-064@4.2.16... (System call)
                                  upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                  upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                  upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                  This upgrade of "smartgarden" will introduce the following changes:
                                  -> 2.0.0:
                                  support for new login procedure to Gardena webservice; admin5 is necessary
                                  -> 1.0.6:
                                  bug fix error handling, changes due to changed behavior Gardena Service, some minor changes in documentation
                                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                  Would you like to upgrade smartgarden from @1.0.5 to @2.0.0 now? [(y)es, (n)o]: y
                                  Update smartgarden from @1.0.5 to @2.0.0
                                  NPM version: 8.11.0
                                  Installing iobroker.smartgarden@2.0.0... (System call)
                                  upload [5] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
                                  upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
                                  upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/style.css style.css text/css
                                  upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
                                  upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/words.js words.js application/javascript
                                  This upgrade of "openweathermap" will introduce the following changes:
                                  -> 0.2.4:
                                  Fix crash case when states have invalid metadata
                                  Would you like to upgrade openweathermap from @0.2.3 to @0.2.4 now? [(y)es, (n)o]: y
                                  Update openweathermap from @0.2.3 to @0.2.4
                                  NPM version: 8.11.0
                                  Installing iobroker.openweathermap@0.2.4... (System call)
                                  upload [3] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index.html index.html text/html
                                  upload [2] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index_m.html index_m.html text/html
                                  upload [1] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/openweathermap.png openweathermap.png image/png
                                  upload [0] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/words.js words.js application/javascript
                                  This upgrade of "javascript" will introduce the following changes:
                                  -> 5.7.0:
                                  Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage))
                                  Lists returned by $-selector are now unified and do not contain double entries
                                  Fix subscribe multiple object ID lists in blockly
                                  -> 5.6.1:
                                  Allow to subscribe multiple object ID lists in blockly
                                  -> 5.6.0:
                                  Make state properties c(omment) and user available to scripts too
                                  make sure values of new or changed alias objects are initialized properly
                                  Enhance scheduler logic and astro events offered by wizard
                                  Respect expected value changes when determining if a value is changed
                                  Fix remembering intermediate state values when state values are subscribed
                                  fix setState logic when states are not subscribed
                                  Would you like to upgrade javascript from @5.5.4 to @5.7.0 now? [(y)es, (n)o]: y
                                  Update javascript from @5.5.4 to @5.7.0
                                  NPM version: 8.11.0
                                  Installing iobroker.javascript@5.7.0... (System call)
                                  upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                  upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                  upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                                  upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
                                  upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
                                  upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
                                  upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
                                  upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
                                  upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.0fde2268.js static/js/runtime-main.0fde2268.js application/javascript
                                  upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                                  upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                                  upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                  upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                  upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                  upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                  upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                  upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                  upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                  upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                  upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                  upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                  upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                  upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                  upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                  upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                  upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                  upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                  upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                  upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                  upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                  This upgrade of "heos" will introduce the following changes:
                                  -> 1.10.0:
                                  fix default value of `sid` (closes #174)
                                  Would you like to upgrade heos from @1.9.2 to @1.10.0 now? [(y)es, (n)o]: y
                                  Update heos from @1.9.2 to @1.10.0
                                  NPM version: 8.11.0
                                  Installing iobroker.heos@1.10.0... (System call)
                                  upload [4] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [3] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/heos.png heos.png image/png
                                  upload [2] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/index_m.html index_m.html text/html
                                  upload [1] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/style.css style.css text/css
                                  upload [0] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/words.js words.js application/javascript
                                  This upgrade of "denon" will introduce the following changes:
                                  -> 1.13.4:
                                  we now respect `requestInterval` on determining the AVR model too
                                  -> 1.13.3:
                                  fixed timeout beeing only applied on first reconnect (fixes #232)
                                  -> 1.13.2:
                                  fixed requesting interval
                                  -> 1.13.1:
                                  added `settings.speakerPreset`
                                  -> 1.13.0:
                                  Would you like to upgrade denon from @1.12.1 to @1.13.4 now? [(y)es, (n)o]: y
                                  Update denon from @1.12.1 to @1.13.4
                                  NPM version: 8.11.0
                                  Installing iobroker.denon@1.13.4... (System call)
                                  upload [12] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                                  upload [11] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [10] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [9] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [8] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [7] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [6] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [4] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [3] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                                  upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                                  -> 1.3.21:
                                  NPM version: 8.11.0
                                  pi@raspberrypi4-iob:~ $ ^C
                                  • A Alfi84
                                    -> 3.3.1:
                                    Bugfix
                                    -> 3.3.0:
                                    NPM version: 8.11.0
                                    -> 0.87.0:
                                    new icons added
                                    -> 0.86.2:
                                    Bugfix
                                    -> 0.86.1:
                                    Bugfix
                                    NPM version: 8.11.0
                                    -> 1.2.0:
                                    NPM version: 8.11.0
                                    -> 1.4.15:
                                    -> 1.4.14:
                                    Corrected GUI bug
                                    -> 1.4.13:
                                    -> 1.4.12:
                                    -> 1.4.11:
                                    -> 1.4.8:
                                    -> 1.4.7:
                                    NPM version: 8.11.0
                                    -> 4.2.16:
                                    NPM version: 8.11.0
                                    -> 2.0.0:
                                    -> 1.0.6:
                                    NPM version: 8.11.0
                                    -> 0.2.4:
                                    NPM version: 8.11.0
                                    -> 5.7.0:
                                    -> 5.6.1:
                                    -> 5.6.0:
                                    NPM version: 8.11.0
                                    -> 1.10.0:
                                    NPM version: 8.11.0
                                    -> 1.13.4:
                                    -> 1.13.3:
                                    -> 1.13.2:
                                    -> 1.13.1:
                                    -> 1.13.0:
                                    NPM version: 8.11.0
                                    -> 1.3.21:
                                    NPM version: 8.11.0
                                    @alfi84
                                    Schade, hätte funktionieren können.
                                      hab ein node.js update gemacht und hab dann aber beim admin update nicht an "latest"
                                      Und was genau hat jetzt ein Upate von nodejs mit dem iobroker-Beta-Repository zu tun?
                                      Zeigen was da jetzt Sache ist:
                                      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @thomas-braun sagte in Admin 6.0 - neu als Beta:
                                      @Homoran
                                      kann man die Beitrag von @Alfi84 nicht verschieben ,
                                      sie haben nichts mit dem ADMIN 6 Thread zu tun !?
                                        @alfi84
                                        Alfi84
                                        vielleicht ist es am besten wenn ich das backup mit 5.3.8 wieder einspiele + nodejs update?
                                        • A Alfi84
                                          @alfi84
                                          Kannst du versuchen. Dann schau dir aber vor dem nodeJS-Upgrade den npm tree an und bereinige den, wenn der 'strubbelig' ist.
