  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 730.8k Aufrufe 117 Beobachtet
  • Horst BöttcherH Horst Böttcher
    @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
    @draexler
    cd /opt/iobroker/
    npm install canvas
    ich arbeite daran das es gefixt wird
    pi@raspberrypi:/opt/iobroker $ iobroker stop
    pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
    pi@raspberrypi:/opt/iobroker $ sudo npm install canvas
    > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
    node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
    gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/14.18.1"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
    gyp ERR! configure error
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
    gyp ERR! System Linux 5.10.17-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v14.18.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
    node-pre-gyp ERR! System Linux 5.10.17-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v14.18.1
    node-pre-gyp ERR! node-pre-gyp -v v1.0.6
    node-pre-gyp ERR! not ok
    npm WARN @rollup/plugin-inject@4.0.4 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN @rollup/pluginutils@3.1.0 requires a peer of rollup@^1.20.0||^2.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN rollup-plugin-polyfill-node@0.8.0 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.9.1 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.9.1 install script.
    npm ERR!     /root/.npm/_logs/2022-04-08T14_22_43_117Z-debug.log
    #729
    @horst-böttcher sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
    NICHT mit sudo hantieren an der Stelle.
    Stand aber auch offenbar so nicht in der Anleitung. Warum macht man das also dann doch?
    System auf Stand halten.
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Danach als user:
    cd /opt/iobroker
    npm install canvas
    Horst BöttcherH 1 Antwort Letzte Antwort
      sudo apt update
      sudo reboot
      Danach als user:
      cd /opt/iobroker
      npm install canvas
      Horst BöttcherH Offline
      Horst Böttcher
      #730
      ich hatte es vorher ohne sudo gemacht
      ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
        #731
        @horst-böttcher
        Hast du jetzt die Hausaufgaben erledigt? System auf Stand?
        cd /opt/iobroker
        npm ls canvas
        liefert?
        • T tombox
          @senior1418 ist gefixt
          senior1418
          #732
          ist gefixt
          herzlichen Dank ! Es funktioniert wieder .
          • T tombox
            @basty2 bräuchte die genaue objekte wo die information drin sind.
            Bei dpd muss erst auf die sendung geklickt werden damit man diese information sieht?
            basty2
            #733
            @tombox Ich wollte nach dem aktuellen Stand nachfragen. Bei mir funktioniert die Darstellung der voraussichtlichen Lieferung und der Anzahl der Stopps nur bei Amazon. Die Infos gibt es bspw. teilweise auch bei der DHL. Ich fände es klasse, wenn diese Infos auch bei den anderen Unternehmen im JSON landen würden.
            • B basty2
              tombox
              #734
              @basty2 Also wenn sie nicht im rohen JSON sind wird es schwer darauf zuzugreifen. Ich habe bisher keine DHL mit Stop gehabt
              DJMarc75D B 2 Antworten Letzte Antwort
              • T tombox
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #735
                @tombox
                Ich hatte schon einige Lieferungen von DHL welche im Livetracking auch die Stopps angezeigt haben - allerdings nur in der Ordnerstruktur. Ich habe aber davon abgesehen dies zu visualisieren oder anders zu verarbeiten da sich die Anzahl der Stopps und eigentlich alle Daten im Livetracking ja auch nur ändern wenn sich die Instanz die Daten holt. In meinem Fall alle 15 Minuten und zwischen den Intervallen sind deutliche Abweichungen im Vergleich zur APP von DHL zu erkennen.
                Habe im Moment leider keine Lieferung von DHL um auch mal zu sehen ob da was in der rohen JSON eingetragen wird.
                Lehrling seit 1975 !!!
                • T tombox
                  basty2
                  #736
                  @djmarc75 @tombox Spannend, bei mir sind ca. 95% der Lieferungen mit Livetracking. Deshalb aktualisiere ich auch aller 5 Minuten. Es reicht ja meistens zu sehen, dass die Stopps angezeigt werden.
                  ich kann aktuell keine Bilder hochladen. Kann Euch aber die Werte sagen. Vielleicht können andere das ergänzen oder eigene Erfahrungen mit einbringen.
                  Anzahl der Stopps sind die beiden Elemente wichtig:
                  parcel.0.dhl.sendungen03.sendungsdetails.liveTracking.countdownTextKey (hier steht aber immer ein CD davor)
                  Ich werde morgen mal schauen, welcher der beiden Werte wirklich die nächsten Stopps anzeigt.
                  Die nächsten beiden Werte haben meist nur einen Dummy: die Uhrzeit 0:00 Uhr, aber manchmal waren da auch schon Uhrzeiten mit Zeitfenstern.
                  parcel.0.dhl.sendungen03.sendungsdetails.zustellung.zustellzeitfensterVon
                  Die Werte des liveTracking bleiben auch bestehen, wenn schon zugestellt wurde. D.h. es wird nicht mit 0 oder so überschrieben.
                  jetzt ging doch der Upload.
                  • B basty2
                    tombox
                    #737
                    @basty2 Einfach den inhalt von
                    parcel.0.dhl.json
                    per pn
                    • Ro75R Offline
                      Ro75R Offline
                      Ro75
                      #738
                      Moin. Zuerst, klasse Adapter. Ich habe heute den Parcel-Adapter von der Version 0.0.12 auf die Version 0.0.15 aktualisiert. Soweit alles gut. Allerdings bekomme ich heute eine Amazon-Sendung angezeigt, welche "verspätet" ist. Allerdings ist diese Sendung tatsächlich zugestellt (16.03.), nur in den Daten nicht.
                            "id": "304-3xxxxxx-xxxxxxx",
                            "name": "Türdichtung Türgummi universal für Backofen E-Herd kompatibel passend für AEG Electrolux Siemens Neff Miele Bosch Küppersbusch Günstig Ersatz",
                            "status": "Unterwegs, aber verspätet",
                            "detailedState": {
                              "deviceType": "desktop",
                              "isLexicalExceptionMessagePresent": true,
                              "orderId": "304-xxxxxx-xxxxxxx",
                              "shortStatus": "IN_TRANSIT",
                              "promise": {
                                "secondaryPromiseIdentifier": "NONE",
                                "promiseMessage": "Unterwegs, aber verspätet"
                              "isApp": false,
                              "themeParameters": "o=304-3xxxxxx-xxxxxxx&s=DFL4rxxxx&i=kjkosqnqornwqr",
                              "itemId": "kjkosqnqornwqr",
                              "signInRedirectUrl": "/progress-tracker/package/ref=ppx_yo_dt_b_track_package?itemId=kjkosqnqornwqr&orderId=304-xxxxxx-xxxxxxx&_encoding=UTF8&shipmentId=DFL4rxxxx&disableCsd=missing-library&vt=YOUR_ORDERS",
                              "isMfn": true,
                              "shipmentId": "DFL4rcxxx",
                              "keepSecondaryUntouched": true,
                              "customerId": "A2M65VYxxxxxxx",
                              "realm": "GBAmazon",
                              "visitTrigger": "YOUR_ORDERS",
                              "trackingId": ""
                      Schon mal dickes Danke an Euch.
                      • Ro75R Ro75
                              "detailedState": {
                                "promise": {
                                "isApp": false,
                                "isMfn": true,
                                "trackingId": ""
                        tombox
                        #739
                        @ro75 Da kann man nichts machen wenn Amazon die Zustellung nicht erfassen kann das passiert manchmal bei Briefsendungen
                        • Ro75R Offline
                          Ro75R Offline
                          Ro75
                          schrieb am zuletzt editiert von Ro75
                          #740
                          Alles klar. Ich gehe davon aus, dass die Sendung dann irgendwann aus der Liste verschwindet. Danke.
                          • DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            #741
                            @basty2
                            Hast Du heute bei deinem Paket die Einträge im JSON verfolgen können ?
                            Ich bekomme am Samstag eins per DHL, werde dann auch mal das LiveTracking verfolgen.
                            • DJMarc75D DJMarc75
                              @basty2
                              tombox
                              #742
                              @djmarc75 Livetracking sollte in der aktuelle github version drin sein
                              B DJMarc75D 2 Antworten Letzte Antwort
                              • T tombox
                                basty2
                                schrieb am zuletzt editiert von basty2
                                #743
                                @tombox Hallo, ich hatte am Donnerstag das Paket bereits erhalten. Heute geht es bereits sehr gut. Aber die Anzahl der Stopps sind beim Namen hinterlegt. Wäre es möglich es hinter "In Zustellung" zu schreiben?
                                    "id": "xxxx",
                                    "name": "xxxx GmbH 4 Stopps",
                                    "status": "In Zustellung",
                                    "source": "DHL",
                                    "delivery_status": 40,
                                    "inDelivery": true,
                                    "direction": "ANKOMMEND"
                                • T tombox
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #744
                                  @tombox said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                  Funktioniert, danke dafür.
                                  Aber ich pflichte @basty2 bei. Besser wäre es tatsächlich hinter In Zustellung (vll mit einem Bindestrich) zu schreiben, da es so in der VIS über das Widget besser ersichtlich ist.
                                  • B basty2
                                        "id": "xxxx",
                                        "source": "DHL",
                                        "inDelivery": true,
                                    tombox
                                    #745
                                    @basty2 Ja muss natürlich in den status habe ich korrigiert
                                    • T tombox
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #746
                                      Hier tut sich so schnell, so viel, dass man gar nicht mehr hinterherkommt :)
                                      Ist in der Zwischenzeit was an den DPD Datenpunkten gemacht worden?
                                      Der JSON Eintrag ist alles , was ich da habe.
                                      Adapter Version 0.0.15
                                      • haselchenH haselchen
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #747
                                        @haselchen said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                        Ich denke in deiner DPD APP ist auch kein Paket mehr drin, weil sonst würde es im Adapter auftauchen.
                                        DPD löscht zugestellte Pakete nach ein paar Wochen automatisch aus dem Account.
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #748
                                          @djmarc75
                                          Jetzt habe ich unschönerweise null / null stehen in meiner VIS
