  4. downgrade Admin v6
downgrade Admin v6
51 Beiträge 9 Kommentatoren 5.9k Aufrufe 3 Beobachtet
    Alfi84
    schrieb am zuletzt editiert von Alfi84
    Kann mir jemand sagen wie ich von Admin 6.0.4 wieder auf 5.3.8 downgrade?
    Habe es über Adapter und upgrade iobroker.admin@5.3.8 versucht aber ohne Erfolg.
    Danke vorab
    • A Alfi84
      Danke vorab
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      @alfi84 da fehlt ein iob am anfang
      iob upgrade iobroker.admin@5.3.8
      Bei Problemen immer den vollständigen Inhalt der Konsole angeben, dass erleichtert die Hilfe.
      • FeuersturmF Feuersturm
        Alfi84
        pi@raspberrypi4-iob:/opt/iobroker $ iob upgrade iobroker.admin@5.3.8
        BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to downgrade admin from @6.0.8 to @5.3.8 now? [(y)es, (n)o]: y
        Update admin from @6.0.8 to @5.3.8
        host.raspberrypi4-iob Adapter "system.adapter.admin.0" is stopped.
        NPM version: 8.11.0
        Installing iobroker.admin@5.3.8... (System call)
        upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        host.raspberrypi4-iob Adapter "system.adapter.admin.0" is started
        • A Alfi84
          NPM version: 8.11.0
          FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          @alfi84 und jetzt geht alles oder welche Probleme liegen noch an?
            Alfi84
            @feuersturm
            habe immer noch v6.0.8 drauf
            • A Alfi84
              @feuersturm
              crunchipC Offline
              crunchipC Offline
              @alfi84 Browser neu laden? ansonsten Version per konsole abfragen
                Alfi84
                @crunchip browser refresh hab ich gemacht.
                hast du mal bitte den Befehl für die versionsabfrage?
                • A Alfi84
                  crunchipC Offline
                  crunchipC Offline
                  @alfi84 iob list adapters bzw iob update -i
                    Alfi84
                    @crunchip
                    system.adapter.admin                   : admin          - v6.0.8
                    system.adapter.backitup                : backitup       - v2.4.6
                    system.adapter.deconz                  : deconz         - v1.3.20
                    system.adapter.denon                   : denon          - v1.12.1
                    system.adapter.discovery               : discovery      - v2.8.0
                    system.adapter.fritzdect               : fritzdect      - v2.2.3
                    system.adapter.heos                    : heos           - v1.9.2
                    system.adapter.hm-rega                 : hm-rega        - v3.0.40
                    system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
                    system.adapter.icons-material-png      : icons-material-png - v0.1.0
                    system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                    system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                    system.adapter.javascript              : javascript     - v5.5.4
                    system.adapter.mqtt                    : mqtt           - v4.0.6
                    system.adapter.openweathermap          : openweathermap - v0.2.3
                    system.adapter.shelly                  : shelly         - v5.3.2
                    system.adapter.smartgarden             : smartgarden    - v1.0.5
                    system.adapter.tr-064                  : tr-064         - v4.2.15
                    system.adapter.vis                     : vis            - v1.4.5
                    system.adapter.vis-bars                : vis-bars       - v0.1.4
                    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.9
                    system.adapter.vis-icontwo             : vis-icontwo    - v0.86.0
                    system.adapter.vis-inventwo            : vis-inventwo   - v3.2.8
                    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                    system.adapter.vis-material            : vis-material   - v0.1.3
                    system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
                    system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
                    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                    system.adapter.weatherunderground      : weatherunderground - v3.4.2
                    system.adapter.web                     : web            - v5.2.3
                    pi@raspberrypi4-iob:/opt/iobroker $ iob update -i
                    Used repository: stable
                    Adapter    "admin"        : 5.3.8    , installed 6.0.8
                    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                    Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
                    Adapter    "denon"        : 1.13.4   , installed 1.12.1 [Updatable]
                    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
                    Adapter    "heos"         : 1.10.0   , installed 1.9.2  [Updatable]
                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                    Adapter    "javascript"   : 5.7.0    , installed 5.5.4  [Updatable]
                    Controller "js-controller": 4.0.23   , installed 4.0.23
                    Adapter    "mqtt"         : 3.0.6    , installed 4.0.6
                    Adapter    "openweathermap": 0.2.4   , installed 0.2.3  [Updatable]
                    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                    Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
                    Adapter    "smartgarden"  : 2.0.0    , installed 1.0.5  [Updatable]
                    Adapter    "socketio"     : 4.2.0    , installed 6.1.7
                    Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
                    Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
                    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.1.9  [Updatable]
                    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.86.0 [Updatable]
                    Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.8  [Updatable]
                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                    Adapter    "web"          : 4.3.0    , installed 5.2.3
                    Adapter    "ws"           : 1.3.0    , installed 2.1.2
                    • A Alfi84
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      @alfi84 hast du den admin vor dem upgrade gestoppt?
                      wie kommst du überhaupt darauf admin v6 zu installieren? du bist doch im stable, hast aber ein Mischmasch an stable/latest und zwischendrin
                        Alfi84
                        @crunchip
                        ja hatte ich gestoppt.
                        hab ein node.js update gemacht und hab dann aber beim admin update nicht an "latest" gedacht...und dann war es passiert :man-facepalming:
                        • A Alfi84
                          @crunchip
                          @alfi84 sagte in Admin 6.0 - neu als Beta:
                          Und was genau hat jetzt ein Upate von nodejs mit dem iobroker-Beta-Repository zu tun?
                          Zeigen was da jetzt Sache ist:
                          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          A GlasfaserG 2 Antworten Letzte Antwort
                            Alfi84
                            Ich habe das Update quasi "ausversehen" durchgeführt. Ist doch jetzt auch egal...das ändert jetzt auch nix dran.
                            ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.15.1
                            v16.15.1
                            8.11.0
                            pi
                            /opt/iobroker
                            OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                            OK:4 https://phoscon.de/apt/deconz bullseye InRelease
                            Alle Pakete sind aktuell.
                            nodejs:
                              Installiert:           16.15.1-deb-1nodesource1
                              Installationskandidat: 16.15.1-deb-1nodesource1
                              Versionstabelle:
                             *** 16.15.1-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                 12.22.5~dfsg-2~11u1 500
                            • A Alfi84
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.15.1
                              v16.15.1
                              8.11.0
                              pi
                              /opt/iobroker
                              nodejs:
                                Versionstabelle:
                              @alfi84 Gut, nodejs ist richtig installiert.
                              iobroker update
                              iobroker stop
                              iobroker upgrade
                              iobroker start
                                iobroker update
                                iobroker stop
                                iobroker upgrade
                                iobroker start
                                Alfi84
                                @thomas-braun said in Admin 6.0 - neu als Beta:
                                iobroker start
                                ist erledigt...
                                crunchipC Thomas BraunT apollon77A 3 Antworten Letzte Antwort
                                • A Alfi84
                                  iobroker start
                                  ist erledigt...
                                  crunchipC Offline
                                  crunchipC Offline
                                  ist erledigt...
                                  nö
                                  • A Alfi84
                                    iobroker start
                                    ist erledigt...
                                    Da klemmt es noch gewaltig...
                                    iobroker update deconz --debug
                                    VOLLSTÄNDIGE Ein- wie Ausgaben posten. Inklusive Eingabezeile.
                                      Alfi84
                                      pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
                                      Used repository: deconz
                                      Error: unknown repository is active - "deconz". Known: stable, latest
                                      • A Alfi84
                                        iobroker start
                                        ist erledigt...
                                        apollon77A Online
                                        apollon77A Online
                                        @alfi84 Versuch erstmal nochmal ein "iob upload admin".
                                        Formal war auch der "downgrade" befehel falsch weil "iob upgrade admin@5.3.8" richtig wäre ... die Standard iobroker befehle ohne "iobroker." im Namen. Sollte zwar meistens weggeschnitten werden, aber wer weiss
                                          @alfi84
                                          Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
                                          iob repo list
                                          sagt?
                                          [Edit:] Und ich habe Blödsinn geschrieben...
                                          iobroker upgrade deconz --debug
                                          muss das heißen.
                                          Alfi84
                                          Der Adapter ist nicht so wichtig, da ich ihn noch nicht nutze.
                                          Wichtig ist der downgrade von Admin.
