  4. downgrade Admin v6
downgrade Admin v6
51 Beiträge 9 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • A Alfi84
    pi@raspberrypi4-iob:/opt/iobroker $ iob upgrade iobroker.admin@5.3.8
    BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to downgrade admin from @6.0.8 to @5.3.8 now? [(y)es, (n)o]: y
    Update admin from @6.0.8 to @5.3.8
    host.raspberrypi4-iob Adapter "system.adapter.admin.0" is stopped.
    NPM version: 8.11.0
    Installing iobroker.admin@5.3.8... (System call)
    upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    host.raspberrypi4-iob Adapter "system.adapter.admin.0" is started
    FeuersturmF Offline
    FeuersturmF Offline
    Feuersturm
    @alfi84 und jetzt geht alles oder welche Probleme liegen noch an?
    • FeuersturmF Feuersturm
      Alfi84
      @feuersturm
      habe immer noch v6.0.8 drauf
      • A Alfi84
        @feuersturm
        crunchipC Offline
        crunchipC Offline
        @alfi84 Browser neu laden? ansonsten Version per konsole abfragen
          Alfi84
          @crunchip browser refresh hab ich gemacht.
          hast du mal bitte den Befehl für die versionsabfrage?
          • A Alfi84
            crunchipC Offline
            crunchipC Offline
            @alfi84 iob list adapters bzw iob update -i
              Alfi84
              schrieb am zuletzt editiert von Alfi84
              @crunchip
              system.adapter.admin                   : admin          - v6.0.8
              system.adapter.backitup                : backitup       - v2.4.6
              system.adapter.deconz                  : deconz         - v1.3.20
              system.adapter.denon                   : denon          - v1.12.1
              system.adapter.discovery               : discovery      - v2.8.0
              system.adapter.fritzdect               : fritzdect      - v2.2.3
              system.adapter.heos                    : heos           - v1.9.2
              system.adapter.hm-rega                 : hm-rega        - v3.0.40
              system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
              system.adapter.icons-material-png      : icons-material-png - v0.1.0
              system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
              system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
              system.adapter.javascript              : javascript     - v5.5.4
              system.adapter.mqtt                    : mqtt           - v4.0.6
              system.adapter.openweathermap          : openweathermap - v0.2.3
              system.adapter.shelly                  : shelly         - v5.3.2
              system.adapter.smartgarden             : smartgarden    - v1.0.5
              system.adapter.tr-064                  : tr-064         - v4.2.15
              system.adapter.vis                     : vis            - v1.4.5
              system.adapter.vis-bars                : vis-bars       - v0.1.4
              system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
              system.adapter.vis-icontwo             : vis-icontwo    - v0.86.0
              system.adapter.vis-inventwo            : vis-inventwo   - v3.2.8
              system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
              system.adapter.vis-material            : vis-material   - v0.1.3
              system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
              system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
              system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
              system.adapter.weatherunderground      : weatherunderground - v3.4.2
              system.adapter.web                     : web            - v5.2.3
              pi@raspberrypi4-iob:/opt/iobroker $ iob update -i
              Used repository: stable
              Adapter    "admin"        : 5.3.8    , installed 6.0.8
              Adapter    "backitup"     : 2.4.9    , installed 2.4.9
              Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
              Adapter    "denon"        : 1.13.4   , installed 1.12.1 [Updatable]
              Adapter    "discovery"    : 3.0.3    , installed 3.0.3
              Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
              Adapter    "heos"         : 1.10.0   , installed 1.9.2  [Updatable]
              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
              Adapter    "javascript"   : 5.7.0    , installed 5.5.4  [Updatable]
              Controller "js-controller": 4.0.23   , installed 4.0.23
              Adapter    "mqtt"         : 3.0.6    , installed 4.0.6
              Adapter    "openweathermap": 0.2.4   , installed 0.2.3  [Updatable]
              Adapter    "shelly"       : 5.3.2    , installed 5.3.2
              Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
              Adapter    "smartgarden"  : 2.0.0    , installed 1.0.5  [Updatable]
              Adapter    "socketio"     : 4.2.0    , installed 6.1.7
              Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
              Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
              Adapter    "vis-hqwidgets": 1.2.0    , installed 1.1.9  [Updatable]
              Adapter    "vis-icontwo"  : 0.87.0   , installed 0.86.0 [Updatable]
              Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.8  [Updatable]
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
              Adapter    "weatherunderground": 3.4.2, installed 3.4.2
              Adapter    "web"          : 4.3.0    , installed 5.2.3
              Adapter    "ws"           : 1.3.0    , installed 2.1.2
              • A Alfi84
                @crunchip
                crunchipC Offline
                crunchipC Offline
                @alfi84 hast du den admin vor dem upgrade gestoppt?
                wie kommst du überhaupt darauf admin v6 zu installieren? du bist doch im stable, hast aber ein Mischmasch an stable/latest und zwischendrin
                  Alfi84
                  @crunchip
                  ja hatte ich gestoppt.
                  hab ein node.js update gemacht und hab dann aber beim admin update nicht an "latest" gedacht...und dann war es passiert :man-facepalming:
                  • A Alfi84
                    @crunchip
                    @alfi84 sagte in Admin 6.0 - neu als Beta:
                    Und was genau hat jetzt ein Upate von nodejs mit dem iobroker-Beta-Repository zu tun?
                    Zeigen was da jetzt Sache ist:
                    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    A GlasfaserG 2 Antworten Letzte Antwort
                      Alfi84
                      Ich habe das Update quasi "ausversehen" durchgeführt. Ist doch jetzt auch egal...das ändert jetzt auch nix dran.
                      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.15.1
                      v16.15.1
                      8.11.0
                      pi
                      /opt/iobroker
                      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                      OK:4 https://phoscon.de/apt/deconz bullseye InRelease
                      Alle Pakete sind aktuell.
                      nodejs:
                        Installiert:           16.15.1-deb-1nodesource1
                        Installationskandidat: 16.15.1-deb-1nodesource1
                        Versionstabelle:
                       *** 16.15.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                           12.22.5~dfsg-2~11u1 500
                      • A Alfi84
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.15.1
                        v16.15.1
                        8.11.0
                        pi
                        /opt/iobroker
                        nodejs:
                          Versionstabelle:
                        @alfi84 Gut, nodejs ist richtig installiert.
                        iobroker update
                        iobroker stop
                        iobroker upgrade
                        iobroker start
                          iobroker update
                          iobroker stop
                          iobroker upgrade
                          iobroker start
                          Alfi84
                          @thomas-braun said in Admin 6.0 - neu als Beta:
                          iobroker start
                          ist erledigt...
                          crunchipC Thomas BraunT apollon77A 3 Antworten Letzte Antwort
                          • A Alfi84
                            iobroker start
                            ist erledigt...
                            crunchipC Offline
                            crunchipC Offline
                            ist erledigt...
                            nö
                            • A Alfi84
                              iobroker start
                              ist erledigt...
                              Da klemmt es noch gewaltig...
                              iobroker update deconz --debug
                              VOLLSTÄNDIGE Ein- wie Ausgaben posten. Inklusive Eingabezeile.
                                Alfi84
                                pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
                                Used repository: deconz
                                Error: unknown repository is active - "deconz". Known: stable, latest
                                • A Alfi84
                                  iobroker start
                                  ist erledigt...
                                  @alfi84 Versuch erstmal nochmal ein "iob upload admin".
                                  Formal war auch der "downgrade" befehel falsch weil "iob upgrade admin@5.3.8" richtig wäre ... die Standard iobroker befehle ohne "iobroker." im Namen. Sollte zwar meistens weggeschnitten werden, aber wer weiss
                                    @alfi84
                                    Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
                                    iob repo list
                                    sagt?
                                    [Edit:] Und ich habe Blödsinn geschrieben...
                                    iobroker upgrade deconz --debug
                                    muss das heißen.
                                    Alfi84
                                    Der Adapter ist nicht so wichtig, da ich ihn noch nicht nutze.
                                    Wichtig ist der downgrade von Admin.
                                    • A Alfi84
                                      Ich wollte die Fehlermeldungen aus der Aktion sehen.
                                      Dann halt die Meldungen zu
                                      iobroker upgrade admin@5.3.8 --debug
                                      crunchipC A 2 Antworten Letzte Antwort
                                        crunchipC Offline
                                        crunchipC Offline
                                        @thomas-braun aber admin vorher stoppen
                                        • Thomas BraunT Online
                                          @crunchip
                                          Joh, keine doofe Idee...
                                          @Alfi84
                                          iobroker stop admin
                                          iobroker start admin
