  4. [Cloud eingestellt] Gigaset Elements
79 Beiträge 10 Kommentatoren 14.4k Aufrufe 11 Beobachtet
  • matthscM matthsc
    @basti97
    • Debug - Prepare test data
    • Debug - Gigaset Elements API - basestations and elements
    Basti97B Offline
    Basti97B Offline
    Basti97
    @matthsc said in [Neuer Adapter] Gigaset Elements:
    @basti97
    Danke werde ich mal aufzeichen und dir morgen schicken. Die Anrufe kommen meistens in der App verzögert. Spätestens wenn man nicht ans Telefon gegangen ist. Kommt eine App Meldung Anruf verpasst.
    Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
    • matthscM matthsc
      @basti97
      Basti97B Offline
      Basti97B Offline
      Basti97
      @matthsc
      Debug Testdaten
        "bs": [],
        "elements": {
          "gp01": [],
          "gp02": [
              "id": "7C2F809EB961",
              "friendlyName": "IP- Telefon 1",
              "frontendTags": {
                "room": {
                  "roomName": "Wohnzimmer"
              "connectionStatus": "online",
              "room": {
                "id": 564537,
                "friendlyName": "Wohnzimmer"
              "capabilities": [
                "hardware.radio.dect.voice",
                "functionality.telephony.emergencyCall"
              "subelements": []
          "yc01": [],
          "bs01": [],
          "bs02": []
        "events": {
          "events": [
              "id": "71d400179bf843bdd59cb5db23fbb227a918e3be",
              "state": "ok",
              "ts": "1650817649188",
              "type": "gp.call",
              "o": {
                "frontendTags": {
                  "room": {
                    "roomName": "Room 000-jgeNV"
                "dialable": true,
                "line_type": "pstn",
                "type": "gp02.call",
                "line_index": 1,
                "call_type": "missed",
                "clip_type": "number",
                "clip": "004957651313282",
                "room": {
                  "id": 564537,
                  "friendlyName": "Room 000-jgeNV"
              "source_id": "7C2F809EB961",
              "source_type": "gp02",
              "state_pre": "ok"
          "home_state": "ok"
      • matthscM matthsc
        @basti97
        Basti97B Offline
        Basti97B Offline
        Basti97
        @matthsc
        Debug - Gigaset Elements API - Ereignisse
          "events": [
              "id": "5bb38d2120d59d6aba4f6dc156d10c8916ef733f",
              "state": "ok",
              "ts": "1651075718166",
              "type": "gp.call",
              "o": {
                "frontendTags": {
                  "room": {
                "friendly_name": "IP- Telefon 1",
                "dialable": true,
                "line_index": 1,
                "call_type": "outgoing",
                "clip": "004937235705457",
                "room": {
                  "id": 564537,
              "state_pre": "ok"
        Brauchst du noch mehr von dem Adapter??
        matthscM 1 Antwort Letzte Antwort
        • Basti97B Basti97
          @matthsc
            "events": [
                "state": "ok",
                "type": "gp.call",
                "o": {
                  "frontendTags": {
                    "room": {
                  "dialable": true,
                  "line_index": 1,
                  "room": {
                    "id": 564537,
                "state_pre": "ok"
          matthscM Offline
          matthscM Offline
          matthsc
          @basti97 said in [Neuer Adapter] Gigaset Elements:
          Das ist schonmal super, danke. Vielleicht noch das von gerade eben (Debug - Gigaset Elements API - Ereignisse) über einen längeren Zeitraum hinweg, momentan sehe ich als Ereignisse "nur" einen ausgehenden Anruf und einen verpassten, möglicherweise gibt es da noch mehr Typen.
          Kleiner Hinweis: in den Daten stehen echte Telefonnummern ("clip": "0049..."), die möchtest du vielleicht anonymisieren (werde ich in der nächsten Version zumindest bei Prepare Test Data berücksichtigen).
          Ich könnte pro Telefon ein Device anlegen. Die Frage wäre noch, wie dann die Anrufe abgebildet werden. Vielleicht pro Typ (Ausgehend, Verpasst, Eingehend(?)) einen State, in dem die letzte Telefonnummer angezeigt wird? Änderungszeitpunkt wäre dann der ungefähre Zeitpunkt des Anrufs. Oder hast du andere Ideen dazu?
          Basti97B 2 Antworten Letzte Antwort
          • matthscM matthsc
            Basti97B Offline
            Basti97B Offline
            Basti97
            Ok ich lasse das mal ein bisschen laufen. Aber ich glaube heute kommen keine Anrufe mehr 😕 .
            Und zwar ist es genauso wie du es gesagt hast. So wird es in der App auch angezeigt (Ausgehend, Verpasst, Eingehend(?)) mit der Uhrzeit und der Telefonnummer.
            Ja das die Telefonnummer mit angezeigt wird ist halt blöde aber es waren nur Werbeanrufe. Deshalb ist es nicht so schlimm wenn die jetzt hier stehen. :)
            Ich wusste gar nicht das es so eine funktion innerhalb des Adapters gibt. Wieder etwas dazu gelernt:
            • matthscM matthsc
              Basti97B Offline
              Basti97B Offline
              Basti97
              @matthsc Im übrigen so zeigt er das jetzt in der App an.
              Screenshot_20220427-203034_Gigaset elements.jpg 20220427_203147.jpg 20220427_203121.jpg
              • Basti97B Basti97
                matthscM Offline
                matthscM Offline
                matthsc
                Du kannst bei "Debug - Gigaset Elements API - Ereignisse" auch den Zeitraum auswählen. Standard ist der heutige Tag, es geht aber bis 30 Tage in die Vergangenheit.
                Ich hab mich da etwas ausgetobt, um einfacher Daten erfassen zu können 🤓
                Basti97B 1 Antwort Letzte Antwort
                • matthscM matthsc
                  Basti97B Offline
                  Basti97B Offline
                  Basti97
                  @matthsc
                  Das ist gut ich melde mich morgen wieder. Wenn ich keine Anrufe habe dann mache ich mal ein paar Test Anrufe.
                  Vor längerer Zeit habe ich schon mal geguckt ob bei Gitub oder hier im Forum ein Adapter von Gigaset gibt. Aber damal habe ich nichts gefunden. Mit zufall bin ich dann auf dein Adapter gestoßen und ich glaube dein Adapter ist ist die Lösung für mein Telefon :) .
                  matthscM Benjamin HäubleinB 2 Antworten Letzte Antwort
                  • Basti97B Basti97
                    @matthsc
                    matthscM Offline
                    matthscM Offline
                    matthsc
                    @basti97 Ich habe Version 0.2.0 mit Unterstützung für Telefone veröffentlicht, sollte demnächst im Latest Repo/NPM auftauchen.
                    Telefone erzeugen einen Channel "gp02-<ID>", mit ein paar allgemeinen States sowie lastCallIncoming, lastCallOutgoing, lastCallMissed. Diese lastCall* States werden dann beim entsprechenden Event befüllt. Ich hoffe dass das so funktioniert und für dich sinnvoll ist :-)
                    Basti97B 3 Antworten Letzte Antwort
                    • Basti97B Basti97
                      @matthsc
                      Benjamin HäubleinB Offline
                      Benjamin Häublein
                      schrieb am zuletzt editiert von Benjamin Häublein
                      @basti97 nur aus Interesse, kannst du vielleicht mal nachschauen, wie bei dir Anrufbenachrichtigungen konfiguriert sind?
                      Bei Gigaset steht, dass man die Möglicherweise explizit konfigurieren muss. Vielleicht bekommt man dann ja sofort eine Benachrichtigung bei einem eingehenden Anruf.
                      Vielen Dank
                      • matthscM matthsc
                        Basti97B Offline
                        Basti97B Offline
                        Basti97
                        @matthsc Danke habe gerade geguckt die aktualierung wird schon angezeigt. Habe ihn gleich aktualisiert. Sobald die ersten DBs befühlt sind werde ich mich wieder melden. Danke für deine Mühe. :)
                        • Benjamin HäubleinB Benjamin Häublein
                          Vielen Dank
                          Basti97B Offline
                          Basti97B Offline
                          Basti97
                          @benjamin-häublein
                          Ich habe gerade auf der Basisstation geguckt. Viel kann man da nicht einstellen. Ich könnte nochmal im Telefon gucken ob es dort mehr Einstellungen gibt.
                          • matthscM matthsc
                            Basti97B Offline
                            Basti97B Offline
                            Basti97
                            @matthsc
                            Sieht schon mal gut Aus die Datenpunkte sind schon mal gekommen und auch das Telefon zeigt er scon mal an.
                            • matthscM matthsc
                              Basti97B Offline
                              Basti97B Offline
                              Basti97
                              @matthsc
                              So nun hat mich jemand mal angerufen bzw ich und ich glaube es funktoniert.
                              Wird eigentlich die Telefonnummern beim nächsten Anruf überschrieben?
                              Was noch gut wäre ist wenn man es zusätzlich als Tabelle bekommt (zb Json) mit der jeweiligen Uhrzeit. Oderso?? :)
                              • Basti97B Basti97
                                @matthsc
                                matthscM Offline
                                matthscM Offline
                                matthsc
                                @basti97 Freut mich dass es funktioniert :-) Ja, beim nächsten Anruf wird last* überschrieben.
                                Je länger ich über so eine Tabelle nachdenke, desto mehr bin ich der Meinung, dass das sehr benutzerspezifisch ist und nicht vom Adapter gemacht werden sollte. Es fängt an mit der Grösse der Tabelle (fix X Einträge, oder etwas dynamischer letzte Y Tage/Wochen), und geht weiter mit der Frage ob es eine Tabelle über alle Anrufe oder einzelne pro Typ sein sollten.
                                Man kann sich so eine Tabelle ja selbst über ein Script/Blockly im Javascript Adapter erstellen.
                                • matthscM matthsc
                                  Basti97B Offline
                                  Basti97B Offline
                                  Basti97
                                  Das mit der eigenen Tabelle wäre auch eine möglichkeit. Woher nehme ich aber die Zeit von den jeweiligen Anruf. Könnte ich auf die Telefonnummer triggern? Und daraus einen neuen DB erstellen?
                                  • Basti97B Basti97
                                    matthscM Offline
                                    matthscM Offline
                                    matthsc
                                    @basti97 Genau, auf die last* Nummern triggern, und den Änderungszeitpunkt bzw. aktuellen Zeitpunkt verwenden. Das hat dann eine maximale Ungenauigkeit des Refresh-Intervalls. Also zum Beispiel alle 60 Sekunden Refresh -> der zugehörige Event kam innerhalb der letzten 60 Sekunden.
                                    • matthscM matthsc
                                      Basti97B Offline
                                      Basti97B Offline
                                      Basti97
                                      @matthsc ok dankeschön
                                      H 1 Antwort Letzte Antwort
                                      • Basti97B Basti97
                                        HomeControl
                                        schrieb am zuletzt editiert von HomeControl
                                        Hallo. Ich habe das Problem, dass immer wenn ich den Adapter installiere, die Fehlermeldung kommt, dass kein Start File vorhanden ist. Kann ich das selbst erstellen, oder wäre es möglich eines hochzuladen?
                                        Vielen Dank.
                                        • H HomeControl
                                          Vielen Dank.
                                          matthscM Offline
                                          matthscM Offline
                                          matthsc
                                          @homecontrol Die Meldung sagt mir nichts. Wie installierst du? Welche Versionen von js-controller, node.js, npm?
