  4. downgrade Admin v6
downgrade Admin v6
51 Beiträge 9 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • A Alfi84
    @thomas-braun said in Admin 6.0 - neu als Beta:
    iobroker start
    ist erledigt...
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 6.0.8
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
    Adapter    "denon"        : 1.13.4   , installed 1.12.1 [Updatable]
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "heos"         : 1.10.0   , installed 1.9.2  [Updatable]
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "javascript"   : 5.7.0    , installed 5.5.4  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 3.0.6    , installed 4.0.6
    Adapter    "openweathermap": 0.2.4   , installed 0.2.3  [Updatable]
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
    Adapter    "smartgarden"  : 2.0.0    , installed 1.0.5  [Updatable]
    Adapter    "socketio"     : 4.2.0    , installed 6.1.7
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
    Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.1.9  [Updatable]
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.86.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.8  [Updatable]
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 5.2.3
    Adapter    "ws"           : 1.3.0    , installed 2.1.2
    @alfi84 sagte in Admin 6.0 - neu als Beta:
    Da klemmt es noch gewaltig...
    iobroker update deconz --debug
    VOLLSTÄNDIGE Ein- wie Ausgaben posten. Inklusive Eingabezeile.
      Alfi84
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
      Used repository: deconz
      Error: unknown repository is active - "deconz". Known: stable, latest
      • A Alfi84
        iobroker start
        ist erledigt...
        @alfi84 Versuch erstmal nochmal ein "iob upload admin".
        Formal war auch der "downgrade" befehel falsch weil "iob upgrade admin@5.3.8" richtig wäre ... die Standard iobroker befehle ohne "iobroker." im Namen. Sollte zwar meistens weggeschnitten werden, aber wer weiss
          @alfi84
          Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
          iob repo list
          sagt?
          [Edit:] Und ich habe Blödsinn geschrieben...
          iobroker upgrade deconz --debug
          muss das heißen.
          Alfi84
          Der Adapter ist nicht so wichtig, da ich ihn noch nicht nutze.
          Wichtig ist der downgrade von Admin.
          • A Alfi84
            Ich wollte die Fehlermeldungen aus der Aktion sehen.
            Dann halt die Meldungen zu
            iobroker upgrade admin@5.3.8 --debug
            crunchipC A 2 Antworten Letzte Antwort
              crunchipC Offline
              crunchipC Offline
              @thomas-braun aber admin vorher stoppen
              • Thomas BraunT Online
                @crunchip
                Joh, keine doofe Idee...
                @Alfi84
                iobroker stop admin
                iobroker start admin
                  @alfi84
                  iob repo list
                  sagt?
                  muss das heißen.
                  Alfi84
                  pi@raspberrypi4-iob:~ $ iob repo list
                  latest        : http://download.iobroker.net/sources-dist-latest.json
                  Active repo(s): stable
                    Alfi84
                    schrieb am zuletzt editiert von Alfi84
                    pi@raspberrypi4-iob:~ $ iobroker upgrade admin@5.3.8 --debug
                    BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                    Would you like to downgrade admin from @6.0.8 to @5.3.8 now? [(y)es, (n)o]: y
                    Update admin from @6.0.8 to @5.3.8
                    host.raspberrypi4-iob Adapter "system.adapter.admin.0" is stopped.
                    NPM version: 8.11.0
                    Installing iobroker.admin@5.3.8... (System call)
                    npm WARN old lockfile
                    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                    npm WARN old lockfile This is a one-time fix-up, please be patient...
                    npm ERR! builtins is not a function
                    npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T18_47_13_428Z-debug-0.log
                    upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
                    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
                    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
                    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                    host.raspberrypi4-iob Adapter "system.adapter.admin.0" is started
                    das Problem liegt wohl an npm!?
                    • A Alfi84
                      NPM version: 8.11.0
                      liegt wohl an npm!?
                      Natürlich.
                      Ich möchte die Meldungen zu
                      iobroker update
                      bitte sehen.
                        liegt wohl an npm!?
                        Natürlich.
                        iobroker update
                        bitte sehen.
                        Alfi84
                        pi@raspberrypi4-iob:~ $ iobroker update
                        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                        pi@raspberrypi4-iob:~ $ iobroker update deconz --debug
                        pi@raspberrypi4-iob:~ $ iobroker upgrade deconz --debug
                        This upgrade of "deconz" will introduce the following changes:
                        -> 1.3.21:
                        added schedule to object definition
                        changed limit for duration to 999999
                        Would you like to upgrade deconz from @1.3.20 to @1.3.21 now? [(y)es, (n)o]: y
                        Update deconz from @1.3.20 to @1.3.21
                        NPM version: 8.11.0
                        Installing iobroker.deconz@1.3.21... (System call)
                        npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T19_00_48_897Z-debug-0.log
                        upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                        upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                        upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                        upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                        Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                        • A Alfi84
                          -> 1.3.21:
                          NPM version: 8.11.0
                          @alfi84
                          iobroker update
                          • A Alfi84
                            -> 1.3.21:
                            NPM version: 8.11.0
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Ich würde die Löschen und IoBroker neu starten .
                            • A Alfi84
                              -> 1.3.21:
                              NPM version: 8.11.0
                              package-lock.json
                              iobroker stop
                              sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lock.jsonalt
                              iobroker start
                                package-lock.json
                                iobroker stop
                                iobroker start
                                Alfi84
                                pi@raspberrypi4-iob:~ $ iobroker stop
                                pi@raspberrypi4-iob:~ $ sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lock.jsonalt
                                • A Alfi84
                                  @alfi84
                                  iobroker update
                                  iobroker upgrade
                                    @alfi84
                                    iobroker update
                                    iobroker upgrade
                                    Alfi84
                                    This upgrade of "vis-inventwo" will introduce the following changes:
                                    -> 3.3.1:
                                    Bugfix
                                    -> 3.3.0:
                                    New widget: configurable colorpicker for HEX, RGB, HSL, HSV and CIE/XY
                                    Would you like to upgrade vis-inventwo from @3.2.8 to @3.3.1 now? [(y)es, (n)o]: y
                                    Update vis-inventwo from @3.2.8 to @3.3.1
                                    NPM version: 8.11.0
                                    Installing iobroker.vis-inventwo@3.3.1... (System call)
                                    Adapter "system.adapter.vis.0" restarted.
                                    Adapter "system.adapter.web.0" restarted.
                                    upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                                    upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                                    upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                                    upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                                    upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                                    upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                                    upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                                    upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                                    upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                                    upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                                    upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                                    upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                                    upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                                    upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                                    upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                                    upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                                    upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                                    upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                                    upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
                                    upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
                                    upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                                    upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                                    This upgrade of "vis-icontwo" will introduce the following changes:
                                    -> 0.87.0:
                                    new icons added
                                    -> 0.86.2:
                                    Bugfix
                                    -> 0.86.1:
                                    Bugfix
                                    Would you like to upgrade vis-icontwo from @0.86.0 to @0.87.0 now? [(y)es, (n)o]: y
                                    Update vis-icontwo from @0.86.0 to @0.87.0
                                    NPM version: 8.11.0
                                    Installing iobroker.vis-icontwo@0.87.0... (System call)
                                    upload [1327] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png
                                    upload [1300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/home_error_red.png Alarm/home_error_red.png image/png
                                    upload [1250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Animated/Maps/map-waypoint.gif Animated/Maps/map-waypoint.gif image/gif
                                    upload [1200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/201.png Backgrounds/Seamless/201.png image/png
                                    upload [1150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/grafana.png Brands/grafana.png image/png
                                    upload [1100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Amazon_Echo/echo_flex.png Devices/Amazon_Echo/echo_flex.png image/png
                                    upload [1050] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Computers/pc_grafana.png Devices/Computers/pc_grafana.png image/png
                                    upload [1000] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Cooling/fan1_on1.png Devices/Cooling/fan1_on1.png image/png
                                    upload [950] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Network/hub2.png Devices/Network/hub2.png image/png
                                    upload [900] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Printers/3D_printer_new.png Devices/Printers/3D_printer_new.png image/png
                                    upload [850] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/laser_off.png Devices/laser_off.png image/png
                                    upload [800] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/Shutter/blinds2_30.png Doors_Windows/Shutter/blinds2_30.png image/png
                                    upload [750] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/window_open.png Doors_Windows/window_open.png image/png
                                    upload [700] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Electricity/switch2.png Electricity/switch2.png image/png
                                    upload [650] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Hobbies/Train/subway.png Hobbies/Train/subway.png image/png
                                    upload [600] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Letters/Rounded/q.png Letters/Rounded/q.png image/png
                                    upload [550] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Lights/light_dim_plus.png Lights/light_dim_plus.png image/png
                                    upload [500] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Misc/A.png Misc/A.png image/png
                                    upload [450] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Navigations/nav_cam1.png Navigations/nav_cam1.png image/png
                                    upload [400] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/41.png Numbers/Rounded/41.png image/png
                                    upload [350] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Numbers/Rounded/87.png Numbers/Rounded/87.png image/png
                                    upload [300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Player/on.png Player/on.png image/png
                                    upload [250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/bedroom2_POWER_on.png Rooms/bedroom2_POWER_on.png image/png
                                    upload [200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/hallway_POWER_on.png Rooms/hallway_POWER_on.png image/png
                                    upload [150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Rooms/warehouse.png Rooms/warehouse.png image/png
                                    upload [100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Signs/delete.png Signs/delete.png image/png
                                    upload [90] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/exercise.png Spa_Fitness/exercise.png image/png
                                    upload [80] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Spa_Fitness/sun-lounger.png Spa_Fitness/sun-lounger.png image/png
                                    upload [70] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/avalanche_land.png Weather/Warning/avalanche_land.png image/png
                                    upload [60] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Warning/volcano.png Weather/Warning/volcano.png image/png
                                    upload [50] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/Wind_Speeds/wind_speed_38-42.png Weather/Wind_Speeds/wind_speed_38-42.png image/png
                                    upload [40] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/day.png Weather/day.png image/png
                                    upload [30] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/direction_w.png Weather/direction_w.png image/png
                                    upload [20] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/pressure_gauge2.png Weather/pressure_gauge2.png image/png
                                    upload [19] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain.png Weather/rain.png image/png
                                    upload [18] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rain_value.png Weather/rain_value.png image/png
                                    upload [17] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/rainy.png Weather/rainy.png image/png
                                    upload [16] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow.png Weather/snow.png image/png
                                    upload [15] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow2.png Weather/snow2.png image/png
                                    upload [14] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow3.png Weather/snow3.png image/png
                                    upload [13] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/snow_value.png Weather/snow_value.png image/png
                                    upload [12] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/storm.png Weather/storm.png image/png
                                    upload [11] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun.png Weather/sun.png image/png
                                    upload [10] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sun_value.png Weather/sun_value.png image/png
                                    upload [9] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunrise.png Weather/sunrise.png image/png
                                    upload [8] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/sunset.png Weather/sunset.png image/png
                                    upload [7] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp.png Weather/temp.png image/png
                                    upload [6] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp2.png Weather/temp2.png image/png
                                    upload [5] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/temp3.png Weather/temp3.png image/png
                                    upload [4] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wet.png Weather/wet.png image/png
                                    upload [3] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind.png Weather/wind.png image/png
                                    upload [2] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/wind_value.png Weather/wind_value.png image/png
                                    upload [1] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windsock.png Weather/windsock.png image/png
                                    upload [0] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Weather/windy.png Weather/windy.png image/png
                                    upload [5] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/admin.d.ts admin.d.ts video/mp2t
                                    upload [4] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/i1_150.png i1_150.png image/png
                                    upload [3] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/icontwo.png icontwo.png image/png
                                    upload [2] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/index_m.html index_m.html text/html
                                    upload [1] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/style.css style.css text/css
                                    upload [0] vis-icontwo.admin /opt/iobroker/node_modules/iobroker.vis-icontwo/admin/words.js words.js application/javascript
                                    This upgrade of "vis-hqwidgets" will introduce the following changes:
                                    -> 1.2.0:
                                    Removed deprecated method `load`
                                    Would you like to upgrade vis-hqwidgets from @1.1.9 to @1.2.0 now? [(y)es, (n)o]: y
                                    Update vis-hqwidgets from @1.1.9 to @1.2.0
                                    NPM version: 8.11.0
                                    Installing iobroker.vis-hqwidgets@1.2.0... (System call)
                                    INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                    upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                    upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                    This upgrade of "vis" will at least introduce the following changes:
                                    -> 1.4.15:
                                    Better check of the offline license
                                    -> 1.4.14:
                                    Corrected GUI bug
                                    -> 1.4.13:
                                    The group attributes will be replaced recursively
                                    -> 1.4.12:
                                    Fixed bug with the export of specific widgets
                                    -> 1.4.11:
                                    Removed ES6 commands to be supported by older browsers
                                    Fixed problem with update of grouped widgets
                                    Added web manifest to be able to handle vis as the web app
                                    -> 1.4.8:
                                    Added support for js-controller 4.x
                                    -> 1.4.7:
                                    Fixed subscribeOidAtRuntime if called with invalid IDs
                                    Added support of license manager
                                    Would you like to upgrade vis from @1.4.5 to @1.4.15 now? [(y)es, (n)o]: y
                                    Update vis from @1.4.5 to @1.4.15
                                    NPM version: 8.11.0
                                    Installing iobroker.vis@1.4.15... (System call)
                                    upload [948] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                    upload [900] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/table.png icon/table.png image/png
                                    upload [850] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/add.png js/fm/icon/actions/add.png image/png
                                    upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEdit.js js/visEdit.js application/javascript
                                    upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-1.10.3.dragdropsort.min.js lib/js/jquery-ui-1.10.3.dragdropsort.min.js application/javascript
                                    upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/js/bars.js widgets/bars/js/bars.js application/javascript
                                    upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micStarted.svg widgets/basic/img/micStarted.svg image/svg+xml
                                    upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/js/hqwidgets.js widgets/hqwidgets/js/hqwidgets.js application/javascript
                                    upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_100.png widgets/jqui-mfd/img/fts_shutter_100.png image/png
                                    upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/light_light_dim_60.svg widgets/jqui-mfd/img/light_light_dim_60.svg image/svg+xml
                                    upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/material/img/light_light_dim_50.png widgets/material/img/light_light_dim_50.png image/png
                                    upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/js/widgets/materialdesign.materialdesignicons.js widgets/materialdesign/js/widgets/materialdesign.materialdesignicons.js application/javascript
                                    upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                                    upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/21-1.png widgets/timeandweather/img/clock/21-1.png image/png
                                    upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/apm.png widgets/timeandweather/img/clock/apm.png image/png
                                    upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider1.gif widgets/vis-inventwo/img/Slider1.gif image/gif
                                    upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/checkbox-intermediate.png widgets/vis-material-advanced/img/checkbox-intermediate.png image/png
                                    upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/garage.png widgets/vis-material-advanced/img/garage.png image/png
                                    upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/light_light_dim_10.png widgets/vis-material-advanced/img/light_light_dim_10.png image/png
                                    upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/ma_checkbox_checked.png widgets/vis-material-advanced/img/ma_checkbox_checked.png image/png
                                    upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/pressure.png widgets/vis-material-advanced/img/pressure.png image/png
                                    upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/temp_verlauf_100.png widgets/vis-material-advanced/img/temp_verlauf_100.png image/png
                                    upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/temp_verlauf_60.png widgets/vis-material-advanced/img/temp_verlauf_60.png image/png
                                    upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/unchecked.png widgets/vis-material-advanced/img/unchecked.png image/png
                                    upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/img/watering_empty.png widgets/vis-material-advanced/img/watering_empty.png image/png
                                    upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListNumber/listNumber.js widgets/vis-material-advanced/js/ListNumber/listNumber.js application/javascript
                                    upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListOccupancy/listOccupancy.js widgets/vis-material-advanced/js/ListOccupancy/listOccupancy.js application/javascript
                                    upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListPresence/listPresence.js widgets/vis-material-advanced/js/ListPresence/listPresence.js application/javascript
                                    upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListPressure/listPressure.js widgets/vis-material-advanced/js/ListPressure/listPressure.js application/javascript
                                    upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListRegenRadar/listRegenRadar.js widgets/vis-material-advanced/js/ListRegenRadar/listRegenRadar.js application/javascript
                                    upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListTemp/listTemp.js widgets/vis-material-advanced/js/ListTemp/listTemp.js application/javascript
                                    upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListTempHumid/listTempHumid.js widgets/vis-material-advanced/js/ListTempHumid/listTempHumid.js application/javascript
                                    upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListText/listText.js widgets/vis-material-advanced/js/ListText/listText.js application/javascript
                                    upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListThermostat/listThermostat.js widgets/vis-material-advanced/js/ListThermostat/listThermostat.js application/javascript
                                    upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListValve/listValve.js widgets/vis-material-advanced/js/ListValve/listValve.js application/javascript
                                    upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListVolume/listVolume.js widgets/vis-material-advanced/js/ListVolume/listVolume.js application/javascript
                                    upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListWindow/listWindow.js widgets/vis-material-advanced/js/ListWindow/listWindow.js application/javascript
                                    upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/ListWindowShutter/listWindowShutter.js widgets/vis-material-advanced/js/ListWindowShutter/listWindowShutter.js application/javascript
                                    upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/TempIcon/TempIcon.js widgets/vis-material-advanced/js/TempIcon/TempIcon.js application/javascript
                                    upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/base.js widgets/vis-material-advanced/js/base.js application/javascript
                                    upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/do widgets/vis-material-advanced/js/do null
                                    upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/genTitleContainer.js widgets/vis-material-advanced/js/genTitleContainer.js application/javascript
                                    upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/list.js widgets/vis-material-advanced/js/list.js application/javascript
                                    upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/vis-material-advanced.js widgets/vis-material-advanced/js/vis-material-advanced.js application/javascript
                                    upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced/js/words.js widgets/vis-material-advanced/js/words.js application/javascript
                                    upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-material-advanced.html widgets/vis-material-advanced.html text/html
                                    upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                    upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                    upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                    upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                    This upgrade of "tr-064" will introduce the following changes:
                                    -> 4.2.16:
                                    Fix info logs on callee/caller
                                    Add special handling for potential broken external image links in phonebook
                                    Prevent some crash cases reported by Sentry
                                    Would you like to upgrade tr-064 from @4.2.15 to @4.2.16 now? [(y)es, (n)o]: y
                                    Update tr-064 from @4.2.15 to @4.2.16
                                    NPM version: 8.11.0
                                    Installing iobroker.tr-064@4.2.16... (System call)
                                    upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                    upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                    upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                    This upgrade of "smartgarden" will introduce the following changes:
                                    -> 2.0.0:
                                    support for new login procedure to Gardena webservice; admin5 is necessary
                                    -> 1.0.6:
                                    bug fix error handling, changes due to changed behavior Gardena Service, some minor changes in documentation
                                    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                    Would you like to upgrade smartgarden from @1.0.5 to @2.0.0 now? [(y)es, (n)o]: y
                                    Update smartgarden from @1.0.5 to @2.0.0
                                    NPM version: 8.11.0
                                    Installing iobroker.smartgarden@2.0.0... (System call)
                                    upload [5] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
                                    upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
                                    upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
                                    upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/style.css style.css text/css
                                    upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
                                    upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/words.js words.js application/javascript
                                    This upgrade of "openweathermap" will introduce the following changes:
                                    -> 0.2.4:
                                    Fix crash case when states have invalid metadata
                                    Would you like to upgrade openweathermap from @0.2.3 to @0.2.4 now? [(y)es, (n)o]: y
                                    Update openweathermap from @0.2.3 to @0.2.4
                                    NPM version: 8.11.0
                                    Installing iobroker.openweathermap@0.2.4... (System call)
                                    upload [3] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index.html index.html text/html
                                    upload [2] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index_m.html index_m.html text/html
                                    upload [1] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/openweathermap.png openweathermap.png image/png
                                    upload [0] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/words.js words.js application/javascript
                                    This upgrade of "javascript" will introduce the following changes:
                                    -> 5.7.0:
                                    Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage))
                                    Lists returned by $-selector are now unified and do not contain double entries
                                    Fix subscribe multiple object ID lists in blockly
                                    -> 5.6.1:
                                    Allow to subscribe multiple object ID lists in blockly
                                    -> 5.6.0:
                                    Make state properties c(omment) and user available to scripts too
                                    make sure values of new or changed alias objects are initialized properly
                                    Enhance scheduler logic and astro events offered by wizard
                                    Respect expected value changes when determining if a value is changed
                                    Fix remembering intermediate state values when state values are subscribed
                                    fix setState logic when states are not subscribed
                                    Would you like to upgrade javascript from @5.5.4 to @5.7.0 now? [(y)es, (n)o]: y
                                    Update javascript from @5.5.4 to @5.7.0
                                    NPM version: 8.11.0
                                    Installing iobroker.javascript@5.7.0... (System call)
                                    upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                                    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
                                    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
                                    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
                                    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
                                    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
                                    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.0fde2268.js static/js/runtime-main.0fde2268.js application/javascript
                                    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                                    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                                    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                    This upgrade of "heos" will introduce the following changes:
                                    -> 1.10.0:
                                    fix default value of `sid` (closes #174)
                                    Would you like to upgrade heos from @1.9.2 to @1.10.0 now? [(y)es, (n)o]: y
                                    Update heos from @1.9.2 to @1.10.0
                                    NPM version: 8.11.0
                                    Installing iobroker.heos@1.10.0... (System call)
                                    upload [4] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/admin.d.ts admin.d.ts video/mp2t
                                    upload [3] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/heos.png heos.png image/png
                                    upload [2] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/index_m.html index_m.html text/html
                                    upload [1] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/style.css style.css text/css
                                    upload [0] heos.admin /opt/iobroker/node_modules/iobroker.heos/admin/words.js words.js application/javascript
                                    This upgrade of "denon" will introduce the following changes:
                                    -> 1.13.4:
                                    we now respect `requestInterval` on determining the AVR model too
                                    -> 1.13.3:
                                    fixed timeout beeing only applied on first reconnect (fixes #232)
                                    -> 1.13.2:
                                    fixed requesting interval
                                    -> 1.13.1:
                                    added `settings.speakerPreset`
                                    -> 1.13.0:
                                    Would you like to upgrade denon from @1.12.1 to @1.13.4 now? [(y)es, (n)o]: y
                                    Update denon from @1.12.1 to @1.13.4
                                    NPM version: 8.11.0
                                    Installing iobroker.denon@1.13.4... (System call)
                                    upload [12] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                                    upload [11] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [10] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [9] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [8] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [7] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [6] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [5] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [4] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [3] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                                    upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                                    -> 1.3.21:
                                    NPM version: 8.11.0
                                    pi@raspberrypi4-iob:~ $ ^C
                                    • A Alfi84
                                      -> 3.3.1:
                                      Bugfix
                                      -> 3.3.0:
                                      NPM version: 8.11.0
                                      -> 0.87.0:
                                      new icons added
                                      -> 0.86.2:
                                      Bugfix
                                      -> 0.86.1:
                                      Bugfix
                                      NPM version: 8.11.0
                                      -> 1.2.0:
                                      NPM version: 8.11.0
                                      -> 1.4.15:
                                      -> 1.4.14:
                                      Corrected GUI bug
                                      -> 1.4.13:
                                      -> 1.4.12:
                                      -> 1.4.11:
                                      -> 1.4.8:
                                      -> 1.4.7:
                                      NPM version: 8.11.0
                                      -> 4.2.16:
                                      NPM version: 8.11.0
                                      -> 2.0.0:
                                      -> 1.0.6:
                                      NPM version: 8.11.0
                                      -> 0.2.4:
                                      NPM version: 8.11.0
                                      -> 5.7.0:
                                      -> 5.6.1:
                                      -> 5.6.0:
                                      NPM version: 8.11.0
                                      -> 1.10.0:
                                      NPM version: 8.11.0
                                      -> 1.13.4:
                                      -> 1.13.3:
                                      -> 1.13.2:
                                      -> 1.13.1:
                                      -> 1.13.0:
                                      NPM version: 8.11.0
                                      -> 1.3.21:
                                      NPM version: 8.11.0
                                      @alfi84
                                      Schade, hätte funktionieren können.
                                        hab ein node.js update gemacht und hab dann aber beim admin update nicht an "latest"
                                        Und was genau hat jetzt ein Upate von nodejs mit dem iobroker-Beta-Repository zu tun?
                                        Zeigen was da jetzt Sache ist:
                                        uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @thomas-braun sagte in Admin 6.0 - neu als Beta:
                                        @Homoran
                                        kann man die Beitrag von @Alfi84 nicht verschieben ,
                                        sie haben nichts mit dem ADMIN 6 Thread zu tun !?
                                          @alfi84
                                          Alfi84
                                          vielleicht ist es am besten wenn ich das backup mit 5.3.8 wieder einspiele + nodejs update?
