  4. downgrade Admin v6
downgrade Admin v6
51 Beiträge 9 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • A Alfi84
    @thomas-braun said in Admin 6.0 - neu als Beta:
    iobroker start
    ist erledigt...
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 6.0.8
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
    Adapter    "denon"        : 1.13.4   , installed 1.12.1 [Updatable]
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "heos"         : 1.10.0   , installed 1.9.2  [Updatable]
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "javascript"   : 5.7.0    , installed 5.5.4  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 3.0.6    , installed 4.0.6
    Adapter    "openweathermap": 0.2.4   , installed 0.2.3  [Updatable]
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
    Adapter    "smartgarden"  : 2.0.0    , installed 1.0.5  [Updatable]
    Adapter    "socketio"     : 4.2.0    , installed 6.1.7
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
    Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.1.9  [Updatable]
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.86.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.8  [Updatable]
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 5.2.3
    Adapter    "ws"           : 1.3.0    , installed 2.1.2
    crunchipC Offline
    crunchipC Offline
    @alfi84 sagte in Admin 6.0 - neu als Beta:
    ist erledigt...
    nö
    • A Alfi84
      iobroker start
      ist erledigt...
      Da klemmt es noch gewaltig...
      iobroker update deconz --debug
      VOLLSTÄNDIGE Ein- wie Ausgaben posten. Inklusive Eingabezeile.
        Alfi84
        pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
        Used repository: deconz
        Error: unknown repository is active - "deconz". Known: stable, latest
        • A Alfi84
          iobroker start
          ist erledigt...
          @alfi84 Versuch erstmal nochmal ein "iob upload admin".
          Formal war auch der "downgrade" befehel falsch weil "iob upgrade admin@5.3.8" richtig wäre ... die Standard iobroker befehle ohne "iobroker." im Namen. Sollte zwar meistens weggeschnitten werden, aber wer weiss
            @alfi84
            Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
            iob repo list
            sagt?
            [Edit:] Und ich habe Blödsinn geschrieben...
            iobroker upgrade deconz --debug
            muss das heißen.
            Alfi84
            Der Adapter ist nicht so wichtig, da ich ihn noch nicht nutze.
            Wichtig ist der downgrade von Admin.
            • A Alfi84
              Ich wollte die Fehlermeldungen aus der Aktion sehen.
              Dann halt die Meldungen zu
              iobroker upgrade admin@5.3.8 --debug
              crunchipC A 2 Antworten Letzte Antwort
                crunchipC Offline
                crunchipC Offline
                @thomas-braun aber admin vorher stoppen
                • Thomas BraunT Online
                  @crunchip
                  Joh, keine doofe Idee...
                  @Alfi84
                  iobroker stop admin
                  iobroker start admin
                    @alfi84
                    iob repo list
                    sagt?
                    muss das heißen.
                    Alfi84
                    pi@raspberrypi4-iob:~ $ iob repo list
                    latest        : http://download.iobroker.net/sources-dist-latest.json
                    Active repo(s): stable
                      Alfi84
                      schrieb am zuletzt editiert von Alfi84
                      pi@raspberrypi4-iob:~ $ iobroker upgrade admin@5.3.8 --debug
                      BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                      Would you like to downgrade admin from @6.0.8 to @5.3.8 now? [(y)es, (n)o]: y
                      Update admin from @6.0.8 to @5.3.8
                      host.raspberrypi4-iob Adapter "system.adapter.admin.0" is stopped.
                      NPM version: 8.11.0
                      Installing iobroker.admin@5.3.8... (System call)
                      npm WARN old lockfile
                      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                      npm WARN old lockfile This is a one-time fix-up, please be patient...
                      npm ERR! builtins is not a function
                      npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T18_47_13_428Z-debug-0.log
                      upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
                      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
                      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
                      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                      host.raspberrypi4-iob Adapter "system.adapter.admin.0" is started
                      das Problem liegt wohl an npm!?
                      • A Alfi84
                        NPM version: 8.11.0
                        liegt wohl an npm!?
                        Natürlich.
                        Ich möchte die Meldungen zu
                        iobroker update
                        bitte sehen.
                          liegt wohl an npm!?
                          Natürlich.
                          iobroker update
                          bitte sehen.
                          Alfi84
                          pi@raspberrypi4-iob:~ $ iobroker update
                          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                          pi@raspberrypi4-iob:~ $ iobroker update deconz --debug
                          pi@raspberrypi4-iob:~ $ iobroker upgrade deconz --debug
                          This upgrade of "deconz" will introduce the following changes:
                          -> 1.3.21:
                          added schedule to object definition
                          changed limit for duration to 999999
                          Would you like to upgrade deconz from @1.3.20 to @1.3.21 now? [(y)es, (n)o]: y
                          Update deconz from @1.3.20 to @1.3.21
                          NPM version: 8.11.0
                          Installing iobroker.deconz@1.3.21... (System call)
                          npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T19_00_48_897Z-debug-0.log
                          upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                          upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                          upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                          upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                          Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                          • A Alfi84
                            -> 1.3.21:
                            NPM version: 8.11.0
                            @alfi84
                            iobroker update
                            • A Alfi84
                              -> 1.3.21:
                              NPM version: 8.11.0
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Ich würde die Löschen und IoBroker neu starten .
                              • A Alfi84
                                -> 1.3.21:
                                NPM version: 8.11.0
                                package-lock.json
                                iobroker stop
                                sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lock.jsonalt
                                iobroker start
                                  package-lock.json
                                  iobroker stop
                                  iobroker start
                                  Alfi84
                                  pi@raspberrypi4-iob:~ $ iobroker stop
                                  pi@raspberrypi4-iob:~ $ sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lock.jsonalt
                                  • A Alfi84
                                    @alfi84
                                    iobroker update
                                    iobroker upgrade
                                      @alfi84
                                      iobroker update
                                      iobroker upgrade
                                      Alfi84
                                      This upgrade of "vis-inventwo" will introduce the following changes:
                                      -> 3.3.1:
                                      Bugfix
                                      -> 3.3.0:
                                      New widget: configurable colorpicker for HEX, RGB, HSL, HSV and CIE/XY
                                      Would you like to upgrade vis-inventwo from @3.2.8 to @3.3.1 now? [(y)es, (n)o]: y
                                      Update vis-inventwo from @3.2.8 to @3.3.1
                                      NPM version: 8.11.0
                                      Installing iobroker.vis-inventwo@3.3.1... (System call)
                                      Adapter "system.adapter.vis.0" restarted.
                                      Adapter "system.adapter.web.0" restarted.
                                      upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                                      upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                                      upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                                      upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                                      upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                                      upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                                      upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                                      upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                                      upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                                      upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                                      upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                                      upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                                      upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                                      upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                                      upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                                      upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                                      upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                                      upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
                                      upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
                                      upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                                      upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                                      This upgrade of "vis-icontwo" will introduce the following changes:
                                      -> 0.87.0:
                                      new icons added
                                      -> 0.86.2:
                                      Bugfix
                                      -> 0.86.1:
                                      Bugfix
                                      Would you like to upgrade vis-icontwo from @0.86.0 to @0.87.0 now? [(y)es, (n)o]: y
                                      Update vis-icontwo from @0.86.0 to @0.87.0
                                      NPM version: 8.11.0
                                      Installing iobroker.vis-icontwo@0.87.0... (System call)
                                      upload [1327] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png
                                      upload [1300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/home_error_red.png Alarm/home_error_red.png image/png
                                      upload [1250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Animated/Maps/map-waypoint.gif Animated/Maps/map-waypoint.gif image/gif
                                      upload [1200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/201.png Backgrounds/Seamless/201.png image/png
                                      upload [1150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/grafana.png Brands/grafana.png image/png
                                      upload [1100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Amazon_Echo/echo_flex.png Devices/Amazon_Echo/echo_flex.png image/png
                                      upload [1050] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Computers/pc_grafana.png Devices/Computers/pc_grafana.png image/png
                                      upload [1000] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Cooling/fan1_on1.png Devices/Cooling/fan1_on1.png image/png
                                      upload [950] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Network/hub2.png Devices/Network/hub2.png image/png
                                      upload [900] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Printers/3D_printer_new.png Devices/Printers/3D_printer_new.png image/png
                                      upload [850] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/laser_off.png Devices/laser_off.png image/png
                                      upload [800] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/Shutter/blinds2_30.png Doors_Windows/Shutter/blinds2_30.png image/png
                                      upload [750] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/window_open.png Doors_Windows/window_open.png image/png
                                      upload [700] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Electricity/switch2.png Electricity/switch2.png image/png
                                      upload [650] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Hobbies/Train/subway.png Hobbies/Train/subway.png image/png
                                      upload [600] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Letters/Rounded/q.png Letters/Rounded/q.png image/png
                                      upload [550] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Lights/light_dim_plus.png Lights/light_dim_plus.png image/png
                                      upload [500] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Misc/A.png Misc/A.png image/png
                                      upload [450] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Navigations/nav_cam1.png Navigations/nav_cam1.png image/png
                                      upload [400] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/41.png Numbers/Rounded/41.png image/png
                                      upload [350] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/87.png Numbers/Rounded/87.png image/png
                                      upload [300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Player/on.png Player/on.png image/png
                                      upload [250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/bedroom2_POWER_on.png Rooms/bedroom2_POWER_on.png image/png
                                      upload [200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/hallway_POWER_on.png Rooms/hallway_POWER_on.png image/png
                                      upload [150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/warehouse.png Rooms/warehouse.png image/png
                                      upload [100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Signs/delete.png Signs/delete.png image/png
                                      upload [90] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/exercise.png Spa_Fitness/exercise.png image/png
                                      upload [80] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/sun-lounger.png Spa_Fitness/sun-lounger.png image/png
                                      upload [70] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/avalanche_land.png Weather/Warning/avalanche_land.png image/png
                                      upload [60] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/volcano.png Weather/Warning/volcano.png image/png
                                      upload [50] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Wind_Speeds/wind_speed_38-42.png Weather/Wind_Speeds/wind_speed_38-42.png image/png
                                      upload [40] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/day.png Weather/day.png image/png
                                      upload [30] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/direction_w.png Weather/direction_w.png image/png
                                      upload [20] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/pressure_gauge2.png Weather/pressure_gauge2.png image/png
                                      upload [19] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain.png Weather/rain.png image/png
                                      upload [18] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain_value.png Weather/rain_value.png image/png
                                      upload [17] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rainy.png Weather/rainy.png image/png
                                      upload [16] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow.png Weather/snow.png image/png
                                      upload [15] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow2.png Weather/snow2.png image/png
                                      upload [14] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow3.png Weather/snow3.png image/png
                                      upload [13] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow_value.png Weather/snow_value.png image/png
                                      upload [12] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/storm.png Weather/storm.png image/png
                                      upload [11] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun.png Weather/sun.png image/png
                                      upload [10] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun_value.png Weather/sun_value.png image/png
                                      upload [9] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunrise.png Weather/sunrise.png image/png
                                      upload [8] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunset.png Weather/sunset.png image/png
                                      upload [7] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp.png Weather/temp.png image/png
                                      upload [6] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp2.png Weather/temp2.png image/png
                                      upload [5] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp3.png Weather/temp3.png image/png
                                      upload [4] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wet.png Weather/wet.png image/png
                                      upload [3] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind.png Weather/wind.png image/png
                                      upload [2] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind_value.png Weather/wind_value.png image/png
                                      upload [1] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windsock.png Weather/windsock.png image/png
                                      upload [0] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windy.png Weather/windy.png image/png
                                      upload [5] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [4] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/i1_150.png i1_150.png image/png
                                      upload [3] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/icontwo.png icontwo.png image/png
                                      upload [2] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/index_m.html index_m.html text/html
                                      upload [1] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/style.css style.css text/css
                                      upload [0] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/words.js words.js application/javascript
                                      This upgrade of "vis-hqwidgets" will introduce the following changes:
                                      -> 1.2.0:
                                      Removed deprecated method `load`
                                      Would you like to upgrade vis-hqwidgets from @1.1.9 to @1.2.0 now? [(y)es, (n)o]: y
                                      Update vis-hqwidgets from @1.1.9 to @1.2.0
                                      NPM version: 8.11.0
                                      Installing iobroker.vis-hqwidgets@1.2.0... (System call)
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                      upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                      upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                      This upgrade of "vis" will at least introduce the following changes:
                                      -> 1.4.15:
                                      Better check of the offline license
                                      -> 1.4.14:
                                      Corrected GUI bug
                                      -> 1.4.13:
                                      The group attributes will be replaced recursively
                                      -> 1.4.12:
                                      Fixed bug with the export of specific widgets
                                      -> 1.4.11:
                                      Removed ES6 commands to be supported by older browsers
                                      Fixed problem with update of grouped widgets
                                      Added web manifest to be able to handle vis as the web app
                                      -> 1.4.8:
                                      Added support for js-controller 4.x
                                      -> 1.4.7:
                                      Fixed subscribeOidAtRuntime if called with invalid IDs
                                      Added support of license manager
                                      Would you like to upgrade vis from @1.4.5 to @1.4.15 now? [(y)es, (n)o]: y
                                      Update vis from @1.4.5 to @1.4.15
                                      NPM version: 8.11.0
                                      Installing iobroker.vis@1.4.15... (System call)
                                      upload [948] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                      upload [900] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/table.png icon/table.png image/png
                                      upload [850] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/add.png js/fm/icon/actions/add.png image/png
                                      upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEdit.js js/visEdit.js application/javascript
                                      upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-1.10.3.dragdropsort.min.js lib/js/jquery-ui-1.10.3.dragdropsort.min.js application/javascript
                                      upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/js/bars.js widgets/bars/js/bars.js application/javascript
                                      upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micStarted.svg widgets/basic/img/micStarted.svg image/svg+xml
                                      upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/js/hqwidgets.js widgets/hqwidgets/js/hqwidgets.js application/javascript
                                      upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_100.png widgets/jqui-mfd/img/fts_shutter_100.png image/png
                                      upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/light_light_dim_60.svg widgets/jqui-mfd/img/light_light_dim_60.svg image/svg+xml
                                      upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/material/img/light_light_dim_50.png widgets/material/img/light_light_dim_50.png image/png
                                      upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/js/widgets/materialdesign.materialdesignicons.js widgets/materialdesign/js/widgets/materialdesign.materialdesignicons.js application/javascript
                                      upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                                      upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/21-1.png widgets/timeandweather/img/clock/21-1.png image/png
                                      upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/apm.png widgets/timeandweather/img/clock/apm.png image/png
                                      upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider1.gif widgets/vis-inventwo/img/Slider1.gif image/gif
                                      upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/checkbox-intermediate.png widgets/vis-material-advanced/img/checkbox-intermediate.png image/png
                                      upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/garage.png widgets/vis-material-advanced/img/garage.png image/png
                                      upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/light_light_dim_10.png widgets/vis-material-advanced/img/light_light_dim_10.png image/png
                                      upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/ma_checkbox_checked.png widgets/vis-material-advanced/img/ma_checkbox_checked.png image/png
                                      upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/pressure.png widgets/vis-material-advanced/img/pressure.png image/png
                                      upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/temp_verlauf_100.png widgets/vis-material-advanced/img/temp_verlauf_100.png image/png
                                      upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/temp_verlauf_60.png widgets/vis-material-advanced/img/temp_verlauf_60.png image/png
                                      upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/unchecked.png widgets/vis-material-advanced/img/unchecked.png image/png
                                      upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/watering_empty.png widgets/vis-material-advanced/img/watering_empty.png image/png
                                      upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListNumber/listNumber.js widgets/vis-material-advanced/js/ListNumber/listNumber.js application/javascript
                                      upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListOccupancy/listOccupancy.js widgets/vis-material-advanced/js/ListOccupancy/listOccupancy.js application/javascript
                                      upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListPresence/listPresence.js widgets/vis-material-advanced/js/ListPresence/listPresence.js application/javascript
                                      upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListPressure/listPressure.js widgets/vis-material-advanced/js/ListPressure/listPressure.js application/javascript
                                      upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListRegenRadar/listRegenRadar.js widgets/vis-material-advanced/js/ListRegenRadar/listRegenRadar.js application/javascript
                                      upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListTemp/listTemp.js widgets/vis-material-advanced/js/ListTemp/listTemp.js application/javascript
                                      upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListTempHumid/listTempHumid.js widgets/vis-material-advanced/js/ListTempHumid/listTempHumid.js application/javascript
                                      upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListText/listText.js widgets/vis-material-advanced/js/ListText/listText.js application/javascript
                                      upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListThermostat/listThermostat.js widgets/vis-material-advanced/js/ListThermostat/listThermostat.js application/javascript
                                      upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListValve/listValve.js widgets/vis-material-advanced/js/ListValve/listValve.js application/javascript
                                      upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListVolume/listVolume.js widgets/vis-material-advanced/js/ListVolume/listVolume.js application/javascript
                                      upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListWindow/listWindow.js widgets/vis-material-advanced/js/ListWindow/listWindow.js application/javascript
                                      upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListWindowShutter/listWindowShutter.js widgets/vis-material-advanced/js/ListWindowShutter/listWindowShutter.js application/javascript
                                      upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/TempIcon/TempIcon.js widgets/vis-material-advanced/js/TempIcon/TempIcon.js application/javascript
                                      upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/base.js widgets/vis-material-advanced/js/base.js application/javascript
                                      upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/do widgets/vis-material-advanced/js/do null
                                      upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/genTitleContainer.js widgets/vis-material-advanced/js/genTitleContainer.js application/javascript
                                      upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/list.js widgets/vis-material-advanced/js/list.js application/javascript
                                      upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/vis-material-advanced.js widgets/vis-material-advanced/js/vis-material-advanced.js application/javascript
                                      upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/words.js widgets/vis-material-advanced/js/words.js application/javascript
                                      upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced.html widgets/vis-material-advanced.html text/html
                                      upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                      upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                      upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                      This upgrade of "tr-064" will introduce the following changes:
                                      -> 4.2.16:
                                      Fix info logs on callee/caller
                                      Add special handling for potential broken external image links in phonebook
                                      Prevent some crash cases reported by Sentry
                                      Would you like to upgrade tr-064 from @4.2.15 to @4.2.16 now? [(y)es, (n)o]: y
                                      Update tr-064 from @4.2.15 to @4.2.16
                                      NPM version: 8.11.0
                                      Installing iobroker.tr-064@4.2.16... (System call)
                                      upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                      upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                      upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                      This upgrade of "smartgarden" will introduce the following changes:
                                      -> 2.0.0:
                                      support for new login procedure to Gardena webservice; admin5 is necessary
                                      -> 1.0.6:
                                      bug fix error handling, changes due to changed behavior Gardena Service, some minor changes in documentation
                                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                      Would you like to upgrade smartgarden from @1.0.5 to @2.0.0 now? [(y)es, (n)o]: y
                                      Update smartgarden from @1.0.5 to @2.0.0
                                      NPM version: 8.11.0
                                      Installing iobroker.smartgarden@2.0.0... (System call)
                                      upload [5] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
                                      upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
                                      upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/style.css style.css text/css
                                      upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
                                      upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/words.js words.js application/javascript
                                      This upgrade of "openweathermap" will introduce the following changes:
                                      -> 0.2.4:
                                      Fix crash case when states have invalid metadata
                                      Would you like to upgrade openweathermap from @0.2.3 to @0.2.4 now? [(y)es, (n)o]: y
                                      Update openweathermap from @0.2.3 to @0.2.4
                                      NPM version: 8.11.0
                                      Installing iobroker.openweathermap@0.2.4... (System call)
                                      upload [3] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index.html index.html text/html
                                      upload [2] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index_m.html index_m.html text/html
                                      upload [1] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/openweathermap.png openweathermap.png image/png
                                      upload [0] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/words.js words.js application/javascript
                                      This upgrade of "javascript" will introduce the following changes:
                                      -> 5.7.0:
                                      Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage))
                                      Lists returned by $-selector are now unified and do not contain double entries
                                      Fix subscribe multiple object ID lists in blockly
                                      -> 5.6.1:
                                      Allow to subscribe multiple object ID lists in blockly
                                      -> 5.6.0:
                                      Make state properties c(omment) and user available to scripts too
                                      make sure values of new or changed alias objects are initialized properly
                                      Enhance scheduler logic and astro events offered by wizard
                                      Respect expected value changes when determining if a value is changed
                                      Fix remembering intermediate state values when state values are subscribed
                                      fix setState logic when states are not subscribed
                                      Would you like to upgrade javascript from @5.5.4 to @5.7.0 now? [(y)es, (n)o]: y
                                      Update javascript from @5.5.4 to @5.7.0
                                      NPM version: 8.11.0
                                      Installing iobroker.javascript@5.7.0... (System call)
                                      upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                                      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
                                      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
                                      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
                                      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
                                      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
                                      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.0fde2268.js static/js/runtime-main.0fde2268.js application/javascript
                                      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                                      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                                      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                      This upgrade of "heos" will introduce the following changes:
                                      -> 1.10.0:
                                      fix default value of `sid` (closes #174)
                                      Would you like to upgrade heos from @1.9.2 to @1.10.0 now? [(y)es, (n)o]: y
                                      Update heos from @1.9.2 to @1.10.0
                                      NPM version: 8.11.0
                                      Installing iobroker.heos@1.10.0... (System call)
                                      upload [4] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [3] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/heos.png heos.png image/png
                                      upload [2] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/index_m.html index_m.html text/html
                                      upload [1] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/style.css style.css text/css
                                      upload [0] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/words.js words.js application/javascript
                                      This upgrade of "denon" will introduce the following changes:
                                      -> 1.13.4:
                                      we now respect `requestInterval` on determining the AVR model too
                                      -> 1.13.3:
                                      fixed timeout beeing only applied on first reconnect (fixes #232)
                                      -> 1.13.2:
                                      fixed requesting interval
                                      -> 1.13.1:
                                      added `settings.speakerPreset`
                                      -> 1.13.0:
                                      Would you like to upgrade denon from @1.12.1 to @1.13.4 now? [(y)es, (n)o]: y
                                      Update denon from @1.12.1 to @1.13.4
                                      NPM version: 8.11.0
                                      Installing iobroker.denon@1.13.4... (System call)
                                      upload [12] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                                      upload [11] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [10] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [9] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [8] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [7] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [6] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [5] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [4] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [3] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                                      upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                                      -> 1.3.21:
                                      NPM version: 8.11.0
                                      pi@raspberrypi4-iob:~ $ ^C
                                      • A Alfi84
                                        -> 3.3.1:
                                        Bugfix
                                        -> 3.3.0:
                                        NPM version: 8.11.0
                                        -> 0.87.0:
                                        new icons added
                                        -> 0.86.2:
                                        Bugfix
                                        -> 0.86.1:
                                        Bugfix
                                        NPM version: 8.11.0
                                        -> 1.2.0:
                                        NPM version: 8.11.0
                                        -> 1.4.15:
                                        -> 1.4.14:
                                        Corrected GUI bug
                                        -> 1.4.13:
                                        -> 1.4.12:
                                        -> 1.4.11:
                                        -> 1.4.8:
                                        -> 1.4.7:
                                        NPM version: 8.11.0
                                        -> 4.2.16:
                                        NPM version: 8.11.0
                                        -> 2.0.0:
                                        -> 1.0.6:
                                        NPM version: 8.11.0
                                        -> 0.2.4:
                                        NPM version: 8.11.0
                                        -> 5.7.0:
                                        -> 5.6.1:
                                        -> 5.6.0:
                                        NPM version: 8.11.0
                                        -> 1.10.0:
                                        NPM version: 8.11.0
                                        -> 1.13.4:
                                        -> 1.13.3:
                                        -> 1.13.2:
                                        -> 1.13.1:
                                        -> 1.13.0:
                                        NPM version: 8.11.0
                                        -> 1.3.21:
                                        NPM version: 8.11.0
                                        @alfi84
                                        Schade, hätte funktionieren können.
                                          hab ein node.js update gemacht und hab dann aber beim admin update nicht an "latest"
                                          Und was genau hat jetzt ein Upate von nodejs mit dem iobroker-Beta-Repository zu tun?
                                          Zeigen was da jetzt Sache ist:
                                          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @thomas-braun sagte in Admin 6.0 - neu als Beta:
                                          @Homoran
                                          kann man die Beitrag von @Alfi84 nicht verschieben ,
                                          sie haben nichts mit dem ADMIN 6 Thread zu tun !?
