  4. js-controller läuft auf Volllast
    apollon77A
42 Beiträge 6 Kommentatoren 4.9k Aufrufe 2 Beobachtet
  • T Th3RockYeah
    @th3rockyeah
    Teil 2
    es ist fortführend...
    2022-03-21 10:03:43.856 - info: javascript.0 (12683) received all objects
    2022-03-21 10:03:45.047 - info: javascript.0 (12683) received all states
    2022-03-21 10:03:45.386 - info: javascript.0 (12683) Start javascript script.js.common.BatteryCheck
    2022-03-21 10:03:45.451 - info: host.raspberrypi instance system.adapter.radar2.0 started with pid 12924
    2022-03-21 10:03:45.514 - info: javascript.0 (12683) script.js.common.BatteryCheck: starting Batterieüberwachung V.1.8.5
    2022-03-21 10:03:45.520 - info: javascript.0 (12683) script.js.common.BatteryCheck: registered 0 subscriptions and 0 schedules
    2022-03-21 10:03:45.603 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12930
    2022-03-21 10:03:45.683 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 12937
    2022-03-21 10:03:45.533 - info: javascript.0 (12683) Start javascript script.js.common.BewegungsmelderV2
    2022-03-21 10:03:45.561 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: *** Bewegungsmelder-Script gestartet *** Folgende Bewegungsmelder werden überwacht: BadGaeste, SchlafzimmerNew, Laundry, BadFirstFloor, FirstFloorLightNew, FirstFloorLightTom, StairsToFirstFloor, BeerCellar, ToolCellar, CellarFloor, StepToCellarFloor, AlarmTest3
    2022-03-21 10:03:45.567 - info: javascript.0 (12683) script.js.common.BewegungsmelderV2: registered 12 subscriptions and 0 schedules
    2022-03-21 10:03:45.569 - info: javascript.0 (12683) Start javascript script.js.common.CommonMix
    2022-03-21 10:03:45.577 - info: javascript.0 (12683) script.js.common.CommonMix: registered 8 subscriptions and 0 schedules
    2022-03-21 10:03:45.578 - info: javascript.0 (12683) Start javascript script.js.common.FritzBox
    2022-03-21 10:03:45.584 - info: javascript.0 (12683) script.js.common.FritzBox: registered 1 subscription and 0 schedules
    2022-03-21 10:03:45.585 - info: javascript.0 (12683) Start javascript script.js.common.LeavingHouse
    2022-03-21 10:03:45.608 - info: javascript.0 (12683) script.js.common.LeavingHouse: registered 2 subscriptions and 0 schedules
    2022-03-21 10:03:45.610 - info: javascript.0 (12683) Start javascript script.js.common.OpenDoorsWindows
    2022-03-21 10:03:45.659 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: registered 0 subscriptions and 0 schedules
    2022-03-21 10:03:45.660 - info: javascript.0 (12683) Start javascript script.js.common.Shellys
    2022-03-21 10:03:45.680 - info: javascript.0 (12683) script.js.common.Shellys: registered 9 subscriptions and 0 schedules
    2022-03-21 10:03:45.807 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 12944
    2022-03-21 10:03:45.872 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 12946
    2022-03-21 10:03:45.979 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 12957
    2022-03-21 10:03:46.064 - info: host.raspberrypi instance system.adapter.info.0 started with pid 12961
    2022-03-21 10:03:46.120 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 12966
    2022-03-21 10:03:46.357 - info: javascript.0 (12683) script.js.common.OpenDoorsWindows: Alle Fenster geschlossen.
    2022-03-21 10:03:59.998 - warn: discovery.0 (12937) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:00.427 - warn: text2command.0 (12966) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:00.527 - warn: radar2.0 (12924) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:00.805 - warn: iot.0 (12946) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:00.827 - warn: backitup.0 (12944) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:00.965 - warn: cloud.0 (12957) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:02.625 - warn: info.0 (12961) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:02.633 - warn: zigbee.0 (12930) slow connection to objects DB. Still waiting ...
    2022-03-21 10:04:54.290 - info: feiertage.0 (12747) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:04:58.146 - info: feiertage.0 (12747) Next holiday: Karfreitag is in 25 days on 15.04.2022
    2022-03-21 10:04:58.476 - info: tr-064.0 (12889) starting. Version 4.2.15 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:04:58.744 - info: feiertage.0 (12747) adapter feiertage objects written
    2022-03-21 10:04:59.180 - info: schoolfree.0 (12878) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.schoolfree, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:04:59.320 - info: feiertage.0 (12747) Terminated (NO_ERROR): Without reason
    2022-03-21 10:04:59.385 - info: shelly.0 (12768) Starting in CoAP mode.
    2022-03-21 10:04:59.630 - info: shelly.0 (12768) [CoAP] Listening for packets in the network
    2022-03-21 10:04:59.709 - info: shelly.1 (12777) Starting in MQTT mode. Listening on Y.X.C..31:1882
    2022-03-21 10:04:59.767 - info: radar2.0 (12924) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:04:59.713 - warn: schoolfree.0 (12878) schoolfree set state error: TypeError: Cannot read property 'name' of undefined
    2022-03-21 10:05:00.167 - info: shelly.0 (12768) [CoAP] Device Y.X.C..28 (shelly1pm / shelly1pm-F27634 / SHSW-PM#F27634#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:00.437 - info: schoolfree.0 (12878) schoolfree request done
    2022-03-21 10:05:00.485 - info: shelly.0 (12768) [CoAP] Device Y.X.C..47 (shellydimmer / shellydimmer-D463D3 / SHDM-1#D463D3#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:00.754 - info: radar2.0 (12924) radar2 initialization started...
    2022-03-21 10:05:00.800 - info: radar2.0 (12924) Will use l2Ping for BT scans.
    2022-03-21 10:05:00.893 - info: radar2.0 (12924) Will run hcitool-mode and not noble on device []!
    2022-03-21 10:05:01.103 - info: host.raspberrypi instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
    2022-03-21 10:05:01.190 - info: radar2.0 (12924) arp-scan will use the following interfaces: [ 'eth0' ]
    2022-03-21 10:05:01.217 - info: radar2.0 (12924) Connected with '0.0.0.0' for DHCP Scan
    2022-03-21 10:05:02.201 - info: text2command.0 (12966) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:05:02.412 - info: discovery.0 (12937) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:05:02.476 - info: cloud.0 (12957) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:05:02.660 - info: zigbee.0 (12930) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:05:03.212 - info: backitup.0 (12944) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:05:03.240 - info: cloud.0 (12957) Connecting with https://iobroker.pro:10555 with "@pro_lars@lars-keller.net_a56c8fe0-59a6-11ea-bbb9-a3d45e2d176f"
    2022-03-21 10:05:03.339 - info: iot.0 (12946) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:05:03.452 - info: backitup.0 (12944) [iobroker] backup was activated at 02:53 every 1 day(s)
    2022-03-21 10:05:03.517 - info: iot.0 (12946) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-03-21 10:05:02.984 - info: zigbee.0 (12930) Starting Zigbee npm ...
    2022-03-21 10:05:03.929 - info: shelly.0 (12768) [CoAP] Device Y.X.C..36 (shelly1 / shelly1-98F4ABF3CF6C / SHSW-1#98F4ABF3CF6C#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:04.474 - info: iot.0 (12946) Connection changed: connect
    2022-03-21 10:05:04.982 - info: zigbee.0 (12930) Installed Version: ioBroker/ioBroker.zigbee
    2022-03-21 10:05:05.086 - info: shelly.0 (12768) [CoAP] Device Y.X.C..67 (shellydimmer / shellydimmer-D3E31B / SHDM-1#D3E31B#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:05.100 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:05:05.152 - info: zigbee.0 (12930) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
    2022-03-21 10:05:05.171 - info: zigbee.0 (12930) Unable to disable LED, unsupported function.
    2022-03-21 10:05:05.181 - info: shelly.0 (12768) [CoAP] Device Y.X.C..44 (shellyplug-s / shellyplug-s-DE15FC / SHPLG-S#DE15FC#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:05.224 - info: zigbee.0 (12930) --> transmitPower : normal
    2022-03-21 10:05:05.254 - info: zigbee.0 (12930) Currently 53 devices are joined:
    2022-03-21 10:05:05.568 - error: backitup.0 (12944) Error: Command failed: sudo mount -t cifs -o username=iobrokerUser,password=****,rw,file_mode=0777,dir_mode=0777 //Y.X.C..109/ioBrokerBackup/ioBroker /opt/iobroker/backups
    mount error(16): Device or resource busy
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    2022-03-21 10:05:05.619 - info: shelly.0 (12768) [CoAP] Device Y.X.C..32 (shellyplug-s / shellyplug-s-8D010E / SHPLG-S#8D010E#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:05.977 - info: zigbee.0 (12930) 0x00158d0007b7ddc0 (addr 51404): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-03-21 10:05:05.979 - info: zigbee.0 (12930) 0x000d6ffffea61fe1 (addr 8521): E1746 - IKEA TRADFRI signal repeater (Router)
    2022-03-21 10:05:05.980 - info: zigbee.0 (12930) Zigbee started
    2022-03-21 10:05:06.418 - info: shelly.0 (12768) [CoAP] Device Y.X.C..30 (shelly1 / shelly1-767AC8 / SHSW-1#767AC8#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:07.055 - info: shelly.0 (12768) [CoAP] Device Y.X.C..33 (shellyplug-s / shellyplug-s-80116A / SHPLG-S#80116A#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:07.606 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater
    2022-03-21 10:05:07.612 - warn: zigbee.0 (12930) DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
    2022-03-21 10:05:08.159 - info: shelly.1 (12777) [MQTT] Device Y.X.C..104 (shellyplus1 / shellyplus1-a8032abeb1e4 / shellyplus1#a8032abeb1e4#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:08.487 - info: shelly.0 (12768) [CoAP] Device Y.X.C..110 (shellyplug-s / shellyplug-s-4BA36E / SHPLG2-1#4BA36E#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:08.734 - info: radar2.0 (12924) Init item YYYY with {name: 'YYYY',bluetooth: [],enabled: -1,id: 'YYYY',type: 'IP',hasMAC: [ '9a:ce:10:0a:71:2e' ],ipVendor: 'N/A',rip: [ 'Y.X.C..114' ],lasthere: '2022-03-21T05:14:19.102Z'}
    2022-03-21 10:05:08.998 - error: cloud.0 (12957) Cloud says: timeout
    2022-03-21 10:05:09.496 - info: shelly.0 (12768) [CoAP] Device Y.X.C..38 (shellydimmer2 / shellydimmer2-D8BFC019EECE / SHDM-2#D8BFC019EECE#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:10.005 - info: cloud.0 (12957) Connection changed: io server disconnect
    2022-03-21 10:05:10.505 - info: shelly.0 (12768) [CoAP] Device Y.X.C..29 (shelly1pm / shelly1pm-F27119 / SHSW-PM#F27119#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:10.772 - info: info.0 (12961) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:05:11.032 - info: info.0 (12961) Reading/updating systemdata.
    2022-03-21 10:05:13.277 - info: shelly.0 (12768) [CoAP] Device Y.X.C..98 (shellyplug-s / shellyplug-s-E435C4 / SHPLG-S#E435C4#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:13.542 - info: shelly.0 (12768) [CoAP] Device Y.X.C..39 (shellyplug-s / shellyplug-s-B4B41F / SHPLG-S#B4B41F#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:14.158 - info: shelly.0 (12768) [CoAP] Device Y.X.C..24 (shellyplug-s / shellyplug-s-577BFA / SHPLG-S#577BFA#1) connected! Polltime set to 5 sec.
    2022-03-21 10:05:14.529 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    2022-03-21 10:05:15.380 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
    2022-03-21 10:05:15.533 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
    2022-03-21 10:05:15.621 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
    2022-03-21 10:05:15.725 - info: info.0 (12961) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    2022-03-21 10:05:16.578 - info: info.0 (12961) cpu Temp res = {"main":75.471,"cores":[],"max":75.471,"socket":[],"chipset":null}
    2022-03-21 10:05:17.656 - info: info.0 (12961) State value to set for "info.0.sysinfo.memory.memLayout.ram0.ecc" has to be stringified but received type "boolean"
    2022-03-21 10:05:18.108 - info: radar2.0 (12924) Init item XXX with {name: 'XXX',bluetooth: [],enabled: -1,id: 'XXX',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2021-12-14T03:02:35.263Z'}
    2022-03-21 10:05:18.497 - info: radar2.0 (12924) Init item CCC with {name: 'CCC',bluetooth: [],enabled: -1,id: 'CCC',type: 'IP',hasMAC: [ 'IPV6' ],ipVendor: 'N/A',rip: [ 'Y.X.C.V' ],lasthere: '2022-03-21T08:59:12.329Z'}
    2022-03-21 10:05:18.501 - info: radar2.0 (12924) Adapter identified macs: (IPV6),
    ips: (Y.X.C.V,Y.X.C.V,Y.X.C.V),
    bts LE: (),
    bts norm: ()
    2022-03-21 10:05:18.828 - info: radar2.0 (12924) radar2 found 3 devices in config (XXX,YYY,CCC) and 3 enabled.
    2022-03-21 10:05:18.830 - info: radar2.0 (12924) radar2 set use of noble(false), doArp("-lgq --retry=5 --timeout=400" on eth0), btid(-1) and doUwz(undefined,30,0,de,true).
    2022-03-21 10:05:31.945 - info: schoolfree.0 (12878) Terminated (NO_ERROR): Without reason
    2022-03-21 10:05:38.446 - error: cloud.0 (12957) Cloud says: timeout
    2022-03-21 10:06:08.453 - error: cloud.0 (12957) Cloud says: timeout
    2022-03-21 10:06:38.469 - error: cloud.0 (12957) Cloud says: timeout
    2022-03-21 10:06:41.946 - warn: schoolfree.0 (12878) get state error: Connection is closed.
    2022-03-21 10:06:41.948 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.949 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.950 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.951 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.952 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.953 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.954 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.955 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:41.956 - warn: schoolfree.0 (12878) get state error: DB closed
    2022-03-21 10:06:43.427 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:06:43.429 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:06:43.431 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:06:43.874 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13310
    2022-03-21 10:06:44.533 - info: host.raspberrypi instance system.adapter.schoolfree.0 terminated with code 0 (NO_ERROR)
    2022-03-21 10:06:47.598 - info: radar2.0 (12924) first scan took 88.765 seconds
    2022-03-21 10:06:47.601 - warn: radar2.0 (12924) scanDelay increased to 90.765 seconds, delayAway to 4 minutes!
    2022-03-21 10:06:48.192 - info: weatherunderground.0 (13310) starting. Version 3.4.1 (non-npm: iobroker-community-adapters/ioBroker.weatherunderground) in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:06:48.209 - info: radar2.0 (12924) Adapter initialization finished!
    2022-03-21 10:07:03.303 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:07:03.460 - info: cloud.0 (12957) Connection changed: connect
    2022-03-21 10:07:03.494 - info: cloud.0 (12957) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
    2022-03-21 10:07:05.559 - error: backitup.0 (12944) umount: /opt/iobroker/backups: not mounted.
    2022-03-21 10:10:20.992 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:10:20.994 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:10:20.995 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:27:49.612 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:27:49.615 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:27:49.616 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:29:04.597 - info: cloud.0 (12957) Trying to connect as system.user.admin
    2022-03-21 10:29:05.276 - info: cloud.0 (12957) Connection changed: connect
    2022-03-21 10:29:15.627 - error: info.0 (12961) States database error: read ECONNRESET
    2022-03-21 10:29:15.609 - error: alexa2.0 (12723) States database error: read ECONNRESET
    2022-03-21 10:29:15.625 - error: weatherunderground.0 (13310) States database error: read ECONNRESET
    2022-03-21 10:29:15.630 - error: discovery.0 (12937) States database error: read ECONNRESET
    2022-03-21 10:29:15.628 - error: shelly.1 (12777) States database error: read ECONNRESET
    2022-03-21 10:29:15.629 - error: text2command.0 (12966) States database error: read ECONNRESET
    2022-03-21 10:29:15.609 - error: zigbee.0 (12930) States database error: read ECONNRESET
    2022-03-21 10:29:15.632 - error: email.0 (12636) States database error: read ECONNRESET
    2022-03-21 10:29:15.640 - error: history.0 (12669) States database error: read ECONNRESET
    2022-03-21 10:29:15.624 - error: pushover.0 (12697) States database error: read ECONNRESET
    2022-03-21 10:29:15.631 - error: tr-064.0 (12889) States database error: read ECONNRESET
    2022-03-21 10:29:15.633 - error: cloud.0 (12957) States database error: read ECONNRESET
    2022-03-21 10:29:15.684 - error: alexa2.0 (12723) Objects database error: read ECONNRESET
    2022-03-21 10:29:15.684 - error: shelly.1 (12777) Objects database error: read ECONNRESET
    2022-03-21 10:29:15.633 - error: backitup.0 (12944) States database error: read ECONNRESET
    2022-03-21 10:29:15.693 - error: zigbee.0 (12930) Objects database error: read ECONNRESET
    2022-03-21 10:29:15.644 - error: radar2.0 (12924) States database error: write ECONNRESET
    2022-03-21 10:29:15.697 - error: weatherunderground.0 (13310) Objects database error: read ECONNRESET
    2022-03-21 10:29:15.634 - error: hue.0 (12760) States database error: read ECONNRESET
    2022-03-21 10:29:15.714 - error: cloud.0 (12957) Objects database error: read ECONNRESET
    2022-03-21 10:29:15.640 - error: iot.0 (12946) States database error: read ECONNRESET
    2022-03-21 10:29:15.913 - info: zigbee.0 (12930) cleaned everything up...
    2022-03-21 10:29:15.910 - info: info.0 (12961) cleaned everything up...
    2022-03-21 10:29:15.912 - info: backitup.0 (12944) cleaned everything up...
    2022-03-21 10:29:15.914 - info: shelly.1 (12777) Closing Adapter
    2022-03-21 10:29:15.923 - error: shelly.0 (12768) Objects database error: write ECONNRESET
    2022-03-21 10:29:15.942 - error: shelly.0 (12768) States database error: read ECONNRESET
    2022-03-21 10:29:15.957 - info: cloud.0 (12957) Connection changed: io client disconnect
    2022-03-21 10:29:15.958 - info: cloud.0 (12957) Connection lost
    2022-03-21 10:29:15.953 - info: shelly.0 (12768) Closing Adapter
    2022-03-21 10:29:16.073 - info: iot.0 (12946) Connection changed: disconnect
    2022-03-21 10:29:16.075 - info: iot.0 (12946) Connection lost
    2022-03-21 10:29:16.089 - info: radar2.0 (12924) Unload adapter now with null
    2022-03-21 10:29:16.091 - info: radar2.0 (12924) Adapter disconnected and stopped with dostop(null) and callback(true)
    2022-03-21 10:29:16.163 - info: zigbee.0 (12930) Zigbee: disabling joining new devices.
    2022-03-21 10:29:16.134 - error: admin.0 (12617) States database error: read ECONNRESET
    2022-03-21 10:29:16.269 - error: javascript.0 (12683) States database error: write ECONNRESET
    2022-03-21 10:29:16.274 - error: javascript.0 (12683) Objects database error: read ECONNRESET
    2022-03-21 10:29:16.280 - info: javascript.0 (12683) Stop script script.js.common.BatteryCheck
    2022-03-21 10:29:16.284 - info: javascript.0 (12683) Stop script script.js.common.BewegungsmelderV2
    2022-03-21 10:29:16.286 - info: javascript.0 (12683) Stop script script.js.common.CommonMix
    2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.FritzBox
    2022-03-21 10:29:16.287 - info: javascript.0 (12683) Stop script script.js.common.LeavingHouse
    2022-03-21 10:29:16.288 - info: javascript.0 (12683) Stop script script.js.common.OpenDoorsWindows
    2022-03-21 10:29:16.290 - info: javascript.0 (12683) Stop script script.js.common.Shellys
    2022-03-21 10:29:16.230 - error: admin.0 (12617) Objects database error: read ECONNRESET
    2022-03-21 10:29:16.334 - info: admin.0 (12617) terminating http server on port 8081
    2022-03-21 10:29:16.928 - error: radar2.0 (12924) uncaught exception: Cannot read property 'init' of null
    2022-03-21 10:29:16.929 - error: radar2.0 (12924) TypeError: Cannot read property 'init' of null
    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:964:82)
    at listOnTimeout (internal/timers.js:557:17)
    at processTimers (internal/timers.js:500:7)
    2022-03-21 10:29:16.930 - error: radar2.0 (12924) Cannot read property 'init' of null
    2022-03-21 10:29:16.931 - warn: radar2.0 (12924) Uncaught Exception: Cannot read property 'init' of null
    2022-03-21 10:29:17.409 - info: email.0 (12636) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.412 - info: discovery.0 (12937) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.414 - info: weatherunderground.0 (13310) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.414 - info: pushover.0 (12697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.415 - info: text2command.0 (12966) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.418 - info: info.0 (12961) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.418 - info: zigbee.0 (12930) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.420 - info: backitup.0 (12944) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.423 - info: tr-064.0 (12889) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.423 - info: shelly.1 (12777) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.433 - info: iot.0 (12946) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.457 - info: shelly.0 (12768) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.462 - info: cloud.0 (12957) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.463 - info: alexa2.0 (12723) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.589 - info: radar2.0 (12924) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.780 - info: javascript.0 (12683) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:17.847 - info: admin.0 (12617) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:20.699 - error: shelly.1 (12777) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.702 - warn: info.0 (12961) get state error: DB closed
    2022-03-21 10:29:20.717 - error: discovery.0 (12937) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.724 - error: alexa2.0 (12723) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.751 - error: weatherunderground.0 (13310) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.753 - error: backitup.0 (12944) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.767 - error: zigbee.0 (12930) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.749 - warn: radar2.0 (12924) get state error: Connection is closed.
    2022-03-21 10:29:20.753 - error: hue.0 (12760) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.763 - error: cloud.0 (12957) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.775 - warn: tr-064.0 (12889) get state error: DB closed
    2022-03-21 10:29:20.797 - warn: email.0 (12636) get state error: DB closed
    2022-03-21 10:29:20.710 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.807 - warn: pushover.0 (12697) get state error: DB closed
    2022-03-21 10:29:20.816 - error: text2command.0 (12966) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.849 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2022-03-21 10:29:20.884 - warn: weatherunderground.0 (13310) get state error: DB closed
    2022-03-21 10:29:20.887 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.920 - error: iot.0 (12946) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.947 - error: shelly.0 (12768) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.992 - warn: shelly.0 (12768) get state error: Connection is closed.
    2022-03-21 10:29:20.798 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.845 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#C383EB#1.online, error - DB closed
    2022-03-21 10:29:20.846 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.847 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.961 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.962 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.982 - warn: shelly.1 (12777) redis get shelly.1.SHSW-1#98F4ABF3CF6C#1.hostname, error - DB closed
    2022-03-21 10:29:20.983 - warn: shelly.1 (12777) redis get shelly.1.SHPLG-S#DE15FC#1.online, error - DB closed
    2022-03-21 10:29:20.984 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.985 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.986 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.987 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.988 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:20.989 - warn: shelly.1 (12777) get state error: DB closed
    2022-03-21 10:29:21.085 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27119#1.hostname, error - Connection is closed.
    2022-03-21 10:29:21.125 - warn: shelly.1 (12777) redis get shelly.1.SHSW-PM#F27634#1.hostname, error - Connection is closed.
    2022-03-21 10:29:21.127 - warn: shelly.1 (12777) redis get shelly.1.shellyplus1#a8032abeb1e4#1.hostname, error - Connection is closed.
    2022-03-21 10:29:21.140 - warn: shelly.1 (12777) redis get shelly.1.undefined#undefined#1.hostname, error - Connection is closed.
    2022-03-21 10:29:21.151 - warn: shelly.1 (12777) setTimeout called, but adapter is shutting down
    2022-03-21 10:29:20.969 - warn: iot.0 (12946) get state error: DB closed
    2022-03-21 10:29:20.970 - warn: iot.0 (12946) get state error: DB closed
    2022-03-21 10:29:20.972 - warn: iot.0 (12946) get state error: DB closed
    2022-03-21 10:29:21.263 - warn: iot.0 (12946) get state error: DB closed
    2022-03-21 10:29:21.264 - warn: iot.0 (12946) get state error: DB closed
    2022-03-21 10:29:21.265 - warn: iot.0 (12946) get state error: DB closed
    2022-03-21 10:29:21.266 - warn: iot.0 (12946) get state error: DB closed
    2022-03-21 10:29:21.367 - error: javascript.0 (12683) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:21.417 - error: admin.0 (12617) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:20.993 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.687 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#DE15FC#1.online, error - DB closed
    2022-03-21 10:29:21.688 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.689 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.690 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.690 - warn: shelly.0 (12768) redis get shelly.0.SHPLG-S#C383EB#1.online, error - DB closed
    2022-03-21 10:29:21.691 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.715 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.717 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#767AC8#1.hostname, error - DB closed
    2022-03-21 10:29:21.720 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.721 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.914 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:21.915 - warn: shelly.0 (12768) get state error: DB closed
    2022-03-21 10:29:22.093 - warn: shelly.0 (12768) redis get shelly.0.SHSW-1#98F4ABF3CF6C#1.hostname, error - Connection is closed.
    2022-03-21 10:29:22.115 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27119#1.hostname, error - Connection is closed.
    2022-03-21 10:29:22.117 - warn: shelly.0 (12768) redis get shelly.0.SHSW-PM#F27634#1.hostname, error - Connection is closed.
    2022-03-21 10:29:22.119 - warn: shelly.0 (12768) setTimeout called, but adapter is shutting down
    2022-03-21 10:29:25.704 - error: shelly.1 (12777) Cannot find view "system" for search "device" : Connection is closed.
    2022-03-21 10:29:25.911 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:25.915 - error: history.0 (12669) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2022-03-21 10:29:25.952 - error: shelly.0 (12768) Cannot find view "system" for search "device" : DB closed
    2022-03-21 10:29:27.034 - info: history.0 (12669) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-21 10:29:30.927 - error: history.0 (12669) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2022-03-21 10:29:36.867 - info: host.raspberrypi iobroker.js-controller version 4.0.19 js-controller starting
    2022-03-21 10:29:36.875 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-03-21 10:29:36.876 - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
    2022-03-21 10:29:36.876 - info: host.raspberrypi ip addresses: Y.X.C.V IPV6
    2022-03-21 10:29:38.900 - info: host.raspberrypi connected to Objects and States
    2022-03-21 10:29:38.972 - info: host.raspberrypi added notifications configuration of host
    2022-03-21 10:29:39.802 - info: host.raspberrypi 32 instances found
    2022-03-21 10:29:39.863 - info: host.raspberrypi starting 21 instances
    2022-03-21 10:29:40.093 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13720
    2022-03-21 10:29:42.077 - error: admin.0 (13720) admin.0 already running
    2022-03-21 10:29:42.081 - warn: admin.0 (13720) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:29:42.717 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:29:42.718 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2022-03-21 10:29:43.901 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13731
    2022-03-21 10:29:45.441 - error: email.0 (13731) email.0 already running
    2022-03-21 10:29:45.445 - warn: email.0 (13731) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:29:46.064 - error: host.raspberrypi instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:29:46.065 - info: host.raspberrypi Restart adapter system.adapter.email.0 because enabled
    2022-03-21 10:29:48.020 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13743
    2022-03-21 10:29:49.579 - error: history.0 (13743) history.0 already running
    2022-03-21 10:29:49.583 - warn: history.0 (13743) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:29:50.203 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:29:50.205 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2022-03-21 10:29:51.992 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13755
    2022-03-21 10:29:55.495 - error: javascript.0 (13755) javascript.0 already running
    2022-03-21 10:29:55.499 - warn: javascript.0 (13755) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:29:55.983 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 13766
    2022-03-21 10:29:56.133 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:29:56.134 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2022-03-21 10:29:57.600 - error: pushover.0 (13766) pushover.0 already running
    2022-03-21 10:29:57.604 - warn: pushover.0 (13766) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:29:58.272 - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:29:58.273 - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
    2022-03-21 10:29:59.978 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 13777
    2022-03-21 10:30:01.640 - error: alexa2.0 (13777) alexa2.0 already running
    2022-03-21 10:30:01.644 - warn: alexa2.0 (13777) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:30:02.263 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:30:02.264 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
    2022-03-21 10:30:04.036 - info: host.raspberrypi instance system.adapter.hue.0 started with pid 13788
    2022-03-21 10:30:05.962 - error: hue.0 (13788) hue.0 already running
    2022-03-21 10:30:06.590 - error: host.raspberrypi instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:30:06.590 - info: host.raspberrypi Restart adapter system.adapter.hue.0 because enabled
    2022-03-21 10:30:08.001 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 13799
    2022-03-21 10:30:10.386 - error: shelly.0 (13799) shelly.0 already running
    2022-03-21 10:30:10.390 - warn: shelly.0 (13799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:30:11.012 - error: host.raspberrypi instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:30:11.012 - info: host.raspberrypi Restart adapter system.adapter.shelly.0 because enabled
    2022-03-21 10:30:11.987 - info: host.raspberrypi instance system.adapter.shelly.1 started with pid 13810
    2022-03-21 10:30:12.836 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 13817
    2022-03-21 10:30:14.257 - error: shelly.1 (13810) shelly.1 already running
    2022-03-21 10:30:14.262 - warn: shelly.1 (13810) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:30:15.043 - error: host.raspberrypi instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:30:15.044 - info: host.raspberrypi Restart adapter system.adapter.shelly.1 because enabled
    2022-03-21 10:30:15.288 - info: admin.0 (13817) starting. Version 5.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:30:15.336 - info: admin.0 (13817) requesting all states
    2022-03-21 10:30:15.337 - info: admin.0 (13817) requesting all objects
    2022-03-21 10:30:16.895 - info: host.raspberrypi instance system.adapter.email.0 started with pid 13836
    2022-03-21 10:30:16.978 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 13843
    2022-03-21 10:30:17.468 - info: admin.0 (13817) received all objects
    2022-03-21 10:30:18.021 - info: admin.0 (13817) Request actual repository...
    2022-03-21 10:30:18.051 - info: admin.0 (13817) http server listening on port 8081
    2022-03-21 10:30:18.053 - info: admin.0 (13817) Use link "http://localhost:8081" to configure.
    2022-03-21 10:30:18.927 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2022-03-21 10:30:19.880 - error: tr-064.0 (13843) tr-064.0 already running
    2022-03-21 10:30:19.884 - warn: tr-064.0 (13843) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:30:20.369 - info: host.raspberrypi instance scheduled system.adapter.weatherunderground.0 6 * * * *
    2022-03-21 10:30:20.399 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 13858
    2022-03-21 10:30:23.820 - info: admin.0 (13817) Repository received successfully.
    2022-03-21 10:30:24.716 - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:30:24.717 - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
    2022-03-21 10:30:24.752 - info: host.raspberrypi instance system.adapter.history.0 started with pid 13869
    2022-03-21 10:30:24.849 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 13875
    2022-03-21 10:30:24.969 - error: weatherunderground.0 (13858) weatherunderground.0 already running
    2022-03-21 10:30:24.974 - warn: weatherunderground.0 (13858) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-03-21 10:30:25.084 - info: email.0 (13836) starting. Version 1.0.10 (non-npm: iobroker-community-adapters/ioBroker.email) in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.19
    2022-03-21 10:30:25.651 - error: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-03-21 10:30:26.272 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 13891
    crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    @th3rockyeah sagte in js-controller 4.0 jetzt im BETA/LATEST!:
    non-npm
    @apollon77 kann es sein das da mit npm etwas nicht passt?
      non-npm
      apollon77A
      apollon77A
      @crunchip Ne das sind GitHub installs ... aber habs nur für email und weatherunderground gesehen, da sollte es eher irrelevant sein ... Javascript 5.4 wäre eher ein Kandidat weil der Ordner anlegt, aber bei den 5 Skripten sollte das fast egal sein
      Denke man muss jetzt mal strukturiert rangehen weil ausser dem controller nichts irklich auffällig ist
      • apollon77A apollon77
        Mar 21 09:59:52 raspberrypi kernel: [54692.153207] Out of memory: Killed process 11917 (iobroker.js-con) total-vm:2677092kB, anon-rss:2470216kB, file-rss:716kB, shmem-rss:0kB, UID:1001 pgtables:6136kB oom_score_adj:0
        Genau wie @Diginix schreibt ... irgendwas ist passiert und der js-controller
        wurde wegen RAM issues vom System gekillt.
        Welche mqtt Version hast Du drauf? Beta oder Stable?
        Bei javsscript habe ich oben gesehen das eine Logzeile doppelt kam ... was auch nicht sein sollte
        Ich schlage Dir folgendes vor.
        • Stoppe iobroker
        • schau das wirklich alles weg ist
        • setze (falls nicht geschehen) die connectTimeout hoch das idealerweise CLI wieder tut. Hattest Du gesagt wie groß die jsonl Files sind?
        • dann per cli mit "iob stop adapter.X" alle instanzen stoppen, ausser admin.0
        • Dann iobroker starten ... wie geht es ihm dann? Schauen das Admin wieder lädt und mal durch die objekte schauen wo vlt diese massen herkommen
        • Dann einen adapter nach dem anderen starten und immer schauen was passiert. sobald es wieder anfängt den Adapter stoppen und schauen ob dann ruhiger wird.
        T
        T
        Th3RockYeah
        @apollon77
        Ok, mach ich. ich starte nach und nach die Adapter und schaue, ob etwas auffällig ist.
        Den MQTT Adapter nutze ich nicht, nur Shelly.
        Nun hat sich der JS-Controller beruhigt und ich kann den IOBroker wieder normal nutzen. Das hier waren die letzten Fehler im Log:
        	Zeit
        warn
        Nachricht
        zigbee.0
        2022-03-21 11:49:59.635	warn	DeviceAvailability:Failed to ping 0x000d6ffffe2e4a54 TRADFRI signal repeater
        zigbee.0
        2022-03-21 11:45:23.370	warn	State value to set for "zigbee.0.00158d00042176ed.pressure" has value "95992" greater than max "10000"
        radar2.0
        2022-03-21 11:34:11.290	warn	State "radar2.0._uIPs.SonosZP_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
        radar2.0
        2022-03-21 11:34:11.273	warn	State "radar2.0._uIPs.SonosZP_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
        radar2.0
        2022-03-21 11:34:11.119	warn	State "radar2.0._uIPs.shellyplug-s-DE15FC_xxx-xxx--xxx-xx" has no existing object, this might lead to an error in future versions
        radar2.0
        2022-03-21 11:34:11.040	warn	State "radar2.0._uIPs.shellyplug-s-DE15FC_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
        radar2.0
        2022-03-21 11:34:10.070	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
        radar2.0
        2022-03-21 11:34:10.034	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
        radar2.0
        2022-03-21 11:34:10.032	warn	State "radar2.0._uIPs.HDot_xxx-xxx-xxx-xxx" has no existing object, this might lead to an error in future versions
        zigbee.0
        2022-03-21 11:25:12.257	warn	DeviceAvailability:Stopping to ping 0x680ae2fffe9c8577 TRADFRI Signal Repeater after 4 ping attempts
        zigbee.0
        2022-03-21 11:19:39.577	warn	State value to set for "zigbee.0.00158d000464c66d.pressure" has value "96079" greater than max "10000"
        radar2.0
        2022-03-21 11:12:30.875	warn	scanDelay increased to 71.119 seconds, delayAway to 2 minutes!
        host.raspberrypi
        2022-03-21 11:07:54.826	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        radar2.0
        2022-03-21 11:07:54.333	warn	Error {} is setState for _uIPs with {"val":"[]","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
        radar2.0
        2022-03-21 11:07:54.330	warn	get state error: Connection is closed.
        radar2.0
        2022-03-21 11:07:54.329	warn	Could not perform strict object check of state radar2.0._uIPs: DB closed
        radar2.0
        2022-03-21 11:07:53.861	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.860	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.859	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
        radar2.0
        2022-03-21 11:07:53.858	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.854	warn	redis get radar2.0._uIPs.192-168-170-210, error - Connection is closed.
        radar2.0
        2022-03-21 11:07:53.853	warn	Error {} is setState for radar2.0._uIPs.xxx-xxx-xxx-xxx with {"val":"{ ipAddress: 'xxx.xxx.xxxx.xxxx', macAddress: '8:33:4d:ca', by: 'arp', hosts: [], getMacVendor: 'N/A'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
        radar2.0
        2022-03-21 11:07:53.852	warn	get state error: Connection is closed.
        radar2.0
        2022-03-21 11:07:53.851	warn	Error {} is setState for info.connection with {"val":false,"ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
        radar2.0
        2022-03-21 11:07:53.850	warn	get state error: Connection is closed.
        radar2.0
        2022-03-21 11:07:53.652	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.651	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.650	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
        radar2.0
        2022-03-21 11:07:53.650	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.649	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.647	warn	redis get radar2.0._uIPs.xxx-xxx-xxx-xxx, error - Connection is closed.
        radar2.0
        2022-03-21 11:07:53.646	warn	Error {} is setState for _uIPs.xxx-xxx-xxx-xxx with {"val":"{ ipAddress: 'xxx.xxx.xxx.xxx', macAddress: '33:4d:ca', by: 'arp', hosts: [], getMacVendor: 'N/A'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
        radar2.0
        2022-03-21 11:07:53.645	warn	get state error: Connection is closed.
        radar2.0
        2022-03-21 11:07:53.332	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.331	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.331	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62)
        radar2.0
        2022-03-21 11:07:53.330	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.329	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.320	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.320	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.319	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
        radar2.0
        2022-03-21 11:07:53.319	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.318	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.316	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.315	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.315	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
        radar2.0
        2022-03-21 11:07:53.314	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.313	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.311	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.289	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.288	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
        radar2.0
        2022-03-21 11:07:53.287	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.286	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.283	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.281	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.279	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
        radar2.0
        2022-03-21 11:07:53.278	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.277	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.275	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.275	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.274	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
        radar2.0
        2022-03-21 11:07:53.273	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.272	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.270	warn	Unhandled rejection at
        radar2.0
        2022-03-21 11:07:53.269	error	Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.268	error	TypeError: Cannot read property 'hosts' of undefined at Timeout.scanAll (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:447:62) at runNextTicks (internal/process/task_queues.js:60:5) at processImmediate (internal/timers.js:437:9)
        radar2.0
        2022-03-21 11:07:53.268	error	unhandled promise rejection: Cannot read property 'hosts' of undefined
        radar2.0
        2022-03-21 11:07:53.267	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        radar2.0
        2022-03-21 11:07:53.264	warn	redis get radar2.0._uIPs.XXX-XXX-XXX-XXX, error - Connection is closed.
        Nur damit ich es gefragt habe, weil es mich nicht "loslässt". Kann die SD-Card kaputt sein?
        • T Th3RockYeah
          @apollon77
          	Zeit
          warn
          Nachricht
          zigbee.0
          zigbee.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          zigbee.0
          zigbee.0
          radar2.0
          host.raspberrypi
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          radar2.0
          Thomas BraunT
          Thomas BraunT
          Möglich. Die eine Karte, die mir mal verreckt ist hat sich in den Logfiles sang- und klanglos verabschiedet.
          Schau mal mit
          dmesg -T | grep -i ext4
          danach.
            Schau mal mit
            danach.
            T
            T
            Th3RockYeah
            Das kommt als Antwort. Was bedeutet das?
            [Mo Mär 21 10:52:17 2022]  ext4_filemap_fault+0x3c/0x818
            • T Th3RockYeah
              Thomas BraunT
              Thomas BraunT
              @th3rockyeah
              Nur die eine Zeile?
              Da muss mehr kommen.
              Aber ext4_filemap_fault ist schon mal schlecht, das sollte nicht kommen.
                @th3rockyeah
                Nur die eine Zeile?
                T
                T
                Th3RockYeah
                Ja nur die eine Zeile:
                • T Th3RockYeah
                  Thomas BraunT
                  Thomas BraunT
                  @th3rockyeah
                  Dann würde ich sagen, die Karte/das Dateisystem ist fehlerhaft.
                    @th3rockyeah
                    T
                    T
                    Th3RockYeah
                    @thomas-braun Ok, dann setze ich hier einmal ebenfalls an.
                    Was müsste denn dort normalerweise stehen, wenn die SD-Card OK wäre?
                    • T Th3RockYeah
                      Thomas BraunT
                      Thomas BraunT
                      @th3rockyeah
                      Da tauchen dann 4 Zeilen auf.
                      Ich komme gerade an mein System nicht ran, sonst hätte ich es gezeigt.
                      Aus deinem obigen Log:
                      ping invoked oom-killer: gfp_mask=0x400dc0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), order=0, oom_score_adj=0
                      gfp_mask ist auch nah am System/RAM/Dateisystem. Ich würde sagen, das Ding schwimmt schon nicht mehr, das ist abgesoffen.
                        @th3rockyeah
                        T
                        T
                        Th3RockYeah
                        schrieb am zuletzt editiert von Th3RockYeah
                        @thomas-braun ok, danke dir! Ich habe jetzt auch mehrere Zeilen bei dem Aufruf in der Console.
                        Ich habe nun den IoBroker auf einem USB Stick neu aufgesetzt und aktuell läuft er total smooth. Ich beobachte es noch eine Weile, aber nach einem Iobroker restart ist das Verhalten normal, der js-controller läuft ohne starke CPU oder Memory last.
                        Es scheint die SD-Card gewesen zu sein #fingercrossed.
                        @apollon77 , @thomas-braun, @Diginix , @crunchip: DANKE für euren Support!!! Kudos to you all! :-)
                        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                        • T Th3RockYeah
                          Thomas BraunT
                          Thomas BraunT
                          Welche?
                            Welche?
                            T
                            T
                            Th3RockYeah
                            diese hier:
                            pi@raspberrypiNew:~ $ dmesg -T | grep -i ext4
                            [Mon Mar 21 15:27:04 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:4F:DD:06 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=dc01fa95-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Mon Mar 21 15:27:07 2022] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                            [Mon Mar 21 15:27:07 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Mon Mar 21 15:27:08 2022] EXT4-fs (sda2): re-mounted. Opts: (null)
                            • T Th3RockYeah
                              diese hier:
                              Thomas BraunT
                              Thomas BraunT
                              @th3rockyeah
                              Ja, so muss das aussehen.
                                @th3rockyeah
                                T
                                T
                                Th3RockYeah
                                @thomas-braun Yihaa! Danke :-)
                                • T Th3RockYeah
                                  apollon77A
                                  apollon77A
                                  @th3rockyeah Interessant ...
                                  • HomoranH
                                    Ich habe diesen Thread mal aus dem controller4.0-Thread herausgelöst.
                                    @Th3RockYeah
                                    Bitte meinen provisorisch gewählten Threadtitel noch anpassen. Ich habe nicht alles gelesen
                                      @Th3RockYeah
                                      T
                                      T
                                      Th3RockYeah
                                      @homoran done. :-)
                                      Für alle: Bei mir sind seit dem Umzug auf den USB Stick alle Probleme weg, die ich in der letzten Zeit hatte. Angefangen von langsamer Performance bis hinzu, dass Zigbee einige Message verschluckt hat. Ich wollte dies nur noch mal als Ergänzung schreiben, da eine sterbende SD-Card nicht offensichtlich ist.
                                      83.9k
