  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 730.7k Aufrufe 117 Beobachtet
  • draexlerD draexler
    Hi ich kann den Adapter nicht nutzen. Er startet erst gar nicht und bleibt rot.
    In den Logs steht folgendes:
    ost.SmartHomePi
    2022-04-05 10:03:47.561	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.SmartHomePi
    2022-04-05 10:03:47.561	error	Caught by controller[0]: }
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    host.SmartHomePi
    2022-04-05 10:03:47.556	error	Caught by controller[0]: ^
    host.SmartHomePi
    2022-04-05 10:03:47.556	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.SmartHomePi
    2022-04-05 10:03:47.555	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
    Neuinstallation, iOBroker Neustart hat nichts gebracht.
    tombox
    #720
    @draexler
    cd /opt/iobroker/
    npm install canvas
    ich arbeite daran das es gefixt wird
    draexlerD Horst BöttcherH 2 Antworten Letzte Antwort
      @thomas-braun.
      Die installierte Version ist die "v14.19.1"
      Also kann es ja daran nicht liegen?
      #721
      @draexler sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
      Kann auch 'schief' installiert sein. Die Versionsnummer alleine sagt nichts aus.
      • T tombox
        @gruter sollte behoben sein
        Gruter
        #722
        @tombox
        Ja, jetzt passt es wieder, Danke!
        • T tombox
          @draexler
          cd /opt/iobroker/
          npm install canvas
          draexlerD Offline
          draexlerD Offline
          draexler
          #723
          @tombox Das hat funktioniert. Danke ☺️
          • T tombox
            Hi ich habe ein neuen Adapter für Paketverfolgung geschrieben
            Anbieter:
            DHL Paket und Briefe
            DPD
            GLS
            UPS
            Hermes
            Amazon
            17Track
            **Steuerung über ***
            parcel.0.refresh Daten manuell updaten
            parcel.0.17tuser.register Paket id unter 17TUser registrieren
            Zum Installieren:
            https://github.com/TA2k/ioBroker.parcel
            Loginablauf
            DHL:
            • DHL App Login eingeben
            • SMS/EMail Code erhalten
            • In die Instanzeinstellungen eingeben und speichern
            Amazon:
            • Login eingeben
            • Wenn nötig vorab ein OTP token aus der 2FA App eingeben.
            DPD, GLS, UPS, Hermes, 17Track User:
            Login und Passwort eingeben
            17Track User maximal 40 Pakete gleichzeitig:
            https://buyer.17track.net/en/myshipment?ob=1
            17Track Api developer maximal 100 Anfragen dann muss bezahlt werden
            Hier ein Security Key beantragen und in die Einstellungen eingeben geht nur wenn man kein 17Track User ist
            https://user.17track.net/de/register?gb=%23maybe%3D16
            https://api.17track.net/en/admin/settings
            Telegram Benachrichtigung für Sendungen und Briefe
            In den Instanz Einstellung telegram.0 eingeben
            Vis
            delivery_status = {
            ERROR: -1,
            UNKNOWN: 5,
            IN_PREPARATION: 20,
            IN_TRANSIT: 30,
            OUT_FOR_DELIVERY: 40,
            DELIVERED: 1,
            Sendungen als Vis Table darstellen
            Datenpunkte alle Sendungen:
            parcel.0.allProviderJson
            Datenpunkte in Zustellung:
            parcel.0.inDelivery
            Widget: json Table
            Anleitung:
            https://www.smarthome-tricks.de/software-iobroker/iobroker-vis-json-table-widget-teil-1-basics/
            DHL Briefverfolgung in Vis anzeigen.
            Den Datenpunkt image ein String img src element zuordnen
            Den Datenpunkt image als HTML element in die vis einfügen mit folgendem Inhalt
            <img src="{parcel.0.dhl.briefe.oldAdvices01.advices01.image}" width="500px" />
            Diskussion Widget
            https://forum.iobroker.net/topic/53045/test-widget-vis-owl-v0-2-x-github
            senior1418
            schrieb am zuletzt editiert von senior1418
            #724
            @tombox
            ich kann leider nicht genau sagen seit wann aber seit einiger Zeit erhalte ich keine Meldungen über PushOver.
            pushover.3 2022-04-08 10:58:38.042	error	Error from Pushover: message cannot be blank
            pushover.3 2022-04-08 10:58:37.882	info	Send pushover notification: {"user":"","text":"📦 Amazon EU SARL\nZustellung erfolgreich","title":"Parcel","priority":0,"message":""}
            :Nachtrag v0.0.13
            • S senior1418
              @tombox
              :Nachtrag v0.0.13
              tombox
              #725
              @senior1418 ist gefixt
              • T tombox
                Anbieter:
                DPD
                GLS
                UPS
                Hermes
                Amazon
                17Track
                Zum Installieren:
                Loginablauf
                DHL:
                Amazon:
                • Login eingeben
                Vis
                delivery_status = {
                ERROR: -1,
                UNKNOWN: 5,
                IN_PREPARATION: 20,
                IN_TRANSIT: 30,
                DELIVERED: 1,
                parcel.0.inDelivery
                Widget: json Table
                Anleitung:
                Diskussion Widget
                Horst BöttcherH Offline
                Horst Böttcher
                #726
                @tombox habe den adapter Installier und er bleibt rot
                host.raspberrypi	2022-04-08 12:14:32.446	info	Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                host.raspberrypi	2022-04-08 12:14:32.445	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi	2022-04-08 12:14:32.444	error	Caught by controller[0]: }
                host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
                host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
                host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
                host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                host.raspberrypi	2022-04-08 12:14:32.436	error	Caught by controller[0]: was compiled against a different Node.js version using
                host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: ^
                host.raspberrypi	2022-04-08 12:14:32.434	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                host.raspberrypi	2022-04-08 12:14:32.433	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
                host.raspberrypi	2022-04-08 12:14:28.563	info	instance system.adapter.parcel.0 started with pid 2182
                host.raspberrypi	2022-04-08 12:14:27.736	info	"system.adapter.parcel.0" enabled
                ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                • Horst BöttcherH Horst Böttcher
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  #727
                  @horst-böttcher
                  https://forum.iobroker.net/post/787171
                  Lehrling seit 1975 !!!
                  • T tombox
                    @draexler
                    cd /opt/iobroker/
                    npm install canvas
                    Horst Böttcher
                    #728
                    @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                    @draexler
                    cd /opt/iobroker/
                    npm install canvas
                    pi@raspberrypi:/opt/iobroker $ iobroker stop
                    pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
                    pi@raspberrypi:/opt/iobroker $ sudo npm install canvas
                    > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
                    > node-pre-gyp install --fallback-to-build
                    node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                    node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                    gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/14.18.1"
                    gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                    gyp ERR! configure error
                    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                    gyp ERR! System Linux 5.10.17-v7l+
                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                    gyp ERR! cwd /opt/iobroker/node_modules/canvas
                    gyp ERR! node -v v14.18.1
                    gyp ERR! node-gyp -v v5.1.0
                    gyp ERR! not ok
                    node-pre-gyp ERR! build error
                    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
                    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                    node-pre-gyp ERR! System Linux 5.10.17-v7l+
                    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                    node-pre-gyp ERR! node -v v14.18.1
                    node-pre-gyp ERR! node-pre-gyp -v v1.0.6
                    node-pre-gyp ERR! not ok
                    npm WARN @rollup/plugin-inject@4.0.4 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN @rollup/pluginutils@3.1.0 requires a peer of rollup@^1.20.0||^2.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN rollup-plugin-polyfill-node@0.8.0 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! canvas@2.9.1 install: `node-pre-gyp install --fallback-to-build`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the canvas@2.9.1 install script.
                    npm ERR!     /root/.npm/_logs/2022-04-08T14_22_43_117Z-debug.log
                      @draexler
                      cd /opt/iobroker/
                      npm install canvas
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      #729
                      @horst-böttcher sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      NICHT mit sudo hantieren an der Stelle.
                      Stand aber auch offenbar so nicht in der Anleitung. Warum macht man das also dann doch?
                      System auf Stand halten.
                      sudo apt update
                      sudo apt full-upgrade
                      sudo reboot
                      Danach als user:
                      cd /opt/iobroker
                      npm install canvas
                      Horst BöttcherH 1 Antwort Letzte Antwort
                        sudo apt update
                        sudo reboot
                        Danach als user:
                        cd /opt/iobroker
                        npm install canvas
                        Horst Böttcher
                        #730
                        ich hatte es vorher ohne sudo gemacht
                          #731
                          @horst-böttcher
                          Hast du jetzt die Hausaufgaben erledigt? System auf Stand?
                          cd /opt/iobroker
                          npm ls canvas
                          liefert?
                          • T tombox
                            senior1418
                            #732
                            ist gefixt
                            herzlichen Dank ! Es funktioniert wieder .
                            • T tombox
                              @basty2 bräuchte die genaue objekte wo die information drin sind.
                              Bei dpd muss erst auf die sendung geklickt werden damit man diese information sieht?
                              basty2
                              #733
                              @tombox Ich wollte nach dem aktuellen Stand nachfragen. Bei mir funktioniert die Darstellung der voraussichtlichen Lieferung und der Anzahl der Stopps nur bei Amazon. Die Infos gibt es bspw. teilweise auch bei der DHL. Ich fände es klasse, wenn diese Infos auch bei den anderen Unternehmen im JSON landen würden.
                              • B basty2
                                tombox
                                #734
                                @basty2 Also wenn sie nicht im rohen JSON sind wird es schwer darauf zuzugreifen. Ich habe bisher keine DHL mit Stop gehabt
                                DJMarc75D B 2 Antworten Letzte Antwort
                                • T tombox
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #735
                                  @tombox
                                  Ich hatte schon einige Lieferungen von DHL welche im Livetracking auch die Stopps angezeigt haben - allerdings nur in der Ordnerstruktur. Ich habe aber davon abgesehen dies zu visualisieren oder anders zu verarbeiten da sich die Anzahl der Stopps und eigentlich alle Daten im Livetracking ja auch nur ändern wenn sich die Instanz die Daten holt. In meinem Fall alle 15 Minuten und zwischen den Intervallen sind deutliche Abweichungen im Vergleich zur APP von DHL zu erkennen.
                                  Habe im Moment leider keine Lieferung von DHL um auch mal zu sehen ob da was in der rohen JSON eingetragen wird.
                                  • T tombox
                                    basty2
                                    #736
                                    @djmarc75 @tombox Spannend, bei mir sind ca. 95% der Lieferungen mit Livetracking. Deshalb aktualisiere ich auch aller 5 Minuten. Es reicht ja meistens zu sehen, dass die Stopps angezeigt werden.
                                    ich kann aktuell keine Bilder hochladen. Kann Euch aber die Werte sagen. Vielleicht können andere das ergänzen oder eigene Erfahrungen mit einbringen.
                                    Anzahl der Stopps sind die beiden Elemente wichtig:
                                    parcel.0.dhl.sendungen03.sendungsdetails.liveTracking.countdownTextKey (hier steht aber immer ein CD davor)
                                    Ich werde morgen mal schauen, welcher der beiden Werte wirklich die nächsten Stopps anzeigt.
                                    Die nächsten beiden Werte haben meist nur einen Dummy: die Uhrzeit 0:00 Uhr, aber manchmal waren da auch schon Uhrzeiten mit Zeitfenstern.
                                    parcel.0.dhl.sendungen03.sendungsdetails.zustellung.zustellzeitfensterVon
                                    Die Werte des liveTracking bleiben auch bestehen, wenn schon zugestellt wurde. D.h. es wird nicht mit 0 oder so überschrieben.
                                    jetzt ging doch der Upload.
                                    • B basty2
                                      tombox
                                      #737
                                      @basty2 Einfach den inhalt von
                                      parcel.0.dhl.json
                                      per pn
                                      • Ro75R Offline
                                        Ro75R Offline
                                        Ro75
                                        #738
                                        Moin. Zuerst, klasse Adapter. Ich habe heute den Parcel-Adapter von der Version 0.0.12 auf die Version 0.0.15 aktualisiert. Soweit alles gut. Allerdings bekomme ich heute eine Amazon-Sendung angezeigt, welche "verspätet" ist. Allerdings ist diese Sendung tatsächlich zugestellt (16.03.), nur in den Daten nicht.
                                              "id": "304-3xxxxxx-xxxxxxx",
                                              "name": "Türdichtung Türgummi universal für Backofen E-Herd kompatibel passend für AEG Electrolux Siemens Neff Miele Bosch Küppersbusch Günstig Ersatz",
                                              "status": "Unterwegs, aber verspätet",
                                              "detailedState": {
                                                "deviceType": "desktop",
                                                "isLexicalExceptionMessagePresent": true,
                                                "orderId": "304-xxxxxx-xxxxxxx",
                                                "shortStatus": "IN_TRANSIT",
                                                "promise": {
                                                  "secondaryPromiseIdentifier": "NONE",
                                                  "promiseMessage": "Unterwegs, aber verspätet"
                                                "isApp": false,
                                                "themeParameters": "o=304-3xxxxxx-xxxxxxx&s=DFL4rxxxx&i=kjkosqnqornwqr",
                                                "itemId": "kjkosqnqornwqr",
                                                "signInRedirectUrl": "/progress-tracker/package/ref=ppx_yo_dt_b_track_package?itemId=kjkosqnqornwqr&orderId=304-xxxxxx-xxxxxxx&_encoding=UTF8&shipmentId=DFL4rxxxx&disableCsd=missing-library&vt=YOUR_ORDERS",
                                                "isMfn": true,
                                                "shipmentId": "DFL4rcxxx",
                                                "keepSecondaryUntouched": true,
                                                "customerId": "A2M65VYxxxxxxx",
                                                "realm": "GBAmazon",
                                                "visitTrigger": "YOUR_ORDERS",
                                                "trackingId": ""
                                        Schon mal dickes Danke an Euch.
                                        • Ro75R Ro75
                                                "detailedState": {
                                                  "promise": {
                                                  "isApp": false,
                                                  "isMfn": true,
                                                  "trackingId": ""
                                          tombox
                                          #739
                                          @ro75 Da kann man nichts machen wenn Amazon die Zustellung nicht erfassen kann das passiert manchmal bei Briefsendungen
