  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 730.6k Aufrufe 117 Beobachtet
    @draexler
    Aktuelle nodeJS-Version? nodeJS@14 ist empfohlen.
    Dann muss der Adapter neugebaut werden.
    draexlerD Offline
    draexlerD Offline
    draexler
    #719
    @thomas-braun.
    Die installierte Version ist die "v14.19.1"
    Also kann es ja daran nicht liegen?
    • draexlerD draexler
      Hi ich kann den Adapter nicht nutzen. Er startet erst gar nicht und bleibt rot.
      In den Logs steht folgendes:
      ost.SmartHomePi
      2022-04-05 10:03:47.561	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.SmartHomePi
      2022-04-05 10:03:47.561	error	Caught by controller[0]: }
      host.SmartHomePi
      2022-04-05 10:03:47.560	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.SmartHomePi
      2022-04-05 10:03:47.560	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
      host.SmartHomePi
      2022-04-05 10:03:47.560	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.SmartHomePi
      2022-04-05 10:03:47.560	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.SmartHomePi
      2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.SmartHomePi
      2022-04-05 10:03:47.559	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
      host.SmartHomePi
      2022-04-05 10:03:47.559	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.SmartHomePi
      2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.SmartHomePi
      2022-04-05 10:03:47.559	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.SmartHomePi
      2022-04-05 10:03:47.558	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.SmartHomePi
      2022-04-05 10:03:47.558	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      host.SmartHomePi
      2022-04-05 10:03:47.558	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.SmartHomePi
      2022-04-05 10:03:47.558	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      host.SmartHomePi
      2022-04-05 10:03:47.557	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      host.SmartHomePi
      2022-04-05 10:03:47.557	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.SmartHomePi
      2022-04-05 10:03:47.557	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
      host.SmartHomePi
      2022-04-05 10:03:47.556	error	Caught by controller[0]: ^
      host.SmartHomePi
      2022-04-05 10:03:47.556	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      host.SmartHomePi
      2022-04-05 10:03:47.555	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
      Neuinstallation, iOBroker Neustart hat nichts gebracht.
      tombox
      #720
      @draexler
      cd /opt/iobroker/
      npm install canvas
      ich arbeite daran das es gefixt wird
      draexlerD Horst BöttcherH 2 Antworten Letzte Antwort
        @thomas-braun.
        #721
        @draexler sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
        Kann auch 'schief' installiert sein. Die Versionsnummer alleine sagt nichts aus.
        • T tombox
          @gruter sollte behoben sein
          Gruter
          #722
          @tombox
          Ja, jetzt passt es wieder, Danke!
          • T tombox
            @draexler
            cd /opt/iobroker/
            npm install canvas
            draexlerD Offline
            draexlerD Offline
            draexler
            #723
            @tombox Das hat funktioniert. Danke ☺️
            • T tombox
              Hi ich habe ein neuen Adapter für Paketverfolgung geschrieben
              Anbieter:
              DHL Paket und Briefe
              DPD
              GLS
              UPS
              Hermes
              Amazon
              17Track
              **Steuerung über ***
              parcel.0.refresh Daten manuell updaten
              parcel.0.17tuser.register Paket id unter 17TUser registrieren
              Zum Installieren:
              https://github.com/TA2k/ioBroker.parcel
              Loginablauf
              DHL:
              • DHL App Login eingeben
              • SMS/EMail Code erhalten
              • In die Instanzeinstellungen eingeben und speichern
              Amazon:
              • Login eingeben
              • Wenn nötig vorab ein OTP token aus der 2FA App eingeben.
              DPD, GLS, UPS, Hermes, 17Track User:
              Login und Passwort eingeben
              17Track User maximal 40 Pakete gleichzeitig:
              https://buyer.17track.net/en/myshipment?ob=1
              17Track Api developer maximal 100 Anfragen dann muss bezahlt werden
              Hier ein Security Key beantragen und in die Einstellungen eingeben geht nur wenn man kein 17Track User ist
              https://user.17track.net/de/register?gb=%23maybe%3D16
              https://api.17track.net/en/admin/settings
              Telegram Benachrichtigung für Sendungen und Briefe
              In den Instanz Einstellung telegram.0 eingeben
              Vis
              delivery_status = {
              ERROR: -1,
              UNKNOWN: 5,
              IN_PREPARATION: 20,
              IN_TRANSIT: 30,
              OUT_FOR_DELIVERY: 40,
              DELIVERED: 1,
              Sendungen als Vis Table darstellen
              Datenpunkte alle Sendungen:
              parcel.0.allProviderJson
              Datenpunkte in Zustellung:
              parcel.0.inDelivery
              Widget: json Table
              Anleitung:
              https://www.smarthome-tricks.de/software-iobroker/iobroker-vis-json-table-widget-teil-1-basics/
              DHL Briefverfolgung in Vis anzeigen.
              Den Datenpunkt image ein String img src element zuordnen
              Den Datenpunkt image als HTML element in die vis einfügen mit folgendem Inhalt
              <img src="{parcel.0.dhl.briefe.oldAdvices01.advices01.image}" width="500px" />
              Diskussion Widget
              https://forum.iobroker.net/topic/53045/test-widget-vis-owl-v0-2-x-github
              senior1418
              schrieb am zuletzt editiert von senior1418
              #724
              @tombox
              ich kann leider nicht genau sagen seit wann aber seit einiger Zeit erhalte ich keine Meldungen über PushOver.
              pushover.3 2022-04-08 10:58:38.042	error	Error from Pushover: message cannot be blank
              pushover.3 2022-04-08 10:58:37.882	info	Send pushover notification: {"user":"","text":"📦 Amazon EU SARL\nZustellung erfolgreich","title":"Parcel","priority":0,"message":""}
              :Nachtrag v0.0.13
              • S senior1418
                @tombox
                :Nachtrag v0.0.13
                tombox
                #725
                @senior1418 ist gefixt
                • T tombox
                  Anbieter:
                  DPD
                  GLS
                  UPS
                  Hermes
                  Amazon
                  17Track
                  Zum Installieren:
                  Loginablauf
                  DHL:
                  Amazon:
                  • Login eingeben
                  Vis
                  delivery_status = {
                  ERROR: -1,
                  UNKNOWN: 5,
                  IN_PREPARATION: 20,
                  IN_TRANSIT: 30,
                  DELIVERED: 1,
                  parcel.0.inDelivery
                  Widget: json Table
                  Anleitung:
                  Diskussion Widget
                  Horst BöttcherH Offline
                  Horst Böttcher
                  #726
                  @tombox habe den adapter Installier und er bleibt rot
                  host.raspberrypi	2022-04-08 12:14:32.446	info	Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                  host.raspberrypi	2022-04-08 12:14:32.445	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.raspberrypi	2022-04-08 12:14:32.444	error	Caught by controller[0]: }
                  host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                  host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
                  host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                  host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                  host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                  host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                  host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
                  host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                  host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                  host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                  host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
                  host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                  host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                  host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                  host.raspberrypi	2022-04-08 12:14:32.436	error	Caught by controller[0]: was compiled against a different Node.js version using
                  host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                  host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: ^
                  host.raspberrypi	2022-04-08 12:14:32.434	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                  host.raspberrypi	2022-04-08 12:14:32.433	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
                  host.raspberrypi	2022-04-08 12:14:28.563	info	instance system.adapter.parcel.0 started with pid 2182
                  host.raspberrypi	2022-04-08 12:14:27.736	info	"system.adapter.parcel.0" enabled
                  ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                  • Horst BöttcherH Horst Böttcher
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #727
                    @horst-böttcher
                    https://forum.iobroker.net/post/787171
                    Lehrling seit 1975 !!!
                    • T tombox
                      @draexler
                      cd /opt/iobroker/
                      npm install canvas
                      Horst Böttcher
                      #728
                      @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      @draexler
                      cd /opt/iobroker/
                      npm install canvas
                      pi@raspberrypi:/opt/iobroker $ iobroker stop
                      pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
                      pi@raspberrypi:/opt/iobroker $ sudo npm install canvas
                      > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
                      > node-pre-gyp install --fallback-to-build
                      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                      node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                      gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/14.18.1"
                      gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                      gyp ERR! configure error
                      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                      gyp ERR! System Linux 5.10.17-v7l+
                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                      gyp ERR! cwd /opt/iobroker/node_modules/canvas
                      gyp ERR! node -v v14.18.1
                      gyp ERR! node-gyp -v v5.1.0
                      gyp ERR! not ok
                      node-pre-gyp ERR! build error
                      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
                      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                      node-pre-gyp ERR! System Linux 5.10.17-v7l+
                      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                      node-pre-gyp ERR! node -v v14.18.1
                      node-pre-gyp ERR! node-pre-gyp -v v1.0.6
                      node-pre-gyp ERR! not ok
                      npm WARN @rollup/plugin-inject@4.0.4 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN @rollup/pluginutils@3.1.0 requires a peer of rollup@^1.20.0||^2.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN rollup-plugin-polyfill-node@0.8.0 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! canvas@2.9.1 install: `node-pre-gyp install --fallback-to-build`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the canvas@2.9.1 install script.
                      npm ERR!     /root/.npm/_logs/2022-04-08T14_22_43_117Z-debug.log
                        @draexler
                        cd /opt/iobroker/
                        npm install canvas
                        gyp ERR! not ok
                        npm ERR! errno 1
                        npm ERR!
                        #729
                        @horst-böttcher sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                        NICHT mit sudo hantieren an der Stelle.
                        Stand aber auch offenbar so nicht in der Anleitung. Warum macht man das also dann doch?
                        System auf Stand halten.
                        sudo apt update
                        sudo apt full-upgrade
                        sudo reboot
                        Danach als user:
                        cd /opt/iobroker
                        npm install canvas
                        Horst BöttcherH 1 Antwort Letzte Antwort
                          sudo apt update
                          sudo reboot
                          Danach als user:
                          cd /opt/iobroker
                          npm install canvas
                          Horst Böttcher
                          #730
                          ich hatte es vorher ohne sudo gemacht
                            #731
                            @horst-böttcher
                            Hast du jetzt die Hausaufgaben erledigt? System auf Stand?
                            cd /opt/iobroker
                            npm ls canvas
                            liefert?
                            • T tombox
                              senior1418
                              #732
                              ist gefixt
                              herzlichen Dank ! Es funktioniert wieder .
                              • T tombox
                                @basty2 bräuchte die genaue objekte wo die information drin sind.
                                Bei dpd muss erst auf die sendung geklickt werden damit man diese information sieht?
                                basty2
                                #733
                                @tombox Ich wollte nach dem aktuellen Stand nachfragen. Bei mir funktioniert die Darstellung der voraussichtlichen Lieferung und der Anzahl der Stopps nur bei Amazon. Die Infos gibt es bspw. teilweise auch bei der DHL. Ich fände es klasse, wenn diese Infos auch bei den anderen Unternehmen im JSON landen würden.
                                • B basty2
                                  tombox
                                  #734
                                  @basty2 Also wenn sie nicht im rohen JSON sind wird es schwer darauf zuzugreifen. Ich habe bisher keine DHL mit Stop gehabt
                                  DJMarc75D B 2 Antworten Letzte Antwort
                                  • T tombox
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #735
                                    @tombox
                                    Ich hatte schon einige Lieferungen von DHL welche im Livetracking auch die Stopps angezeigt haben - allerdings nur in der Ordnerstruktur. Ich habe aber davon abgesehen dies zu visualisieren oder anders zu verarbeiten da sich die Anzahl der Stopps und eigentlich alle Daten im Livetracking ja auch nur ändern wenn sich die Instanz die Daten holt. In meinem Fall alle 15 Minuten und zwischen den Intervallen sind deutliche Abweichungen im Vergleich zur APP von DHL zu erkennen.
                                    Habe im Moment leider keine Lieferung von DHL um auch mal zu sehen ob da was in der rohen JSON eingetragen wird.
                                    • T tombox
                                      basty2
                                      #736
                                      @djmarc75 @tombox Spannend, bei mir sind ca. 95% der Lieferungen mit Livetracking. Deshalb aktualisiere ich auch aller 5 Minuten. Es reicht ja meistens zu sehen, dass die Stopps angezeigt werden.
                                      ich kann aktuell keine Bilder hochladen. Kann Euch aber die Werte sagen. Vielleicht können andere das ergänzen oder eigene Erfahrungen mit einbringen.
                                      Anzahl der Stopps sind die beiden Elemente wichtig:
                                      parcel.0.dhl.sendungen03.sendungsdetails.liveTracking.countdownTextKey (hier steht aber immer ein CD davor)
                                      Ich werde morgen mal schauen, welcher der beiden Werte wirklich die nächsten Stopps anzeigt.
                                      Die nächsten beiden Werte haben meist nur einen Dummy: die Uhrzeit 0:00 Uhr, aber manchmal waren da auch schon Uhrzeiten mit Zeitfenstern.
                                      parcel.0.dhl.sendungen03.sendungsdetails.zustellung.zustellzeitfensterVon
                                      Die Werte des liveTracking bleiben auch bestehen, wenn schon zugestellt wurde. D.h. es wird nicht mit 0 oder so überschrieben.
                                      jetzt ging doch der Upload.
                                      • B basty2
                                        tombox
                                        #737
                                        @basty2 Einfach den inhalt von
                                        parcel.0.dhl.json
                                        per pn
                                        • Ro75R Offline
                                          Ro75R Offline
                                          Ro75
                                          #738
                                          Moin. Zuerst, klasse Adapter. Ich habe heute den Parcel-Adapter von der Version 0.0.12 auf die Version 0.0.15 aktualisiert. Soweit alles gut. Allerdings bekomme ich heute eine Amazon-Sendung angezeigt, welche "verspätet" ist. Allerdings ist diese Sendung tatsächlich zugestellt (16.03.), nur in den Daten nicht.
                                                "id": "304-3xxxxxx-xxxxxxx",
                                                "name": "Türdichtung Türgummi universal für Backofen E-Herd kompatibel passend für AEG Electrolux Siemens Neff Miele Bosch Küppersbusch Günstig Ersatz",
                                                "status": "Unterwegs, aber verspätet",
                                                "detailedState": {
                                                  "deviceType": "desktop",
                                                  "isLexicalExceptionMessagePresent": true,
                                                  "orderId": "304-xxxxxx-xxxxxxx",
                                                  "shortStatus": "IN_TRANSIT",
                                                  "promise": {
                                                    "secondaryPromiseIdentifier": "NONE",
                                                    "promiseMessage": "Unterwegs, aber verspätet"
                                                  "isApp": false,
                                                  "themeParameters": "o=304-3xxxxxx-xxxxxxx&s=DFL4rxxxx&i=kjkosqnqornwqr",
                                                  "itemId": "kjkosqnqornwqr",
                                                  "signInRedirectUrl": "/progress-tracker/package/ref=ppx_yo_dt_b_track_package?itemId=kjkosqnqornwqr&orderId=304-xxxxxx-xxxxxxx&_encoding=UTF8&shipmentId=DFL4rxxxx&disableCsd=missing-library&vt=YOUR_ORDERS",
                                                  "isMfn": true,
                                                  "shipmentId": "DFL4rcxxx",
                                                  "keepSecondaryUntouched": true,
                                                  "customerId": "A2M65VYxxxxxxx",
                                                  "realm": "GBAmazon",
                                                  "visitTrigger": "YOUR_ORDERS",
                                                  "trackingId": ""
                                          Schon mal dickes Danke an Euch.
