  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 730.6k Aufrufe 117 Beobachtet
  • T tombox
    @gruter sollte behoben sein
    draexlerD Offline
    draexlerD Offline
    draexler
    #717
    Hi ich kann den Adapter nicht nutzen. Er startet erst gar nicht und bleibt rot.
    In den Logs steht folgendes:
    ost.SmartHomePi
    2022-04-05 10:03:47.561	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.SmartHomePi
    2022-04-05 10:03:47.561	error	Caught by controller[0]: }
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.SmartHomePi
    2022-04-05 10:03:47.560	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.SmartHomePi
    2022-04-05 10:03:47.559	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.SmartHomePi
    2022-04-05 10:03:47.558	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.SmartHomePi
    2022-04-05 10:03:47.557	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    host.SmartHomePi
    2022-04-05 10:03:47.556	error	Caught by controller[0]: ^
    host.SmartHomePi
    2022-04-05 10:03:47.556	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.SmartHomePi
    2022-04-05 10:03:47.555	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
    Neuinstallation, iOBroker Neustart hat nichts gebracht.
    Thomas BraunT T 2 Antworten Letzte Antwort
    • draexlerD draexler
      ost.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      host.SmartHomePi
      #718
      @draexler
      Aktuelle nodeJS-Version? nodeJS@14 ist empfohlen.
      Dann muss der Adapter neugebaut werden.
      draexlerD 1 Antwort Letzte Antwort
        @draexler
        draexlerD Offline
        draexlerD Offline
        draexler
        #719
        @thomas-braun.
        Die installierte Version ist die "v14.19.1"
        Also kann es ja daran nicht liegen?
          ost.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          host.SmartHomePi
          tombox
          #720
          @draexler
          cd /opt/iobroker/
          npm install canvas
          ich arbeite daran das es gefixt wird
          draexlerD Horst BöttcherH 2 Antworten Letzte Antwort
            @thomas-braun.
            #721
            @draexler sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
            Kann auch 'schief' installiert sein. Die Versionsnummer alleine sagt nichts aus.
            • T tombox
              Gruter
              #722
              @tombox
              Ja, jetzt passt es wieder, Danke!
              • T tombox
                @draexler
                cd /opt/iobroker/
                npm install canvas
                draexlerD Offline
                draexlerD Offline
                draexler
                #723
                @tombox Das hat funktioniert. Danke ☺️
                • T tombox
                  Hi ich habe ein neuen Adapter für Paketverfolgung geschrieben
                  Anbieter:
                  DHL Paket und Briefe
                  DPD
                  GLS
                  UPS
                  Hermes
                  Amazon
                  17Track
                  **Steuerung über ***
                  parcel.0.refresh Daten manuell updaten
                  parcel.0.17tuser.register Paket id unter 17TUser registrieren
                  Zum Installieren:
                  https://github.com/TA2k/ioBroker.parcel
                  Loginablauf
                  DHL:
                  • DHL App Login eingeben
                  • SMS/EMail Code erhalten
                  • In die Instanzeinstellungen eingeben und speichern
                  Amazon:
                  • Login eingeben
                  • Wenn nötig vorab ein OTP token aus der 2FA App eingeben.
                  DPD, GLS, UPS, Hermes, 17Track User:
                  Login und Passwort eingeben
                  17Track User maximal 40 Pakete gleichzeitig:
                  https://buyer.17track.net/en/myshipment?ob=1
                  17Track Api developer maximal 100 Anfragen dann muss bezahlt werden
                  Hier ein Security Key beantragen und in die Einstellungen eingeben geht nur wenn man kein 17Track User ist
                  https://user.17track.net/de/register?gb=%23maybe%3D16
                  https://api.17track.net/en/admin/settings
                  Telegram Benachrichtigung für Sendungen und Briefe
                  In den Instanz Einstellung telegram.0 eingeben
                  Vis
                  delivery_status = {
                  ERROR: -1,
                  UNKNOWN: 5,
                  IN_PREPARATION: 20,
                  IN_TRANSIT: 30,
                  OUT_FOR_DELIVERY: 40,
                  DELIVERED: 1,
                  Sendungen als Vis Table darstellen
                  Datenpunkte alle Sendungen:
                  parcel.0.allProviderJson
                  Datenpunkte in Zustellung:
                  parcel.0.inDelivery
                  Widget: json Table
                  Anleitung:
                  https://www.smarthome-tricks.de/software-iobroker/iobroker-vis-json-table-widget-teil-1-basics/
                  DHL Briefverfolgung in Vis anzeigen.
                  Den Datenpunkt image ein String img src element zuordnen
                  Den Datenpunkt image als HTML element in die vis einfügen mit folgendem Inhalt
                  <img src="{parcel.0.dhl.briefe.oldAdvices01.advices01.image}" width="500px" />
                  Diskussion Widget
                  https://forum.iobroker.net/topic/53045/test-widget-vis-owl-v0-2-x-github
                  senior1418
                  schrieb am zuletzt editiert von senior1418
                  #724
                  @tombox
                  ich kann leider nicht genau sagen seit wann aber seit einiger Zeit erhalte ich keine Meldungen über PushOver.
                  pushover.3 2022-04-08 10:58:38.042	error	Error from Pushover: message cannot be blank
                  pushover.3 2022-04-08 10:58:37.882	info	Send pushover notification: {"user":"","text":"📦 Amazon EU SARL\nZustellung erfolgreich","title":"Parcel","priority":0,"message":""}
                  :Nachtrag v0.0.13
                  • S senior1418
                    @tombox
                    :Nachtrag v0.0.13
                    tombox
                    #725
                    @senior1418 ist gefixt
                    • T tombox
                      Anbieter:
                      DPD
                      GLS
                      UPS
                      Hermes
                      Amazon
                      17Track
                      Zum Installieren:
                      Loginablauf
                      DHL:
                      Amazon:
                      • Login eingeben
                      Vis
                      delivery_status = {
                      ERROR: -1,
                      UNKNOWN: 5,
                      IN_PREPARATION: 20,
                      IN_TRANSIT: 30,
                      DELIVERED: 1,
                      parcel.0.inDelivery
                      Widget: json Table
                      Anleitung:
                      Diskussion Widget
                      Horst BöttcherH Offline
                      Horst Böttcher
                      #726
                      @tombox habe den adapter Installier und er bleibt rot
                      host.raspberrypi	2022-04-08 12:14:32.446	info	Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                      host.raspberrypi	2022-04-08 12:14:32.445	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi	2022-04-08 12:14:32.444	error	Caught by controller[0]: }
                      host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                      host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
                      host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                      host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                      host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                      host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
                      host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                      host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                      host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
                      host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                      host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
                      host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                      host.raspberrypi	2022-04-08 12:14:32.436	error	Caught by controller[0]: was compiled against a different Node.js version using
                      host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                      host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: ^
                      host.raspberrypi	2022-04-08 12:14:32.434	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                      host.raspberrypi	2022-04-08 12:14:32.433	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
                      host.raspberrypi	2022-04-08 12:14:28.563	info	instance system.adapter.parcel.0 started with pid 2182
                      host.raspberrypi	2022-04-08 12:14:27.736	info	"system.adapter.parcel.0" enabled
                      ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                      • Horst BöttcherH Horst Böttcher
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #727
                        @horst-böttcher
                        https://forum.iobroker.net/post/787171
                        Lehrling seit 1975 !!!
                        • T tombox
                          @draexler
                          cd /opt/iobroker/
                          npm install canvas
                          Horst Böttcher
                          #728
                          @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                          @draexler
                          cd /opt/iobroker/
                          npm install canvas
                          pi@raspberrypi:/opt/iobroker $ iobroker stop
                          pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
                          pi@raspberrypi:/opt/iobroker $ sudo npm install canvas
                          > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
                          > node-pre-gyp install --fallback-to-build
                          node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                          node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                          gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/14.18.1"
                          gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                          gyp ERR! configure error
                          gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                          gyp ERR! System Linux 5.10.17-v7l+
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                          gyp ERR! cwd /opt/iobroker/node_modules/canvas
                          gyp ERR! node -v v14.18.1
                          gyp ERR! node-gyp -v v5.1.0
                          gyp ERR! not ok
                          node-pre-gyp ERR! build error
                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
                          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                          node-pre-gyp ERR! System Linux 5.10.17-v7l+
                          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                          node-pre-gyp ERR! node -v v14.18.1
                          node-pre-gyp ERR! node-pre-gyp -v v1.0.6
                          node-pre-gyp ERR! not ok
                          npm WARN @rollup/plugin-inject@4.0.4 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                          npm WARN @rollup/pluginutils@3.1.0 requires a peer of rollup@^1.20.0||^2.0.0 but none is installed. You must install peer dependencies yourself.
                          npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                          npm WARN rollup-plugin-polyfill-node@0.8.0 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! canvas@2.9.1 install: `node-pre-gyp install --fallback-to-build`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the canvas@2.9.1 install script.
                          npm ERR!     /root/.npm/_logs/2022-04-08T14_22_43_117Z-debug.log
                            @draexler
                            cd /opt/iobroker/
                            npm install canvas
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            #729
                            @horst-böttcher sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                            NICHT mit sudo hantieren an der Stelle.
                            Stand aber auch offenbar so nicht in der Anleitung. Warum macht man das also dann doch?
                            System auf Stand halten.
                            sudo apt update
                            sudo apt full-upgrade
                            sudo reboot
                            Danach als user:
                            cd /opt/iobroker
                            npm install canvas
                            Horst BöttcherH 1 Antwort Letzte Antwort
                              sudo apt update
                              sudo reboot
                              Danach als user:
                              cd /opt/iobroker
                              npm install canvas
                              Horst Böttcher
                              #730
                              ich hatte es vorher ohne sudo gemacht
                                #731
                                @horst-böttcher
                                Hast du jetzt die Hausaufgaben erledigt? System auf Stand?
                                cd /opt/iobroker
                                npm ls canvas
                                liefert?
                                • T tombox
                                  senior1418
                                  #732
                                  ist gefixt
                                  herzlichen Dank ! Es funktioniert wieder .
                                  • T tombox
                                    @basty2 bräuchte die genaue objekte wo die information drin sind.
                                    Bei dpd muss erst auf die sendung geklickt werden damit man diese information sieht?
                                    basty2
                                    #733
                                    @tombox Ich wollte nach dem aktuellen Stand nachfragen. Bei mir funktioniert die Darstellung der voraussichtlichen Lieferung und der Anzahl der Stopps nur bei Amazon. Die Infos gibt es bspw. teilweise auch bei der DHL. Ich fände es klasse, wenn diese Infos auch bei den anderen Unternehmen im JSON landen würden.
                                    • B basty2
                                      tombox
                                      #734
                                      @basty2 Also wenn sie nicht im rohen JSON sind wird es schwer darauf zuzugreifen. Ich habe bisher keine DHL mit Stop gehabt
                                      DJMarc75D B 2 Antworten Letzte Antwort
                                      • T tombox
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #735
                                        @tombox
                                        Ich hatte schon einige Lieferungen von DHL welche im Livetracking auch die Stopps angezeigt haben - allerdings nur in der Ordnerstruktur. Ich habe aber davon abgesehen dies zu visualisieren oder anders zu verarbeiten da sich die Anzahl der Stopps und eigentlich alle Daten im Livetracking ja auch nur ändern wenn sich die Instanz die Daten holt. In meinem Fall alle 15 Minuten und zwischen den Intervallen sind deutliche Abweichungen im Vergleich zur APP von DHL zu erkennen.
                                        Habe im Moment leider keine Lieferung von DHL um auch mal zu sehen ob da was in der rohen JSON eingetragen wird.
                                        • T tombox
                                          basty2
                                          #736
                                          @djmarc75 @tombox Spannend, bei mir sind ca. 95% der Lieferungen mit Livetracking. Deshalb aktualisiere ich auch aller 5 Minuten. Es reicht ja meistens zu sehen, dass die Stopps angezeigt werden.
                                          ich kann aktuell keine Bilder hochladen. Kann Euch aber die Werte sagen. Vielleicht können andere das ergänzen oder eigene Erfahrungen mit einbringen.
                                          Anzahl der Stopps sind die beiden Elemente wichtig:
                                          parcel.0.dhl.sendungen03.sendungsdetails.liveTracking.countdownTextKey (hier steht aber immer ein CD davor)
                                          Ich werde morgen mal schauen, welcher der beiden Werte wirklich die nächsten Stopps anzeigt.
                                          Die nächsten beiden Werte haben meist nur einen Dummy: die Uhrzeit 0:00 Uhr, aber manchmal waren da auch schon Uhrzeiten mit Zeitfenstern.
                                          parcel.0.dhl.sendungen03.sendungsdetails.zustellung.zustellzeitfensterVon
                                          Die Werte des liveTracking bleiben auch bestehen, wenn schon zugestellt wurde. D.h. es wird nicht mit 0 oder so überschrieben.
                                          jetzt ging doch der Upload.
