  4. downgrade Admin v6
downgrade Admin v6
51 Beiträge 9 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • A Alfi84
    Kann mir jemand sagen wie ich von Admin 6.0.4 wieder auf 5.3.8 downgrade?
    Habe es über Adapter und upgrade iobroker.admin@5.3.8 versucht aber ohne Erfolg.
    Danke vorab
    FeuersturmF Offline
    FeuersturmF Offline
    Feuersturm
    @alfi84 da fehlt ein iob am anfang
    iob upgrade iobroker.admin@5.3.8
    Bei Problemen immer den vollständigen Inhalt der Konsole angeben, dass erleichtert die Hilfe.
    • FeuersturmF Feuersturm
      Alfi84
      pi@raspberrypi4-iob:/opt/iobroker $ iob upgrade iobroker.admin@5.3.8
      BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to downgrade admin from @6.0.8 to @5.3.8 now? [(y)es, (n)o]: y
      Update admin from @6.0.8 to @5.3.8
      host.raspberrypi4-iob Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.11.0
      Installing iobroker.admin@5.3.8... (System call)
      upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.raspberrypi4-iob Adapter "system.adapter.admin.0" is started
      • A Alfi84
        NPM version: 8.11.0
        FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        @alfi84 und jetzt geht alles oder welche Probleme liegen noch an?
          Alfi84
          @feuersturm
          habe immer noch v6.0.8 drauf
          • A Alfi84
            @feuersturm
            crunchipC Offline
            crunchipC Offline
            @alfi84 Browser neu laden? ansonsten Version per konsole abfragen
              Alfi84
              @crunchip browser refresh hab ich gemacht.
              hast du mal bitte den Befehl für die versionsabfrage?
              • A Alfi84
                crunchipC Offline
                crunchipC Offline
                @alfi84 iob list adapters bzw iob update -i
                  Alfi84
                  schrieb am zuletzt editiert von Alfi84
                  @crunchip
                  system.adapter.admin                   : admin          - v6.0.8
                  system.adapter.backitup                : backitup       - v2.4.6
                  system.adapter.deconz                  : deconz         - v1.3.20
                  system.adapter.denon                   : denon          - v1.12.1
                  system.adapter.discovery               : discovery      - v2.8.0
                  system.adapter.fritzdect               : fritzdect      - v2.2.3
                  system.adapter.heos                    : heos           - v1.9.2
                  system.adapter.hm-rega                 : hm-rega        - v3.0.40
                  system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
                  system.adapter.icons-material-png      : icons-material-png - v0.1.0
                  system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                  system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                  system.adapter.javascript              : javascript     - v5.5.4
                  system.adapter.mqtt                    : mqtt           - v4.0.6
                  system.adapter.openweathermap          : openweathermap - v0.2.3
                  system.adapter.shelly                  : shelly         - v5.3.2
                  system.adapter.smartgarden             : smartgarden    - v1.0.5
                  system.adapter.tr-064                  : tr-064         - v4.2.15
                  system.adapter.vis                     : vis            - v1.4.5
                  system.adapter.vis-bars                : vis-bars       - v0.1.4
                  system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                  system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
                  system.adapter.vis-icontwo             : vis-icontwo    - v0.86.0
                  system.adapter.vis-inventwo            : vis-inventwo   - v3.2.8
                  system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                  system.adapter.vis-material            : vis-material   - v0.1.3
                  system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
                  system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
                  system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                  system.adapter.weatherunderground      : weatherunderground - v3.4.2
                  system.adapter.web                     : web            - v5.2.3
                  pi@raspberrypi4-iob:/opt/iobroker $ iob update -i
                  Used repository: stable
                  Adapter    "admin"        : 5.3.8    , installed 6.0.8
                  Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                  Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
                  Adapter    "denon"        : 1.13.4   , installed 1.12.1 [Updatable]
                  Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                  Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
                  Adapter    "heos"         : 1.10.0   , installed 1.9.2  [Updatable]
                  Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                  Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                  Adapter    "javascript"   : 5.7.0    , installed 5.5.4  [Updatable]
                  Controller "js-controller": 4.0.23   , installed 4.0.23
                  Adapter    "mqtt"         : 3.0.6    , installed 4.0.6
                  Adapter    "openweathermap": 0.2.4   , installed 0.2.3  [Updatable]
                  Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                  Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
                  Adapter    "smartgarden"  : 2.0.0    , installed 1.0.5  [Updatable]
                  Adapter    "socketio"     : 4.2.0    , installed 6.1.7
                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
                  Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
                  Adapter    "vis-hqwidgets": 1.2.0    , installed 1.1.9  [Updatable]
                  Adapter    "vis-icontwo"  : 0.87.0   , installed 0.86.0 [Updatable]
                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.8  [Updatable]
                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                  Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                  Adapter    "web"          : 4.3.0    , installed 5.2.3
                  Adapter    "ws"           : 1.3.0    , installed 2.1.2
                  • A Alfi84
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    @alfi84 hast du den admin vor dem upgrade gestoppt?
                    wie kommst du überhaupt darauf admin v6 zu installieren? du bist doch im stable, hast aber ein Mischmasch an stable/latest und zwischendrin
                      Alfi84
                      @crunchip
                      ja hatte ich gestoppt.
                      hab ein node.js update gemacht und hab dann aber beim admin update nicht an "latest" gedacht...und dann war es passiert :man-facepalming:
                      • A Alfi84
                        @crunchip
                        @alfi84 sagte in Admin 6.0 - neu als Beta:
                        Und was genau hat jetzt ein Upate von nodejs mit dem iobroker-Beta-Repository zu tun?
                        Zeigen was da jetzt Sache ist:
                        uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        A GlasfaserG 2 Antworten Letzte Antwort
                          Alfi84
                          Ich habe das Update quasi "ausversehen" durchgeführt. Ist doch jetzt auch egal...das ändert jetzt auch nix dran.
                          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.15.1
                          v16.15.1
                          8.11.0
                          pi
                          /opt/iobroker
                          OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                          OK:4 https://phoscon.de/apt/deconz bullseye InRelease
                          Alle Pakete sind aktuell.
                          nodejs:
                            Installiert:           16.15.1-deb-1nodesource1
                            Installationskandidat: 16.15.1-deb-1nodesource1
                            Versionstabelle:
                           *** 16.15.1-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                               12.22.5~dfsg-2~11u1 500
                          • A Alfi84
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.15.1
                            v16.15.1
                            8.11.0
                            pi
                            /opt/iobroker
                            nodejs:
                              Versionstabelle:
                            @alfi84 Gut, nodejs ist richtig installiert.
                            iobroker update
                            iobroker stop
                            iobroker upgrade
                            iobroker start
                              iobroker update
                              iobroker stop
                              iobroker upgrade
                              iobroker start
                              Alfi84
                              @thomas-braun said in Admin 6.0 - neu als Beta:
                              iobroker start
                              ist erledigt...
                              crunchipC Thomas BraunT apollon77A 3 Antworten Letzte Antwort
                              • A Alfi84
                                iobroker start
                                ist erledigt...
                                crunchipC Offline
                                crunchipC Offline
                                ist erledigt...
                                nö
                                • A Alfi84
                                  iobroker start
                                  ist erledigt...
                                  Da klemmt es noch gewaltig...
                                  iobroker update deconz --debug
                                  VOLLSTÄNDIGE Ein- wie Ausgaben posten. Inklusive Eingabezeile.
                                    Alfi84
                                    pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
                                    Used repository: deconz
                                    Error: unknown repository is active - "deconz". Known: stable, latest
                                    • A Alfi84
                                      iobroker start
                                      ist erledigt...
                                      @alfi84 Versuch erstmal nochmal ein "iob upload admin".
                                      Formal war auch der "downgrade" befehel falsch weil "iob upgrade admin@5.3.8" richtig wäre ... die Standard iobroker befehle ohne "iobroker." im Namen. Sollte zwar meistens weggeschnitten werden, aber wer weiss
                                        @alfi84
                                        Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
                                        iob repo list
                                        sagt?
                                        [Edit:] Und ich habe Blödsinn geschrieben...
                                        iobroker upgrade deconz --debug
                                        muss das heißen.
                                        Alfi84
                                        Der Adapter ist nicht so wichtig, da ich ihn noch nicht nutze.
                                        Wichtig ist der downgrade von Admin.
                                        • A Alfi84
                                          Ich wollte die Fehlermeldungen aus der Aktion sehen.
                                          Dann halt die Meldungen zu
                                          iobroker upgrade admin@5.3.8 --debug
                                          crunchipC A 2 Antworten Letzte Antwort
