  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 730.2k Aufrufe 117 Beobachtet
  • draexlerD draexler
    Hi ich kann den Adapter nicht nutzen. Er startet erst gar nicht und bleibt rot.
    In den Logs steht folgendes:
    ost.SmartHomePi
    2022-04-05 10:03:47.561	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.SmartHomePi
    2022-04-05 10:03:47.561	error	Caught by controller[0]: }
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    host.SmartHomePi
    2022-04-05 10:03:47.556	error	Caught by controller[0]: ^
    host.SmartHomePi
    2022-04-05 10:03:47.556	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.SmartHomePi
    2022-04-05 10:03:47.555	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
    Neuinstallation, iOBroker Neustart hat nichts gebracht.
    #718
    @draexler
    Aktuelle nodeJS-Version? nodeJS@14 ist empfohlen.
    Dann muss der Adapter neugebaut werden.
    draexlerD 1 Antwort Letzte Antwort
      @draexler
      draexlerD Offline
      draexlerD Offline
      draexler
      #719
      @thomas-braun.
      Die installierte Version ist die "v14.19.1"
      Also kann es ja daran nicht liegen?
        ost.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        host.SmartHomePi
        tombox
        #720
        @draexler
        cd /opt/iobroker/
        npm install canvas
        ich arbeite daran das es gefixt wird
        draexlerD Horst BöttcherH 2 Antworten Letzte Antwort
          @thomas-braun.
          #721
          @draexler sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
          Kann auch 'schief' installiert sein. Die Versionsnummer alleine sagt nichts aus.
          • T tombox
            @gruter sollte behoben sein
            Gruter
            #722
            @tombox
            Ja, jetzt passt es wieder, Danke!
            • T tombox
              @draexler
              cd /opt/iobroker/
              npm install canvas
              draexlerD Offline
              draexlerD Offline
              draexler
              #723
              @tombox Das hat funktioniert. Danke ☺️
              • T tombox
                Hi ich habe ein neuen Adapter für Paketverfolgung geschrieben
                Anbieter:
                DHL Paket und Briefe
                DPD
                GLS
                UPS
                Hermes
                Amazon
                17Track
                **Steuerung über ***
                parcel.0.refresh Daten manuell updaten
                parcel.0.17tuser.register Paket id unter 17TUser registrieren
                Zum Installieren:
                https://github.com/TA2k/ioBroker.parcel
                Loginablauf
                DHL:
                • DHL App Login eingeben
                • SMS/EMail Code erhalten
                • In die Instanzeinstellungen eingeben und speichern
                Amazon:
                • Login eingeben
                • Wenn nötig vorab ein OTP token aus der 2FA App eingeben.
                DPD, GLS, UPS, Hermes, 17Track User:
                Login und Passwort eingeben
                17Track User maximal 40 Pakete gleichzeitig:
                https://buyer.17track.net/en/myshipment?ob=1
                17Track Api developer maximal 100 Anfragen dann muss bezahlt werden
                Hier ein Security Key beantragen und in die Einstellungen eingeben geht nur wenn man kein 17Track User ist
                https://user.17track.net/de/register?gb=%23maybe%3D16
                https://api.17track.net/en/admin/settings
                Telegram Benachrichtigung für Sendungen und Briefe
                In den Instanz Einstellung telegram.0 eingeben
                Vis
                delivery_status = {
                ERROR: -1,
                UNKNOWN: 5,
                IN_PREPARATION: 20,
                IN_TRANSIT: 30,
                OUT_FOR_DELIVERY: 40,
                DELIVERED: 1,
                Sendungen als Vis Table darstellen
                Datenpunkte alle Sendungen:
                parcel.0.allProviderJson
                Datenpunkte in Zustellung:
                parcel.0.inDelivery
                Widget: json Table
                Anleitung:
                https://www.smarthome-tricks.de/software-iobroker/iobroker-vis-json-table-widget-teil-1-basics/
                DHL Briefverfolgung in Vis anzeigen.
                Den Datenpunkt image ein String img src element zuordnen
                Den Datenpunkt image als HTML element in die vis einfügen mit folgendem Inhalt
                <img src="{parcel.0.dhl.briefe.oldAdvices01.advices01.image}" width="500px" />
                Diskussion Widget
                https://forum.iobroker.net/topic/53045/test-widget-vis-owl-v0-2-x-github
                senior1418
                schrieb am zuletzt editiert von senior1418
                #724
                @tombox
                ich kann leider nicht genau sagen seit wann aber seit einiger Zeit erhalte ich keine Meldungen über PushOver.
                pushover.3 2022-04-08 10:58:38.042	error	Error from Pushover: message cannot be blank
                pushover.3 2022-04-08 10:58:37.882	info	Send pushover notification: {"user":"","text":"📦 Amazon EU SARL\nZustellung erfolgreich","title":"Parcel","priority":0,"message":""}
                :Nachtrag v0.0.13
                • S senior1418
                  @tombox
                  :Nachtrag v0.0.13
                  tombox
                  #725
                  @senior1418 ist gefixt
                  • T tombox
                    Anbieter:
                    DPD
                    GLS
                    UPS
                    Hermes
                    Amazon
                    17Track
                    Zum Installieren:
                    Loginablauf
                    DHL:
                    Amazon:
                    • Login eingeben
                    Vis
                    delivery_status = {
                    ERROR: -1,
                    UNKNOWN: 5,
                    IN_PREPARATION: 20,
                    IN_TRANSIT: 30,
                    DELIVERED: 1,
                    parcel.0.inDelivery
                    Widget: json Table
                    Anleitung:
                    Diskussion Widget
                    Horst BöttcherH Offline
                    Horst Böttcher
                    #726
                    @tombox habe den adapter Installier und er bleibt rot
                    host.raspberrypi	2022-04-08 12:14:32.446	info	Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                    host.raspberrypi	2022-04-08 12:14:32.445	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi	2022-04-08 12:14:32.444	error	Caught by controller[0]: }
                    host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                    host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
                    host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                    host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                    host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                    host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                    host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
                    host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                    host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                    host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                    host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
                    host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                    host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                    host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                    host.raspberrypi	2022-04-08 12:14:32.436	error	Caught by controller[0]: was compiled against a different Node.js version using
                    host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                    host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: ^
                    host.raspberrypi	2022-04-08 12:14:32.434	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                    host.raspberrypi	2022-04-08 12:14:32.433	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
                    host.raspberrypi	2022-04-08 12:14:28.563	info	instance system.adapter.parcel.0 started with pid 2182
                    host.raspberrypi	2022-04-08 12:14:27.736	info	"system.adapter.parcel.0" enabled
                    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                    • Horst BöttcherH Horst Böttcher
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #727
                      @horst-böttcher
                      https://forum.iobroker.net/post/787171
                      Lehrling seit 1975 !!!
                      • T tombox
                        @draexler
                        cd /opt/iobroker/
                        npm install canvas
                        Horst Böttcher
                        #728
                        @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                        @draexler
                        cd /opt/iobroker/
                        npm install canvas
                        pi@raspberrypi:/opt/iobroker $ iobroker stop
                        pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
                        pi@raspberrypi:/opt/iobroker $ sudo npm install canvas
                        > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
                        > node-pre-gyp install --fallback-to-build
                        node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                        node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                        gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/14.18.1"
                        gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                        gyp ERR! configure error
                        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                        gyp ERR! System Linux 5.10.17-v7l+
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                        gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        gyp ERR! node -v v14.18.1
                        gyp ERR! node-gyp -v v5.1.0
                        gyp ERR! not ok
                        node-pre-gyp ERR! build error
                        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
                        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                        node-pre-gyp ERR! System Linux 5.10.17-v7l+
                        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        node-pre-gyp ERR! node -v v14.18.1
                        node-pre-gyp ERR! node-pre-gyp -v v1.0.6
                        node-pre-gyp ERR! not ok
                        npm WARN @rollup/plugin-inject@4.0.4 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN @rollup/pluginutils@3.1.0 requires a peer of rollup@^1.20.0||^2.0.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN rollup-plugin-polyfill-node@0.8.0 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! canvas@2.9.1 install: `node-pre-gyp install --fallback-to-build`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the canvas@2.9.1 install script.
                        npm ERR!     /root/.npm/_logs/2022-04-08T14_22_43_117Z-debug.log
                          @draexler
                          cd /opt/iobroker/
                          npm install canvas
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          #729
                          @horst-böttcher sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                          NICHT mit sudo hantieren an der Stelle.
                          Stand aber auch offenbar so nicht in der Anleitung. Warum macht man das also dann doch?
                          System auf Stand halten.
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                          Danach als user:
                          cd /opt/iobroker
                          npm install canvas
                          Horst BöttcherH 1 Antwort Letzte Antwort
                            sudo apt update
                            sudo reboot
                            Danach als user:
                            cd /opt/iobroker
                            npm install canvas
                            Horst Böttcher
                            #730
                            ich hatte es vorher ohne sudo gemacht
                              #731
                              @horst-böttcher
                              Hast du jetzt die Hausaufgaben erledigt? System auf Stand?
                              cd /opt/iobroker
                              npm ls canvas
                              liefert?
                              • T tombox
                                senior1418
                                #732
                                ist gefixt
                                herzlichen Dank ! Es funktioniert wieder .
                                • T tombox
                                  @basty2 bräuchte die genaue objekte wo die information drin sind.
                                  Bei dpd muss erst auf die sendung geklickt werden damit man diese information sieht?
                                  basty2
                                  #733
                                  @tombox Ich wollte nach dem aktuellen Stand nachfragen. Bei mir funktioniert die Darstellung der voraussichtlichen Lieferung und der Anzahl der Stopps nur bei Amazon. Die Infos gibt es bspw. teilweise auch bei der DHL. Ich fände es klasse, wenn diese Infos auch bei den anderen Unternehmen im JSON landen würden.
                                  • B basty2
                                    tombox
                                    #734
                                    @basty2 Also wenn sie nicht im rohen JSON sind wird es schwer darauf zuzugreifen. Ich habe bisher keine DHL mit Stop gehabt
                                    DJMarc75D B 2 Antworten Letzte Antwort
                                    • T tombox
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #735
                                      @tombox
                                      Ich hatte schon einige Lieferungen von DHL welche im Livetracking auch die Stopps angezeigt haben - allerdings nur in der Ordnerstruktur. Ich habe aber davon abgesehen dies zu visualisieren oder anders zu verarbeiten da sich die Anzahl der Stopps und eigentlich alle Daten im Livetracking ja auch nur ändern wenn sich die Instanz die Daten holt. In meinem Fall alle 15 Minuten und zwischen den Intervallen sind deutliche Abweichungen im Vergleich zur APP von DHL zu erkennen.
                                      Habe im Moment leider keine Lieferung von DHL um auch mal zu sehen ob da was in der rohen JSON eingetragen wird.
                                      • T tombox
                                        basty2
                                        #736
                                        @djmarc75 @tombox Spannend, bei mir sind ca. 95% der Lieferungen mit Livetracking. Deshalb aktualisiere ich auch aller 5 Minuten. Es reicht ja meistens zu sehen, dass die Stopps angezeigt werden.
                                        ich kann aktuell keine Bilder hochladen. Kann Euch aber die Werte sagen. Vielleicht können andere das ergänzen oder eigene Erfahrungen mit einbringen.
                                        Anzahl der Stopps sind die beiden Elemente wichtig:
                                        parcel.0.dhl.sendungen03.sendungsdetails.liveTracking.countdownTextKey (hier steht aber immer ein CD davor)
                                        Ich werde morgen mal schauen, welcher der beiden Werte wirklich die nächsten Stopps anzeigt.
                                        Die nächsten beiden Werte haben meist nur einen Dummy: die Uhrzeit 0:00 Uhr, aber manchmal waren da auch schon Uhrzeiten mit Zeitfenstern.
                                        parcel.0.dhl.sendungen03.sendungsdetails.zustellung.zustellzeitfensterVon
                                        Die Werte des liveTracking bleiben auch bestehen, wenn schon zugestellt wurde. D.h. es wird nicht mit 0 oder so überschrieben.
                                        jetzt ging doch der Upload.
                                        • B basty2
                                          tombox
                                          #737
                                          @basty2 Einfach den inhalt von
                                          parcel.0.dhl.json
                                          per pn
